Still moving and circling around the room, Alicia sends more silver fire at him and casts another true strike so she can better trip up any charges.
[19:41] <@Ebiris> roll 40d10 DC 47 ref half
[19:41] <Penuche> Ebiris invokes Penuche's magic: < 223 > [40d10=223]
Alicia HP: 1074+240/1074
Active spells:  Many moments of prescience (CL 34), extended mind blank (CL 35), extended nondetection (CL 35), greater heroism (CL 34), repelling shield (CL 34), extended ray deflection (CL 35), epic mage armour (CL 35), dance of the unicorn (CL 36), recitation (CL 35), opal protection (CL 35)
Defences: AC 98, CMD 122, spell resistance 50, energy immunity (fire and cold), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 49)
Stat buffs/penalties: +4 morale skills/attack/saves, +9 shield AC, +10 armour AC, +25 competence perception, +40 str, -2 dex, +20 con, +2 int, +4 wis, +4 cha, +15 natural armour AC, -8 size, +8 saves vs poison, +3 luck attack/saves, +3 morale AC
Sorcerer spell slots: 6/16/16/16/9/9/11/8/6/5/6/3/4/3/4
Duskblade spell slots: 6/23/23/17/10/7/4
Moments of prescience: 2
> roll 1d20+37 ref
<Penuche> Kotono invokes Penuche's magic: < 54 > [d20=17]
Another grazing blow, yet the golem sags after it. It's full of holes and yet no closer to touching you. "Too good," ehs ays, as his chest opens wide. Dozens of diamonds fly out, a barrage of them all around - even over Antenora and Syala, who scowls as...
Ref saves, all.
[19:50] <@Ebiris> roll 1d20+58 ref
[19:50] <Penuche> Ebiris invokes Penuche's magic: < 62 > [d20=4]
> roll 1d20+63 ref Antenora
<Penuche> Kotono invokes Penuche's magic: < 75 > [d20=12]
> roll 1d20+46 Syala ref
<Penuche> Kotono invokes Penuche's magic: < 48 > [d20=2]
Guh! Diamond surrounds you, encases you. Glittering diamond solidifies and traps you where you stand, completely coating you. Syala's half heard exclamation of shock suggests she is as well, but Antenora?
"That WAS a duel," Antenora's voice is cold, "Yet you attacked us indiscriminately? Dishonorable and weak. Alicia may need a few moments to free herself, but I'll occupy you until then."
Antenora is a bit pissed and is joining init. He never rolled since you have supreme so I'll roll him too.
> roll 1d20+13
<Penuche> Kotono invokes Penuche's magic: < 27 > [d20=14]
> roll 1d20+18
<Penuche> Kotono invokes Penuche's magic: < 19 > [d20=1]
Init is Alicia (Supreme Init) > Antenora (27) > Nei-Vallas (19)
Go, you're still first in the round.
Antenora
HP: 840/840
Bonuses: Attack+5 (+3 luck, +2 strength), Damage+3 (+3 strength) AC+6 (+3 morale, +3 luck), Saves+6 (+3 morale, +3 luck), Skills+0, Checks+0
Resources: Holy Fury 39/39 (enc) Divine Retribution 1/1 Smite Evil 13/13 Channel Energy 16/17 Lay On Hands 490/490 Remove Disease 10/10 (week), Spiritual Connection 3/3 Blinding Speed 24/25 Divine Blast 15/17
Spells Used: Healx2, Opal Protection, Opal Fury
SLAs Used:
Spells Active: Mind Blank (CL36), Recitation (CL36), Opal Protection (CL36), Opal Fury (CL36)
Syala
HP: 700/700
Bonuses: Attack+3 (+3 luck), Damage+0 AC+24 (+3 morale, +3 luck, +18 armor), Saves+6 (+3 morale, +3 luck), Skills+0, Checks+0
Spells Used: 1 8th level spell, 1 9th level spell, 1 10th level spell, 1 11th level spell, 1 14th level spell.
SLAs Used:
Spells Active: Mind Blank (CL36), Energy Immunity(Fire)(CL35), Epic Mage Armor (CL35), Recitation (CL36), Opal Protection (CL36)
This isn't so hard to get out of. Shrinking down to the size of a mouse, the crystal shaped around her colossal form is no impediment as Alicia sends a beam of silver fire through both the diamond and Nei-Vallas. That gives her room to fly through and off to the side before resuming gigantic size.
"It's fine Antenora it wasn't a lethal attack. I have this!" she calls over, seeing no need to make this a group battle.
[20:36] <@Ebiris> roll 40d10 DC 47 ref half
[20:36] <Penuche> Ebiris invokes Penuche's magic: < 223 > [40d10=223]
Do you have any way of seeing through the diamond?
Is the diamond not transparent?
Well otherwise I have tremorsense which should let me know what's going on through the diamond/floor while I'm in contact with it, at least enough to properly aim the silver fire to hit Nei-Vallas.
Good enough.
> roll 1d20+37 ref
<Penuche> Kotono invokes Penuche's magic: < 46 > [d20=9]
Another blast that cores through the diamond and strikes Nei-Vallas. This time he falls over from it and does not get up, a groan from the golem's lips. "...I should have used a different golem," he grouses, "But the win is yours, Alicia Reynes. The win is yours."
She shrinks down to normal size now. "It did force me to fight unconventionally, but I'm not just a one-trick pony," she says with a smile.
Alicia HP: 794+240/794
Defences: AC 96, CMD 100, spell resistance 50, energy immunity (fire and cold), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 49)
Stat buffs/penalties: +4 morale skills/attack/saves, +9 shield AC, +10 armour AC, +25 competence perception, +4 str, +2 dex, +4 con, +2 int, +4 wis, +4 cha, +1 natural armour AC, +8 saves vs poison, +3 luck attack/saves, +3 morale AC
"I promote you to a solid two tricks. Well fought, Alicia. You paid attention to my battle." Antenora smiles faintly as Syala divine blasts her way out of the diamond, flying up amid a cascade of shards downward.
Meanwhile a door slides open in the back, "Go out, that'll take you out safely," The fallen golem manages, not showing any signs of getting up.
"Nothing wrong with playing it careful," she nods to Antenora. "Good luck next time Nei-Vallas!" she then calls before leading the trio out the newly revealed door. Still a lot further to go and more to fight, no doubt about it.
You find your guide awaits you outside once you come out the back.
"You won," He says, tongue flicking out into the air.
"We did, thanks for waiting for us," Alicia says to Partanyx. "It was a good fight."
"Do you like diamonds?" Syala asks as the three of you join him.
Antenora merely brushes herself off, a gentle trickle of will cleansing herself.
"Ah, you fought Nei-Vallas?" Is the question back, "I do like diamonds."
A fragment of diamond, the size of a man's forefinger or so, is casually tossed to the serpent. He catches it with his tongue and it vanishes moments after. Syala holds up a handful of shards, "Trophies. It's real diamond - I'd love to know how he did it, but I don't think he'd tell us. Or how he gathered that much diamond to begin with."
"You won't know without asking," Alicia points out, but she's not that much interested in diamonds herself. "Anyway now we're past that lets keep going deeper and to more forbidden parts."
