Regeneration
Started by Anastasia, May 30, 2020, 10:30:49 PM
Tryll takes option 3 and phases through the wall.
I don't need precise details here with how ti's laid out, but are you aiming closer to the rend in the wall or the doors?
You slip in. Ahead lies an open dome, a vast space. Here circular levels of chairs and long tables can be seen, from the broad outermost circle atop to a small circle at the bottom with but a single throne. It is quiet here, no sign of immediate distress or trouble. The walls are cracked and crumbling, the chairs old and forgotten. The tables are dusty and the crash of thunder from outside is muted by constant.
'No immediate signs of danger, come on in.'
The party follows.
"It's ruined," Benyen says simply, and then, "More than I'd expect. Forgotten."
"Even as a safe place you'd expect it would be used by travelers more often," Miranda says, going to a table and running her finger through the thick dust there. "But it looks like no soul has been here in centuries."
'I'd assume the living statuary would discourage most travelers.' Tryll replies.
"They weren't that bad," Miranda disagrees, "And it's better to risk them than the storm."
Jayne flies about the room, peering down. "It's really empty," she says, "I don't see anything at all."
"I'm sensing a conspicuous lack of abomination." Calleigh asserts.
"So far," Dana agrees, "So where the fuck here is it?"
"There's more to explore," Miranda offers, starting to go ahead, "Why don't we look around?"
Search/perception check or what?
Perception's good if you wanna look around, sure.
Tryll[blockquote]Rolled 1d20+48 : 8 + 48, total 56[/blockquote]Calleigh[blockquote]Rolled 1d20+41 : 4 + 41, total 45[/blockquote]
There's several doors that lead further into the building, as well as gaps you could explore as well. Lots of options here.
Nothing in this room, however. Whatever this room once was, it's nothing but a forgotten memory now.
'Shall-' "OHHH LET'S EXPLORE!" Calleigh squeals, zipping off into a nearby gap.
'..let's not split the party, yes?' Tryll floats after her.
