Striving for 777
Started by Anastasia, October 29, 2019, 10:13:49 PM
How's this look? Slightly different structure but same idea. Thoughts?
Commune with Knowledge
Divination
Level: Brd 10, Clr 12, Sor/Wiz 12
Components: V, S, F
Casting Time: 10 minutes
Range: Personal
Target: You
Duration: Concentration
This spell contacts the platonic ideal of knowledge itself to obtain answers. This spell functions as contact other plane, except that the chance of a true answer is 1-96, the chance of a random answer is 97-100 and the Intelligence DC to avoid Intelligence and Charisma loss is 20, it lasts 8 weeks and a natural roll of 1 always results in a failure, no matter the total*. Certain questions, such as those that seek the secrets of deities, anathemic knowledge or knowledge protected by epic abjurations cause this spell to return a result of unknown instead of an answer. Unlike with contact other plane, the answers may be as long as needed and not only one word.
* Bards and clerics use Charisma and Wisdom in place of an Intelligence check, and lose their bard or cleric spellcasting in place of arcane spellcasting.
That is fine from a functional standpoint though the eight weeks seems pretty punishing, but if you think that's fair then I won't object. I suppose failure should come with a cost.
That's also pattered on contact other plane. Could bump it up a level to provide relief from that, I suppose.
So 11/13 but without the failure?
Without at least the time, I'd have to fiddle a bit but something like that, yeah.
That is fine with me, take your time .
How's this look?
Divination
Level: Brd 11, Clr 13, Sor/Wiz 13
Components: V, S, F
Range: Personal
Target: You
This spell contacts the platonic ideal of knowledge itself to obtain answers. This spell functions as contact other plane, except that the chance of a true answer is 1-96, the chance of a random answer is 97-100 and the Intelligence DC to avoid Intelligence and Charisma loss is 18, it lasts 1 day and a natural roll of 1 always results in a failure, no matter the total*. Certain questions, such as those that seek the secrets of deities, anathemic knowledge or knowledge protected by epic abjurations cause this spell to return a result of unknown instead of an answer. Unlike with contact other plane, the answers may be as long as needed and not only one word.
Okay, so going to cast that then, right off?
Yes.
Charisma roll here.
[blockquote]Rolled 1d20+30 : 12 + 30, total 42[/blockquote]
Okay, give me your first question.
'With all the knowledge I've collected so far on this research, where is one place I can go to fill in the most gaps?'
The Terminal Archive.
Today in confirmation of what you probably didn't want to hear...
'Who can I speak to there who I can trust to be fair and not betray any agreements?'
None, it is a demonic place. Workable agreements are possible, however, with sufficient force, guile and negotiation.
