Contact
Started by Anastasia, January 31, 2019, 12:54:36 PM
i don't know if the board can accommodate it but let's see. Should be 20d6
[blockquote]Rolled 20d6 : 5, 1, 4, 3, 6, 6, 1, 2, 2, 2, 3, 1, 4, 2, 1, 1, 6, 6, 2, 2, total 60[/blockquote]
[blockquote]Rolled 20d6 : 1, 5, 4, 1, 2, 5, 3, 3, 2, 5, 1, 2, 1, 5, 5, 3, 3, 1, 2, 4, total 58[/blockquote]
I didn't realize that DBF is a glorious spell. If you'd allow it I'd like to spend two smites on it. If so, the ref dc rises to 41, without it it's 31.
She will also add 18 to the damage if both fireballs.
On top of all of that it needs to make a fort save to avoid being blinded by both. I do not know if the dc is based on the spell level, or if it's increased via smite.
Yeah sure, that's fine.
> roll 1d20+32
> roll 1d20+32
<Penuche> Kotono invokes Penuche's magic: < 38 > [d20=6]
<Penuche> Kotono invokes Penuche's magic: < 41 > [d20=9]
> roll 1d20+32 fort
> roll 1d20+32 fort
<Penuche> Kotono invokes Penuche's magic: < 49 > [d20=17]
<Penuche> Kotono invokes Penuche's magic: < 52 > [d20=20]
A double blast of holy power momentarily makes the marilith scream, a sharp noise that's cut off into a snarl. As the four of you plummet, Xandra just finds one problem - the snow's blocking her view, unable to see the marilith now. Whatever she does, you don't see her immediately again and...
Go.
moore doesn't have much to do, Xandra will try and see what she can see.
[blockquote]Rolled 1d20+61 : 5 + 61, total 66[/blockquote] Perception for her.
If she doesn't see anything she will just try and be ready to give the marilith a smitin'
By the way, are you going to be on IRC anytime soon? Not critical, merely curious.
You're heading down further. The blizzard is slowly thinning as you do - but you catch it coming from above, from deeper in. A faint gleam of black, flying down amid the storm, a blast coming the party's way.
hopefully. Waiting for my car to finish service.
Xandra, knowing two people can't dodge at all right know, tries her best to destroy the blast prematurely!
she is going to try and pull a beam battle by throwing a Sunlance into the blast. Whether it actually works is obviously suspect but it's the only idea she has available at the moment.
Hope it goes well.
Gimme a CL check.
[blockquote]Rolled 1d20+32 : 2 + 32, total 34[/blockquote]
Also, on checking, Xandra's out of 11th level spell charges so I need a different move.
The roll of 2 will be kept as appropriate.
Xandra
HP: 391/538
Aura: Menace 20ft (-2 attacks, AC, saves; DC 37)
Bonuses: Attack+30 (+8 competence, +18 morale, +4 sacred, +2d6 holy weapons), Damage+22 (+18 morale, +4 sacred) AC+16 (+12 morale, +4 sacred), Saves+16 (+19 fort)(+12 morale, +4 morale, +4 sacred)(+14 more vs charm/fear), Skills+4 (+4 morale), Checks+0
Resources: Smite Evil 9/9 Lay On Hands 16/16 Servant of the Heavens 1/1 Sudden Empower 1/1 Sudden Enlarge 1/1
Spells Used: 2 9th, 4 10th, ALL 11th, ALL 12th
SLAs Used:
Spells Active: True Seeing (CL32), Celestial Valor (CL32), Mass Energy Immunity (Cold) (CL32), Mass Freedom of Movement (CL32), Mass Death Ward (CL32), Fortunate Fate (CL20), Mass Surefooted Stride (CL??), Surge of Hope (CL31)
Notes: Has bardic music in the rare event Moore can't cover something.
my bad! Lets go with Hellball then.
The hellball flies and meets the beam - and the fury of the elements is smashed through, obliterated as the snows continue to thin. You barely have a chance to act before...!!!
Ref saves, all.
[blockquote]Rolled 1d20+35 : 4 + 35, total 39[/blockquote]Xandra
[blockquote]Rolled 1d20+41 : 18 + 41, total 59[/blockquote]Moore, evasion, the other two I assume auto fail
It didn't add the extras, Xandra should be 56 and Moore 45
> roll 20d10
<Penuche> Kotono invokes Penuche's magic: < 106 > [d10=7,10,5,4,7,1,7,7,5,3,4,9,2,5,1,4,5,10,4,6]
Xandra half, Kaja and Jetina full and Moore takes full.
HP after that?
Moore has 112 temp hp so that brought it to 6 so he's still okay.
The others should also be fine due to that, including Xandra. Still waiting on the car ........
Everything okay with your car?
The blast sends you tumbling end over end, the world pain and snow. You're falling away from Xandra, knocked away from her arm as Kaja and Jetina do the same. You barely have a moment to react as you hear a cackle - burned but intact, the marilith from before is charging down.
Init.
Xandra
HP: 338/538
SLAs Used:
