Deep into the Infinite Stair
Started by Anastasia, November 08, 2019, 02:58:54 PM
It's not in 3 miles sight yet.
Thus you advance again.
Now it's just under 3 miles away - a single point of radiance, a young man emitting all that light. No older than 21 or 22, clad in white and throwing bolts down, another one coming your way.
Go ahead and counter.
[20:48] <@Ebiris> roll 40d10 silver fire damage
[20:48] <Penuche> Ebiris invokes Penuche's magic: < 221 > [40d10=221]
> roll 100d4
<Penuche> Kotono invokes Penuche's magic: < 250 > [100d4=250]
Another bolt stopped, countered smoothly.
Go.
Effectively 5 rounds at current pace before we're close enough for melee, though could manage long range spells after 4 if anyone cares to try.
"Keep going, we won't change if he doesn't," Alicia says, twisting space and zipping through it before she prepared to counter with more ever-reliable silver fire.
Now that it's known, give me four counter checks.
[21:00] <@Ebiris> roll 4#40d10 silver fire
[21:00] <Penuche> Ebiris invokes Penuche's magic: < 231, 208, 249, 235 >
Four more times. It's done, one more step should take you to him. The young man isn't alarmed, but continues on with steady patience.
Go Alicia, your turn.
"The next one takes us right to him," Alicia warns before it happens, and she's the first one through making her attack on him in a flash!
[21:05] <@Ebiris> roll 1d20+90 blinding speed, 6th level arcane strike, channelled maximised/vivacious combust
[21:05] <Penuche> Ebiris invokes Penuche's magic: < 96 > [d20=6]
[21:05] <Penuche> Ebiris invokes Penuche's magic: < 108 > [d20=18]
[21:05] <Penuche> Ebiris invokes Penuche's magic: < 99 > [d20=9]
[21:05] <@Ebiris> roll 1d20+85 blinding speed, 6th level arcane strike, channelled maximised/vivacious combust
[21:05] <Penuche> Ebiris invokes Penuche's magic: < 91 > [d20=6]
[21:05] <Penuche> Ebiris invokes Penuche's magic: < 86 > [d20=1]
[21:05] <@Ebiris> roll 1d20+80 blinding speed, 6th level arcane strike, channelled maximised/vivacious combust
[21:05] <Penuche> Ebiris invokes Penuche's magic: < 83 > [d20=3]
[21:05] <Penuche> Ebiris invokes Penuche's magic: < 90 > [d20=10]
[21:05] <@Ebiris> roll 1d20+75 blinding speed, 6th level arcane strike, channelled maximised/vivacious combust
[21:05] <Penuche> Ebiris invokes Penuche's magic: < 76 > [d20=1]
[21:05] <Penuche> Ebiris invokes Penuche's magic: < 81 > [d20=6]
[21:06] <@Ebiris> roll 1d20+90 blinding speed, 6th level arcane strike, channelled maximised/vivacious combust crit check
[21:06] <Penuche> Ebiris invokes Penuche's magic: < 110 > [d20=20]
[21:06] <@Ebiris> roll 6d6+52+17+2d6+6d4+80 17 is fire, 80 is divine
[21:06] <Penuche> Ebiris invokes Penuche's magic: < 191 > [d6=6,2,3,2,1,6,6,2][d4=1,2,2,1,4,4]
[21:06] <Penuche> Ebiris invokes Penuche's magic: < 194 > [d6=2,2,5,5,3,5,6,2][d4=1,1,4,4,4,1]
[21:06] <Penuche> Ebiris invokes Penuche's magic: < 198 > [d6=4,3,6,3,6,1,4,5][d4=1,2,4,3,4,3]
[21:06] <Penuche> Ebiris invokes Penuche's magic: < 195 > [d6=5,1,5,2,4,4,4,4][d4=4,2,4,4,1,2]
[21:06] <Penuche> Ebiris invokes Penuche's magic: < 191 > [d6=6,4,4,3,5,3,1,1][d4=3,3,1,1,3,4]
[21:06] <Penuche> Ebiris invokes Penuche's magic: < 191 > [d6=3,2,4,4,4,2,1,6][d4=3,2,2,4,3,2]
[21:06] <Penuche> Ebiris invokes Penuche's magic: < 205 > [d6=6,6,2,5,4,6,5,2][d4=4,4,2,4,4,2]
[21:06] <Penuche> Ebiris invokes Penuche's magic: < 187 > [d6=4,6,2,6,1,1,2,2][d4=4,3,3,2,1,1]
[21:06] <Penuche> Ebiris invokes Penuche's magic: < 194 > [d6=4,2,4,4,5,4,4,1][d4=4,3,3,2,3,2]
[21:07] <@Ebiris> roll 12d6+104+34+2d6+6d4+160 34 is fire, 160 is divine if 108/110 was a crit
[21:07] <Penuche> Ebiris invokes Penuche's magic: < 368 > [d6=2,2,5,4,4,6,1,2,2,6,5,4,4,6][d4=1,4,3,4,3,2]
[21:07] <@Ebiris> roll 6d6+52+17+2d6+6d4+80 17 is fire, 80 is divine if it wasn't
[21:07] <Penuche> Ebiris invokes Penuche's magic: < 200 > [d6=6,5,5,2,5,4,5,6][d4=2,3,1,2,1,4]
Will use moments of prescience on the next 4 attacks if the first 2 miss for another +30.
2 swifts left.
Alicia HP: 1044/1044
Active spells: Extended mind blank (CL 35), extended nondetection (CL 35), greater heroism (CL 34), sensual blessing (CL 34), recitation (CL 34), righteous wrath of the faithful (CL 34), foresight (CL 34), extended spell turning (CL 35), extended freedom of movement (CL 35), keen edge (CL 34), repelling shield (CL 34), extended ray deflection (CL 35), greater visage of the deity (CL 34), many moments of prescience (CL 34), Seira's arcane thesis (CL 34)
Defences: AC 97, CMD 141, spell resistance 49, energy immunity (fire and cold), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 49)
Stat buffs/penalties: +4 morale skills, +25 competence perception, +3 luck AC/attack/saves, +2 insight AC/reflex, +9 shield AC, +36 str, -2 dex, +20 con, +2 int, +4 wis, +4 cha, +15 natural armour, -8 size, +10 morale attack/damage, +8 morale saves, +8 dodge AC, +5 spell DCs, +10 SR checks, +8 morale strength
Perceptions: Arcane sight, perception +82
Sorcerer spell slots: 6/16/16/11/6/9/10/8/8/5/7/7/4/3/2
Duskblade spell slots: 6/23/23/19/11/7/8
No MMOP needed.
Your blade is a relentless hunter, the young man slashed asunder like a pit fiend before your power.
A blink.
You are back in the arena, about 40ft away from a glowing sphere. A prismatic sphere, radiant and shielding something within from sight. You know this spell, even if it looks as non magical to you as a rock in a field.
Continue with the swifts.
Init is Alicia (Supreme Init) > Jessica (38) > Queen (36) > ??? (35) > Jessica (25)
No use for them right now, turn over.
"Sister, can you take down that sphere," Jessica asks right away, "Queen?"
"I'll try a disjunction, that usually works," Alicia says. Otherwise having to go through the spell chain will be a long and laborious process.
Jessica and Queen hold then.
From within the sphere they emerge - a great barrage of a familiar spell, magic missiles slamming into the three of you.
> roll 1d20+38 this one is actually mimicking a spell enough to have this apply
<Penuche> Kotono invokes Penuche's magic: < 47 > [d20=9]
SR?
49
Yet the missiles do nothing against any of you. Instead the three of you endure them, no more from the sphere for now.
Go ahead.
