Raven's Nest
Started by Anastasia, June 04, 2018, 11:25:43 AM
Yet the spell crumbles, a word from Seira returning the magic to whence it came, fleeing the sorcerers as if it was never theirs to command.
At the same time ethereal armor coats the other two ravens, planes of force gathering over them as...
Init is Alicia (42) > Amaryl (36) > Seira (19) > Antenora (14) > Raven Riders (12) > Ravens (11)
Ravens are up.
Wounded and burning, the raven on Seira lurches forward, wounds healing before Seira's eyes as it tries to peck and talon her apart, big, oversized moves as much clumsy as powerful.
> roll 1d20+33
> roll 1d20+33
> roll 1d20+33
<Rei-chan> Kotono rolled : 1d20+33 --> [ 1d20=20 ]{53}
<Rei-chan> Kotono rolled : 1d20+33 --> [ 1d20=18 ]{51}
<Rei-chan> Kotono rolled : 1d20+33 --> [ 1d20=4 ]{37}
> roll 1d20+33 crit?
<Rei-chan> Kotono rolled : 1d20+33 crit? --> [ 1d20=20 ]{53}
Any miss chance, Seira?
AC 93, no miss chance.
> roll 16d6+40 that's really just dreadful luck
<Rei-chan> Kotono rolled : 16d6+40 that's really just dreadful luck --> [ 16d6=50 ]{90}
Does not defeat your DR.
The talons rip into your forearm, tearing apart red scales and drawing blood - catching in a perfect groove and powering through, a fluke hit that nonetheless spills your blood. As this happens the other ravens slowly circle around, positioning about 100ft away, one on each of Seira's sides. Ahead more are gathering above the castle as these three engage you.
Alicia.
Flying forward two hundred feet she'll lag a little behind Antenora at first, but she can make it up later. Point is this lets Alicia unload some spells to support Seira at a distance, a trio of bright rainbow blasts erupting around each of the ravens currently threatening her!
2 swift and 1 normal radiant assaults, one per raven/rider combo.
[19:41] <@Ebiris> roll 3#1d20+30 radiant assault SR checks
[19:41] <Rei-chan> Ebiris rolled : 3#1d20+30 radiant assault SR checks --> [ 1d20=18 ]{48}, [ 1d20=3 ]{33}, [ 1d20=11 ]{41}
[19:41] <@Ebiris> roll 3#15d6 radiant assault damage
[19:41] <Rei-chan> Ebiris rolled : 3#15d6 radiant assault damage --> [ 15d6=60 ]{60}, [ 15d6=45 ]{45}, [ 15d6=70 ]{70}
[19:41] <@Ebiris> roll 3#1d6 radiant assault debuff duration
[19:41] <Rei-chan> Ebiris rolled : 3#1d6 radiant assault debuff duration --> [ 1d6=1 ]{1}, [ 1d6=2 ]{2}, [ 1d6=4 ]{4}
Dazed for set number of rounds. DC 30 will halves damage and converts dazed to dazzled.
Alicia: 624+62/624
Active spells: Extended nondetection (CL 31), many moments of prescience (CL 31), extended greater anticipate teleportation (CL 31), foresight (CL 31), death ward (CL 30), greater heroism (CL 31), vision of the omniscient eye (CL 31), spell turning (CL 31), good hope (CL 31), righteous wrath of the faithful (CL 30), dance of the unicorn (CL 30), recitation (CL 30), greater visage of the deity (CL 30), extended repelling shield (CL 31), master's touch (CL 30), sensual blessing (CL 30), celestial valor (CL 31), glorious rally (CL 31), divine insight (CL 31)
Defences: AC 81 (touch 45), CMD 93, spell resistance 45, energy immunity (fire, cold), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affection, fear, dazzled, blinded), freedom of movement, nondetection (DC 46)
Stat buffs/penalties: +2 insight AC/reflex, +6 morale attack/damage/AC/saves, +4 morale skills, +10 insight perception, +3 morale damage, +2 morale ability checks, +3 luck attack/saves, +4 Str, +2 Dex, +4 Con, +2 Int, +4 Wis, +4 Cha, +1 natural armour, +7 shield AC, +4 insight skills, +25 competence perception, +4 sacred attack/damage/AC/saves
Perceptions: Darkvision, scent, low-light vision, blindsight, tremorsense 1 mile, true seeing, perception +83
Sorcerer spell slots: 6/8/8/4/6/5/5/7/5/5/7/5/5/4
Duskblade spell slots: 6/12/11/10/9/4
> roll 1d20+27 Raven 1 (wounded)
<Kobot> Kotono rolled 1d20+27 Raven 1 (wounded) --> [ 1d20=18 ]{45}
> roll 1d20+27 Raven 2
<Kobot> Kotono rolled 1d20+27 Raven 2 --> [ 1d20=1 ]{28}
> roll 1d20+27 Raven 3
<Kobot> Kotono rolled 1d20+27 Raven 3 --> [ 1d20=17 ]{44}
> roll 1d20+20 rider 1-1
<Kobot> Kotono rolled 1d20+20 rider 1-1 --> [ 1d20=6 ]{26}
> roll 1d20+20 rider 1-2
<Kobot> Kotono rolled 1d20+20 rider 1-2 --> [ 1d20=9 ]{29}
> roll 1d20+20 rider 1-3
<Kobot> Kotono rolled 1d20+20 rider 1-3 --> [ 1d20=18 ]{38}
> roll 1d20+20 rider 2-1
<Kobot> Kotono rolled 1d20+20 rider 2-1 --> [ 1d20=9 ]{29}
> roll 1d20+20 rider 2-2
<Kobot> Kotono rolled 1d20+20 rider 2-2 --> [ 1d20=20 ]{40}
> roll 1d20+20 rider 2-3
<Kobot> Kotono rolled 1d20+20 rider 2-3 --> [ 1d20=6 ]{26}
> roll 1d20+20 rider 3-1
<Kobot> Kotono rolled 1d20+20 rider 3-1 --> [ 1d20=2 ]{22}
> roll 1d20+20 rider 3-2
<Kobot> Kotono rolled 1d20+20 rider 3-2 --> [ 1d20=11 ]{31}
> roll 1d20+20 rider 3-3
<Kobot> Kotono rolled 1d20+20 rider 3-3 --> [ 1d20=8 ]{28}
The following are dazed: Raven 2, rider 1-1, rider 1-2, rider 2-1, rider 2-3, rider 3-1, rider 3-3.
The burst of power barely seems to injure the ravens, wounds healing in a flash, yet the multiheaded beasts are reeling, riders knocked back and away, the blasts of light momentarily illuminating the darkened Air sky.
'Seira, can you finish the one I wounded off?' Amaryl sends to her, already moving. She leaps into the air, a blur of a moment as she races towards the dazed raven, a flurry of arrows flying true.
> roll 1d20+60 (+6 morale, +4 sacred, +2 luck)
<Kobot> Kotono rolled 1d20+60 (+6 morale, +4 sacred, +2 luck) --> [ 1d20=4 ]{64}
<Kobot> Kotono rolled 1d20+60 (+6 morale, +4 sacred, +2 luck) --> [ 1d20=11 ]{71}
<Kobot> Kotono rolled 1d20+60 (+6 morale, +4 sacred, +2 luck) --> [ 1d20=8 ]{68}
<Kobot> Kotono rolled 1d20+60 (+6 morale, +4 sacred, +2 luck) --> [ 1d20=19 ]{79}
<Kobot> Kotono rolled 1d20+60 (+6 morale, +4 sacred, +2 luck) --> [ 1d20=6 ]{66}
> roll 1d20+60 (+6 morale, +4 sacred, +2 luck) crit threat on 4
<Kobot> Kotono rolled 1d20+60 (+6 morale, +4 sacred, +2 luck) crit threat on 4 --> [ 1d20=14 ]{74}
> roll 1d8+44+10d6+4d6
<Kobot> Kotono rolled 1d8+44+10d6+4d6 --> [ 1d8=8 10d6=36 4d6=20 ]{108}
<Kobot> Kotono rolled 1d8+44+10d6+4d6 --> [ 1d8=2 10d6=33 4d6=13 ]{92}
<Kobot> Kotono rolled 1d8+44+10d6+4d6 --> [ 1d8=5 10d6=32 4d6=17 ]{98}
<Kobot> Kotono rolled 1d8+44+10d6+4d6 --> [ 1d8=2 10d6=36 4d6=17 ]{99}
>  roll 3d8+132+10d6+4d6
<Kobot> Kotono rolled 3d8+132+10d6+4d6 --> [ 3d8=6 10d6=32 4d6=14 ]{184}
Today: Aggressive combat archery. Also, forgot her +4 from greater arrow mind, but irrelevant since this is easy shots for her.
Arrow after arrow plunges into the second raven, burning it alight like the first, exploding within it. As it burns, the scent of cooking bird-meat carried on the wind?
Seira, go.
Antenora
HP: 550+62/550
Spells Active: Good Hope (CL31), Celestial Valor (CL31), Glorious Rally (CL31), Recitation (CL31), Divine Insight (CL31), Divine Presence (CL30), Righteous Wrath of the Faithful (CL31), Death Ward (CL30), Mind Blank (CL31), Vision of the Omniscient Eye (CL31), Foresight (CL31), Spell Turning (CL31)
Bonuses: +6 morale attack rolls, weapon damage rolls, saving throws and armor class, +2 morale ability checks and skill checks, +8 sacred saves vs fear and negative emotion magic, +4 sacred attack, saving throws, armor class and weapon damage rolls, nonstacking holy on all weapons, immunity to fear, +2 luck attack roll sand saving throws, +15 to one skill check, +5/+10/+15 (does not worship Alicia/one alignment opposed/both alignments opposed) sacred bonus to Intimidate, extra attack on full attack, death ward immunities, +10 insight spot.
Resources Used: Divine Presence,
Amaryl
HP: 488+62/488
Spells Active: Good Hope (CL31), Celestial Valor (CL31), Glorious Rally (CL31), Recitation (CL31), Divine Insight (CL31), Amaryl's Greater Arrow Mind (CL17), Righteous Wrath of the Faithful (CL31), Death Ward (CL30)
Bonuses: +6 morale attack rolls, weapon damage rolls, saving throws and armor class, +2 morale ability checks and skill checks, +8 sacred saves vs fear and negative emotion magic, +4 sacred attack, saving throws, armor class and weapon damage rolls, nonstacking holy on all weapons, immunity to fear, +2 luck attack roll sand saving throws, +15 to one skill check, threaten within reach with bow, do not trigger AoOs for using bow, +4 insight ranged attack rolls, +1 bonus attack with with bow as if hasted, extra attack on full attack, death ward immunities, +10 insight spot.
Resources Used: 1 5th level spell,
#35
'Probably,' Seira muses. She had miscalculated the distance, however, and there is now only one way to actually make it. She shrinks into her other form, and darts towards the beast in the ensuing confusion!
18:42 <Lucille> roll 1d20+54+13 impromptu sneak attack
18:42 <Kobot> Lucille rolled 1d20+54+13 impromptu sneak attack --> [ 1d20=10 ]{77}
18:43 <Lucille> roll 1d6+71+16d6
18:43 <Kobot> Lucille rolled 1d6+71+16d6 --> [ 1d6=3 16d6=57 ]{131}
18:43 <Lucille> roll 30d6 twinned, channeled
18:43 <Kobot> Lucille rolled 30d6 twinned, channeled --> [ 30d6=118 ]{118}
Damage is 131+118x2 = 361
Seira's spells: nondetection (CL 31), mind blank (CL 31) many moments of prescience (CL 31), moment of prescience (CL 31), greater anticipate teleportation (CL 31), foresight (CL 31), death ward (CL 30), vision of the omniscient eye (CL 31), spell turning (CL 31), good hope (CL 31), righteous wrath of the faithful (CL 30), recitation (CL 31), sensual blessing (CL 31), celestial valor (CL 31), glorious rally (CL 31), greater arcane sight (CL 31), divine insight (CL 31)
DragonSeira: 657/666
Armor Class: 81 (Touch AC 46)
Full Attack (GMF +5, Haste, flanking): +60/+60/+60/+60/+55/+50/+45 (6d10+92+15d6) and bite +58 (4d6+92+15d6) and claw +58 (2d8+83+15d6) and wings +58/+58 (2d6+83+15d6) and tail slap +58 (2d8+101+15d6)
Saves: Fort +61, Ref +52, Will +53
+13 attack, +10 damage
+10 saves (+12 ref), +12 AC
Acrobatics is +48 unassisted, I'd happily take 10 to close in. AC is 91.
Seira shrinks, going from dragon to humanoid. In an instant she is a blur, blade slicing through the raven in a blur. She passes by it, and a moment later the burning raven is sliced apart in a dozen directions, plummeting into air, its riders falling with it. Got them!
Acrobatics succeeded.
Antenora nods to you and flies ahead and to the right, positioning with her wings flapping furious, lining up with the active raven.
Positioning for Antenora. Riders are up.
The one remaining second rider that isn't a dazed mess, utters a single profane word, a lancing beam flying at Amaryl.
> roll 1d20+22 touch AC
<Kobot> Kotono rolled 1d20+22 touch AC --> [ 1d20=17 ]{39}
Touch AC is currently 44, so miss.
Yet Amaryl flips back in the air, drawing another arrow in retort and lining up as shot, as meanwhile the one remaining and functional caster on the third raven screams, "T-that's Seira Aryn and Alicia Reynes!" He screams in Auran, easily understood by the both of you. HE fumbles and undoes straps keeping him in place, leaping into the air and plunging down, retreating away.
Ravens. Only the third one is still alive and able to act.
The third raven closes in with Seira, coming within 60ft. Both heads then rear back, a great tornado of wind breathed out at her as meanwhile, the rest of the ravens gather, a pack of approximately nine, gathering above the Raven's Nest.
Ref, Seira.
Actually strike that, you can't fail the save. My bad.
Yet Seira twists out of the way of the winds, body contorting around a whirlwind before a word of power bursts the winds apart, burning with golden fire.
Alicia, go.
19:07 <Lucille> roll 1d20+58+12 improved evasion
19:08 <Kobot> Lucille rolled 1d20+58+12 improved evasion --> [ 1d20=18 ]{88}
With Antenora going to the right, Alicia pushes in on the left but she spares the time to glance up at the ravens gathering above the fortress and rears her arm back before she flings a streak of sunlight up to detonate on the one in the middle of the pack!
Flying 200 feet then casting sunlance
[17:13] <@Ebiris> roll 1d20+50 sunlance ranged touch
[17:13] <Kobot> Ebiris rolled 1d20+50 sunlance ranged touch --> [ 1d20=15 ]{65}
[17:13] <@Ebiris> roll 30d6
[17:13] <Kobot> Ebiris rolled 30d6 --> [ 30d6=102 ]{102}
[17:14] <@Ebiris> roll 6d6 sunlance area damage
[17:14] <Kobot> Ebiris rolled 6d6 sunlance area damage --> [ 6d6=23 ]{23}
DC 36 ref half on the area damage, and if you fail the save you're blinded.
Alicia: 624+62/624
Sorcerer spell slots: 6/8/8/4/6/5/5/7/5/5/7/4/5/4
> roll 1d20+15 behemoths aren't good at reflex
<Kobot> Kotono rolled 1d20+15 behemoths aren't good at reflex --> [ 1d20=18 ]{33}
> roll 1d20+14 nor are the riders
<Kobot> Kotono rolled 1d20+14 nor are the riders --> [ 1d20=2 ]{16}
From afar, Alicia's sunlance flies. It explodes amid them, a detonation of searing light that makes them scream, leaving the ravens and riders reeling. Meanwhile Amaryl darts and leaps back, firing away on her prey as it tries to recover, "Fall!" she cries.
<Kobot> Kotono rolled 1d20+60 (+6 morale, +4 sacred, +2 luck) --> [ 1d20=7 ]{67}
<Kobot> Kotono rolled 1d20+60 (+6 morale, +4 sacred, +2 luck) --> [ 1d20=20 ]{80}
<Kobot> Kotono rolled 1d20+60 (+6 morale, +4 sacred, +2 luck) --> [ 1d20=2 ]{62}
<Kobot> Kotono rolled 1d20+60 (+6 morale, +4 sacred, +2 luck) --> [ 1d20=5 ]{65}
<Kobot> Kotono rolled 1d20+60 (+6 morale, +4 sacred, +2 luck) --> [ 1d20=16 ]{76}
> roll 1d20+60 (+6 morale, +4 sacred, +2 luck) crit check on 2?
<Kobot> Kotono rolled 1d20+60 (+6 morale, +4 sacred, +2 luck) crit check on 2? --> [ 1d20=17 ]{77}
<Kobot> Kotono rolled 1d8+44+10d6+4d6 --> [ 1d8=6 10d6=32 4d6=14 ]{96}
<Kobot> Kotono rolled 1d8+44+10d6+4d6 --> [ 1d8=1 10d6=36 4d6=10 ]{91}
<Kobot> Kotono rolled 1d8+44+10d6+4d6 --> [ 1d8=6 10d6=41 4d6=16 ]{107}
<Kobot> Kotono rolled 1d8+44+10d6+4d6 --> [ 1d8=7 10d6=32 4d6=13 ]{96}
<Kobot> Kotono rolled 3d8+132+10d6+4d6 --> [ 3d8=17 10d6=39 4d6=18 ]{206}
Like this the second behemoth raven is immolated, burning asunder before your eyes. It falls, little more than charcoal and burning feathers as...
Seira, go. Y'all are dominating this encounter pretty hard.
Seira uses this chance to shoot off towards the group of nine behemoths, turning into her dragon form to slam into the nearest one with all the power she can bring to bear! Meanwhile, a very confused astral deva appears in the mix of blinded ravens, perfectly situated to flank with Seira!
[19:54] <@Lisa> roll 1d20+58+13 charge~
[19:54] <Kobot> Lisa rolled 1d20+58+13 charge~ --> [ 1d20=3 ]{74}
[19:55] <@Lisa> roll 6d10+92+14d6
[19:55] <Kobot> Lisa rolled 6d10+92+14d6 --> [ 6d10=33 14d6=54 ]{179}
Gimme a quick Perception check here, Seira.
