Elemental Movements
Started by Anastasia, September 17, 2018, 10:51:14 AM
Loot updated, go check it out and post once you have.
so noted. Will have to solve the riddle of life one day.
"Whew," Kaja declares, "Nasty trick he had there."
Jetina nods, "I'm surprised he fought alone. Why?"
Xandra frowns, "I've heard of that trick before. It works best alone, letting your foes slay themselves against you while you survive."
"It works especially if you can heal yourself. Thankfully that's easy enough to stop." Moore shakes his head as he looks around. "This is what your war college amounts to?"
He proceeds onward!
"Try harder, failing grade," Cresiel agrees as you head to the door to the next set of stairs. This door is locked.
"Oh, no. Cresiel, we've run into a locked door!" Moore says with a great deal of shock and aghast.
He blinks, then sighs.
"I really need to learn how to use Knock, or at least get an item that can just open this sort of thing." Moore says as a follow up. "Would you please?" He asks Cresiel.
"Hold the door for me, Kaja," Cresiel says.
Kaja does so without comment, while Xandra says, "Worry not, I do not foresee this door evading or attacking you."
Indeed, a few blows shatter the door, revealing another set of stairs going down.
Moore snorts. "See, you do have a sense of humor." He says as he proceeds onwards.
The stairs here are colored. Some stairs are blue, some stars are red and some stares are orange. There is a plaque on the wall which reads in Ignan, "Only the hottest souls are safe."
Does a Spellcraft of 74 tell me anything useful?
It does not. Whatever magic is there may be deep in the stone, deep enough to block such divinations.
"Try and fly over these, if you can." Moore says to the others as he continues forward, flying over the stairs!
Marching order here? Matters.
Moore, Cresiel, Xandra, Kaja Jetina.
Moore flies, followed by Cresiel. You fly over the stairs, only for tremendous blasts of flame to erupt from the stairs, a bright, too intense to look at blue.
Reflex save, -3, both of you.
