Crossed swords
Started by Anastasia, July 21, 2020, 12:45:28 PM
It's heavy but you do so easily enough.
Strange. But Seira uses this chance to return to the others, magically cleaning herself up as soon as she exits the acid lake to not be a hazard, and places the lump on the ground.
The crystal is a pale, lime green color. It's large as Hanna or so and quite bulky.
"Is that it?" Donald asks, "Doesn't look like it to me, does it?"
Seira tries to examine it, now that she's in a more comfortable situation!
Does Greater Arcane Sight tell me anything? Legend Lore?
Moore will do the same. Take 10 for 119 on K:A as appropriate, or K... whatever else would work, if it's some sort of gem or something else for 101. :)
Unknown Mineral
This crystal is supercharged with life energies. It's hard and suitable to be used in arms and armor as well. It may well be unique, considering where it was found.
Seira snaps her fingers. "Elle, this might be more up your alley," she notes. "I thought it might be like that when magic actually worked on it, so mind taking a look?"
Glancing over at Moore, she muses, "Perhaps it's time to try stronger divinations?"
Moore nods. "I can try something with Wish, if you want. Failing that, I know a stronger one but it would take a bit of time to cast." He says.
She's taking 10 as needed.
Elle studies it, "I'd have to experiment to know for sure," she finally says, "But you could make an amazing weapon based around restoration and healing with this." She taps the crystal, "I'd absolutely want to craft it in fine conditions to maximize what I could get out of it."
"Then look after it," Seira tells Elle with a grin, before giving Moore a nod. "Go for the lengthy spell, I'll take another dip in the acid for a second look around so we don't waste any time."
Moore nods and will take a breath to start to invoke his Commune with Knowledge spell.
Guessing he's not going to get interrupted.
Question 1:
How do we find the artifact Seira is seeking?
As Seira begins to search again? It's a huge lake of acid, but something very far ahead is sensed. Lumpy but small.
Meanwhile for Moore: Dive down below and continue.
May as well find anything else relevant while they're here...
'Are there any other unique minerals nearby like the one we found?'
Seira makes her way towards it!
Seira reaches it. Whatever it is, it's a lump about the size of your head and covered in a thick, shell like substance.
Meanwhile Moore's answer is: Yes.
