The depths of Ice
Started by Anastasia, August 20, 2018, 01:33:26 PM
Tornado Blast's got a radius. I'm assuming that it could damage Benyen & Dana as well as the golem, right?
Yes, assuming the radius is big enough to get them.
Bummer. Continuing to hold until he pushes them away again.
Again the winds come, "Brace!" Benyen calls, as bitterly cold winds pierce through your bodies.
Ref all.
Magic, like last time. 50% chance of getting through, make the save and I'll sort it out in the morning.
Tryll[blockquote]Rolled 1d100 : 63, total 63[/blockquote]Calleigh[blockquote]Rolled 1d100 : 74, total 74[/blockquote]
The save, Yuth, not the incorporeal miss chance check. The Reflex save called for.
i misunderstands
Tryll[blockquote]Rolled 1d20+26 : 13 + 26, total 39[/blockquote]Calleigh[blockquote]Rolled 1d20+29 : 16 + 29, total 45[/blockquote]
> roll 1d20+38 Dana evasion
<Kobot> Sunshine_Ko rolled 1d20+38 Dana evasion --> [ 1d20=19 ]{57}
> roll 1d20+26 Miranda evasion
<Kobot> Sunshine_Ko rolled 1d20+26 Miranda evasion --> [ 1d20=12 ]{38}
> roll 1d20+30 Benyen
<Kobot> Sunshine_Ko rolled 1d20+30 Benyen --> [ 1d20=8 ]{38}
>  roll 1d20+35 Debonah
<Kobot> Sunshine_Ko rolled 1d20+35 Debonah --> [ 1d20=7 ]{42}
> roll 1d100 vs 1-50 C&T
<Kobot> Sunshine_Ko rolled 1d100 vs 1-50 C&T --> [ 1d100=69 ]{69}
No joy on incorporeal this time. Brace.
> roll 20d8 piercing cold so ignores resistance and deals half to immunes
<Kobot> Sunshine_Ko rolled 20d8 piercing cold so ignores resistance and deals half to immunes --> [ 20d8=92 ]{92}
Tryll takes full, Calleigh takes none since I know she has evasion and please remember to include that, Dana takes none while Miranda, Benyen and Debonah all take full.
> roll 1d20+7 Strength Dana
<Kobot> Sunshine_Ko rolled 1d20+7 Strength Dana --> [ 1d20=20 ]{27}
> roll 1d20+8 Strength Benyen
<Kobot> Sunshine_Ko rolled 1d20+8 Strength Benyen --> [ 1d20=20 ]{28}
...natural 20s are bad?
The winds blow fanatically, vicious, cutting into you. All of you endure as Tryll feels numbness, slicing into his form, freezing him hard. As he with stands it, there's one problem - Benyen and Dana manage to somehow hold their group, resisting the winds and staying right where they are.
At the same time all but Dana are covered in ice, thick ice - so is Tryll, surrounding him in a tomb of frost that he floats right on through, hardly bothered at all.
Going to act now? Golem's done, everyone but you two and Dana is iced over. Otherwise Debonah and then Miranda are up.
Dana
HP: 597/597 (fast healing 2)
Aura:
Resources: Rage 1/1 Offensive Chain 3/3 Defensive Chain 3/3 Defensive Stance 9/9 Protection Devotion 1/1 Bulwark 3/3 Haste 9/10
Spells Used: Power Points 390/457
SLAs Used:
Spells Active: Attune Form (CL5), Psionic Freedom of Movement (CL31)
Notes: Triggers frost blood on a slashing or piercing melee attack.
Miranda
HP: 277/405
Aura: Courage 10ft (+4 morale vs fear)
Bonuses: Attack+2 (+2 morale), Damage+0 AC+0, Saves+2 (+2 morale), Skills+2 (+2 morale), Checks+0
Resources:
Spells Used:
SLAs Used:
Spells Active: Attune Form (CL5), Heroism (CL?)
Notes: Favored enemy applies to attack rolls. No real resource issues with anything she does, can function all day.
Benyen
HP: 293 (508 max right now) (87 frostburn)/609 (fast healing 3)
Negative Conditions: Hypothermia (Exhausted)
Aura: Magic Circle Against Evil 10ft (Protection from Evil), Courage 10ft (+4 morale vs fear)
Bonuses: Attack+0, Damage+0 AC+0, Saves+0, Skills+0, Checks+0 Resistance to cold 30.
Resources: Smite Evil 20/21 Channel Energy 12/13 Lay On Hands 60/60 Remove Disease 1/1 (week) Incarnum Overload 1/1 Servant of the Heavens 1/1 +5 One Attack On FA 1/1 (rnd) Take 10 On One Attack (rnd) 1/1 Rage 2/2 Hell Striker Takeover 1/1 (mth) Dimension Door 3/3
Spells Used:
SLAs Used:
Spells Active: Attune Form (CL5), Resist Energy (Cold) (CL35)
Notes: Typical smite bonus damage is 27*2=54+6=60. 60+12=72*2=144 on charge.
Debonah
HP: 873 (117)/873 (regeneration 20)
Aura:
Bonuses: Attack+6 (insight), Damage+6 (insight), AC+6 (insight), Saves+0, Skills+0, Checks+0
Resources: +5 One Attack On FA 1/1 (rnd) Take 10 On One Attack (rnd)
Spells Used: Power Points: 718/742
SLAs Used:
Spells Active: Attune Form (CL5), Psionic Freedom of Movement (CL35), Debonah's Mental Awakening (CL35)
Thought. How much does that block of ice that Tryll ignored weigh?
40-60 pounds, maybe? It's not a huge block as much as a tight, thick coating.
Okay. the shells and such from the others, are they still around? Lots of debris being piled up?
Neato.
Tryll abandons the power of wind, as it will not serve him well right now. Instead he reaches out and grabs every piece of loose debris in the room; ice chunks, corpses, weapons, arrows, anything not currently held or nailed down, and launches it at the golem with violent speed!
Telekinetic Thrust
It's the Squid Missile power, used on other stuff.
Augment: 32 PP
Effect: Up to 750 lbs of debris and weaponry is launched at the target.
SR: Only for objects moved directly by this power
Range: 320 ft
Strike: Ranged attack rolls, 1 per object thrown
I need to know how many loose items are in the area, please. :3
