A book and many things to do
Started by Anastasia, July 09, 2019, 11:04:47 PM
Alyssa uses her TK to slam the man into the wall, hoping to end whatever is about to happen.
Which usage if any, or just a generic push back here?
It would be some form of Violent Thrust, but there's not really anything written in the spell or classes that translates the raw force of it to any sort of damage. I suppose we could do some sort of conversion for the amount of force-lbs to damage? Fling Skyward might be close, but that has nothing for someone hitting an object, just fall damage.
Okay, we'll work with that.
Your telekinetic slam hits the man hard. With a cry he goes limp - even as his skin begins to swell and push out, more and more by the moment.
Alyssa raises an eyebrow and steps back out of the cell. That's sure to be messy.
You step back as the man's flesh expands out more and more.
Once, you remember watching Mother cook when you were young. You sat and watched the cookfire as she cooked a sausage, only to need to run out for a reason that escapes you. You remember the sausage starting to burn and overcook, the skin of it splitting apart and greasy juices dribbling out under the heat.
As blood splashes about the room, the memory is recalled in vivid detail. It's rather like that. You can glimpse something within, something writhing and moving inside of the man.
Alyssa tries to pin whatever it is to the ground before it can attack or do anything else.
The man's chained up on the wall and it's inside of him still. How are you going to get it to the ground?
I thought he was split open and stuff? Could I just target it and pull it out or the like?
He split open but it's still inside. You could try sure, if you don't mind possibly hurting him more.
Granted he's in a bad way anyway. Don't need a Heal check to tell that.
I mean, the only way he's surviving is if I get this out of him and then use Regenerate on him, so it's sort of a need-to-do thing. That said, Alyssa *is* super good with TK, so it's pretty reasonable to do it.
You can try, sure. Gimme a CMB check here.
Can I knowledge devotion this foo?
