Getting the band together
Luckily, Seira has the skills to defuse traps from a distance! Staying at a distance of 30ft, Seira takes care of the traps while being at her stealthiest! With luck, she'll take the wards down before the elementals notice her, and then the others could join her in taking them out!
Stealth 10 at 106, divine insight discharged.
Ranged legerdemain: Disable Device at DC +5:
19:39 <CC> roll 1d20+77
19:39 <Penuche> CC invokes Penuche's magic: < 80 > [d20=3]
Just to be clear here since it matters - and you made the DC here regardless - what means are you using to be unseen as you advance, if any?
Clarity may matter here.
Epic skills are bullshit so I figured if I were stealthy enough they wouldn't notice me. After all, the fluff had 'being lost' in a haze of heat, and presumably there'd be shadows as well and what not. If that's not how it works, I can invis myself.
No that's fine, I just wanted to make sure I was on the same page. It's been a rough few days for my focus with everything going on.
Seira is ab lur as she sneaks ahead, heat haze and her own stealth keeping her hidden as she gets closer and closer and...
Ball is in your court to decide how close you get and how you act, we'll resolve it from there.
I will get within 30ft of the traps and disable them. I already rolled for that~
I mean how close to the elementals and the like, since the traps are before that and you've disabled them. Just looking for a ball park here, a plan of attack if nothing goes wrong, whatever.
With the traps disabled, Seira gives Oraga and Lagann a mental command to advance even as she detonates three fireballs in the elemental ranks.
Delayed Blast Fireball, goldenfire, Ref DC39 half
20:09 <CC> roll 20d6
20:09 <Penuche> CC invokes Penuche's magic: < 70 > [d6=2,5,1,1,1,4,6,5,6,6,5,2,4,5,4,1,1,4,3,4]
20:09 <Penuche> CC invokes Penuche's magic: < 69 > [d6=5,6,6,4,4,3,1,5,3,3,2,1,3,5,3,6,2,5,1,1]
20:10 <CC> roll 20d6
20:10 <Penuche> CC invokes Penuche's magic: < 80 > [d6=1,6,5,5,4,1,5,4,2,5,3,4,5,3,4,6,5,6,3,3]
> roll 1d20+15 evasion fireball 1
> roll 1d20+15 evasion fireball 2
> roll 1d20+15 evasion fireball 3
<Penuche> Kotono invokes Penuche's magic: < 34 > [d20=19]
<Penuche> Kotono invokes Penuche's magic: < 35 > [d20=20]
<Penuche> Kotono invokes Penuche's magic: < 19 > [d20=4]
Sizzling goldenfire strikes, burning what cannot be burned. Shields half melt as they stand their ground, sizzling as Lagann approaches. He snaps his fingers and...
> roll 1d20+15 wall
<Penuche> Kotono invokes Penuche's magic: < 20 > [d20=5]
> roll 20d8
<Penuche> Kotono invokes Penuche's magic: < 97 > [d8=8,2,3,2,8,7,6,3,2,7,4,7,1,8,6,6,4,6,3,4]
Steel walls appear around them, crunching in silently. When they fade and part, only mangled shields and embers are left behind.
Free act, that was purely clean up.
Seira proceeds with her now-usual cleanup, taking anything magical, disintegrating any remains or piles of nonmagical gear and cleaning up the passageway so that the signs of battle no longer appear in it!
And then she proceeds ahead, with a grin at Lagann.
Lagann returns it with an easy nod, 'Minions, nothing but!' he declares. 'Surely hoping to bore to death any real challengers.'
They must feel themselves safe past all the defenses, though getting all the way to our destination without raising the alarm takes skill all the same. I'm happy to practice it now and then.
Up you go - up and up and up and up. More traps here - simple tripwires, connected to something in the walls. Past all this and higher up is another passage leading deeper in, light coming from there.
Seira heads into it! Mindful of traps, and sneakily!
It's trivial to over look them and peeking ahead with divine vision? A massive cavern is here, lit and with clear vision ahead. Here stone barriers are build, high enough for efreet to use them for cover, dozens of them dotted about. All about passages come into this room, and in the back they all head into a central building of glowing hot red brick.
Elementals supplement them, kneeling before the various barriers with tower shield, blocking the way.
Atop the building stands a single figure - an efreet clad in white and red, bandages top to bottom, nothing else worn. The only visible part of him is his eyes, pits of molten fire that glare ahead balefully.
Oraga, take out that bandaged efreet on the top. Yandrazrt, deal with the elementals.
Seira, for her part, turns invisible and makes her way towards the building and then into it through one of its entrances while under her best stealth!
Also channeling Twinned Ray of Exhaustion into Dragon's Grace and refreshing one-off spells like Sign and Divine Insight, as always when out of combat.
