Forward
Started by Anastasia, December 27, 2018, 08:15:18 AM
> roll 20d6 force owwies
<Penuche> Kotono invokes Penuche's magic: < 67 > [d6=6,1,5,3,5,1,2,1,6,2,1,1,3,3,4,4,2,5,6,6]
Plus Fort. It's stunning, note if immune.
Not immune[blockquote]Rolled 1d20+24 : 12 + 24, total 36[/blockquote]
> roll 1d4
<Penuche> Kotono invokes Penuche's magic: < 3 > [d4=3]
Stunned 3 rounds.
You're stunned, unable think or move. You float there in a daze, the crystals going quiet. Just as you get your wits back, the burst happens again, slamming into you as you regain your facilities.
Beware possible stun locking. Ref again.
Oh look a large scale trap. How big is the room?
On and on and on you rush. You rush right into a crystalline cavern, reflecting light a thousand times over. A rainbow of radiance illuminates the room, every inch covered in thick inches of pure, flawless crystals. Great stalagmites and stalactites of it can be seen as well, the entire chamber hundreds of feet wide and three dozen feet tall.
From the post when you came in.
Oh, groovy. Thanks.
Paragon's Fortune.
Tryll denies the effect, his nature as a paragon overwhelming whatever power the crystals have. Simultaneously, he speeds straight downward and through the cavern floor!
It's a momentary burst of power, enough to escape out of the trapped room and safe. Whew. You avoid any more pain and suffering from it, struck hard but nothing more.
Fast healing is a Real Thing.
Tryll skirts the edges of the cavern, continuing his chase after the ruby.
This does slow you down a bit, but it lets you keep following. And soon enough you erupt into another large cavern. This one is without the crystals of the last and quite large - and here you can sense it and...
Perception is needed.
True Seeing & Darkvision
[blockquote]Rolled 1d20+48 : 5 + 48, total 53[/blockquote]
A blur. Two quick, tiny mice moving far faster than mice should, down into a tiny tunnel like the others you've seen, on the far end and out of sight. It's the exact direction you're being pulled in, too.
Straight lines are faster than twisty tunnels! Tryll marches on!
Though he keeps an eye out for rocket mice.
Onward you go - and abruptly the pull is heading down and ahead, rather than just ahead, by the time you reach the far end of the cavern.
Tryll pours on the speed, following.
A Correspond to Miranda, 'I think I'm being toyed with.'
'How so?' is the answer you get.
