The first peaceful day
You return to find Hope's Landing intact. Always a relief as additionally Grias tells you, "Oh, it's been quiet, very quiet," he says, "Everything's fine, Moore."
"Good to hear." Moore says.
So, here's the question: Moore learned of this new spell, but how is he going to cast it? Does he need to wait until a level up, or what would you like to see done there? It kind of feels shitty to have to learn it as an actual spell given its nature. :(
I had assumed you'd retrain a slot to use it. Was I wrong?
You are not. If I'm able to do so now, I would.
Okay. I'll swap Reaving Dispel for it, in that case.
Done. Okay, going to cast it right off?
Yes. I am guessing you need me to specify what I am casting it on.
In that case it is the ritual to weaken the effects of spiritual wounds on Lifasa by using Moore's blood.
Okay, so the idea that Moore's blood can mitigate and reduce spiritual wounds caused on Lifasa, then? Just to be clear since precision here is needed.
Yes I think that is sufficient.
Okay, go ahead and record that you've made that anathemic knowledge on your sheet, along with the spell that did it and the limits on it. Note who already knows about it and is thus immune as well. Crosspost that here when you're done.
*the idea that Moore's blood can mitigate and reduce spiritual wounds caused on Lifasa
Anathemic Knowledge, the Bard 9 Cleric spell was used to create this.
People who know already: Moore, Tepen, Xandra, Cresiel.
Didn't you tell Saluiel and a few others?
The casting is time consuming - the ritual is exacting, but in the end it's done, the last note of the spell sung. You feel the knowledge change somehow, slipping away from most, becoming unknown.
I don't think I told him what I was planning on doing with it specifically, but I can add him anyway.
I'm pretty sure he didn't mention his plans to anyone else at least I'm terms of specifics.
With that finally done, Moore will make sure he didn't miss any exciting news while he focused on this. If he didn't, then it's time to go see Tepen.
It's been quiet on your front as...
Any prep/who is going with you for Tepen? Well, Kaja basically so.
