Dust and blood
Started by Anastasia, August 05, 2020, 10:13:10 PM
A deep nod at that, "I'm home," Is her answer, "It's home like I always imagined it would be. I feel like I'm in the right place at last."
"Well, I'm glad to hear that. When you've finished with this project, let me know. I'm interested to see where it takes you."
With that, Alyssa pats her on the shoulder and returns to her office.
Who was the other one you were going to look into?
"I will," Is the simple promise as you depart.
Araseis. The Tiefling you almost killed like four times in her first appearance.
You find Araseis in an inn room - run down but dry. She sits on the bed, a spellbook in lap. From the way she's working, you can easily tell she's perfecting new spells and expanding her horizons. She's improved.
Araseis is now a rogue 6//wizard 6.
Oo, neat. She deserves a reward. Can I remotely add a spell to her spellbook?
Let's do that, then. Based on the last adventure of hers, this is probably the best choice.
Alyssa weaves a bit of magic and adds a spell to Araseis' spellbook!
Your growth and path make me proud.
Presip's Life Walk
Conjuration (Healing)
Level: Clr 3, Hlr 3
Components: V, S, DF
Range: Touch
Target: Living creature touched
Duration: 1 round/level
Spell Resistance: No
When you cast this spell, the movement of the target's body creates tiny fissures to the Positive Energy Plane, allowing them to heal. For every 5ft the target moves, they heal 1 hit point. For example, if the target moves 30ft, they heal 6 hit points. This healing stacks with fast healing and other sources of healing. Only direct movement by the target causes healing, being pushed or thrown does not, nor does being magically moved in any way (such as teleportation).
You...do understand that's not on her spell list as it's not a wizard spell, right?
Why did my brain transpose that. I read through them like four times and I swear I saw it as a wiz spell... I think I got it switched up with my second option.
Flash Bolt
Transmutation
Level: Sor/Wiz 3
Components: V, S
Casting Time: 1 standard cction
Range: Close (25ft + 5ft/2 levels)
Target: One creature
Duration: Instantaneous
Spell Resistance: Yes
You point at your target as you chant, the words of magic causing your hand to glow until a bolt of light fires from your hand with the last word.
You fire a bolt into your target's face with a successful ranged touch attack that blinds them for 1d4+1 rounds.
This spell has no effect on creatures without eyes or creatures that don't depend on eyes for vision.
The spell appears as Araseis' spellbook, a moment of surprise before, "A gift!" It is whispers reverently as she scans the new spell.
Alyssa leaves her to the new spell for now.
With that done, you next...
Next move since you're knocking things out right now?
This one: Another Prime, a great college of researchers all work together towards a symbol of great magic, as so many strive to cross beyond the ninth circle.
Cool, what are you going to do with that?
