Ahead lies...?
It is indeed a sealing enchantment. A dispel undoes it, Jetina readying her shield, "It's safe," she calls back.
"Thank you." Moore says as he goes to open it and go inside!
Inside - hello. A sunken chamber, like a pool filled. Filled with golden coins that is, filled to the brim with small piles about the edges, as if splashed over.
"A king's ransom," Cresiel observes as the party enters, "Yet only gold."
Moore checks around for magic before he gathers it all up into his bag!
Take 10 for 103 on Spellcraft, then a Moore's Quick Gather.
As you clear it out, you find magic at the bottom - there's a plug beneath all the coins, about as wide around as Hanna. It's enchanted to need a key to open.
Can I UMD to fake the key on this somehow? Barring that let's just dispel it.
It's probably just keeping something out but we may as well see.
Take 10 for 88 on UMD then.
You can't take 10 on UMD without something that allows it, so gimme a roll or point out that you do have such a thing.
i think I used to have something but it got replaced.
[blockquote]Rolled 1d20+78 : 6 + 78, total 84[/blockquote]
It takes some work and concentration, but the seal is undone, the plug able to be removed now.
Moore will try! If he needs help then Kaja and Cresiel can pitch in.
The three of you grunt and are able to pull it out - you see why, the lower half is solid steel. Ooof. Beneath it is a ladder leading into a deep crevice, where a single book sits atop a table. Besides the book is a bejeweled dagger, a writing quill and a golden ring.
"...I do not even know where to begin." Moore says. He flies down to investigate!
Take 10 on 103 for Spellcraft and 108 on k:a. What's going on down here?
Give me a quick CL check on whatever you're using to detect magic?
