[17:03] <@Ebiris> roll 1d20+65 ref
[17:03] <Penuche> Ebiris invokes Penuche's magic: < 78 > [d20=13]
Actually since this is gas we should all get +4 from dance of the unicorn. So 82 for me. Might help Syala proc her improved evasion!
> roll 1d20+68 Antenora ref
<Penuche> Kotono invokes Penuche's magic: < 84 > [d20=16]
> roll 1d20+47 Syala ref improved evasion
<Penuche> Kotono invokes Penuche's magic: < 49 > [d20=2]
440 again but the upshot is that everyone halves so 220 to all.
The gas burns dreadfully hot, again assaulting your skin as you know the taste of pain. But that's not all - the vast snakes leap down from the gorgon's hair, flying down at the party, mouths wide open.
> roll 1d20+63
<Penuche> Kotono invokes Penuche's magic: < 74 > [d20=11]
AC all?
+4 Str, +2 Dex, +4 Con, +2 Int, +4 Wis, +4 Cha. +1 natural armor.
Antenora
HP: 412(840)/910 (840)
Bonuses: Attack+10 (+4 morale, +3 luck, +3 strength), Damage+3 (+3 strength), AC+3 (+3 luck), Saves+7 (+4 morale, +3 luck), Skills+4 (+4 morale), Checks+0
Resources: Holy Fury 35/39 (enc) Divine Retribution 1/1 Smite Evil 12/13 Channel Energy 16/17 Lay On Hands 150/490 Remove Disease 10/10 (week), Spiritual Connection 3/3 Blinding Speed 23/25 Divine Blast 15/17
Spells Used: Healx2, Opal Protection, Opal Furyx2
SLAs Used:
Spells Active: Mind Blank (CL36), Recitation (CL36), Freedom of Movement (CL35), Forestfold (CL35), Mass Swim (CL35)
Syala
HP: 480/700
Bonuses: Attack+3 (+3 luck), Damage+0 AC+24 (+3 morale, +3 luck, +18 armor), Saves+3 (+3 luck), Skills+0, Checks+0
Spells Used: 1 8th level spell, 1 9th level spell, 1 10th level spell, 2 11th level spell, 1 12th level spell, 3 14th level spell.
SLAs Used:
Spells Active: Mind Blank (CL36), Energy Immunity(Fire)(CL35), Epic Mage Armor (CL35), Recitation (CL36), Freedom of Movement (CL35), Forestfold (CL35), Mass Swim (CL35)
105.
Alicia HP: 761/1249
Active spells: Many moments of prescience (CL 35), extended mind blank (CL 35), extended nondetection (CL 35), greater heroism (CL 35), repelling shield (CL 35), extended ray deflection (CL 35), epic mage armour (CL 35), dance of the unicorn (CL 36), recitation (CL 35), opal protection (CL 35), sensual blessing (CL 35), arcane sight (CL 35), freedom of movement (CL 35), foresight (CL 35)
Defences: AC 105, CMD 134, spell resistance 50, energy immunity (fire and cold), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 50), freedom of movement
Stat buffs/penalties: +4 morale skills/attack/saves, +9 shield AC, +10 armour AC, +25 competence perception, +40 str, -2 dex, +20 con, +2 int, +4 wis, +4 cha, +15 natural armour AC, -8 size, +8 saves vs poison, +3 luck attack/saves, +3 morale AC, +2 insight AC/ref, +10 morale str/dex/con
Sorcerer spell slots: 6/10/10/10/7/8/0/4/4/4/5/2/3/0/2
Duskblade spell slots: 6/13/13/6/10/4/1
Moments of prescience: 2
Again, only Antenora is hit.
> roll 1d6+35
<Penuche> Kotono invokes Penuche's magic: < 41 > [d6=6]
> roll 1d20+64 Antenora
<Penuche> Kotono invokes Penuche's magic: < 68 > [d20=4]
The snakes bite away and only get Antenora, but that's not all. A moment later they burst into gas, lesser bursts of the game gas ravaging all of you.
Ref again, all. Persistent damage dealer.
Antenora
HP: 391(840)/910 (840)
SLAs Used:
Syala
HP: 480/700
SLAs Used:
[17:50] <@Ebiris> roll 1d20+65 ref
[17:50] <Penuche> Ebiris invokes Penuche's magic: < 73 > [d20=8]
<Penuche> Ko invokes Penuche's magic: < 81 > [d20=13]
> roll 1d20+47 Syala improved evasion
<Penuche> Ko invokes Penuche's magic: < 64 > [d20=17]
Everyone made it, so you two take half and Syala takes none.
> roll 24*4
<Penuche> Ko invokes Penuche's magic: < 96 >
So 48 damage.
The blast of gas is enough to wound the two of you more, Antenora's flesh boiling and flaking away, as is yours. As you stand there? 'Do you need healing?' Antenora sends.
Antenora's up, actions depend on reply.
Antenora
HP: 343(840)/910 (840)
SLAs Used:
Syala
HP: 480/700
SLAs Used:
"I'm fine!" Alicia returns. She's taken a lot of hurt but she has plenty more to take!
Alicia HP: 713/1249
Antenora begins to heal right away, wounds returning to normal. A moment later she launches herself into the air, charging the gorgon head long.
Her last heal spell on herself and then another divine succor to follow up.
> roll 1d20+39 (+2 charge, +13 various,  -30 PA) hoping brilliant weapon comes through
<Penuche> Ko invokes Penuche's magic: < 58 > [d20=19]
> roll 2d8+198
<Penuche> Ko invokes Penuche's magic: < 207 > [d8=2,7]
Antenora darts in and impales the gorgon's stomach, but it barely stops her at all. Syala just holds position and chants, healing coming over the two of you.
Mass Heal, +250 both of you since pain. Go.
Antenora
HP: 595(840)/910 (840)
Resources: Holy Fury 34/39 (enc) Divine Retribution 1/1 Smite Evil 12/13 Channel Energy 16/17 Lay On Hands 150/490 Remove Disease 10/10 (week), Spiritual Connection 3/3 Blinding Speed 23/25 Divine Blast 15/17
Spells Used: Healx3, Opal Protection, Opal Furyx2
SLAs Used:
Syala
HP: 730/700
Spells Used: 1 8th level spell, 1 9th level spell, 2 10th level spell, 2 11th level spell, 1 12th level spell, 3 14th level spell.
SLAs Used:
"How many times must we slay the same foe?" Alicia asks in irritation, her titanic bare body shifting to meet the equally titanic but far more modestly garbed gorgon, swords cutting through its armour as if it weren't there.
[18:42] <@Ebiris> roll 1d20+89 blinding speed, channelled black ice touch, 10th level arcane strike. Ignores armour/shield AC
[18:42] <Penuche> Ebiris invokes Penuche's magic: < 95 > [d20=6]
[18:42] <Penuche> Ebiris invokes Penuche's magic: < 98 > [d20=9]
[18:42] <Penuche> Ebiris invokes Penuche's magic: < 94 > [d20=5]
[18:42] <Penuche> Ebiris invokes Penuche's magic: < 104 > [d20=15]
[18:42] <@Ebiris> roll 1d20+84 blinding speed, channelled black ice touch, 10th level arcane strike. Ignores armour/shield AC
[18:42] <Penuche> Ebiris invokes Penuche's magic: < 89 > [d20=5]
[18:42] <Penuche> Ebiris invokes Penuche's magic: < 99 > [d20=15]
[18:42] <@Ebiris> roll 1d20+79 blinding speed, channelled black ice touch, 10th level arcane strike. Ignores armour/shield AC
[18:42] <Penuche> Ebiris invokes Penuche's magic: < 95 > [d20=16]
[18:42] <Penuche> Ebiris invokes Penuche's magic: < 98 > [d20=19]
[18:42] <@Ebiris> roll 1d20+74 blinding speed, channelled black ice touch, 10th level arcane strike. Ignores armour/shield AC
[18:42] <Penuche> Ebiris invokes Penuche's magic: < 76 > [d20=2]
[18:42] <Penuche> Ebiris invokes Penuche's magic: < 89 > [d20=15]
[18:42] <@Ebiris> roll 1d20+79 blinding speed, channelled black ice touch, 10th level arcane strike. Ignores armour/shield AC - crit check
[18:42] <Penuche> Ebiris invokes Penuche's magic: < 88 > [d20=9]
[18:42] <@Ebiris> roll 1d20+42 SR
[18:42] <Penuche> Ebiris invokes Penuche's magic: < 62 > [d20=20]
[18:42] <@Ebiris> OOC: 41 rather
[18:43] <@Ebiris> roll 6d6+38+10d4+15d6 last 15d6 is cold
[18:43] <Penuche> Ebiris invokes Penuche's magic: < 140 > [d6=5,5,4,3,6,5][d4=3,3,2,2,2,1,2,4,4,2][d6=1,4,4,6,1,6,5,3,2,1,6,5,3,1,1]
[18:43] <Penuche> Ebiris invokes Penuche's magic: < 128 > [d6=2,2,1,3,1,4][d4=2,1,4,2,3,4,2,2,1,2][d6=3,5,1,3,1,6,5,5,4,5,3,4,6,2,1]
[18:43] <Penuche> Ebiris invokes Penuche's magic: < 137 > [d6=5,3,6,3,6,5][d4=2,2,4,3,2,3,4,4,3,2][d6=1,6,4,2,3,2,2,1,1,2,4,4,2,4,4]
[18:43] <Penuche> Ebiris invokes Penuche's magic: < 141 > [d6=5,3,6,5,3,3][d4=1,1,3,3,2,1,2,3,4,4][d6=4,5,2,3,5,1,1,6,6,4,1,2,4,6,4]
[18:43] <Penuche> Ebiris invokes Penuche's magic: < 124 > [d6=1,2,6,4,4,2][d4=2,3,1,3,4,2,1,1,3,2][d6=5,1,4,4,2,6,1,3,5,1,4,1,6,1,1]
[18:43] <Penuche> Ebiris invokes Penuche's magic: < 128 > [d6=6,4,2,4,2,2][d4=1,1,4,1,1,2,3,2,3,1][d6=2,6,2,3,6,6,2,3,4,2,3,6,3,1,2]
[18:43] <Penuche> Ebiris invokes Penuche's magic: < 134 > [d6=1,1,2,2,2,5][d4=3,3,4,1,2,2,1,1,1,4][d6=3,5,6,6,4,6,3,5,1,2,6,2,4,4,4]
[18:43] <@Ebiris> roll 12d6+76+10d4+30d6 last 30d6 is cold
[18:43] <Penuche> Ebiris invokes Penuche's magic: < 228 > [12d6=36][10d4=22][30d6=94]
[18:43] <Penuche> Ebiris invokes Penuche's magic: < 122 > [d6=2,2,5,3,2,6][d4=2,2,2,4,1,2,2,4,1,1][d6=5,1,4,5,2,5,2,1,1,4,2,2,2,3,4]
[18:43] <Penuche> Ebiris invokes Penuche's magic: < 122 > [d6=4,3,1,6,2,2][d4=2,3,1,2,2,3,2,2,1,2][d6=3,2,3,3,6,5,1,3,4,5,5,1,3,1,1]
[18:44] <@Ebiris> roll 10#1d4 negative levels
[18:44] <Penuche> Ebiris invokes Penuche's magic: < 3, 2, 2, 2, 3, 4, 4, 2, 1, 2 >
Alicia HP: 1217/1249
Sorcerer spell slots: 6/10/10/10/7/8/0/4/4/4/4/2/3/0/2
Duskblade spell slots: 6/13/13/6/10/4/0
This time it is enough. The gorgon tumbles back and falls, overwhelmed by spear and blade. When it hits the ground it is gone - and you are on a beach. A warm, sunny beach as Antenora immediately begins healing wounds.
Free act.
"Is that it for the moment?" Alicia looks around at her full size to take stock of their surroundings. "All these changes in foes and environments so rapidly, the power beyond magic really is fearsome."
As Antenora heals your wounds, "A good battle, if a trying one that put us at a disadvantage. At least our natures now are less dependent on our equipment than they were before."
It's a wide open, sunny beach. Behind you are hazy sand dunes, while ahead is the clear blue ocean. Syala sits for a moment, "We proved our might well enough, that was no small opponent."
Antenora
HP: 910(840)/910 (840)
SLAs Used:
Syala
HP: 700/700
SLAs Used:
"Not quite as good as our normal weapons but these are still passable in a pinch," Alicia holds up her temporary sword.
Can I sense anything within range of blindsight/remorsense?
Alicia HP: 1249/1249
As far as you can feel, it's a beach and you three are the only souls on it.
"They're wonderful work, Alicia," Antenora says as you sense away. "One aspect of divinity I savor is our greater independence. Not to be alone, but to stand better so that our goals and the goals of our allies are more possible."
"I'd be embarrassed to put them next to anything made by Latha, but they'll do," Alicia says. "I can't sense anything moving for miles. Syala can you get the lay of the land with your magic?"
