The assault on Salty Pier
"Working on it!" Kaja calls back with a bloodthirsty smile, "C'mon!"
> roll 1d20+61 (+18 morale, +4 sacred, +3 luck, +8 competence, +4 untyped, +1 haste, -30 power attack)
<Serith> Kotono roll for Serith < 67 > [d20=6]
<Serith> Kotono roll for Serith < 63 > [d20=2]
> roll 1d20+56 (+18 morale, +4 sacred, +3 luck, +8 competence, +4 untyped, +1 haste, -30 power attack)
<Serith> Kotono roll for Serith < 60 > [d20=4]
<Serith> Kotono roll for Serith < 72 > [d20=16]
> roll 1d20+51 (+18 morale, +4 sacred, +3 luck, +8 competence, +4 untyped, +1 haste, -30 power attack)
<Serith> Kotono roll for Serith < 70 > [d20=19]
<Serith> Kotono roll for Serith < 66 > [d20=15]
> roll 1d20+46 (+18 morale, +4 sacred, +3 luck, +8 competence, +4 untyped, +1 haste, -30 power attack)
<Serith> Kotono roll for Serith < 47 > [d20=1]
<Serith> Kotono roll for Serith < 66 > [d20=20]
> roll 1d20+46 all of that bite
<Serith> Kotono roll for Serith < 56 > [d20=10]
> roll 1d20+56 (+18 morale, +4 sacred, +3 luck, +8 competence, +4 untyped, +1 haste, -30 power attack) crit check 1
<Serith> Kotono roll for Serith < 67 > [d20=11]
> roll 1d20+51 (+18 morale, +4 sacred, +3 luck, +8 competence, +4 untyped, +1 haste, -30 power attack) crit check 2
<Serith> Kotono roll for Serith < 59 > [d20=8]
> roll 1d20+51 (+18 morale, +4 sacred, +3 luck, +8 competence, +4 untyped, +1 haste, -30 power attack) crit check 3
<Serith> Kotono roll for Serith < 53 > [d20=2]
> roll 1d20+46 (+18 morale, +4 sacred, +3 luck, +8 competence, +4 untyped, +1 haste, -30 power attack) crit check 4
<Serith> Kotono roll for Serith < 60 > [d20=14]
> roll 1d6+102+2d6 gem 1
<Serith> Kotono roll for Serith < 118 > [d6=4,6,6]
> roll 1d6+102+2d6 gem 2
<Serith> Kotono roll for Serith < 113 > [d6=1,4,6]
> roll 4d6+408+2d6 gem 3
<Serith> Kotono roll for Serith < 433 > [d6=1,6,6,2,6,4]
Not going to bother, the rest of the damage is grossly overkill. Groooooossly. May tone him down a bit, though admittedly this is under Moore conditions so to hit bonuses are plentiful and extreme.
What Kaja does is resemble a whirlwind with blades. It reminds Moore a bit of watching Westwind fight, more strikes but perhaps less power behind each one. Darting and moving around, the efreet opposing Kaja are sliced apart, blood and flaming guts spilling everywhere before they become heaps of basalt and obsidian, slaughtered.
"I see what you meant, Moore," Kaja calls back with a laugh, golden scales glistening with wet, red blood.
Xandra.
Xandra makes a gesture and sends a brilliant ray of frost energy at one of the efreet on Cresiel!
[22:08] <Nephrite> roll 1d20
[22:08] <Serith> Nephrite roll for Serith < 2 > [d20=2]
Polar Ray at the first Efreet in range. I'm pretty sure since it's touch I don't need to do math but let me know if this is not the case.
[22:11] <Nephrite> roll 25d6
[22:11] <Serith> Nephrite roll for Serith < 82 > [d6=4,4,2,5,4,1,2,1,6,5,4,6,3,2,6,2,3,1,6,6,4,1,1,2,1]
Since half of this is divine damage, does that mean that only half of it is increased? I am presuming they have a weakness to frost damage.  I also do not know what the fortitude save actually is for the dazzling effect, it also may not, uh, matter at all.
I'll sit down with you at a later time and get all these notes in order so this doesn't become a hassle.
Correct, no math needed. Correct, only half is multiplied.
Init is Moore (46) > Kaja (29) > Xandra (26) > Efreet (25) > Jetina (18) > Cresiel (17)
With a deft shot and quick aim, Xandra points and shatters the efreet. That's exactly what happens, the beam hitting the genie and causing him to flash-freeze and then shatter apart like a thousand shards of shining glass.
As this happens, the remaining handful of efreet begin to withdraw, gushes of flames covering their retreat as...
Enemy is in disarray and withdrawing. Go ahead and free act for the second.
Cresiel
HP: 680+42/680
Spells Active: Tyche's Touch (CL19), Surge of Hope (CL30), Mass Energy Immunity (CL30), Celestial Valor (CL30), Web of Generosity (CL27), Fortunate Fate (CL30)
Bonuses: +4 luck saves (-1 each save), +4 morale attack rolls, saving throws, ability checks, skill checks, immunity to fear, immunity to fire, +8 sacred fear and negative emotions, +4 sacred attack rolls, weapon damage rolls, armor class, saving throws, +2d6 non stacking holy to weapons, aware of everyone as if by greater status, cast spells of up to 6th level through the link, +18 morale attacks, weapon damage rolls and vs charm, +8 competence attack rolls, +3 fort saves, +12 morale to saves and +12 dodge to AC, +4 attack and weapon damage rolls, +15 to crit thread comfirmations, improved critical feat gained, +1 attack rolls, reflex and attack on a full attack, +30 enhancement movement, +2 luck attacks and saves.
Xandra
HP: 510+56/510
Resources Used: 1 8th level spell, 1 9th level spell.
Kaja
HP: 500+51/500
Resources Used: 1 dervish dance
Jetina
HP: 467+28/467
Resources Used: 1 pal 8 spell, 2 healer 13 spells.
"Honestly, I was expecting a little bit more." Moore admits. "I certainly hope Mr. Firebearded is more of a challenge. Anyone have any idea where he actually is?"
Moore throws up a spell since they have some breathing room!
Haste on everyone again to refresh it. 30/r
"Down below," Xandra intones, "We keep on fighting."
Kaja laughs, "Good, I'm just getting started."
"There's plenty of stuff here that we can repurpose for much better causes." Moore agrees. "Let's keep going."
Do the stairs keep winding down? If so, we'll go down some more.
They do not, you'll need to explore in either direction.
Then let's proceed in the direction Cresiel was holding off, if possible.
Molre richness as the party hurries ahead. Down a lavish hall to a set of double doors leading further in, hastily closed shut and tight.
Cresiel advances, hammer already raised. "Be ready," he warns.
Moore nods to Cresiel.
"Let's show them our resolve." He says.
Under Cresiel's hammer the door breaks. Here is a small dance room, doors on the far side and the left wall as well. Tables and desks have been set up as barricades all about, spread apart and six total. Each one is manned by several efreets, some with bow and arrow, vial and spell or simply flames. They're using them as cover as...
"Kill them!" One calls, a tall, rangy specimen with a flaming glare, wearing flowing ember-red robes. "Kill them and present their heads to the Sultan!"
Init and K:P.
Take 10 for 89 on K:P
[blockquote]Rolled 1d20+40 : 17 + 40, total 57[/blockquote] Moore
[blockquote]Rolled 1d20+6 : 16 + 6, total 22[/blockquote] Xandra
[blockquote]Rolled 1d20+5 : 12 + 5, total 17[/blockquote] Jetina
Brain go dumb, what's your init boost again?
It's 17, and I don't know why those numbers don't match up. I am going to reroll them.
[blockquote]Rolled 1d20+6 : 14 + 6, total 20[/blockquote] Xandra
[blockquote]Rolled 1d20+5 : 7 + 5, total 12[/blockquote] Jetina
Okay, I have no idea why this isn't working... I'll just do a 1d20 and manually add afterwards because for some reason doing a 1d20+6+17 is coming up with the wrong numbers.
[blockquote]Rolled 1d20 : 17, total 17[/blockquote] Xandra (+23)
[blockquote]Rolled 1d20 : 19, total 19[/blockquote] Jetina (+22)
