Fairy waltz
You manage to resist that song as you move, advancing forward as...
Continue.
So currently, it's super spooky darkness, but we can see the mess behind us, so in theory we can move away from it which is back the way we came, right?
Question to add to that: Bluff has an epic use where I can bluff alignment. Can I do something similar and bluff myself as a Sharran? Moore has an idea that this darkness is only affecting them because they aren't Sharrans. :)
It's the sort of thing that I might allow, but you have no idea on the DC and if you could do it trying out of the blue. Feel free to try if you want to gamble, though.
He may as well try. I assume it'll eat his standard action?
Either way, Take 10 on Bluff for 133. He doesn't have to make Shar believe him, just reality!
So to be clear: He is attempting to bluff reality into believing he is a Sharran.
What's your base alignment?
Neutral Good. Technically as part of this I'd also be bluffing to be evil since there's... you know, probably no neutral Sharran, but I did not specify that so I'll take the hit on it not working if needed.
Nothing seems to change, at least to your eyes. It does feel warmer, however - you don't feel so overwhelmed by Shar's presence. Your mind is clearer.
Assuming that was his Standard, that's it for Moore's turn. If it wasn't then he'd move again in the same direction.
Okay, Kaja time then. Go.
He's not got anything meaningful to do, so he will follow whatever Sylvie does.
> roll 1d20+140 (+5 ???)
<Kobot> Kotono rolled 1d20+140 (+5 ???) --> [ 1d20=12 ]{152}
Hits.
> roll 6d6+120+3d6
<Kobot> Kotono rolled 6d6+120+3d6 --> [ 6d6=20 3d6=10 ]{150}
Temp HP eats it.
Sylvie hurries along, a blade at her side to slice as she reaches Moore and past him, hurrying along as fast as she can.
Full move. Kaja?
He's also going to use his move action to Inspire Excellence - everyone gets +16 competence bonus to Constitution. If we're going to fight, we're going to fight. Of course, now I have to do math, so let me see...
+16 competence to Constitution ends up being a +8 modifier to everyone's total Constitution, so that's... I believe everyone gains 288 Hit points, does that sound right?
So 14d10 for the first part, which was rolled. Kaja's Consitution is at +10 normally, adding +16 to his score brings it up to a +18 bonus. 14 hit dice x 18 con bonus =  252, plus the 14d10s gives us 355.
Buffs currently:
+22 morale bonus on attack and weapon damage rolls
+18 to Dodge AC, +18 Morale bonus to Saves
+6 to attack and damage rolls, Improved Critical Feat, +18 to threat confirmation rolls
They also gain +14 Attack rolls and +7 competence to fort saves.
Total Buffs:
+45 to attack rolls
+28 to damage rolls
+Improved Critical Feat
+18 to threat confirms for crits
Immune to any spell or effect that would inflict negative emotions, such as fear or the effects of symbol of hopelessness. Also immune to fear.
Fast healing 11, and gain damage reduction 11/-.
+16 Charisma.
Kaja
HP: 590(433)/877(581)+355(375 Shar damage, noting separately)
Aura: Divine 10ft (various)
Resources: Breath Weapon 1/1 Dervish Dance 13/13 Endless Cuts 3/3 +5 One Attack On FA 1/1 (rnd) Take 10 On One Attack (rnd) 1/1 Retribution Domain 1/1 Wrath Domain 1/1
Spells Used:
SLAs Used:
Spells Active:
Notes: Goes in and wrecks things. The end.
Sylvie
HP: 1008(701)+205/1145(849)
Resources: Inspiration 13/30 (enc) Opportunistic Piety 17/17 Mimic Class Feature 1/9 Mentalism Domain 1/1
Spells Used: AD: Time Stop, Wish
SLAs Used:
Spells Active: Bibliotheca Arcana (CL37), Lore of the Gods (CL37), Superior Mighty Wallop (CL36), Sylvie's Mental Peak (CL36)
Notes:
He will follow suit and double / full move.
Anything to prevent an AoO?
<Kobot> Kotono rolled 1d20+140 (+5 ???) --> [ 1d20=19 ]{159}
> roll 1d20+140 (+5 ???) crit?
<Kobot> Kotono rolled 1d20+140 (+5 ???) crit? --> [ 1d20=8 ]{148}
If not, AC?
Gonna be honest, he probably has some feat that does prevent it but I really don't know what it's called.
If he really doesn't then he could try a tumble I guess? Sorry, this is one of those times where I don't know the name of these things are!
He has mobility for +4 AC vs AoOs. Probably not a difference maker here.
Acrobatics check to avoid AoOs then. Bear in mind it's against Shar so he may fail the check anyway.
