Raven's Nest
Started by Anastasia, June 04, 2018, 11:25:43 AM
Aegis does.
> roll 1d100 vs 50
<Kobot> Kotono rolled 1d100 vs 50 --> [ 1d100=54 ]{54}
No joy.
240 damage to both of you.
Init is Amaryl (47) > Eye of Shar (42) > Alicia (30) > Palave (22) > Antenora (21) > Seira (18)
The beams hit both of you like liquid agony, a moment of burning, all-body pain followed by absolute numbness. It passes as the two reclaim themselves, numbness pushed aside. Seira's body throbs as she hears Amaryl scream, flashing purple and black, entire body shimmering with the same lights Seira's own form is.
Alicia's up. Go.
Antenora
HP: 550+200/550
Spells Active: Good Hope (CL31), Celestial Valor (CL31), Glorious Rally (CL31), Recitation (CL31), Divine Insight (CL31), Divine Presence (CL30), Righteous Wrath of the Faithful (CL31), Death Ward (CL30), Mind Blank (CL31), Vision of the Omniscient Eye (CL31), Foresight (CL31), Spell Turning (CL31), Opal Fury (CL30)
Bonuses: +6 morale attack rolls, weapon damage rolls, saving throws and armor class, +2 morale ability checks and skill checks, +8 sacred saves vs fear and negative emotion magic, +4 sacred attack, saving throws, armor class and weapon damage rolls, nonstacking holy on all weapons, immunity to fear, +2 luck attack roll sand saving throws, +15 to one skill check, +5/+10/+15 (does not worship Alicia/one alignment opposed/both alignments opposed) sacred bonus to Intimidate, extra attack on full attack, death ward immunities, +10 insight spot, +4 sacred strength, +3d6 damage vs evil.
Resources Used: Divine Presence, Opal Fury,  1 use of boots, 1 smite evil, 32/33 holy fury for the encounter
Amaryl
HP: 310/488
Spells Active: Good Hope (CL31), Celestial Valor (CL31), Glorious Rally (CL31), Recitation (CL31), Divine Insight (CL31), Amaryl's Greater Arrow Mind (CL17), Righteous Wrath of the Faithful (CL31), Death Ward (CL30)
Bonuses: +6 morale attack rolls, weapon damage rolls, saving throws and armor class, +2 morale ability checks and skill checks, +8 sacred saves vs fear and negative emotion magic, +4 sacred attack, saving throws, armor class and weapon damage rolls, nonstacking holy on all weapons, immunity to fear, +2 luck attack roll sand saving throws, +15 to one skill check, threaten within reach with bow, do not trigger AoOs for using bow, +4 insight ranged attack rolls, +1 bonus attack with with bow as if hasted, extra attack on full attack, death ward immunities, +10 insight spot.
Resources Used: 1 5th level spell
Alicia starts to really move, flying up towards Shar's orb at top speed before abruptly throwing a wall of force in her path to block any attacks it might send her way!
Run for 800 feet, so I'm now 800 feet away from it after the 400 I moved previously. Quickened wall of force for defence.
Alicia: 864+62/864
Active spells: Extended nondetection (CL 31), many moments of prescience (CL 31), extended greater anticipate teleportation (CL 31), foresight (CL 31), death ward (CL 30), greater heroism (CL 31), vision of the omniscient eye (CL 31), spell turning (CL 31), good hope (CL 31), righteous wrath of the faithful (CL 30), dance of the unicorn (CL 30), recitation (CL 30), greater visage of the deity (CL 30), extended repelling shield (CL 31), master's touch (CL 30), sensual blessing (CL 30), celestial valor (CL 31), glorious rally (CL 31), divine insight (CL 31), keen edge (CL 30), ray deflection (CL 31), extended energy immunity (CL 31), extended latha's sunmantle (CL 31)
Defences: AC 72 (touch 36), CMD 116, spell resistance 45, energy immunity (fire, cold, acid), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affection, fear, dazzled, blinded), freedom of movement, nondetection (DC 46)
Stat buffs/penalties: +2 insight AC/reflex, +6 morale attack/damage/AC/saves, +4 morale skills, +10 insight perception, +3 morale damage, +2 morale ability checks, +3 luck attack/saves, +36 Str, -2 Dex, +20 Con, +2 Int, +4 Wis, +4 Cha, +15 natural armour, -8 size AC/attack, +7 shield AC, +4 insight skills, +25 competence perception, +4 sacred attack/damage/AC/saves
Perceptions: Darkvision, scent, low-light vision, blindsight, tremorsense 1 mile, perception +83
Sorcerer spell slots: 6/5/8/4/5/5/4/6/5/5/7/2/3/4
Duskblade spell slots: 6/12/11/9/9/3
How close to you is the wall?
30 feet in front of me. It's 30 ten foot square's worth and set up so I'm closer to the right hand side so I can easily move around it next turn but it fully occludes even colossal me from direct line of effect via the orb.
Palave flies up another 800ft, near Alicia with his arms crossed now. Winds are gathering around him, more and more, howling about him like a tempest. "Retreat and save what little of your dignity remains, Shar."
Antenora's up.
Antenora keeps pace with you, hiding with your walls as well, using them as cover. "Shar has no dignity," Antenora murmurs quietly, overheard by you thanks to deific senses.
Seira, go.
Since the Eye of Shar (not actually the mechanical Eye of Shar) didn't save vs various AoE spells, do I have any direction of what might work on it?
K:A and K:P and K:R 10 of 79
Seira believes it to be a direct manifestation of Shar. Most likely a direct application of holy, physical force should be able to hurt it. The sunlance didn't do much, which suggests some manner of warding against light, magic or holiness as well.
With little to lose, Seira stops time!
Now there is plenty of opportunity to heal herself, summon friends to assist with the basic distractions Seira so often relies on, and get right into melee range. Then, as time resumes its course, Seira strikes!
19:02 <Lucille> roll 1d4+1
19:02 <Kobot> Lucille rolled 1d4+1 --> [ 1d4=3 ]{4}
Round 1: Standard/Heal via Miracle, move to get 380ft closer.
Round 2: Standard/Heal via Miracle, move to get 380ft closer, swift for assay spell resistance.
Round 3: Standard/Greater Heroism via Miracle, move to position properly, true casting for flux grasp, swift to activate holy warrior.
Round 4: Standard/Summon Monster VI for 1d4+1 minions to flank with, move to channel flux grasp, swift to activate Dragonfire Wrath, swift to True Strike
Flanking minions!
19:17 <Lucille> roll 1d4+1
19:17 <Kobot> Lucille rolled 1d4+1 --> [ 1d4=4 ]{5}
When time returns, Seira will use her remaining swift action to Superb Dispel Shar and then full attack her.
Seira's spells: nondetection (CL 31), mind blank (CL 31) many moments of prescience (CL 31), moment of prescience (CL 31), greater anticipate teleportation (CL 31), foresight (CL 31), death ward (CL 30), vision of the omniscient eye (CL 31), spell turning (CL 31), good hope (CL 31), righteous wrath of the faithful (CL 30), recitation (CL 31), sensual blessing (CL 31), celestial valor (CL 31), glorious rally (CL 31), greater arcane sight (CL 31), divine insight (CL 31), sensual blessing (CL 31)
Twinned Flux Grasp, Twinned Sunlance, Widened Delayed Blast Fireball used up
DragonSeira: 666+20/666
Armor Class: 81 (Touch AC 46)
Full Attack (GMF +5, Haste, flanking): +60/+60/+60/+60/+55/+50/+45 (6d10+92+15d6) and bite +58 (4d6+92+15d6) and claw +58 (2d8+83+15d6) and wings +58/+58 (2d6+83+15d6) and tail slap +58 (2d8+101+15d6)
Saves: Fort +61, Ref +52, Will +53
+13 attack, +10 damage
+10 saves (+12 ref), +12 AC
Okay, goes without incident, make 23 dispel checks first of all.
[19:43] <@Lisa> roll 23#1d20+32+7
[19:43] <Kobot> Lisa rolled 23#1d20+32+7 --> [ 1d20=2 ]{41}, [ 1d20=2 ]{41}, [ 1d20=3 ]{42}, [ 1d20=18 ]{57}, [ 1d20=20 ]{59}, [ 1d20=16 ]{55}, [ 1d20=1 ]{40}, [ 1d20=15 ]{54}, [ 1d20=4 ]{43}, [ 1d20=6 ]{45}, [ 1d20=5 ]{44}, [ 1d20=12 ]{51}, [ 1d20=17 ]{56}, [ 1d20=13 ]{52}, [ 1d20=9 ]{48}, [ 1d20=5 ]{44}, [ 1d20=7 ]{46}, [ 1d20=4 ]{43}, [ 1d20=4 ]{43}, [ 1d20=15 ]{54}, [ 1d20=2 ]{41}, [ 1d20=17 ]{56}, [ 1d20=6 ]{45}
A bit of magic crumbles around the emblem of Shar hanging in the air as...
Rest of your turn?
Seira launches her attack!
[20:01] <@Lisa> roll 1d20+60+13+5+20
[20:01] <Kobot> Lisa rolled 1d20+60+13+5+20 --> [ 1d20=14 ]{112}
[20:05] <@Lisa> roll 6d10+92+3d8+2d6+15+7d6+7d6 SA broken in two, in case only half applies via Penetrating Strike
[20:05] <Kobot> Lisa rolled 6d10+92+3d8+2d6+15+7d6+7d6 SA broken in two, in case only half applies via Penetrating Strike --> [ 6d10=28 3d8=15 2d6=7 7d6=21 7d6=25 ]{203}
[20:01] <@Lisa> roll 1d20+32+10+10 SR for Flux Grasp
[20:01] <Kobot> Lisa rolled 1d20+32+10+10 SR for Flux Grasp --> [ 1d20=11 ]{63}
[20:03] <@Lisa> roll 32d12
[20:03] <Kobot> Lisa rolled 32d12 --> [ 32d12=181 ]{181}
Flux Grasp:
Your successful melee touch inflicts 1d12 acid damage per caster level (maximum 40d12), furthermore this potent acid dissolves and weakens scales and armour both, inflicting a -10 penalty to the victim's armor and natural armor bonuses. If this penalty reduces the armor bonus to 0, the item is destroyed (or dispelled in the case of magical armor such as the Mage Armor spell), otherwise it must be repaired to regain its effectiveness. Natural armor so weakened can only be restored with a Regenerate or greater spell.
And now, the rest of the attacks!
[20:06] <@Lisa> roll 1d20+60+13+5
[20:06] <Kobot> Lisa rolled 1d20+60+13+5 --> [ 1d20=15 ]{93}
[20:09] <@Lisa> roll 1d20+60+13+5
[20:09] <Kobot> Lisa rolled 1d20+60+13+5 --> [ 1d20=7 ]{85}
[20:10] <@Lisa> roll 1d20+60+13+5
[20:10] <Kobot> Lisa rolled 1d20+60+13+5 --> [ 1d20=8 ]{86}
[20:11] <@Lisa> roll 1d20+55+13+5+10 untyped 1/day bonus
[20:11] <Kobot> Lisa rolled 1d20+55+13+5+10 untyped 1/day bonus --> [ 1d20=13 ]{96}
[20:11] <@Lisa> roll 1d20+50+13+5+25 moment of prescience
[20:11] <Kobot> Lisa rolled 1d20+50+13+5+25 moment of prescience --> [ 1d20=18 ]{111}
[20:12] <@Lisa> roll 1d20+45+13+5+30 many moments of prescience
[20:12] <Kobot> Lisa rolled 1d20+45+13+5+30 many moments of prescience --> [ 1d20=9 ]{102}
[20:12] <@Lisa> roll 1d20+58+13+5
[20:12] <Kobot> Lisa rolled 1d20+58+13+5 --> [ 1d20=17 ]{93}
[20:12] <Kobot> Lisa rolled 1d20+58+13+5 --> [ 1d20=2 ]{78}
[20:12] <Kobot> Lisa rolled 1d20+58+13+5 --> [ 1d20=10 ]{86}
[20:12] <Kobot> Lisa rolled 1d20+58+13+5 --> [ 1d20=5 ]{81}
[20:12] <Kobot> Lisa rolled 1d20+58+13+5 --> [ 1d20=7 ]{83}
[20:13] <@Lisa> roll 6#6d10+92+3d8+2d6+15+7d6+7d6 SA broken in two, in case only half applies via Penetrating Strike
[20:13] <Kobot> Lisa rolled 6#6d10+92+3d8+2d6+15+7d6+7d6 SA broken in two, in case only half applies via Penetrating Strike --> [ 6d10=36 3d8=16 2d6=7 7d6=29 7d6=21 ]{216}, [ 6d10=28 3d8=14 2d6=6 7d6=22 7d6=25 ]{202}, [ 6d10=22 3d8=13 2d6=10 7d6=25 7d6=26 ]{203}, [ 6d10=35 3d8=16 2d6=7 7d6=29 7d6=23 ]{217}, [ 6d10=41 3d8=11 2d6=8 7d6=17 7d6=25 ]{209}, [ 6d10=31 3d8=12 2d6=10 7d6=23 7d6=28 ]{211}
[20:14] <@Lisa> roll 4d6+92+14d6+3d8+15+2d6+7d6+7d6
[20:14] <Kobot> Lisa rolled 4d6+92+14d6+3d8+15+2d6+7d6+7d6 --> [ 4d6=10 14d6=43 3d8=9 2d6=7 7d6=26 7d6=30 ]{232}
This particular damage should be -43 (forgot to remove the original SA), so the total for it is 189.
[20:14] <@Lisa> roll 2d8+83+3d8+15+2d6+7d6+7d6
[20:14] <Kobot> Lisa rolled 2d8+83+3d8+15+2d6+7d6+7d6 --> [ 2d8=13 3d8=9 2d6=3 7d6=24 7d6=27 ]{174}
[20:14] <@Lisa> roll 2d6+83+3d8+15+2d6+7d6+7d6
[20:15] <Kobot> Lisa rolled 2d6+83+3d8+15+2d6+7d6+7d6 --> [ 2d6=7 3d8=12 2d6=7 7d6=25 7d6=19 ]{168}
[20:15] <Kobot> Lisa rolled 2d6+83+3d8+15+2d6+7d6+7d6 --> [ 2d6=5 3d8=13 2d6=5 7d6=23 7d6=24 ]{168}
[20:15] <@Lisa> roll 2d8+101+3d8+15+2d6+7d6+7d6
[20:15] <Kobot> Lisa rolled 2d8+101+3d8+15+2d6+7d6+7d6 --> [ 2d8=9 3d8=5 2d6=4 7d6=17 7d6=20 ]{171}
Twinned Flux Grasp, Twinned Sunlance, Widened Delayed Blast Fireball, Flux Grasp, Superb Dispelling x1 used up
Naturally, holy attacks.
Seira is there in a moment, time having stopped. The symbol of Shar looms hugely above you, like a patch of pure nothingness imposed over Air. You punch it, claw it - it's like nothing's there at all, but you feel a rippling from your strikes. A sensation of pushing against something, slowly tearing it, even as you hit again and again. As she does, allies surrounding it and giving her angles to attack at, you see a faint silvery glow briefly manifest around the eye, in time to your strikes against it.
Amaryl is up.
Amaryl flies up higher and higher, gasping in pain. She comes up just behind Seira, readying herself and...
Full moved, positioning. Eye of Shar is up.
From the Eye of Shar in the sky a pulse ripples, a sudden numbness passing through everyone nearby and...
Fort saves for Seira, Amaryl and the summons, please.
Antenora
HP: 550+200/550
Amaryl
HP: 310/488
[20:46] <@Lisa> roll 5#1d20+8+15 bralani saves
[20:46] <Kobot> Lisa rolled 5#1d20+8+15 bralani saves --> [ 1d20=17 ]{40}, [ 1d20=18 ]{41}, [ 1d20=6 ]{29}, [ 1d20=3 ]{26}, [ 1d20=4 ]{27}
[20:47] <@Lisa> roll 1d20+61+10+30 many moments of prescience2
[20:47] <Kobot> Lisa rolled 1d20+61+10+30 many moments of prescience2 --> [ 1d20=18 ]{119}[
Seira also uses an immediate for Stand Fast. Saves are made with +15 to them.
[spoiler]Seira's spells: nondetection (CL 31), mind blank (CL 31) many moments of prescience (CL 31), moment of prescience (CL 31), greater anticipate teleportation (CL 31), foresight (CL 31), death ward (CL 30), vision of the omniscient eye (CL 31), spell turning (CL 31), good hope (CL 31), righteous wrath of the faithful (CL 30), recitation (CL 31), sensual blessing (CL 31), celestial valor (CL 31), glorious rally (CL 31), greater arcane sight (CL 31), divine insight (CL 31), sensual blessing (CL 31)
