The assault on Salty Pier
[blockquote]Rolled 1d20+60 : 1 + 60, total 61[/blockquote] evasion
Fire damage omitted.
> roll 10d6 sonic damage
<Rei-chan> Kotono rolled : 10d6 sonic damage --> [ 10d6=41 ]{41}
BOOOOOM! An explosion sends you rocketing back into Cresiel's stomach, getting a soft oof from him as your vision swims. OW!
Kaja is ahead of you, scimitars out, just in time. Rushing into the room is a pair of efreet, one with two scimitars and the other with a curved, red-hot wand. "Stop and surrender to the generous majesty of the Grand Sultan or be taken to him in chains!"
Suffice to say, init.
He has 30 resistance to sonic, so that does 11 total. I'm pretty sure sonic is covered, anyway? It's a 30 to all energy types resistance. Everyone gets +17 to initiative.
[blockquote]Rolled 1d20+40 : 10 + 40, total 50[/blockquote]
> roll 1d20+32 Cresiel
<Rei-chan> Kotono rolled : 1d20+32 Cresiel --> [ 1d20=15 ]{47}
> roll 1d20+21 Xandra
<Rei-chan> Kotono rolled : 1d20+21 Xandra --> [ 1d20=18 ]{39}
> roll 1d20+30 Kaja
<Rei-chan> Kotono rolled : 1d20+30 Kaja --> [ 1d20=8 ]{38}
> roll 1d20+20 Jetina
<Rei-chan> Kotono rolled : 1d20+20 Jetina --> [ 1d20=14 ]{34}
> roll 1d20+8 efreet 1
<Rei-chan> Kotono rolled : 1d20+8 efreet 1 --> [ 1d20=13 ]{21}
> roll 1d20+10 efreet 2
<Rei-chan> Kotono rolled : 1d20+10 efreet 2 --> [ 1d20=16 ]{26}
Init is Moore (50) > Cresiel (46) > Xandra (39) > Kaja (38) > Jetina (34) > Efreet 2 (26) > Efreet 1 (21)
Open.
"Drop your weapons." Moore says. "This is your only warning."
Take 10 for 75 on Intimidate, using Divine Insight.
No sense rolling for the one who can be feared, he can't make the check.
The one with the scimitars startles and stumbles back, something in Moore's voice enough. The other with the wand steps back carefully, brandishing it at the ready as...
Was that it this turn?
Lemme level with you, running 4 NPCs is a bit much here. Do you wanna run a couple of them for combat here? I'm trying not to get stuck in 30 minute combat posts where I have to do entire turns in between yours.
i figured we could split up somewhere but that never happened. I'll handle Xandra and Jetina.
Sure. I thought it might too, but you choose th eroof and here we are.
Cresiel holds back, "Kaja, go," he says, "Through the door!"
Cresiel holds due not wanting to block the entire door up with his large sized body.
Xandra is up. Go.
Xandra will hold since there's no reason to waste perfectly good spells on chumps.
In a second Kaja is there, grinning viciously as his blades swirl, a slicing dance to rip deep into the wand-wielding efreet, matching his every move. "Too slow!" Kaja barks.
> roll 1d20+61 (+18 morale, +4 sacred, +3 luck, +8 competence, +4 untyped, +1 haste, -30 power attack)
<Rei-chan> Kotono rolled : 1d20+61 (+18 morale, +4 sacred, +3 luck, +8 competence, +4 untyped, +1 haste, -30 power attack) --> [ 1d20=3 ]{64}
> roll 1d6+102+2d6
<Rei-chan> Kotono rolled : 1d6+102+2d6 --> [ 1d6=3 2d6=6 ]{111}
A single slice tears the efreet's left arm off, fiery blood spraying from the almost casual wounding, Kaja's scimitar flickering through in a split-second. The wand wielder screams as he staggers back and...
Jetina.
Cresiel
HP: 680+42/680
Spells Active: Tyche's Touch (CL19), Surge of Hope (CL30), Mass Energy Immunity (CL30), Celestial Valor (CL30), Web of Generosity (CL27), Fortunate Fate (CL30)
Bonuses: +4 luck saves (-1 each save), +4 morale attack rolls, saving throws, ability checks, skill checks, immunity to fear, immunity to fire, +8 sacred fear and negative emotions, +4 sacred attack rolls, weapon damage rolls, armor class, saving throws, +2d6 non stacking holy to weapons, aware of everyone as if by greater status, cast spells of up to 6th level through the link, +18 morale attacks, weapon damage rolls and vs charm, +8 competence attack rolls, +3 fort saves, +12 morale to saves and +12 dodge to AC, +4 attack and weapon damage rolls, +15 to crit thread comfirmations, improved critical feat gained, +1 attack rolls, reflex and attack on a full attack, +30 enhancement movement, +2 luck attacks and saves.
Xandra
HP: 510+56/510
Kaja
HP: 500+51/500
Jetina
HP: 467+28/467
Resources Used: 1 pal 8 spell, 2 healer 13 spells.
[/quote]
It took too long for me to decide on this, but Jetina will also hold.
Wounded and disarmed, the wand-wielding efreet stumbles back, gushing blood and screaming.
Withdrawl action, going out of sight down whatever's past this door.
The other efreet does the same, but goes in the opposite direction in a hurry.
Free act.
"Ridiculous." Moore says as he goes to fly around the corner, after the non-injured efreet! It would make sense that he'd be going to get reinforcements, so he may as well go the same way!
