Going down
Started by Anastasia, August 16, 2019, 03:30:24 PM
Ahah! Beneath a heap of bones is a narrow chasm going straight down - just big enough for someone like Dana or Benyen to fall down.
Calleigh drops through the floor to investigate!
'Found a chasm. About Dana-sized. Calleigh's checking it out.'
Calleigh goes down. It's about a 100ft or so fall, ending in a pitch dark chasm with dark waters flooding it. There's a passage ahead down here, a single one.
That gets investigated too!
It's pretty long and winding - no sign of an end. You do, however, notice ripples as well as shadows beneath the surface of the dark water.
How far has she gone down this tunnel?
Ominous!
Will go another hundred before doubling back.
It winds on further, no end in sight. You return back without incident and...
Go ahead.
"Nope, just a super long endless tunnel with probably underwater monsters after a hundred foot drop!"
"So...we go down it?" Benyen says, "Sea monsters are a good time."
"Krakens are, at least." Miranda observes, "They're often easy targets for my arrows, once they breech the surface."
'I'm game.'
"It'sa real small cave, from what I was able to see. You guys are proooobably gonna be in the water most of the time."
"Could be worse," Dana shrugs, "Let's go do this shit." She hops on down, Benyen following.
Tryll heads down as well.
"Well, I tried." Calleigh says, floating over to Miranda. "You heading in too?"
"They need an archer to save them from their foolishness," Miranda agrees, hopping down after.
