Explore Everything 12
Started by Corwin, January 02, 2025, 11:22:09 AM
19:32 — Skaya decides to check where the passage back leads now.
19:37 <•Kotono> Skaya heads out. It's a mountainside, just like last time. However, looking up, she can see the mountaintop is a yellow flame with hints of white.
19:38 <Skaya> Fuck. She heads back in, intending to take the other path and find either the orange fire where she left her friends or the blue fire that she seeks.
19:45 <•Kotono> Skaya goes back to the path. The heat coming from it is fearsome - she can feel it through her ward. Not greatly, but it's not nothing, either.
19:46 <Skaya> What can she do but proceed? Except this time, she won't bother with making the path easier to return from. Nothing short of a sheer cliff over 10ft in height will deter her!
19:48 <•Kotono> roll 3#2d6 fire damage each round going down, might get a few point sof damage through if it rolls 11 or 12.
19:48 <Kobot> Kotono rolled 3#2d6 fire damage each round going down, might get a few point sof damage through if it rolls 11 or 12. --> [ 2d6=5 ]{5}, [ 2d6=7 ]{7}, [ 2d6=7 ]{7}
19:50 <•Kotono> Skaya's protection holds when she reaches the bottom. A ripple. Back the way you came again, this time the heat coming from below painful even from here, making Skaya reflexively scurry back. Behind her is another path out.
19:51 — Skaya checks where this path out leads!
19:54 <•Kotono> It leads to anothe rmountainside. This time, the flame above is a brillant blue. You can feel the heat from it even from here, radiant and nigh overwhelming. You also see the base of the mountain is manned. From up here you can see dozens of massive fire elementals, each made of blue fire, standing guard around the mountain. None look your way at least, all guarding outward rather than inward.
19:56 <Skaya> OOC: How large is the flame? Is it effectively a single square, or large enough that one can move within, even if it's a few feet?
19:56 <•Kotono> OOC: Large enough to move in. It's pretty big, quite a few squares big.
19:57 <Skaya> Well then. Wasn't there some legend about someone streaking into a holy flame on Fire and disappearing? At least Skaya won't be alone if this fails.
19:57 <Skaya> OOC: How far is the fire from me?
20:06 <•Kotono> OOC: It's a good ways up, it'll take some climbing. You'd estimate a few minutes of climbing.
20:07 — Skaya starts climbing, trying to be stealthy about it. Her skills should cover for her, since the elementals are looking outwards and she's already past their protective ring.
20:08 <•Kotono> OOC: Stealth check and climb check.
20:08 <Skaya> roll 1d20+16 stealth
20:08 <Kobot> Skaya rolled 1d20+16 stealth --> [ 1d20=20 ]{36}
20:08 <Skaya> OOC: Taking 10 for Climb 23
20:10 <•Kotono> Slow, careful climbing. You make it up without incident, incredibly quiet and sufficiently nimble. Perhaps fortune was on your side, but you can feel the heat of this blue flame. It's hardt o look at this close to it and it's painfully hot, like standing in front of an overheated oven.
20:12 <Skaya> Well then. Skaya swiftly changes clothes and puts everything away in her haversack. The belt is the last to go, but she triggers it before dropping it with the haversack and diving into the blue flames! Presip's Life Walk works by healing you as you move, and the fire has the space for that!
20:13 <Skaya> OOC: So the idea is to use the swift action and then double move within the blue fire for 80ft.
20:14 <•Kotono> OOC: Is she wearing anything at all or some throwaway clothes or...?
20:14 <Skaya> OOC: The male clothes from the night
20:15 <•Kotono> OOC: Okay.
20:16 <•Kotono> Skaya goes to step in - but she's knocked back, as if by a physical force. In the blue fire a pair of blazing eyes form. They regard Skaya neutrally, but then in her mind. 'Who are you, to enter this most special flame? Are you the one who dared with the lesser fires?'
20:18 <Skaya> ' My name is Skaya,' she responds in her mind. 'I was told this was the most special fire, and I decided to challenge myself with it and reforge myself. I didn't bother with the lesser fires and went straight here.'
20:20 <•Kotono> 'A bold strategy.' A heat blossoms in her mind as the voice laughs, 'Foolish, but beautifully bold. Bold as the fires that burn all away. What makes you worthy of this fire?'
20:22 <Skaya> 'Of course I'm worthy! I made my way here, didn't I? Aside from that, isn't the best test the actual fire? Nothing I say here can compare to showing it with my actions!'
20:24 <•Kotono> 'Then I have little more to say, save for this: This fire will change you, profoundly, and is a deep investment. You will be of Fire after this. You may enter if you wish and believe you will not perish, though I doubt that.' Then the voice is silent.
20:26 — Skaya steps inside!
20:27 <•Kotono> Skaya steps inside and...! OOC: Fort save.
20:27 <Skaya> roll 1d20+6+6
20:27 <Kobot> Skaya rolled 1d20+6+6 --> [ 1d20=3 ]{15}
20:28 <•Kotono> roll 15d6 this may have been a bad choice full damage fire
20:28 <Kobot> Kotono rolled 15d6 this may have been a bad choice full damage fire --> [ 15d6=55 ]{55}
20:29 Skaya set the topic: Skaya: 11/42 Devar 57/57 (-2 str (in 10hr), melee attacks -4) Anne 60/60 Sanda 39/39 Rina 57/57
20:31 <•Kotono> Skaya is BURNING ALIVE. The agony blows anything else away, a mindless sor tof pain that's overwhelming her by the second. She's burning up! There's a flicker of warmth, but the whole burning alive part is rather taking precedence. The whole blackening skin, agony and then strange numbness, all the signs of massive third degree burns all over.
20:36 <Skaya> This was a terrible idea! Having survived, Skaya rushes out of the fire and rolls over the ground to prevent any lingering flames from remaining on her body.
20:37 Skaya set the topic: Skaya: 41/42 Devar 57/57 (-2 str (in 10hr), melee attacks -4) Anne 60/60 Sanda 39/39 Rina 57/57
20:37 Skaya set the topic: Skaya: 25/42 Devar 57/57 (-2 str (in 10hr), melee attacks -4) Anne 60/60 Sanda 39/39 Rina 57/57
20:38 <•Kotono> Rolling around and healing helps. Aborting, Skaya feels healing come to soothe the worst of the pain, even as...OOC: REfresh me, did you have boosts reversed by Ice?
20:38 <Kobot> Kotono rolled around and healing helps. Aborting, Skaya feels healing come to soothe the worst of the pain, even as...OOC: REfresh me, did you have boosts reversed by Ice? --> error: malformed expression
20:38 <•Kotono> OOC: Oh Kobot.
20:38 <Skaya> OOC: No
20:38 <•Kotono> OOC: Okay, carry on then.
20:39 <•Kotono> As you roll the voice is active once more. 'As I thought. Do you require mercy, creature of flesh?'
20:40 — Skaya doesn't stop moving to make the best use of the healing power of the belt. After making a circle around the blue fire, Skaya picks up a towel and wipes off the sooth and dead skin cells, sighing dejectedly. 'I really thought I was meant for this. I overcame a lot of things! Really improbable, scary ones!'
20:41 Skaya set the topic: Skaya: 39/42 Devar 57/57 (-2 str (in 10hr), melee attacks -4) Anne 60/60 Sanda 39/39 Rina 57/57
20:43 <•Kotono> 'I remember...' It murmurs, voice sounding strangely dreamlike. 'I remember Starre here, screaming as she burned to death. I remember Anne here, screaming as she burned to death. I remember Rina, who...who...' A strange trail-off. 'How strange, to remember what was not and was at the same time.'
20:45 <Skaya> 'It's because this place is broken with reflections of reality,' Skaya responds, dressing herself up in another spare male outfit. 'Another Starre told us this fire was special, and I suppose at least I didn't die like the rest of them? Since you mentioned mercy, can you tell me what I did wrong and how can I do better?'
20:50 <•Kotono> 'Broken. The nightmares.' It reflects, 'The one I remember succeeding is Rina. She was tempered and then cooled, and no strings are on her.' The voice is thoughtful. 'The others are more indistinct. Sanda, Milla, Devar, Regis and man I can't remember the name of.'
20:51 <Skaya> 'So I should bring Rina back here with me?'
20:55 <•Kotono> 'It may be so,' It answers. Silence, but just before you can do anything else. 'The blood of chaos is in your veins?'
20:56 <Skaya> 'I'm actually proud of it! Is that a problem?'
21:01 <•Kotono> 'No. More that...' The voice is strangely silent. A long silence before, 'I don't entirely remember, but I remember that -' A curious stop again. 'There's something in the mountain, if any of you are strong enough. Something of your blood.'
21:02 <Skaya> 'Literally here?' Skaya asks. 'Requiring us to dig? Or in one of the iterations of this place, where there's chaos instead of a fire with a different color?'
21:04 <•Kotono> 'This mountain,' Is the clarification, 'But I do not see in the mountain, and the memory is hazy.'
21:06 <Skaya> 'Okay! First, I need to get back to my friends and bring Rina over. I left them by the orange fire, but the paths kept shifting and the way back disappeared. Do you know how I can return without relying on luck?' Skaya puts her gear on, in the meantime, ready to head off.
21:08 <•Kotono> In answer, a human sized hand of blue fire erupts out of the blue flame, reaching out towards you.
21:08 <Skaya> It would be silly to resist at this point so Skaya just waits patiently.
21:11 <•Kotono> You're grabbed, and with a wind up, hurled. AAAAAAAAAAAA- OOC: More, #evil.
21:11 <•Kotono> The conversation is interrupted as suddenly Skaya slams down from above, right in between all of you. She seems unhurt if facedown.
21:12 <•Kotono> "AH!" Sanda yelps, stumbling back and staff out.
21:12 <Devar> "I considered taking a vow of poverty." Devar says. "But  it was---" Devar jumps back at the sudden Skaya.
21:12 <Skaya> "So maybe he was a little offended," Skaya mutters, climbing to her feet.
21:12 <•Kotono> "SKAYA!" Anne races over, "Are you injured?"
21:12 <Devar> "W...welcome back?" He offers, going to help Skaya up.
21:13 <Skaya> "Right. So. First the highlights! The passages disappear and get replaced, so I couldn't get back. I found the blue fire. It talked to me telling me I wasn't worthy. I went in anyway. It turns out fire knows its stuff. It did say Rina is possibly worthy, and also there's something chaotic on this very mountain that if we're strong enough would be great to find."
21:13 <Skaya> Then Skaya reports on her adventures in more detail.
21:15 <Devar> "'Tempered and cooled,' huh?" Devar says. "I guess Rina and I would fit that... but I'm not sure we want to get turned into Fire, I feel like that would cause some real issues with our icy friend... but it might be worth it to try anyway."
21:16 <Skaya> "We can seek out the chaos thing anyway, Devar. Ah, but I do want to try being special once again with the power of friendship and arcane magic. Are we still doing this?":
21:17 <Devar> "It doesn't sound like what you found was lying." Devar agrees. "I'm all for going in, especially since we know if we stick together we'll be okay."
21:18 <Skaya> "It was also a horrible pain and I wish I had something to show for it. I'm okay with trying again!"
21:18 <•Kotono> Rina's quiet, before, "I have nothing to lose and I need to be stronger," she declares, "I'd accept it if offered."
21:19 <Devar> "Oh, since you were in there, do we need to be protected against fire?" He asks.
21:20 <Skaya> "If you don't have protection you'll be toasty. It's better to use it than just heal afterwards. Who likes pain, right? Ah, but you should be fairly okay, especially if you don't intend to jump in. I figure if Anne supports us with ranged healing as we dive into the fire you'll be okay!"
21:21 <Devar> "I mostly just meant on the trip inside the mountain." Devar says. "If anyone enters the fire, we can heal them."
21:21 <Devar> "As much as I'd like to try it myself, I don't think this one's meant for me." He adds.
21:22 <Skaya> "I get you. I think you will be mostly fine but everyone else really wants fire resistance."
21:23 — Devar nods.
21:24 <•Kotono> OOC: Okay, so plans?
21:24 <Skaya> OOC: Everyone but me and Devar gets fire res 10 if possible. I lead us into the cavern, checking out when we reach the blue fire. Then I bring us to the blue fire!
21:25 <Skaya> OOC: Skaya can help people descend safely if it looks dangerous.
21:26 <•Kotono> OOC: Only one more resist energy to go around. Anne has those Bear's Endurance spells in her 2nd level slots. She does have two Protections from Energy, though.
21:27 <Skaya> OOC: Let's use resist energy on Rina and save the prot from energy for now. It was only 3 rounds, we can get past that with healing.
21:27 <Skaya> OOC: Specifically, let's bug Devar to provide some turning if we accumulate damage
21:28 <Devar> OOC: Can do
21:34 <•Kotono> The party heads down to the first path down. As you go...OOC: What order are you going and any prep?
21:35 <Skaya> OOC: I'm first, I'll try to catch anyone slipping and generally help out by showing any footholds.
21:36 <•Kotono> OOC: Okay, and order for the rest?
21:37 <Skaya> OOC: Skaya, Anne, Rina, Sanda, Devar
21:42 <•Kotono> roll 1d20+10 Anne acrobatics
21:42 <Kobot> Kotono rolled 1d20+10 Anne acrobatics --> [ 1d20=19 ]{29}
21:43 <•Kotono> roll 1d20+13 Rina
21:43 <Kobot> Kotono rolled 1d20+13 Rina --> [ 1d20=10 ]{23}
21:43 <•Kotono> roll 1d20+5 Sanda, grateful for her boots giving her something here
21:43 <Kobot> Kotono rolled 1d20+5 Sanda, grateful for her boots giving her something here --> [ 1d20=20 ]{25}
21:43 <•Kotono> OOC: Acrobatics, Devar.
21:44 <Devar> OOC: Can I fly down instead? :)
21:44 <•Kotono> OOC: It's extremely narrow, winged flight isn't gonna work in such confines.
21:44 <Devar> roll 1d20+3 maybe one day I'll take acrobatics
21:44 <Kobot> Devar rolled 1d20+3 maybe one day I'll take acrobatics --> [ 1d20=7 ]{10}
21:45 <•Kotono> roll 2d6 fire damage all more
21:45 <Kobot> Kotono rolled 2d6 fire damage all more --> [ 2d6=8 ]{8}
21:46 <•Kotono> It's slow, difficult going - and it's baking all of you alive. WEll, those of you who aren't Skaya and Rina. Anne grimaces in pain, Sanda in a similar state. AS they go Devar stumbles, trying to right himself as...OOC: Acrobatics, +5 bonus. At least the narrow walls help with this part.
21:46 <Devar> roll 1d20+3+5 maybe one day I'll take acrobatics
21:46 <Kobot> Devar rolled 1d20+3+5 maybe one day I'll take acrobatics --> [ 1d20=4 ]{12}
21:46 <•Kotono> roll 1d20 Sanda (-5 momentum)
21:46 <Kobot> Kotono rolled 1d20 Sanda (-5 momentum) --> [ 1d20=1 ]{1}
21:47 <•Kotono> roll 1d20+3 Rina (-10 momentum)
21:47 <Kobot> Kotono rolled 1d20+3 Rina (-10 momentum) --> [ 1d20=5 ]{8}
21:47 <•Kotono> roll 1d20-5 Anne (-15 momentum)
21:47 <Kobot> Kotono rolled 1d20-5 Anne (-15 momentum) --> [ 1d20=18 ]{13}
21:47 — Skaya helps keep Anne stable!
21:47 <•Kotono> OOC: Acrobatics check, Skaya, -20 penalty. Goooood luck. 20 would help a lot.
21:47 <Skaya> roll 1d20-4
21:47 <Kobot> Skaya rolled 1d20-4 --> [ 1d20=6 ]{2}
21:48 <•Kotono> Gah! It's Devar who slips and manages to start a painful, scraping tumble. Sanda screams as she's bowled over, and in turn Rina is. Anne tries to brace with Skaya, but it's too much and everyone is tumbling and burning in a horrible mess. OOC: More.
21:49 <•Kotono> roll 4d6 damage first of all, not fire damage, all.
21:49 <Kobot> Kotono rolled 4d6 damage first of all, not fire damage, all. --> [ 4d6=12 ]{12}
21:49 <•Kotono> roll 2d6 fire damage all
21:49 <Kobot> Kotono rolled 2d6 fire damage all --> [ 2d6=10 ]{10}
21:50 <•Kotono> OOC: REf aves all.
21:50 <Devar> roll 1d20+11
21:50 <Kobot> Devar rolled 1d20+11 --> [ 1d20=1 ]{12}
21:50 <•Kotono> roll 1d20+5 Sanda
21:50 <Kobot> Kotono rolled 1d20+5 Sanda --> [ 1d20=9 ]{14}
21:50 <Skaya> roll 1d20+3
21:50 <Kobot> Skaya rolled 1d20+3 --> [ 1d20=17 ]{20}
21:50 <•Kotono> roll 1d20+6 Anne
21:50 <Kobot> Kotono rolled 1d20+6 Anne --> [ 1d20=16 ]{22}
21:50 <Skaya> OOC: That was +6+6 and evasion, so 29
21:50 <•Kotono> roll 1d20+9 Rina
21:50 <Kobot> Kotono rolled 1d20+9 Rina --> [ 1d20=14 ]{23}
21:52 <•Kotono> Somehow you're all at the bottom and then at the first repetition in a horrible heap. Hurt, dazed. What's worse? Devar can feel agony from his leg, a crack and a break and something horrid. Sanda's screaming as well as all of you are a complete mess, but at least alive despite that mishap.
21:52 <Skaya> "Dammit!" Skaya complains, extricating herself from this mess. As she keeps on saying, she's the strongest in this group! Then, she gets around to helping those who can still stand up. Devar and Anne will heal them, she's certain of it.
21:53 <•Kotono> Sanda first - and her arm is visibly bent in the wrong direction, more screams from her. Loud, echoing in the hot caverns. Anne manages to crawl aside, coughing and groaning. Devar's below that - his leg with a visible, compound fracture, bone poking out. "J-jetina..." Anne manages.
21:53 <•Kotono> roll 3d6
21:53 <Kobot> Kotono rolled 3d6 --> [ 3d6=8 ]{8}
21:53 <•Kotono> OOC: 12 healing.
21:54 <Devar> "Augh - sorry, give me just a second and I'll do what I can." Devar mutters as he tries to add to what Anne is doing by healing everyone else as well!
21:54 <Devar> roll 1d6 healing
21:54 <Kobot> Devar rolled 1d6 healing --> [ 1d6=5 ]{5}
21:54 <•Kotono> Healing comes. Arm sets and screams stop, and Devar's leg likewise mends a good way, no longer a compound fracture. Thankfully. It's still unpleasantly hot here, though, but you're alive.
21:55 <Skaya> "Hang on a moment," Skaya tells the others before ducking out to see where they are, fire color-wise.
21:56 <•Kotono> Rina rolls aside, against the wall as best she can as people detangle. "You're in front next time, Devar," she groans aloud.
21:56 <Devar> "Or I'll just go way after the rest of you." He says. "Next time I'll just go into the ground. I've still got plenty of healing, so once we're either out of here or going forward I'll use it."
21:57 <•Kotono> Skaya wiggles around and manages to get out. It's the blue one she nearly died in.
21:58 — Skaya returns and waves everyone over. "So long as the elementals didn't hear us coming, we've arrived to the blue fire. Let's go!"
22:03 <Devar> Devar will go first to follow!
22:05 <•Kotono> The party heads up to the blue flame...and the same climbing problem is still there. How are you all going to get up?
22:05 <Devar> *This* time Devar can surely fly! ...He does try to, at least, and hopes this isn't like the acid mountain.
22:06 <•Kotono> roll 1d8+5 Anne heals herself meanwhile converts divine favor
22:06 <Kobot> Kotono rolled 1d8+5 Anne heals herself meanwhile converts divine favor --> [ 1d8=1 ]{6}
22:06 — Skaya will climb, she's done it before. Since Devar is flying, he can bring the others over.
22:06 <•Kotono> Nothing like that, flight is fine.
22:06 <Devar> "I can patch everyone else up." He says while carrying people up. "I'll do it after whatever Rina goes through."
22:08 <•Kotono> OOC: Okay then. Climb and stealth for Skaya real quick.
22:08 <Skaya> OOC: Climb 10 for 23, Stealth 10 for 26
22:10 <•Kotono> LIke this the party reaches the blue flame intact and together. It awaits as...OOC: Go ahead.
22:12 <Devar> "I have to touch you to heal you, so make sure you're close enough." Devar says. "At least, for the big stuff."
22:12 <Skaya> 'I brought Rina!' Skaya thinks really hard at the fire, waving at it for good measure. 'She wants to try this, and I want to try it again. Is it fine?'
22:14 <•Kotono> An answer comes...next time! After Christmas! Merry Christmas, everyone!
19:11 <•Kotono> Rina steps forward, "I'm willing to."
19:13 <•Kotono> In response the fires roar, nob arrier for Rina to progress on. Anne merely gets ready, holy symbol in hand.
19:14 <Devar> "You can do it." Devar says supportively. "We're here to help."
19:15 <•Kotono> A long breath from Rina, "Be ready in case it goes wrong," she half says, half asks.
19:16 — Skaya casts a spell and joins Rina, leaving her things with Devar for safekeeping.
19:16 <Skaya> roll 1d10+5 false life
19:16 <Kobot> Skaya rolled 1d10+5 false life --> [ 1d10=8 ]{13}
19:21 <•Kotono> Rina nods to Skaya, "Are you going to..." she looks into the fire.
19:21 <Skaya> "I'm challenging it again. Because I asked for permission and got it."
19:25 <•Kotono> Somehow Anne doesn't sigh. Meanwhile Rina just nods back to Skaya, "Good luck," she offers.
19:26 <Skaya> "You actually succeed in some alternate timelines. So good luck!"
19:31 <•Kotono> With this, Rina steps in and Skaya...OOC: Going in with her?
19:32 — Skaya steps in, hopeful in the magical power of friendship! And protective magic!
19:35 <•Kotono> Thus Skaya steps into the fires again and immediately begins to burn, burn horribly that...OOC: Fort save.
19:35 <Skaya> roll 1d20+6+6
19:35 <Kobot> Skaya rolled 1d20+6+6 --> [ 1d20=11 ]{23}
19:41 <•Kotono> roll 1d20+15 (+4 ???)
19:41 <Kobot> Kotono rolled 1d20+15 (+4 ???) --> [ 1d20=17 ]{32}
19:41 <•Kotono> roll 15d6 fire damage full Skaya half Rina
19:41 <Kobot> Kotono rolled 15d6 fire damage full Skaya half Rina --> [ 15d6=37 ]{37}
19:42 <Skaya> OOC: It's temp hp > fire protection > fire resistance, iirc
19:43 <•Kotono> OOC: I believe so.
19:43 — Skaya is kept unburnt by virtue of her magical protections! But it does look grim!
19:43 <•Kotono> Burning - burning horribly, burning alive once more. Rina screams but somehow endures, the fires not stopping for either of you, as Sanda watches on grimly, Anne tense and ready. OOC: Fort round 2.
19:44 <Skaya> roll 1d20+6+6
19:44 <Kobot> Skaya rolled 1d20+6+6 --> [ 1d20=18 ]{30}
19:44 <•Kotono> roll 1d20+15 (+4 ???)
19:44 <Kobot> Kotono rolled 1d20+15 (+4 ???) --> [ 1d20=15 ]{30}
19:44 <•Kotono> roll 15d6 fire damage half both
19:44 <Kobot> Kotono rolled 15d6 fire damage half both --> [ 15d6=61 ]{61}
19:45 <Skaya> OOC: May I act?
19:45 <•Kotono> OOC: Sure.
19:46 <Devar> Devar is nearby - stepping nearby to help Rina since she looks like she's gotten it much worse off, things seemed to be going so well, too! OOC: Devar will Lay on Hands Rina for 35, if he has to take some fire damage for putting his hand in to touch her that is okay.
19:47 <Skaya> As all but one of her magical protections fizzle out, Skaya reaches out towards Rina and channels positive energy into her breaking body. Really, Anne should've been supporting from a distance, but maybe it's Skaya's fault for not instructing her to before. But Skaya is the only one actually in the fire so she can do her best to ensure Rina gains the approval of the blue fire's  spirit!
19:47 <Skaya> OOC: +16hp channel
19:52 <•Kotono> Devar beats Anne to the punch - and reaches in, only to be burned along with them, the flames assailing him as well. They reach a sudden, near overwhelming roar as Skaya begins to feel something move in her. OOC: For all three of you.
19:52 <•Kotono> roll 1d20+15 (+4 ???)
19:52 <Kobot> Kotono rolled 1d20+15 (+4 ???) --> [ 1d20=1 ]{16}
19:52 <Skaya> roll 1d20+6+6
19:52 <Kobot> Skaya rolled 1d20+6+6 --> [ 1d20=5 ]{17}
19:53 <Devar> OOC: I was just sticking my hand in! But so noted
19:53 <Devar> roll 1d20+16 hopefully I take less!!
19:53 <Kobot> Devar rolled 1d20+16 hopefully I take less!! --> [ 1d20=14 ]{30}
19:53 — Skaya heals herself this time, since she'd seen Anne moving. Surely she doesn't need to jump into the flames like Devar! It'll be enough to heal them from afar! Probably!
19:53 <Skaya> OOC: +16hp to me
19:54 <•Kotono> OOC: Doesn't apply until after the damage, you already spent your action this round healing Rina.
19:54 <Skaya> OOC: That's fine
19:54 <•Kotono> roll 16d6+5  Skaya and Rina full, Devar half Anne is free to heal and will after this roll, however
19:54 <Kobot> Kotono rolled 16d6+5 Skaya and Rina full, Devar half Anne is free to heal and will after this roll, however --> [ 16d6=49 ]{54}
19:55 <•Kotono> roll 3d6
19:55 <Kobot> Kotono rolled 3d6 --> [ 3d6=11 ]{11}
19:55 <•Kotono> OOC: 16 healing all. Go ahead and adjust Rina's as well this time Skaya, since there's multiple hands in the pot.
19:57 <Skaya> OOC: Done. I have fire res 10. Actually, does Rina have any fire res?
19:59 <•Kotono> OOC: No.
19:59 <•Kotono> The flame burst sends Skaya and Rina out of the flames. Burning, crackling - but alive. Lying there and feeling different, even as Anne heals again.
19:59 <•Kotono> roll 3d6 healing all three
19:59 <Kobot> Kotono rolled 3d6 healing all three --> [ 3d6=7 ]{7}
19:59 <•Kotono> OOC: 10 total.
20:01 <Skaya> "It... worked..." Skaya gasps, grabbing for the spare blanket she'd prepared ahead of time. It is a feeling impossible to describe, of being healed by magic but feeling phantom and psychological pain from being burnt alive repeatedly.
20:01 <Devar> Devar for his part adds in some of his own channeling a few times - three, in fact!
20:01 <Devar> roll 3d6 healing
20:01 <Kobot> Devar rolled 3d6 healing --> [ 3d6=8 ]{8}
20:03 <Devar> He shakes his arm where it was burnt just a moment or two ago. "Yeah, I promise, it didn't feel too great when I did it either and I wasn't going to try and repeat the process." He says. "Just touching it to help out hurt quite enough."
20:10 <•Kotono> Healing comes as Skaya feels strange still, like she's burning alive on the inside. Rina shudders all over, on her hands and knees. "U-ugh..." she coughs up flame repeatedly, "So hot...."
20:10 <•Kotono> With a concerned look, "Um, did you swallow any of that fire?"
20:11 <Skaya> "It's just... the fire nature... transformation..." Skaya stammers, trying not to fight the strangeness. It should pass eventually, right?
20:12 <Devar> "Oh, wow, were you two made part fire or something?" Devar asks. "I've still got more healing if need be."
20:14 <•Kotono> The answer is for...OOC: Fort saves you two.
20:15 <Skaya> roll 1d20+6+6
20:15 <Kobot> Skaya rolled 1d20+6+6 --> [ 1d20=10 ]{22}
20:15 <•Kotono> roll 1d20+15 (+4 ???)
20:15 <Kobot> Kotono rolled 1d20+15 (+4 ???) --> [ 1d20=18 ]{33}
20:21 <•Kotono> Fire erupts out of Skaya and Rina's mouths. Skaya's knocked over and convulses, while Rina manages to stay up. The flame slowly tempers down into steam, which trails away entirely. Slowly and carefully, but it trails down.
20:23 <Devar> "Woah, are you both all right!? That didn't... look fun..." Devar says, staying nearby in case they need anything.
20:23 — Skaya clutches the blanket as her hands spasm, trying to devote all her dwindling attention to not biting her tongue off.
20:25 <•Kotono> IT slows at last as...OOC: Cor, did you get any of the original fire bonuses?
20:26 <Skaya> OOC: No, this is the first time I jumped into fire productively
20:26 <•Kotono> OCO: PM in amoment.
20:29 <•Kotono> Rina coughs and coughs, but lies there, "Oh...this is way more than...is this how you felt, DevaR?"
20:31 <Devar> "Well mine didn't involve puking up any fire, so... probably not." Devar says with a smile. "But if I were to take a guess, based on the intensity, it's probably slightly stronger than what I got out of the other one. You both feel okay now?"
20:34 <Skaya> "I'm made of fire," Skaya croaks. "Fifteen to twenty percent is fire."
20:34 <Devar> "Well, that sounds handy... I think?" Devar offers.
20:34 <•Kotono> "At least," Rina groans out, her body scorched and burnt even now. "Feel s-stronger."
20:35 <•Kotono> Anne shakes her head, "You're alive, better than anyone should be for walking into fire."
20:35 <Skaya> "Wow! I understand! That spell Sanda used to burn things with her hands, it was engraved on my palms from the inside!"
20:36 <Devar> "Oh, yeah, I had one of those too, it got turned into a cold spell when that elemental touched me." Devar says, then frowns. "...That thing might have a problem with you two now, actually. But we can worry about that later."
20:38 <Skaya> Now that she can move, Skaya doesn't give in to the manic appreciation of fire that she wants to, and instead takes her stuff back and dresses in yet another spare male outfit. She only has one of her own useful for adventuring and it'd be left safe until she really needs it!
20:39 <Devar> "Oh, didn't you mention there was... something in here?" Devar asks, gesturing at the blue fire.
20:39 <•Kotono> Rina nabs one herself and changes, "Same here, and I feel stronger. Better."
20:40 <Skaya> "The spirit of fire? Of course it's still here. It's been here all along."
20:42 <Devar> "Like the ice elemental?" Devar asks. He goes up - near, but not into - the blue fire. "Hello? You still in there?"
20:47 <•Kotono> A ripple of fire, 'So I remembered right. Rina did not burn to death.'
20:49 <Skaya> "I survived this time, too! With the power of friendship!"
20:49 <Devar> "Couldn't you just... condense this fire into some more easily absorbed substance so we don't have to try and burn ourselves at all?" Devar asks. "And wait, what do you mean by remembered? Are you aware of the different 'versions'?"
20:55 <•Kotono> 'I remember strange things that didn't happen,' Is the answer, 'And so you did, another memory to hold.'
20:56 <•Kotono> "I feel so much stronger thanks to this," Rina says, "Like a fire's been lit inside of me."
20:56 <Devar> "Can you tell us where we can find the 'warm waters'?" Devar asks. "Or does your knowledge only apply to this mountain?"
21:00 <•Kotono> 'I do not,' Is th esimple answer Devar gets.
21:01 <Devar> With a glance back at Skaya then to the fire. "But you know there's something else in the mountain that we can utilize?" He asks. "Is there any trick to finding it in there?"
21:02 <Skaya> "The chaotic place, right? I wish I knew how to get there, it sounds fun!"
21:06 <•Kotono> 'Survive,' Is the answer, 'Go within and survive.'
21:07 <Skaya> "Oh! Down the fiery passages? The slippery ones?"
21:09 <•Kotono> 'If you can find the way, yes,' Is confirmed, as Sanda hmms at that.
21:09 <•Kotono> "If we avoid the problem last time, of course," Sanda adds. Grimaces all around at that.
21:09 <Skaya> "I actually came up with a solution for that, but it'd only work if people don't burn easily."
21:10 <Devar> "Well, I imagine you and Rina are covered for that, so that leaves the rest of us." Devar says.
21:10 <Skaya> "You're actually fairly okay!"
21:10 <Skaya> OOC: Did someone beside me get fire res 10 earlier via magic?
21:12 <Devar> "Besides the balance thing." Devar says with a small smile.
21:12 <•Kotono> OOC: I don't believ eos.
21:12 <Skaya> "Besides the balance thing," Skaya agrees in a flat tone of voice. "Hey, are there any enemies to fight below?"
21:15 <•Kotono> 'Of course,' Is the answer, 'Did you expect otherwise?'
21:16 <•Kotono> "No, I suppose not," Anne murmurs.
21:16 <Skaya> "Can't I hope?!"
21:17 <Devar> "So I guess do we feel we have the resources to delve down there?" Devar asks.
21:18 <Skaya> "What spells do you all have available?" Skaya muses. "Aside from Anne's residual protection from energy spell, I'm not sure."
21:19 <Devar> "I've still got several energy channels, but they aren't the most potent." Devar says.
21:21 <Skaya> "What about magic? Since Anne has protection from fire and fire resistance, one each, we barely have the minimum to attempt it if those cover Sanda and Anne herself."
21:26 <Devar> "I don't have that one, but I think it's something I could swap to if we decided to take a rest before we went down there." Devar says.
19:09 <•Kotono> "I have healing but not much elemental protection," Anne explains, "So I wouldn't recommend a full party trip."
19:09 <•Kotono> Sanda hms, "Well, statistically speaking, aren't Rina and Skaya best suited for it, and maybe Devar for his wings?"
19:10 <•Kotono> "On the other hand," Rina says slowly, "That means not being by Anne. With how dangerous things are here, that might be the riskier option."
19:11 <Skaya> "Let's give it a try," Skaya proposes. "If we use the fire protection and fire resistance spells on Devar, he should be okay. And if it's just us three, I'll have an easier time preventing a nasty collision."
19:12 <•Kotono> "Alright," Anne says, "But be cautious."
19:13 <•Kotono> "We'll be alright," Rina promises, a glance at Devar. "Do you have much healing available?"
19:13 <Devar> "I'm limited on personal healing, but have a decent amount of channeling energy left. We have some potions too, so I think we're all right." He says.
19:15 <•Kotono> With a long breath, "Be careful," Anne emphasizes, but says no more. With that decided, how are you all going to do this?
19:17 <Skaya> OOC: So Devar gets Fire Res 10 and Protection from Fire 50. Then we use rope while he goes first and I go second, and Rina brings up the rear.
19:21 <•Kotono> OOC: Doable. Okay, more.
19:21 <•Kotono> The party returns to the passage down. Now the three of you are ready to go down, and...OOC: Okay, give me acrobatics each of you, and note anything you're doing to try to make this not a straight out tumble.
19:23 <Skaya> OOC: 10 for 27 for me, plus the belt of ignoring difficult terrain or fall hazards. Strength of 19, so that I could help prevent Devar from falling via rope or catch Rina if she does without too much effort (ie cumulative penalties).
19:23 <Devar> OOC: I don't think I have anything besides wings to try and help with the matter.
19:23 <Devar> roll 1d20+2
19:23 <Kobot> Devar rolled 1d20+2 --> [ 1d20=17 ]{19}
19:26 <•Kotono> OOC: Rina takes 10 for 24. More.
19:28 <•Kotono> With careful movement, rope and caution, the party descends. It's hot! Hot hot hot hot. The walls glow with a faint heat, a dull red light to illuminate all. After some careful descend, you come to a small chamber. It opens up, no longer cramped and with relatively even ground. Straight ahead is a door forged of solid steel that glows faintly in the heat. A sign sits above the door. There's
19:28 <•Kotono> passages winding further down to the sides, one each for two other passages total.
19:30 <Devar> "I really wonder what the obsession with this place about doors is." Devar says.
19:30 — Skaya checks the sign!
19:31 <•Kotono> Rina pokes the door, her flesh unburned by the heat. "Doors. Coming and going. Maybe it means something? Though it's more the ken of Sanda or Anne to figure that out."
19:31 <•Kotono> OOC: Languages?
19:31 <Skaya> OOC: Common, Elven, Dwarven, Celestial, Draconic
19:33 <•Kotono> The writing is in words Skaya does not understand...until her mind grows warm. Heat suffuses her body as the words make sense. It reads: A path to the tools of glory only opens to the most humble key.OOC: You can now speak and read Ignan, Skaya.
19:35 <Skaya> "Hey, Rina, come and glance at the sign here," Skaya tells her, curious whether this is part of becoming fire.
19:37 <•Kotono> Rina does so, "I-my head burns, but I can read it now," Rina says slowly, "The path to the tools of glory only opens to the most humble key." She licks her lips slowly, "This is Ignan?"
19:38 <Skaya> "Definitely."
19:39 <Devar> "Huh, I wonder if I can read something in... uh, whatever the ice language is." Devar says. "But what's a humble key? I mean, Kneeling in front of something is usually a sign of humility?"
19:39 <•Kotono> Then in perfect Ignan Rina repeats herself, "It's like I've spoken it every day of my life," she switches back to Common. "Can you read it, Devar? As for a humble key, I don't know, but maybe?"
19:39 — Skaya examines the door itself. Is there even a lock?
19:40 <•Kotono> No lock. IT's smooth and fitted into the doorframe with zero give or gaps.
19:40 <Devar> Devar looks up to peer at it!
19:40 <Skaya> "Isn't the key probably down one of the passages?"
19:41 <•Kotono> Devar's brain suddenly burns like liquid fire, heat erupting throughout as steam bursts out of his ears, and...
19:41 <•Kotono> roll 10d6 fire damage owwies and more, that protection from energy will help at least
19:41 <Kobot> Kotono rolled 10d6 fire damage owwies and more, that protection from energy will help at least --> [ 10d6=38 ]{38}
19:41 <•Kotono> It's like his brain being boiled, but suddenly it clicks. The same language blooms in Devar's mind, able to read the sign naturally as can be.
19:41 <•Kotono> OOC: Devar can now read and speak Ignan.
19:43 <Devar> "Gah!" Devar recoils back. "It wasn't quite as... smooth as the rest of you, but it worked, I guess."
19:45 <Skaya> "Let's go down this path?" Skaya proposes, as Devar seems fine.
19:45 <•Kotono> "So it's something in the sign itself?" Rina peers up, "Who makes a sign that cooks your mind to teach Ignan?"
19:45 <Devar> "Fire elementals." Devar says. "But yes, we won't get anywhere just standing around."
19:48 <•Kotono> OOC: Which path are you going down, then?
19:49 <Skaya> roll 1d4
19:49 <Kobot> Skaya rolled 1d4 --> [ 1d4=3 ]{3}
19:49 <Skaya> Clockwise from the door, path #3!
19:54 <•Kotono> OOC: There's two total, one left and right. Just to be clear.
19:54 <Skaya> OOC: Then left
19:55 <•Kotono> Down the party goes. It's not far until the path doesn't just slope. IT drops off, a drop of approximately 30ft to the bottom. The rock wall is nothing but smooth, slippery and sheer volcanic glass, not a handhold to be seen.
19:57 <Skaya> "Getting down is one thing, but would you be able to fly us back up, Devar?"
19:57 <Devar> OOC: Do I have room to fly as far as I can tell?
19:59 <•Kotono> Devar thinks he has room to fly back up. It's not as tight as the first passage down.
19:59 <Devar> "Yeah, as long as it isn't like the acid mountain and gets mad at me for flying." He confirms.
20:00 <Skaya> "Got it." Skaya secures her rope at the top and then kneels, telling Rina, "Climb on my back and grab hold. I'll get us down safely."
20:02 <•Kotono> Rina hops right on, "Better than trying to climb down that. Wouldn't be able to do it safely with that surface."
20:04 <Skaya> "It'd take too long to make proper footholds, and someone might slip anyway," Skaya muses, scaling the rope and then just sliding down with one hand on the smooth wall to steady the drop.
20:04 <Skaya> OOC: 10ft rope, 20ft slow fall
20:06 <Devar> Devar will just fly down after the two of them make it!
20:09 <•Kotono> Between slow fall and flight, getting down is safe enough. At the bottom you can see a larger space. Here a criss-cross of various stone walkways, crumbling and delicate, sit high above a pool of molten stone. Well below, about 100ft at least, liquified rock bubbles and belches. The various walkways make an interconnecting warren of paths to walk, and eventually leads to passage further
20:09 <•Kotono> ahead. However-! One walkway suddenly dissolves into liquid stone and falls below, while a tendril of molten lava reaches up, which quickly solidfies into a new walkway, subtly changing about the entire mess of paths.
20:10 <•Kotono> Rina takes one good, long look at all of that. Really looks, before, "Devar, you can carry us." she says, "I think only a madwoman would chance those paths."
20:11 <Devar> "
20:12 <Devar> "I'm beginning to see why this is where something chaotic might reside." Devar says.
20:12 <Skaya> "But first, check if flight works alright?"
20:12 <Devar> Devar will do just that - experimentally lifting himself up slightly where they are.
20:13 <•Kotono> Flightworks as it should.
20:14 <Devar> "It looks like there's only one path that actually goes forward?" Devar says, looking ahead. "Is that right?"
20:16 — Skaya studies the walkways to see if their disappearance is entirely random or can be predicted by lava outbursts.
20:17 <•Kotono> OOC: PErception.
20:19 <Skaya> OOC: 10 for 26
20:23 <•Kotono> There's only one passage ahead, and as far as Skaya can tell, the walkways and replacements eem random.
20:23 <Skaya> "Yeah, even I'm not crazy enough to insist on rushing that when flight is an option."
20:25 <Devar> Devar nods - he will carry Rina over first and then Skaya, in that case!
20:30 <•Kotono> Carrying people over is...
20:30 <•Kotono> roll 1d100 first
20:30 <Kobot> Kotono rolled 1d100 first --> [ 1d100=20 ]{20}
20:30 <•Kotono> roll 1d100+20 second
20:30 <Kobot> Kotono rolled 1d100+20 second --> [ 1d100=43 ]{63}
20:31 <•Kotono> Lucky. No bursts come close, and only heat gets you instead of anything worse. Whew. You all make it to the far side, safe and intact.
20:31 <Skaya> Thanking Devar, Skaya leads the way onwards!
20:31 <Devar> Devar nods and will go with them!
20:34 <•Kotono> Down another path and another. Then a more open space again. Here, carved into the stone walls, are a pair of pillars and a mouth of a great, serpentine creature of some kind. Its eyes blaze with red fire and its tongue is the carpet to the path leading further within.
20:35 <Skaya> "This seems incredibly unsafe," Skaya notes.
20:35 <Devar> "It does have that 'this is obviously a trap' look to it, doesn't it?" Devar agrees.
20:39 <•Kotono> "It's suspect," Rina agrees, hand reaching for her sword. "But this entire place is."
20:40 — Skaya decides to check for any hidden doors or traps, once more regretting that Starre is no longer traveling with them.
20:40 <Skaya> roll 1d20+16 perception
20:40 <Kobot> Skaya rolled 1d20+16 perception --> [ 1d20=5 ]{21}
20:40 <Devar> "There's nothing gained by not moving forward though, right?" Devar says as he doesn't slow his pace any, except to give Skaya time to look around.
20:41 <Skaya> "We could also take the second path," Skaya points out.
20:41 <Devar> "I have a feeling it just leads to the same place." He says. "But we can always explore it after this."
20:42 <•Kotono> Skaya doesn't see any traps or the like.
20:42 <Skaya> "Okay, let's literally step inside the mouth," Skaya agrees, doing just that. "Good thing Anne's not here."
20:43 <Devar> "There's no real avoiding the literal comparison here, is there?" Devar says as he joins her.
20:46 <•Kotono> OOC: Perception all.
20:46 <Devar> roll 1d20+8 maybe he hits a 20
20:46 <Kobot> Devar rolled 1d20+8 maybe he hits a 20 --> [ 1d20=15 ]{23}
20:46 <Skaya> roll 1d20+16 perception
20:46 <Kobot> Skaya rolled 1d20+16 perception --> [ 1d20=8 ]{24}
20:47 <•Kotono> roll 1d20+11 Rina
20:47 <Kobot> Kotono rolled 1d20+11 Rina --> [ 1d20=20 ]{31}
20:50 <•Kotono> You walk in, and as you do? Rina grabs both of you and pulls back. Just in time, because on both walls, where you just were? Secret doors slide open and spears stab out where the two of you just were. You see strange beings, one poking out of each door. Red and black scaled, its upper body humanoid and the lower body that of a serpent. Two males, each with a spear in hand and faces that
20:50 <•Kotono> are more hawk than human.
20:52 <Devar> "Woah, what kind of... things are these?" Devar stammers out. OOC: Any relevant Knowledges to identify the snake-hawk-people?
20:52 <Skaya> Nice, Rina! You've overtaken your master!
20:53 — Skaya retrieves the wand of Magic Missiles since there appear to be irreconcilable differences.
20:54 <•Kotono> OOC: K:P and then init after I resolve that.
20:54 <Skaya> roll 1d20+14 K:P
20:54 <Kobot> Skaya rolled 1d20+14 K:P --> [ 1d20=3 ]{17}
20:54 <Devar> OOC: Take 10 in K:P for 22
20:55 <•Kotono> Devar recognizes them as salamanders, natives of Fire and rather nasty creatures. He doesn't know much about them, but they're outsiders instead of elementals, so they lack an elemental's array of resistances.
20:56 <•Kotono> roll 1d20+11 init Rina
20:56 <Kobot> Kotono rolled 1d20+11 init Rina --> [ 1d20=19 ]{30}
20:56 <Kobot> Kotono rolled 1d20+1 --> [ 1d20=10 ]{11}
20:56 <Kobot> Kotono rolled 1d20+1 --> [ 1d20=15 ]{16}
20:56 <Devar> roll 1d20+2 my life for supreme initiative
20:56 <Kobot> Devar rolled 1d20+2 my life for supreme initiative --> [ 1d20=14 ]{16}
20:56 <Skaya> roll 1d20+9
20:56 <Kobot> Skaya rolled 1d20+9 --> [ 1d20=7 ]{16}
20:56 <•Kotono> Init is Rina (30) > Salamander 2 = Devar = Skaya (16) > Salamander 1 (11)
21:01 <•Kotono> Rina moves fast - she blurs ahead and slices by one of the salamanders before anyone can react, blade lashing out for a quick strike.
21:01 <•Kotono> roll 1d20+13
21:01 <Kobot> Kotono rolled 1d20+13 --> [ 1d20=2 ]{15}
21:02 <•Kotono> Which unfortunately glances off the salamander's scales, as it hisses in Ignan, "None shall reach the Great Flame!" IT whirls on Rina, slithering out enough to stab at her, spear going for her chest.  OOC: Everyone's up, doing this first as y'all ready your actions.
21:02 <•Kotono> roll 1d20+11
21:02 <Kobot> Kotono rolled 1d20+11 --> [ 1d20=17 ]{28}
21:02 <•Kotono> roll 1d8+3 ow Rina
21:02 <Kobot> Kotono rolled 1d8+3 ow Rina --> [ 1d8=6 ]{9}
21:03 <•Kotono> A stab right into Rina's middle, not deep but enough to well up blood and get her to hiss in pain. OOC: Go yo utwo.
21:03 <Devar> "Salamanders! Fire natives, but not as annoying to deal with as elementals are!" Devar shouts as he takes out Treant's Wrath - which rather helpfully does more damage to things like this, he hopes! "I'll deal with the other one!" Devar moves to engage the other salamander to keep it busy, taking a swing at it!
21:04 <Devar> roll 1d20+9 bonk
21:04 <Kobot> Devar rolled 1d20+9 bonk --> [ 1d20=2 ]{11}
21:04 <Skaya> "That works, but why not blow it up from range?" Skaya mutters to herself, following up on her original plan of magic missiles.
21:04 <Skaya> roll 2d4+2+5 on Rina's target
21:04 <Kobot> Skaya rolled 2d4+2+5 on Rina's target --> [ 2d4=5 ]{12}
21:04 <Devar> "I'll do that once we've only got one to deal with!" Devar calls out.
21:08 <•Kotono> Devar swings wide, missing. The salamander whirls on you, now a target in close as meanwhile, the first salamander gets missiles to the face. Its knocked back by it, a burst of blood from the impact, the creature's nose ruined. It slithers forward as the others are occupied, stabbing out  at Skaya, forcing her back out.
21:08 <•Kotono> roll 1d20+11
21:08 <Kobot> Kotono rolled 1d20+11 --> [ 1d20=7 ]{18}
21:08 <•Kotono> OOC: AC?
21:08 <Skaya> OOC: Higher than that.
21:09 <Devar> OOC: You should have mage armor for +4 also for the sake of the rest of the fight
21:09 <Skaya> OOC: Yes, it's 28 with it, since I already have +2 from bracers of armor
21:09 <Devar> OOC: /me thumbs up
21:11 <•Kotono> A stab that's stopped by a swift dodge, Skaya's monkly graces enough to avoid it. AT least for now, as Rina then pivots back, and with the salamander's attention off of her, darts in and out to deliver a quick stab.
21:11 <•Kotono> roll 1d20+13
21:11 <Kobot> Kotono rolled 1d20+13 --> [ 1d20=17 ]{30}
21:12 <•Kotono> roll 1d6+3+2d6
21:12 <Kobot> Kotono rolled 1d6+3+2d6 --> [ 1d6=1 2d6=5 ]{9}
21:13 <•Kotono> A slash across its back and side, not deep at all. Blood is drawn but not too much, Rina on the defensive as meanwhile...OOC: All three are up. Devar's getting FAed and I'll do that right away, while you two prepare.
21:13 <Skaya> Since the salamander came here to die, how can Skaya not oblige? And with Rina helping flank it, Skaya is confident of her chances at putting it down for good!
21:13 <•Kotono> Freshly wounded but already set, the second salamander hisses out, "Die for your impudence!" before stabbing away at Devar.
21:13 <Skaya> roll 2#1d20+8+2+4
21:13 <Kobot> Skaya rolled 2#1d20+8+2+4 --> [ 1d20=4 ]{18}, [ 1d20=15 ]{29}
21:14 <•Kotono> OOC: Two hits.
21:14 <Skaya> roll 2#1d10+4+4
21:14 <Kobot> Skaya rolled 2#1d10+4+4 --> [ 1d10=9 ]{17}, [ 1d10=4 ]{12}
21:14 <•Kotono> OOC: What do your strikes count as for DR?
21:14 <Skaya> OOC: Magic
21:15 <•Kotono> roll 1d20+11
21:15 <Kobot> Kotono rolled 1d20+11 --> [ 1d20=8 ]{19}
21:15 <•Kotono> roll 1d20+6
21:15 <Kobot> Kotono rolled 1d20+6 --> [ 1d20=1 ]{7}
21:15 <•Kotono> roll 1d20+9 tail slap
21:15 <Kobot> Kotono rolled 1d20+9 tail slap --> [ 1d20=10 ]{19}
21:15 <•Kotono> OOC: AC Devar?
21:15 <Devar> OOC: 31 against melee attacks
21:17 <Devar> Seeing an opening in his target, Devar swings again!
21:17 <Devar> roll 1d20+9 bonk
21:17 <Kobot> Devar rolled 1d20+9 bonk --> [ 1d20=5 ]{14}
21:21 <•Kotono> It's an exchange back and forth. Devar swings and is parried, but in time counters and parries back. Neither is hurt in the back and forth, as meanwhile Skaya pummels her target. Multiple blows and kicks hit it, leaving it cracked and with an arm dangling - but it's not given up yet, despite the wound, and whirls on Skaya to try and tear her apart.
21:21 <•Kotono> roll 1d20+11
21:21 <Kobot> Kotono rolled 1d20+11 --> [ 1d20=2 ]{13}
21:21 <•Kotono> roll 1d20+6
21:21 <Kobot> Kotono rolled 1d20+6 --> [ 1d20=10 ]{16}
21:22 <•Kotono> roll 1d20+9
21:22 <Kobot> Kotono rolled 1d20+9 --> [ 1d20=1 ]{10}
21:22 <Skaya> OOC: All misses
21:22 <•Kotono> Yet Skaya weaves and dodges, completely untouched by the barrage, as Rina steps back again, before darting forward to stab at the badly injured one, going for the hopeful finish.
21:22 <Skaya> "Is this bullying? This is bullying, isn't it?" Skaya mutters, half-heartedly dodging those fierce attacks.
21:22 <•Kotono> roll 1d20+13
21:22 <Kobot> Kotono rolled 1d20+13 --> [ 1d20=6 ]{19}
21:23 <•Kotono> roll 1d6+3+2d6
21:23 <Kobot> Kotono rolled 1d6+3+2d6 --> [ 1d6=1 2d6=6 ]{10}
21:23 <•Kotono> Init is Rina (30) > Salamander 2 = Devar = Skaya (16)
21:24 — Skaya moves to support Devar, now! There will be more flanking!
21:24 <•Kotono> With a stab in the back the salamander slumps back, spear dropped. It lies there and bleeds, no longer a threat. Rina smoothly pulls her sword free and calls, "Surrender!" in Ignan. OOC: Everyone's up. Go.
21:24 <Skaya> roll 1d20+9+2+4
21:24 <Kobot> Skaya rolled 1d20+9+2+4 --> [ 1d20=19 ]{34}
21:24 <Skaya> roll 1d10+4+4
21:24 <Kobot> Skaya rolled 1d10+4+4 --> [ 1d10=3 ]{11}
21:25 <Devar> "I have a feeling they can't!" Devar says, as he takes another swing - hopefully with a bit more aim this time.
21:25 <Devar> roll 1d20+9 bonk?
21:25 <Kobot> Devar rolled 1d20+9 bonk? --> [ 1d20=19 ]{28}
21:25 <•Kotono> OOC: Hit.
21:25 <Devar> roll 1d8+4 doubled if they're the Fire subtype
21:25 <Kobot> Devar rolled 1d8+4 doubled if they're the Fire subtype --> [ 1d8=1 ]{5}
21:26 <•Kotono> OOC: Doubled.
21:26 <•Kotono> roll 1d20+11 going for Devar with all three
21:26 <Kobot> Kotono rolled 1d20+11 going for Devar with all three --> [ 1d20=15 ]{26}
21:26 <•Kotono> roll 1d20+6
21:26 <Kobot> Kotono rolled 1d20+6 --> [ 1d20=1 ]{7}
21:26 <•Kotono> roll 1d20+9 tail slap
21:26 <Kobot> Kotono rolled 1d20+9 tail slap --> [ 1d20=13 ]{22}
21:26 <•Kotono> OOOC: AC still 31?
21:26 <Devar> OOC: Yessir
21:27 <•Kotono> There's no retreat, only blows exchanged. Fist and club smack it, both landing solid hits. A crack to the side and ribs broken by club, and a powerful stomp to the tail, breaking something within. Together it retorts but poorly, not a sign of retreat still. Nor of even countering with it sspear's reach, Rina going in for the kill quickly.
21:27 <•Kotono> roll 1d20+13
21:27 <Kobot> Kotono rolled 1d20+13 --> [ 1d20=20 ]{33}
21:27 <•Kotono> roll 1d20+13 crit?
21:27 <Kobot> Kotono rolled 1d20+13 crit? --> [ 1d20=13 ]{26}
21:27 <•Kotono> roll 2d6+6+2d6
21:27 <Kobot> Kotono rolled 2d6+6+2d6 --> [ 2d6=7 2d6=5 ]{18}
21:28 <•Kotono> A stab between the shoulder blades ends it, just like that. The second one slumps over, the battle finished. OOC: Free act.
21:28 <Skaya> After the battle, Skaya glances over at Rina, mentioning, "It occurs to me that Rina's not in the best shape."
21:29 <Devar> "We can use a potion or I can just spend some of my channeling." Devar offers. "I guess I didn't realize it before we left."
21:30 <Skaya> "How are your potions, Rina? Got any left?"
21:30 <•Kotono> Rina puts a hand to her stomach, "I'm out," Rina announces, "And yes, I could use some healing."
21:33 — Skaya gives Rina a cure medium wounds potion.
21:33 <Devar> "I've got plenty left if you want me to do anything, but I can save it for when you're both injured." Devar offers.
21:35 <•Kotono> roll 2d8+3
21:35 <Kobot> Kotono rolled 2d8+3 --> [ 2d8=12 ]{15}
21:35 <•Kotono> The potion is taken, the medicine healing her wounds and restoring her energy. "I'm alright now," Rina says, "Good enough."
21:36 — Devar nods.
21:37 <Skaya> "Got it. Let's go!"
21:37 <•Kotono> The way ahead is long and dimly lit with the red glow of the walls. There's two now open secret doors to possibly explore as well.
21:40 — Skaya peeks into the leftmost secret door.
21:42 <•Kotono> It opens into a wide corridor running alongsides the main passage, before turning aways from it further down.
21:42 — Skaya follows the corridor! Surely it won't be filled with traps if their own people need to travel silently through it!
21:48 <•Kotono> Skaya goes down the corridor - areyou following, DevaR?
21:48 — Devar will follow!
21:52 <•Kotono> The path goes on. When it turns, it goes into what looks to be a simple living space. A raised dais of stone, red hot. An iron bowl of burning red fruits, like large pears but the color of a camp fire. Several stone tablets piled up against a wall.
21:52 — Skaya checks for any exits out of here! Devar can grab the fruits for snacking on later.
21:53 <Skaya> roll 1d20+16 perception
21:53 <Kobot> Skaya rolled 1d20+16 perception --> [ 1d20=12 ]{28}
21:54 <Devar> "...This is kind of weird, isn't it?" Devar says as he looks around. He goes to experimentally put a hand near the fruits - do they appear to be as hot as a fire? "Some weird living space for a random salamander to pop out and go 'got you!'"
21:54 <Skaya> "I guess outsiders don't really need much."
21:55 <Devar> "I guess it's no less weird than an evil magical bandage behind a door." Devar laments.
21:56 <Skaya> "Didn't we agree that never happened? I feel that's the sort of thing we should repress."
21:57 <•Kotono> Skaya doesn't find any secret doors or anything. The fruits are quite hot, hot as fire. "Do you think those are safe to eat for us now?" Rina asks aloud.
21:58 <Skaya> "Not a chance. But we might not die? Let's save it for when we're out of this whole maze."
21:58 <Devar> "Maybe you two." Devar says. "Haversacks can't get lit on fire from the inside, can they?"
21:59 <•Kotono> "Do you want to risk it? It sounds like a terrible idea," Rina says, "They're just weird fire fruits anyway."
22:01 <Devar> "Maybe we can find something to wrap them in that isn't, itself, also on fire." Devar says. "But we might as well check the other door."
22:03 <Skaya> "Just bring the bowl. Maybe some large fire cat will show up and we can befriend it!" Skaya tells Devar, examining the tablets.
22:05 <•Kotono> Skaya goes to read them, which show her things...next time!
22:05 <Devar> Devar will dig in his sack to find some cloth to grab the bowl with - he's protected against fire but you never know and safely store the bowl (that he hopes he will remember is still hot later) with the fruits.
22:05 <Devar> Which he will do next time!!!
19:02 <•Kotono> The tablets look to be various instructions in some sort of cult. While vague, it seems to often boil down to burning anything it can alive in the name of the 'Azure-Red Flame'.
19:03 <Skaya> "Ah, a cult. Amazing," Skaya says in a deadpan voice, returning to the main path.
19:03 <•Kotono> Devar gets the bowl. It's quite warm but he gets it. How exactly are you storing it?
19:03 <•Kotono> Rina wrinkles her nose, "A cult means trouble."
19:04 <Devar> Devar will carefully get it into the Haversack, it shoudn't be too much trouble slide it in without burning himself or anything else. Devar will follow the others afterwards. "I wonder if this is related to what the elemental told you about. So far this just seems to be More Fire." He says.
19:11 <•Kotono> "So far," Rina agrees as yo ugo to the other door. IT looks identical to the previous, leading to a turn going in the opposite direction of the previous. Nothing unusal here so far.
19:13 <Skaya> OOC: Wasn't there also the main path ahead? The one that Rina saved us from getting ambushed on?
19:15 <•Kotono> OOC: There is, yes. I see, you wanted to go ont he main path, think that got mangled inb etween sessions. Strike then.
19:18 <•Kotono> "So far," Rina agrees as you go back to the main path. It proceeds forward ahead, but in the distance, heat haze rapidly distorts and obscures what lies ahead. However, the fact that you're not alone renders that moot. 30ft away and closing in, you see three more salamanders. Two more are like the previous, but the third is wearing armor - a breastplate, greaves, bracers and open helmet -
19:18 <•Kotono> and carries a spear that has its own field of heat haze around it. That one points his spear at you, "You!" he bellows in Ignan, "You have broached our sanctum, intruders! Surrender yourselves immediately!"
19:20 <Devar> "I'm guessing it doesn't matter if the Blue Fire spirit told us about this place?" Devar asks aloud.
19:21 <•Kotono> From the way their spears are pointed the party's way, Devar suspects he's correct. "Surrender!" is barked out one more time, again.
19:21 <Skaya> "No, you surrender! Or die!"
19:26 <•Kotono> The response is what you'd expect - shouts of violence and the next thing you know, the salamanders advance. OOC: Init. I think we saw this one coming.
19:26 <•Kotono> roll 1d20+4 (+3 ???) Salamander 1
19:26 <•Kotono> OOC: One moment while Kobot is restored.
19:27 → Kobot joined (~dunefar@95933D4C.659326DE.4EEAC6BE.IP)
19:27 <Skaya> roll 1d20+9
19:27 <Kobot> Skaya rolled 1d20+9 --> [ 1d20=10 ]{19}
19:27 <•Kotono> roll 1d20+4 (+3 ???) Salamander 1
19:27 <Kobot> Kotono rolled 1d20+4 (+3 ???) Salamander 1 --> [ 1d20=7 ]{11}
19:27 <•Kotono> roll 1d20+6 (+3 ???) Salamander 2
19:27 <Kobot> Kotono rolled 1d20+6 (+3 ???) Salamander 2 --> [ 1d20=11 ]{17}
19:27 <•Kotono> roll 1d20+8 Armored Salamander
19:27 <Kobot> Kotono rolled 1d20+8 Armored Salamander --> [ 1d20=13 ]{21}
19:27 <•Kotono> OOC: INcludes the +3.
19:28 <•Kotono> roll 1d20+11 Rina
19:28 <Kobot> Kotono rolled 1d20+11 Rina --> [ 1d20=1 ]{12}
19:28 <Devar> roll 1d20+2 init devar
19:28 <Kobot> Devar rolled 1d20+2 init devar --> [ 1d20=7 ]{9}
19:28 <•Kotono> Init is Armored Salamander (21) > Skaya (19) > Salamander 2 (17) > Rina (12) > Salamander 1 (11) > Devar (9)
19:29 <•Kotono> The armored salamander stays put as the other advances, spinning his spear and gesturing with it, before a bolt of lightning flies out from him towards Skaya. OOC: Evasion.
19:30 <Skaya> roll 1d20+7+6 I do have evasion
19:30 <Kobot> Skaya rolled 1d20+7+6 I do have evasion --> [ 1d20=19 ]{32}
19:30 <•Kotono> OOC: And by evasion I mean reflex, sorry, got game wires crossed with IDdy. But yes, evasion gets it.
19:31 <•Kotono> Skaya throws herself to the ground to dodge it, flying past harmlessly. She hops back up, just in time to...OOC: Skaya, go.
19:31 <Devar> "They have a magical lightning spear too!?" Devar shouts.
19:33 → Iddy joined (uid408070@lunarnet-423F0355.irccloud.com)
19:33 — Skaya decides to try and take one of the slower salamanders by surprise! Even if it takes a bit of effort to avoid the lead guy, she'll try to get behind him and strike!
19:34 <Skaya> OOC: Do I need acrobatics here? I'm not sure how wide the tunnel is and if it's a longspear or what
19:36 <•Kotono> OOC: Yes, they're long spears so acrobatics. The tunnel's wide but not that wide, so roll it up.
19:36 <Skaya> OOC: Taking 10 for 27, then
19:37 <Skaya> roll 1d20+9+6 attack on salamander #1, also stunning fist
19:37 <Kobot> Skaya rolled 1d20+9+6 attack on salamander #1, also stunning fist --> [ 1d20=19 ]{34}
19:37 <Skaya> roll 1d10+4+6 and Fort 18
19:37 <Kobot> Skaya rolled 1d10+4+6 and Fort 18 --> [ 1d10=8 ]{18}
19:38 <•Kotono> roll 1d20+8
19:38 <Kobot> Kotono rolled 1d20+8 --> [ 1d20=6 ]{14}
19:38 <•Kotono> Init is Armored Salamander (21) > Skaya (19) > Salamander 2 (17) > Rina (12) > Salamander 1 (11 stunned 1 round) > Devar (9)
19:39 <•Kotono> Skaya dodges a spear stab as she tumbles in, a blow to its back. It knocks it forward, arms waving wildly as its completely off balance and stunned. The second salamander meanwhile closes in on Rina, stabbing out for her throat with a loud cry.
19:39 <•Kotono> roll 1d20+14 (+1 ???)
19:39 <Kobot> Kotono rolled 1d20+14 (+1 ???) --> [ 1d20=10 ]{24}
19:40 <•Kotono> roll 1d8+5+4d6 ow pain
19:40 <Kobot> Kotono rolled 1d8+5+4d6 ow pain --> [ 1d8=7 4d6=17 ]{29}
19:41 <•Kotono> While the salamander Skaya hit now likely has something broken in its back, Rina gets stabbed in the side. It's a half dodge, not good enough. As she gasps and tries to react, it then headbutts her hard, knocking her back and off the spear, reeling and bleeing. Both from her wound and a busted nose, completely battered before...OOC: Rina.
19:46 <•Kotono> Wounded and with her mobility pinned down, Rina has no choice but to commit, retorting with a stab back at her attacker. "Could use some help!" she cries.
19:46 <•Kotono> roll 1d20+11
19:46 <Kobot> Kotono rolled 1d20+11 --> [ 1d20=2 ]{13}
19:46 <Kobot> Kotono rolled 1d20+11 --> [ 1d20=11 ]{22}
19:46 <•Kotono> roll 1d6+3
19:46 <Kobot> Kotono rolled 1d6+3 --> [ 1d6=6 ]{9}
19:48 <•Kotono> Rina retorts with a slash that catches the cheek of the salamander, drawing steaming hot blood that sizzles in the air. A lifelong mark without healing, but not enough to put it down as...OOC: Devar, salamander 1 is stunned this round.
19:48 <•Kotono> Init is Armored Salamander (21) > Skaya (19) > Salamander 2 (17) > Rina (12) > Salamander 1 (11) > Devar (9)
19:51 <Devar> "Hang on!" Devar calls out, as he summons Storm's Eye. "We really need to figure out how to make you do things in a larger area, but for now, that one!" Devar shouts, pointing his own spear to summon lightning towards the currently stunned Salamander!
19:51 <Devar> roll 5d8 DC is reflex 20 so die while you're stunned, idiot
19:51 <Kobot> Devar rolled 5d8 DC is reflex 20 so die while you're stunned, idiot --> [ 5d8=25 ]{25}
19:52 <Devar> Devar will leap through the air with his wings to land directly in front of the larger and armored salamander after that, hoping to draw its attention and ire away from the others!
19:53 <•Kotono> roll 1d20+7
19:53 <Kobot> Kotono rolled 1d20+7 --> [ 1d20=11 ]{18}
19:54 <•Kotono> The stunned salamander is hit again, convulsing all over. It screams loudly as Devar flies in - and gets a spear stabbed right at him for his troubles. OOC: Thing has reach on you and a long spear so g'luck.
19:54 <•Kotono> roll 1d20+14
19:54 <Kobot> Kotono rolled 1d20+14 --> [ 1d20=6 ]{20}
19:54 <•Kotono> OOC: AC?
19:54 <Devar> OOC: 31 against melee attacks
19:55 <•Kotono> Devar smoothly sidesteps it as meanwhile, the armored salamander looks on. It intones strange, twisting words that are somehow familiar toh Skaya - before it points and five magic missiles fly from its finger, all to slam into the wounded Rina.
19:55 <•Kotono> roll 5d4+5
19:55 <Kobot> Kotono rolled 5d4+5 --> [ 5d4=12 ]{17}
19:56 <Devar> OOC: Do I get any ability to hamper its casting since I'm in melee with it?
19:57 <•Kotono> OOC: What's your reach right now
19:57 <•Kotono> ?
19:57 <Devar> OOC: 5ft
19:57 <•Kotono> OOC: Oh right, slight revision then. It steps back slightly, using a 5ft step not to be AoOed.
19:58 <•Kotono> Rina screams as the missiles hit her chest. There's a terrible cracking noise, something giving within her. She falls to a knee, coughing up spit, bile and blood. She's just barely up, wounded terrifically, "Ah...Regis..." Rina manages to choke out, blood staining her lips as...OOC: She's in trouble. Skaya, you're up.
20:02 <Skaya> Is there nothing she can do?! But no, Skaya calms herself, and just before the electrocuted salamander she and Devar had brought to death's door recovers, Skaya disengages. Slipping past the armored one is as easy now as it had been before, and then she arrives behind the salamander menacing Rina with a kick!
20:02 <Skaya> roll 1d20+9+2+6 stunning fist, again
20:02 <Kobot> Skaya rolled 1d20+9+2+6 stunning fist, again --> [ 1d20=13 ]{30}
20:03 <Skaya> roll 1d10+4+6 and Fort DC18
20:03 <Kobot> Skaya rolled 1d10+4+6 and Fort DC18 --> [ 1d10=9 ]{19}
20:03 <•Kotono> roll 1d20+8
20:03 <Kobot> Kotono rolled 1d20+8 --> [ 1d20=19 ]{27}
20:04 <•Kotono> CRACK! Scale a nd bone both give to a heavy blow, pinning the salamander between the two of them. It arches forward, a bellow of pain - but isn't disabled. No, it keeps itself together and with simple, focused intensity, goes to try and finish off Rina before dealing with Skaya.
20:04 <•Kotono> roll 1d20+14 (+1 ???)
20:04 <Kobot> Kotono rolled 1d20+14 (+1 ???) --> [ 1d20=11 ]{25}
20:04 <•Kotono> roll 1d8+5
20:04 <Kobot> Kotono rolled 1d8+5 --> [ 1d8=7 ]{12}
20:05 <•Kotono> The stab is brutal. Rina goes limp, her blade falling form her hand as the tip of the spear pokes out of her back. She slides off bonelessly, a look of agony and relief on her face as her eyes close. She falls to the ground, her life spilling out by the second as...OOC: Ow. Rina rolls to stabilize right away. Con 20 so she has 10 HP to play with.
20:05 <•Kotono> roll 1d100
20:05 <Kobot> Kotono rolled 1d100 --> [ 1d100=76 ]{76}
20:06 <•Kotono> OOC: -11 HP now.
20:06 <•Kotono> Meanwhile, the first salamander whirls on Devar, going to pin him with the other, stabbing out quickly and viciously.
20:06 <•Kotono> roll 1d20+14 (+2 flanking)
20:06 <Kobot> Kotono rolled 1d20+14 (+2 flanking) --> [ 1d20=13 ]{27}
20:06 <•Kotono> OOC: AC?
20:07 <Devar> OOC: 31 against melee
20:07 <•Kotono> A quick, brutal stab that Devar jukes around, dodging in between both now, under siege from both directions. It's just enough to avoid them both as...OOC: Devar.
20:08 <Devar> Seeing the salamander (1) is weakened already, Devar goes in to try and finish it off! This is already bad, but hopefully this can turn this back towards them!
20:08 <Devar> roll 1d20+9 bonk
20:08 <Kobot> Devar rolled 1d20+9 bonk --> [ 1d20=10 ]{19}
20:08 <•Kotono> OOC: Hit.
20:08 <Devar> roll 1d8+4 bonk bonk doubled
20:08 <Kobot> Devar rolled 1d8+4 bonk bonk doubled --> [ 1d8=6 ]{10}
20:09 <Devar> OOC: So 20
20:10 <•Kotono> WHAM! The unnatural effectiveness of Devar's weapon against fire proves true. A mere blow to the side results in a tremendous crack, a gurgling scream as the salamander collapses. It immediately breaks into fire that sputters out, only leaving behind its spear. Got it!
20:10 <•Kotono> Init is Armored Salamander (21) > Skaya (19) > Salamander 2 (17) > Rina (12) > Devar (9)
20:11 <•Kotono> Turning on Devar now, the armored salamander snarls, before fully unleashing its wrath on Devar, up close and personal! Hints of blue fire dance around its spear as it stabs for Devar's softest bits.
20:11 <•Kotono> roll 1d20+16 (+1 ???)
20:11 <Kobot> Kotono rolled 1d20+16 (+1 ???) --> [ 1d20=15 ]{31}
20:11 <•Kotono> roll 1d20+11 (+1 ???)
20:11 <Kobot> Kotono rolled 1d20+11 (+1 ???) --> [ 1d20=10 ]{21}
20:11 <•Kotono> roll 1d20+14 (+1 ???) tail
20:11 <Kobot> Kotono rolled 1d20+14 (+1 ???) tail --> [ 1d20=3 ]{17}
20:11 <•Kotono> roll 1d8+7+1d6 ow
20:11 <Kobot> Kotono rolled 1d8+7+1d6 ow --> [ 1d8=7 1d6=1 ]{15}
20:12 <Devar> OOC: Is any of that fire damage?
20:13 <•Kotono> OOC: No.
20:14 <Devar> OOC: Okay
20:14 <•Kotono> Devar dodges the main stab, but not enough to block a quick counter bash from the spear butt. It slams him in the throat, making him cough and wheeze in pain. It makes it hard to breathe, though he's still up and alive despite the wound. In return....OOC: Skaya, go.
20:19 <Skaya> Burning with indignation, Skaya strikes at the salamander that took down Rina!
20:19 <Skaya> roll 2#1d20+9
20:19 <Kobot> Skaya rolled 2#1d20+9 --> [ 1d20=9 ]{18}, [ 1d20=19 ]{28}
20:19 <Skaya> OOC: -1, so 17 and 27
20:23 <Skaya> OOC: I'll also use stunning fist x2 here if I can
20:24 <•Kotono> OOC: Second one hits.
20:24 <Skaya> roll 1d10+4 and Fort DC18
20:24 <Kobot> Skaya rolled 1d10+4 and Fort DC18 --> [ 1d10=4 ]{8}
20:24 <•Kotono> roll 1d20+8
20:24 <Kobot> Kotono rolled 1d20+8 --> [ 1d20=2 ]{10}
20:24 <•Kotono> Init is Armored Salamander (21) > Skaya (19) > Salamander 2 (17 stunned 1) > Rina (12) > Devar (9)
20:25 <•Kotono> Skaya slams back. It's a shot right to its chin, snapping its head back and leaving it seeing stars. Blood dribbles down, steaming hot, as it's completely off balance and unable to react. Just in time for Rina to...
20:25 <•Kotono> roll 1d100 vs 20
20:25 <Kobot> Kotono rolled 1d100 vs 20 --> [ 1d100=20 ]{20}
20:25 <•Kotono> OOC: Rina stabilizes.
20:26 <•Kotono> OOC: Devar, go.
20:26 <Skaya> OOC: Incidentally, stun makes people drop everything so the salamander's spear is on the ground
20:26 <•Kotono> OOC: Okay.
20:27 <Devar> Glancing behind himself at Skaya, Devar stands his ground - but with his current injury, he fights more defensively to avoid any further nicks!
20:27 <Devar> roll 1d20+9-4 fighting defensively
20:27 <Kobot> Devar rolled 1d20+9-4 fighting defensively --> [ 1d20=12 ]{17}
20:27 <Devar> roll 1d8+4 doubled if that hit anyway
20:27 <Kobot> Devar rolled 1d8+4 doubled if that hit anyway --> [ 1d8=1 ]{5}
20:27 <Devar> OOC: AC is currently 33
20:27 <Devar> OOC: And I also forgot my DR so I am adjusting for that
20:33 <•Kotono> Devar is on the defensive - no serious blows land, but he's safe at least. Protecting himself as the armored salamander steps another 5ft back, before with a snarl, "Cursed be to suffer this power!" the armored salamander declares, gesturing and drawing patterns in the air, before magic missiles pepper Devar...except for one, which peels away and darts for Rina instead, going to try and
20:33 <•Kotono> finish the job.
20:33 <•Kotono> roll 4d4+4 Devar
20:33 <Kobot> Kotono rolled 4d4+4 Devar --> [ 4d4=10 ]{14}
20:33 <•Kotono> roll 1d4+1 Rina
20:33 <Kobot> Kotono rolled 1d4+1 Rina --> [ 1d4=2 ]{3}
20:35 <•Kotono> The missiles all strike true. Devar jerks back with them, bruised and battered all across his chest and stomach. He's hit hard, while Rina's hit in the side, another splurt of blood coming from her, her injuries provoked anew. OOC: No longer stabilized due to more damage taken. Skaya, you're up. Go.
20:35 — Skaya grabs Rina and the salamander's dropped spear and dashes for the side passage they had just explored. It had a door, and that would cut off line of sight for any hostile magics. Plus, she could stand guard there and protect Rina to give her a fighting chance!
20:36 <•Kotono> Skaya does that as the second salamander recovers, darting back and away to safety. Rina continues to bleed as...
20:36 <•Kotono> roll 1d100 vs 20
20:36 <Kobot> Kotono rolled 1d100 vs 20 --> [ 1d100=75 ]{75}
20:36 <•Kotono> OOC: -15.
20:36 <•Kotono> Init is Armored Salamander (21) > Skaya (19) > Salamander 2 (17) > Rina (12) > Devar (9)
20:36 <•Kotono> OOC: Devar, go.
20:37 <•Kotono> The armored salamander snarls but holds his ground, steam rising from his body as his armor heats up. "You've chosen to resist and die!" he snaps, "May ten thousand buckets of water torment you for eternity!"
20:39 <Devar> OOC: In relation to the armored salamander, where's Salamander number 2 now?
20:42 <•Kotono> OOC: About 30ft away, it moved into attack Rina round 1 and stuck on her.
20:42 <Devar> Okay.
20:43 <Devar> Devar will withdraw 5ft himself and fly over to try and finish off the now-weaponless salamander! He can endure a few more magic missiles if the need arises!
20:43 <Devar> roll 1d20+9 bonk
20:43 <Kobot> Devar rolled 1d20+9 bonk --> [ 1d20=18 ]{27}
20:44 <Devar> roll 1d8+4 doubled bonk
20:44 <Kobot> Devar rolled 1d8+4 doubled bonk --> [ 1d8=4 ]{8}
20:44 <Devar> OOC: so 16
20:47 <•Kotono> Another heavy hit leaves that salamander reeling. Its head is bashed, blood pouring freely - but not down. INstead the armored salamander now has space, and sends another barrage of magic missiles at Devar. How many of these does he have?!
20:48 <•Kotono> roll 5d4+5
20:48 <Kobot> Kotono rolled 5d4+5 --> [ 5d4=10 ]{15}
20:48 <•Kotono> Devar is hit again and again, bruises coming and blood leaking from broken skin. All across his front he's hit as he holds his ground, refusing to fall as...OOC: Skaya, go.
20:49 — Skaya doesn't waste any time before guiding her dwindling energy into Rina to revive her before she's too far gone!
20:49 <Skaya> OOC: +16HP
20:50 <•Kotono> Rina stirs. Her injuries heal, at least enough to stave off death. She's barely awake, groaning and breathing, but alive. Not that it stops the other salamander, bloodied as it is, as it falls onto Devar with a furious passion. Rather than using its spear though, it  leaps high and comes down with a massive tail slam at his chest.
20:51 <•Kotono> roll 1d20+9 (+1 ????, -5 PA)
20:51 <Kobot> Kotono rolled 1d20+9 (+1 ????, -5 PA) --> [ 1d20=10 ]{19}
20:52 <•Kotono> It's a heavy blow but fortune is not on his side. It's just too slow, Devar juking aside amid the steaming hot battlefield, as Rina slowly, painfully sits up, "S-skaya?" she asks, gasping. She scrambles to her feet out of more instinct than anything, ,looking around in confusion. OOC: Not in a state to do much, so. Devar, go.
20:53 <Skaya> "I've got your back," Skaya tells her. "Take my last potion, it's better than nothing."
20:53 <Skaya> OOC: Rina can grab and use my CLW
20:53 <Devar> He can't really endure any more of the missiles, but he's got an opening here, so he takes it and swings at the salamander!
20:54 <Devar> roll 1d20+9 bonk
20:54 <Kobot> Devar rolled 1d20+9 bonk --> [ 1d20=4 ]{13}
20:54 <•Kotono> It's a bad swing, the salamander able to duck it and end up on all fours, snarling and with a forked tongue seen. Meanwhile Rina nods and does that, potion consumed.
20:54 <•Kotono> roll 1d8+1
20:54 <Kobot> Kotono rolled 1d8+1 --> [ 1d8=5 ]{6}
20:54 <Devar> He then immediately flies back and into the hallway opposite of where Rina and Skaya are - hopefully the armored one is either out of missiles or can't do anything since he can't see them!
20:55 <•Kotono> OOC: You'll eat an AoO in that case since it's still large enough to have reach on you. Okay with that?
20:56 <Devar> OOC: That's fine
20:56 <•Kotono> roll 1d20+9 (+1 ????, -5 PA) AoO  gets a second try at the home run swing
20:56 <Kobot> Kotono rolled 1d20+9 (+1 ????, -5 PA) AoO gets a second try at the home run swing --> [ 1d20=8 ]{17}
20:57 <•Kotono> Devar dodges another tail swipe as he retreats away, out of sight. With the break in tempo, what the armored one does is a question, since both of you are out of sight of him. OOC: Skaya.
20:58 <Devar> Devar gives Rina a weak raised hand in greeting. "Couldn't kill the other one, not sure if the big one still has any magic left." He says, a bit out of breath.
20:59 <Skaya> "Stay here," Skaya tells Rina, leaving the spear with her. And then she peers out into the main corridor, wand of magic missiles in hand.
20:59 <Skaya> OOC: I will MM the second salamander if he's there
21:00 <Skaya> roll 2d4+2+5
21:00 <Kobot> Skaya rolled 2d4+2+5 --> [ 2d4=5 ]{12}
21:00 <•Kotono> Skaya darts out and finds the armored salamander has advanced, only 15ft away now. The second salamander is still there, not yet reacted - and takes missiles to the face. This time they punch through its body as it erupts into flames, crumbling away save for its spear.
21:01 <•Kotono> Init is Armored Salamander (21) > Skaya (19) > Rina (12) > Devar (9)
21:01 <Skaya> "And then there was only one," Skaya tells the armored salamander smugly.
21:01 <•Kotono> Rina sits there and rests, still in no shape to battle. She recovers for now as thea rmored salamander bares its teeth at her, shiny white. Then Devar....OOC: Devar, go.
21:05 <Devar> Devar takes a breath and moves out and back into melee with the big one, hoping to keep it from casting anything else, going in for a defensive strike!
21:05 <Devar> roll 1d20+9-4 fighting defensively
21:05 <Kobot> Devar rolled 1d20+9-4 fighting defensively --> [ 1d20=2 ]{7}
21:05 <•Kotono> OOC: You'll take an AoO moving in if you do that, okay with that?
21:06 <Devar> OOC: I will have to risk it for this to work, so go for it and hope I don't die
21:06 <•Kotono> roll 1d20+16 (+1 ???)
21:06 <Kobot> Kotono rolled 1d20+16 (+1 ???) --> [ 1d20=2 ]{18}
21:06 <Devar> OOC: Even Kobot can be merciful at times
21:07 <•Kotono> Devar closes in and the two exchange blow. Both dodge, countering one another enough to stop the exchange. It's just enough to keep both of you unhurt, before Devar is savagely torn into once more, in direct melee battle!
21:07 <•Kotono> roll 1d20+16 (+1 ???)
21:07 <Kobot> Kotono rolled 1d20+16 (+1 ???) --> [ 1d20=15 ]{31}
21:07 <•Kotono> roll 1d20+11 (+1 ???)
21:07 <Kobot> Kotono rolled 1d20+11 (+1 ???) --> [ 1d20=7 ]{18}
21:07 <•Kotono> roll 1d20+14 (+1 ???) tail
21:07 <Kobot> Kotono rolled 1d20+14 (+1 ???) tail --> [ 1d20=7 ]{21}
21:07 <•Kotono> OOC: AC?
21:07 <Devar> OOC: 33 while fighting defensively
21:08 <•Kotono> Devar, on the defensive, is able to stay untouched. The two exchange more inconclusive blows, going back and forth viciously. A dodge and a counter, a parry and a duck, all of it meaning Devar isn't hurt. Yet. OOC: Skaya.
21:08 <Skaya> "You like to play with missiles, don't you?" Skaya asks with a grin, brandishing her wand. "Have some back!"
21:08 <Skaya> roll 2d4+2+5
21:08 <Kobot> Skaya rolled 2d4+2+5 --> [ 2d4=4 ]{11}
21:15 <•Kotono> The missiles hit, the salamander hit all over as it roars in pain and fury, more and more absolutely livid, as meanwhile...OOC: Rina's staying out of it for obvious reasons. Devar. It mad.
21:15 <Devar> Devar goes fully on the defensive, ready to parry and block and dodge - he will keep these two safe!
21:15 <Devar> OOC: Total defense for the record, AC goes to 35
21:21 <•Kotono> WIth Devar on the defensive, the salamander promptly ignores him and sprints past - opening up Devar to take a free shot, at least. OOC: It's going at Skaya, but opens itself up for an AoO if yo uwant to take it. It's not keen on facing someone so obviously a defensive master going full defense, and when the other target is both squishier and more annoying.
21:23 <Devar> Why yes, Devar will in fact do that!
21:23 <Devar> roll 1d20+9 bonk gimme a 20
21:23 <Kobot> Devar rolled 1d20+9 bonk gimme a 20 --> [ 1d20=11 ]{20}
21:23 <Devar> OOC: I mean that is a 20
21:23 <•Kotono> OOC: MIss. Kobot was too literal.
21:23 <•Kotono> roll 1d20+16 (+1 ???, +2 charge, -2 PA)
21:23 <Kobot> Kotono rolled 1d20+16 (+1 ???, +2 charge, -2 PA) --> [ 1d20=15 ]{31}
21:23 <•Kotono> OOC: AC Skaya?
21:24 <Skaya> OOC: 28
21:24 <•Kotono> roll 1d8+11+1d6 the ow
21:24 <Kobot> Kotono rolled 1d8+11+1d6 the ow --> [ 1d8=4 1d6=6 ]{21}
21:25 <•Kotono> Skaya's too slow. The spear pierces her middle, the armoreds alamander grinning horribly as she's gotten. She twists away in part, enough to make it a jagged side wound rather than an impalement. But it still bleeds, a serious blow as...OOC: Skaya, go. It's on you now, suffice to say. Also, you can dimly notice Rina's lurking in the doorway.
21:29 — Skaya retreats further into the side corridor where Rina is waiting. If Devar takes up position by the door, getting past him will get harder! And she knows she's capable of dodging this guy, so once she's gained some distance yet more missiles pepper its hateful face.
21:30 <Skaya> OOC: Acrobatics 27 to get away, MM
21:30 <Skaya> roll 2d4+2+5
21:30 <Kobot> Skaya rolled 2d4+2+5 --> [ 2d4=2 ]{9}
21:30 <•Kotono> More missiles hit. One strikes its chin, snapping its head back as if it got punched. It spits out steaming blood after, teeth now stained with it. It still doesn't put it down though, as...OOC: Devar, go.
21:32 <Devar> Devar flies up, over, and right in front of it again, standing in the doorway to block it from getting through, still playing the defense game! OOC: I'm assuming I can do this without provoking anything since I'm already in its attack range to begin with and not really leaving it.
21:33 <Devar> OOC: Actually, let me redo that - he's still doing that move action, but will also drink a potion this turn
21:34 <Devar> roll 3d8+3 potion
21:34 <Kobot> Devar rolled 3d8+3 potion --> [ 3d8=11 ]{14}
21:35 <•Kotono> OOC: It'll provoke - remember it has a lot of reach with that spear, 20ft of it and you only have so much movement. You can do it, but you'll risk another stabbin'.
21:36 <Devar> OOC: Okay. Drink potion first, move then. AC is 31
21:37 <Devar> OOC: math was wrong on the potion so +2 more healing
21:37 <Skaya> OOC: It's only another stab if it has combat reflexes!
21:39 <•Kotono> OOC: He does, unfortunately. He knows what he's doing with his build and reach games.
21:39 <•Kotono> roll 1d20+16 (+1 ???, +2 charge, -2 PA)
21:39 <Kobot> Kotono rolled 1d20+16 (+1 ???, +2 charge, -2 PA) --> [ 1d20=3 ]{19}
21:39 <•Kotono> Devar flies back and blocks the way, dodging a stab up. He gets in position, just in time to take the full salamander wrath now, the two locked in battle once more.
21:40 <•Kotono> roll 1d20+16 (+1 ???)
21:40 <Kobot> Kotono rolled 1d20+16 (+1 ???) --> [ 1d20=16 ]{32}
21:40 <•Kotono> roll 1d20+11 (+1 ???)
21:40 <Kobot> Kotono rolled 1d20+11 (+1 ???) --> [ 1d20=17 ]{28}
21:40 <•Kotono> roll 1d20+14 (+1 ???) tail AC?
21:40 <Kobot> Kotono rolled 1d20+14 (+1 ???) tail AC? --> [ 1d20=2 ]{16}
21:40 <Devar> OOC: One hit, I don't have any emergency ways to get my armor two higher at the moment
21:42 <•Kotono> roll 1d8+7+1d6
21:42 <Kobot> Kotono rolled 1d8+7+1d6 --> [ 1d8=1 1d6=5 ]{13}
21:42 <•Kotono> This time Devar gets a spear bash in the middle, winding him and sending spikes of pain throughout his middle. Painful but not fatal, at least not yet, as...OOC: SKaya, it's your go.
21:42 <Skaya> What a nasty situation! Can Skaya do anything besides blasting away with magic missiles? Nothing else comes to mind!
21:43 <Skaya> roll 2d4+2+5
21:43 <Kobot> Skaya rolled 2d4+2+5 --> [ 2d4=7 ]{14}
21:43 <•Kotono> Ker-RACK! Missiles blast it, the two of them boring into its shoulders. IT gasps loudly and staggers from the blows, trying to stay up as...OOC: Devar, go.
21:45 <Devar> He's not going to let this thing through, not at all! He stands against this creature, defending his friends behind him! OOC: full defense, AC is 35
21:47 <•Kotono> The salamander steps back, carefully withdrawing - and with a burst of unknown speed, retreats massively. IT falls back over 60ft, into the heat haze and out of immediate range. Fleeing the battle despite its anger, falling back with both sides battered, injured but alive. OOC: It's just visible but the heat haze is providing it cover. Skaya, go.
21:48 <Skaya> There is no cover from magic missiles! Skaya sends a pair after him as she gives chase!
21:48 <Skaya> roll 2d4+2+5 and I'll move just close enough I'm not in its melee range
21:48 <Kobot> Skaya rolled 2d4+2+5 and I'll move just close enough I'm not in its melee range --> [ 2d4=3 ]{10}
21:48 <•Kotono> OOC: Going to pursue then? How far do you move?
21:49 <Skaya> OOC: If it has reach of 20ft, then I'll get to within 25ft of it. I presume Devar will follow and get in front of me!
21:50 <•Kotono> The missiles hit - and injure it anew. It grimaces in pain as you can see a bit ahead now. There's something beyond the heat haze, too indistinct, but there's definitely something ahead. OOC: Devar, go.
21:50 <Devar> Devar moves out to get in front of Skaya again, defending her from a charge, he hopes!
21:51 ⇐ Iddy quit (uid408070@lunarnet-423F0355.irccloud.com) Quit: Connection closed for inactivity
21:53 <•Kotono> A wise choice - for with a scream of injured rage, the salamander aborts that plan and charges right on in!
21:53 <•Kotono> roll 1d20+16 (+1 ???, +2 charge, -2 PA)
21:53 <Kobot> Kotono rolled 1d20+16 (+1 ???, +2 charge, -2 PA) --> [ 1d20=10 ]{26}
21:54 <Devar> OOC: 35 whew
21:54 <•Kotono> But Devar's defenses are too good, stopping the powerful charge cold. A quick dodge that's just enough, the two of them having bought more time that...OOC: Skaya and then Devar.
21:55 <Skaya> "Just die! Die die die die die!"
21:55 <Skaya> roll 2d4+2+5
21:55 <Kobot> Skaya rolled 2d4+2+5 --> [ 2d4=4 ]{11}
21:59 <•Kotono> Another missiled assault. The salamander falls to a knee, struggling as missiles slam into its guts and bury themselves in. Blood follows once they fade, serious wounds as it struggles tos tay up. "Y-you..." it hisses after yet another barrage, while Devar...OOC: Go.
22:00 <Skaya> "Screw you! Your guys attacked us without a warning, and now this! You cultists are all the same! Nasty!"
22:01 <Devar> "You're the one who wouldn't surrender." Devar says in agreement. "You did this to yourself." Nonetheless, he continues to guard Skaya and stays on the defensive.
22:01 <Devar> "Violence should never be your first option." He adds, rather sadly.
22:02 <•Kotono> Dying and mostly broken, the salamander has no choice - it swings at Devar, trying to break through to Skay all the while.
22:02 <•Kotono> roll 1d20+16 (+1 ???)
22:02 <Kobot> Kotono rolled 1d20+16 (+1 ???) --> [ 1d20=18 ]{34}
22:02 <•Kotono> roll 1d20+11 (+1 ???)
22:02 <Kobot> Kotono rolled 1d20+11 (+1 ???) --> [ 1d20=3 ]{14}
22:02 <•Kotono> roll 1d20+14 (+1 ???) tail
22:02 <Kobot> Kotono rolled 1d20+14 (+1 ???) tail --> [ 1d20=9 ]{23}
22:02 <Devar> OOC: thankfully 35
22:02 <•Kotono> OOC: AC?
22:03 <•Kotono> Yet Devar's defenses hold, just long enough, another few seconds so that Skaya...OOC: Go Skaya.
22:04 — Skaya hopes that the salamander dies for good as she brandishes the wand again!
22:04 <Skaya> roll 2d4+5+2
22:04 <Kobot> Skaya rolled 2d4+5+2 --> [ 2d4=8 ]{15}
22:07 <•Kotono> Two hits - and one punches through the salamander's forehead. It falls back as it crumbles to fire, only leaving behind its armor, a spear and the wounds inflicted on all of you.
22:07 <•Kotono> Is it...is it over? OOC: Free act.
22:09 <Devar> Devar lets out a breath as his adrenaline starts to fade, his body sagging.
22:09 <Devar> "That had better have been the last thing in our way." He says, composing himself.
22:10 <Skaya> "It definitely isn't," Skaya affirms. "Let's get Rina and you can heal the two of us up before we consider our next step." She doesn't forget to collect the armor and all three spears, of course.
22:11 <•Kotono> Rina limps out, hand over one of her many wounds. "Ugh..." is all she manages.
22:12 <Devar> Devar nods, channeling energy for the two of them a few times - three, in fact!
22:12 <Devar> roll 3d6 healing for Skaya and Rina
22:12 <Kobot> Devar rolled 3d6 healing for Skaya and Rina --> [ 3d6=10 ]{10}
22:13 <Devar> and three more times for good measure!
22:13 <Devar> roll 3d6 healing for Skaya and Rina
22:13 <Kobot> Devar rolled 3d6 healing for Skaya and Rina --> [ 3d6=15 ]{15}
22:13 <Devar> OOC: He's got 3 left
22:14 <•Kotono> Wounds heal. Rina is still considerably injured, but the worst of it is past. She groans softly and restsin against Devar, "We don't have much in us. Can we really afford to go forward like this?"
22:15 <Skaya> "We really can't," Skaya says with a frown. "I might have another, but then I'm out. So the question becomes, do we check the haze anyway or retreat?"
22:16 <Devar> Devar nods to Skaya. "We can at least check, and run back."
22:17 <Skaya> "If there's more of them, let's just rush back to the side corridor and have Devar block the way. I don't know if there's a better choice here."
22:18 — Devar nods.
22:18 <•Kotono> THus the party proceeds forward...next time! OOC: Rina might argue it, but it's over our  normal time and I need to get up, so we'll pause here. More when I get back.
19:02 <•Kotono> The party proceeds forward and through the heat haze. It beats down on all of you ferociously and...
19:02 <•Kotono> roll 5d6 fire damage only really impacts Devar since Rina and Skaya have resistance 30 I believe
19:02 <Kobot> Kotono rolled 5d6 fire damage only really impacts Devar since Rina and Skaya have resistance 30 I believe --> [ 5d6=22 ]{22}
19:04 <Devar> OOC: It eats the rest of the fire protection but then gets nullified by the resistance 10
19:07 <•Kotono> Past that, you come into clarity. Here sits a large, wide open chamber. Cooler than before, still boiling hot, but no danger with your protections. The floor is sloped downward, into a wide, circular gap about 15ft in diameter, that plunges deeper. However, hovering 10ft above that is a large block of what looks to be solid obsidian. It's shiny and smooth, black interrupted with ripples
19:07 <•Kotono> and flecks of deep red within it. Atop this cube sits a curious icon, that of a flame carved of some manner of blue stone. Gem-like but not quite right, crude in its construction. The flame has two eyes, and as you look carefully, little scales are drawn into the fire.
19:09 — Skaya approaches it and studies the eyes of the flame.
19:10 <•Kotono> The eyes are deep, and Skaya can feel herself being drawn into them. Beautiful. So beautiful.
19:11 <Skaya> "So beautiful-- no, no," Skaya stops herself, shaking her head. They can't afford to be drawn into something in enemy territory!
19:11 <Devar> "Do you want me to try and identify it?" Devar asks, looking around.
19:12 <Skaya> "Sure, but be careful. It's very amazing!"
19:13 <Devar> He nods and will move forward, casting detect magic! OOC: If there is magic he'll use his identify ability to figure out what these are.
19:15 <•Kotono> Rina stays on guard, wary all the while. Devar goes to identify it and...OOC: SEc for loot post.
19:20 <•Kotono> OOC: Updatedpost.
19:23 <Devar> "Oh, uh..." Devar looks over at Skaya. "Did you feel anything weird when you looked at it? I guess it's... part of a test? You passed, it looks like." He explains. "We shouldn't try and touch it, but you did whatever you were supposed to."
19:24 <Skaya> "I felt drawn into it, but I stopped myself from looking any deeper," Skaya muses. "I don't know, I didn't feel anything strange after looking away. Should I try looking at it longer?"
19:24 <Devar> Devar hums once. OOC: Do I think that by identifying it that *I* passed the test, or do we still need to look at it?
19:25 <•Kotono> Rina looks on, "Is it worth the risk?" she asks plainly, looking to Devar. "Do you know what happens if you fail the test?"
19:25 <•Kotono> OOC: As far as you're aware, you didn't take it.
19:25 <Devar> OOC: Okay.
19:27 <Devar> "Ah, I see now - sorry, there's another spell cast on top of it." He explains. "It's dangerous - you can't protect yourself at all, you just have to hope you pass... I'm probably the best person here to give it a shot, but I'm not sure what to suggest to you both if I fail."
19:28 <Skaya> "What's the benefit from passing the trial, anyway?"
19:30 <Devar> "I don't know exactly." He says. "I imagine it opens something, but I can't tell you exactly what. Failing the trial results in you trying to throw yourself into the chasm, but I don't know if that's a one-time thing or... what."
19:31 — Skaya purses her lips. "So this is not the best spot for it given enemy territory, but do we want to continue?" she asks, glancing between Devar and Rina.
19:32 <•Kotono> "I'm curious, but-" she hesitates, "I...I need the strength. I need to be stronger." she decides, "I wasn't strong e nough there."
19:33 <Devar> "I don't mind trying, the worst that would happen is you'd need to grab me, I think... and I wonder what happens after I throw myself in, anyway, I don't think it's intended for anyone who can just fly." A shrug afterwards. "I don't mind trying, but if we want to see if we even can continue this way for now that's fine too, I imagine whatever is ahead won't open, though if you don't pass
19:33 <Devar> this."
19:34 <Skaya> "I'll give it a try," Skaya voices. "I think it'd be better if you were the one who tried to catch me if I fail, on account of flight. Since we're continuing, we might as well check this out."
19:34 — Skaya approaches the icon again, and this time doesn't look away. If she already passed the trial, surely it would be alright to look again.
19:35 <Devar> Devar will move over nearby her to grab her by the wrist if needed!
19:35 <•Kotono> Skaya goes to the icon and carefully stares into its eyes. So beautiful, so so so...-! OOC: Will save.
19:36 <Skaya> roll 1d20+5+6 (+2 more vs enchantment)
19:36 <Kobot> Skaya rolled 1d20+5+6 (+2 more vs enchantment) --> [ 1d20=16 ]{27}
19:36 <•Kotono> OOC: What's the +6 from?
19:36 <Skaya> OOC: Inspiration.
19:37 <•Kotono> roll 10d6 full no save
19:37 <Kobot> Kotono rolled 10d6 full no save --> [ 10d6=32 ]{32}
19:38 <•Kotono> Skaya is abruptly slammed back and down, a loud CRACK against stone. As her mind reels with pain, one though fills her - to hurl herself below, into the circular chasm below.
19:39 <Skaya> OOC: I don't understand this
19:39 <•Kotono> OOC: The inspiration counted as resisting or warding the Will save.
19:40 <Skaya> OOC: It's a competence bonus, and this honestly wasn't clear. If anything adjusting the result autofails, wasn't I doomed to autofail due to Monk's Still Mind bonus of +2 vs enchantment?
19:42 <Skaya> OOC:I took interfering in test results to mean protections like say tying myself with rope to prevent jumping successfully into the chasm, not this
19:42 <•Kotono> OOC: Maybe, maybe not, but right now it is what it is. I suggest y'all doing something to stop Skaya from hurling herself in.
19:45 <Devar> Knowing how this works, Devar just runs over to grab Skaya's wrist to try and pull her away from the edge! "Rina, a little help!" He calls out.
19:46 <•Kotono> Rina dashes over as well, going to grab one of Skaya's arms, "Skaya, don't!"
19:54 <Skaya> "I must jump! I must!" Skaya cries, struggling.
19:55 <•Kotono> "Sh-" Rina scowls, "Devar, back out?" she suggests, gesturing with her head towards your wings.
19:56 <Devar> "I've got an idea." He says, going to just grab onto Skaya. "Let her go - she jumps and I'll just carry her out. That should rid her of the compulsion."
19:57 <Devar> OOC: So the idea is I'm holding her from the back and will just run with her while still holding her.
19:57 <•Kotono> OOC: Okay.
19:57 <•Kotono> Rina lets go on that idea, doing just that.
19:57 <Skaya> Now freer, Skaya dives in head first.
19:58 <•Kotono> Skaya and Devar dive in - a straight drop into molten rock. However, flight neatly interrupts gravity, even as heat wells up from above. Skaya's mind clears, leaving her with a view of the lava below but no more, courtesy of Air Devar.
19:58 <Skaya> "I hate this place," Skaya states in monotone. "Let's go back."
19:59 <Devar> "Hey, that didn't work." He says, helpfully as he drops her off on the side. "I wonder if you can just look at it again?" He blinks, then smiles a bit. "No, that's a fine attitude too."
19:59 <Skaya> "No, let's go back. I have not stated clearly how much I hate it."
19:59 <•Kotono> Rina sighs in deep relief, "Glad you're okay, Skaya." She glances at the icon, "Maybe we should destroy it?"
20:00 <Skaya> "We are in absolutely no condition to fight anything, so that's a-- actually sure. Do you know how?"
20:00 <•Kotono> "Throw it into the lava?" Rina suggests.
20:01 <Skaya> "I... guess you could try it?"
20:01 <Devar> "No, don't touch it." Devar warns them.
20:01 <•Kotono> Rina doesn't move, "Something you want to share, Devar?"
20:01 <Devar> "If you try and touch it, the same thing happens that happened to you, Skaya." He says. "Though, I guess if I looked at it I would just run in like we just did and I can fly out."
20:02 <Skaya> "For fuck's sake. Let's just go," Skaya says, turning back.
20:03 <•Kotono> Rina doesn't argue further, following back along. The heat haze beckons ahead, just as potentially painful for Devar as last time.
20:03 <Devar> "This'll sting, but I should be okay. If I pass out from the heat, I apologize." He says.
20:03 <•Kotono> Rina nods, picking up her step as...
20:03 <•Kotono> roll 5d6 fire damage, only Devar's at any risk here
20:03 <Kobot> Kotono rolled 5d6 fire damage, only Devar's at any risk here --> [ 5d6=11 ]{11}
20:04 <•Kotono> It's not comfortable, but the trip back out is uneventful if singing for Devar. Heading all the way back out now or...?
20:05 <Skaya> "I wonder is this place is related to demons," Skaya muses as she leads the way back to Anne and Sanda. "I'd have said devils but it was supposed to be chaos-oriented."
20:06 <•Kotono> "I'm guessing that's further in?" Rina suggests as you go.
20:06 <Devar> "It might be the other path." Devar offers. "Do you want to investigate that after we recover?"
20:06 <Skaya> "At least we got nice armor and five spears. Maybe some of it would be magical."
20:06 <Skaya> To Devar's question, she responds with a blank, "No."
20:08 <Devar> "I'll identify them." He says. "I've been wondering if Storm can absorb them or something."
20:08 <•Kotono> Back up. The rest of the trip isn't a problem at least, and soon enough, "You're back!" Sanda calls, waving, "How was it?"
20:08 <•Kotono> "Horrible!" Rina calls back. "Deadly!"
20:09 <Skaya> "It was the worst."
20:09 <•Kotono> Anne takes one look at you and pulls out her holy symbol, "And every healing I feel more like a mother comforting her hurt children. Gather around, please."
20:10 <•Kotono> "Did you at least find treasure?" Sanda asks, hopefully, "Odds are you did!"
20:10 <•Kotono> roll 3d6 turn 1
20:10 <Kobot> Kotono rolled 3d6 turn 1 --> [ 3d6=8 ]{8}
20:10 <•Kotono> OOC: 12 total all but Anne.
20:10 <Skaya> "It wasn't very good treasure, I'm afraid."
20:10 <•Kotono> roll 3d6 turn 2
20:10 <Kobot> Kotono rolled 3d6 turn 2 --> [ 3d6=14 ]{14}
20:10 <•Kotono> OOC: 21 total all but Anne, for 33 as a grand total.
20:13 <Skaya> "Thanks, Anne," Skaya says, before sighing. "I think we're at an impasse. It's not impossible to treat this place as a dungeon and plan out how to conquer it, but it would be risky and time-consuming. I estimate 3-4 days at minimum, plus you two would need to jump into some fires. So clearly, the superior choice is to head for what we think is the exit."
20:14 <•Kotono> "I agree," Anne says without any hesitation, "We've been wonderfully blessed to endure this far, but no one can deny how taxing and risky these battles are. To be blunt, we've been pushed to the end of our limits."
20:14 <•Kotono> "I still want that frost sword," Rina immediately disagrees, "And we'll need some way to sneak past Ice, or otherwise not get his attention."
20:14 <•Kotono> A sniff from Sanda, "You've said that the entire time, Anne."
20:15 <Devar> "I don't mind still exploring, but I'm also fine if we want to just get out of here." Devar says. "Sanda, would you help me later look over a few things? I think a few of the items we've found that 'aren't magical' are actually hidden with Magic aura, something I found out down below."
20:15 <Skaya> "The sword, huh. It would be difficult. I don't think we can take on that ice dragon, and anything of that level would be hard to fight, too."
20:15 <•Kotono> "It's still true," Anne disagrees, "There's no shame in accepting the risk isn't worth the reward. Or to know when to quit and walk away rich, rather than push it a nd lose your life."
20:16 <•Kotono> "I'll be glad to," Sanda agrees.
20:16 <•Kotono> Rina half sourly looks at Anne, but shakes her head, "I know, but I still need to be stronger. I need things like that sword and everything we've gotten."
20:17 <Devar> "Would you mind if I looked around for the warm water before we left?" Devar asks. "We might be able to find something there to help with it."
20:17 <Skaya> "Sure."
20:20 <Devar> "So should we get out of here, rest, then look around when we're refreshed before heading back to the frozen city?" Devar asks.
20:21 <•Kotono> You get general nods as...OOC: Okay then, where do yo uwant to rest? Assuming it goes well, going to ID anything while you rest?
20:21 <Skaya> OOC: Wait, why rest?
20:22 <•Kotono> OOC: Because Devar said you were? I fyou want to argue about it, by all means do so. I was just going along with it, don't care either way as the DM.
20:22 <Skaya> OOC: We're just going to ID the stuff from the salamanders and then Devar is going for a swim, right? I think Devar's line is the first that rest was mentioned, I don't think we need it.
20:22 <Devar> OOC: All good, just wasn't sure if we wanted to rest or not
20:23 <Devar> OOC: But as for IDing, Devar will show Sanda the Gold and orange gemstone pendant, not magical - that's the only thing I think might be magical. We'll ID the spears and armor from the salamanders.
20:24 <•Kotono> OOC: Okay, and you want her to spellcraft it to check?
20:25 <Devar> OOC: Yeah please
20:25 <•Kotono> roll 1d20+12
20:25 <Kobot> Kotono rolled 1d20+12 --> [ 1d20=5 ]{17}
20:26 <•Kotono> "It's still not magical," Sanda says, "But as for the spear?" OOC: Loot.
20:27 <Skaya> "I've got to say, I thought it would be a spear of magic missiles."
20:28 <Devar> "Huh. I wonder..." Devar summons Storm's Eye. "Hey, Storm, question - can you absorb or imbue yourself with this, or are you strictly lightning?" He asks, turning to Skaya. "I wonder if there are mages who specialize in that spell."
20:29 <Skaya> "There certainly are, but it's not the best magical path."
20:31 <•Kotono> "There are," Sanda agrees, but Storm's Eye appears. It yawns long before, "Mmm, interesting energy," it says slowly. "Very fiery. Surprised you aren't gifting it to one of your ladies."
20:32 <•Kotono> Anne slowly exhales, very subtly sighing.
20:32 <•Kotono> Sanda eyes the spear, "Ignoring everything else you said, it wouldn't be the worst weapon for me if it wasn't so big. But I'd have to figure out how to use an oversized weapon."
20:33 <•Kotono> Rina sits, arms crossed. "What about Devar's question?"
20:35 <Devar> "I don't want to just start stealing any magic items we come across." Devar says with a smile to the others. "But I figure if we have the option of somehow making him-" He wiggles Storm's Eye a little, "-stronger, we might as well explore the opportunity."
20:35 <•Kotono> Chuckling, "Maybe," it says, "It is awfully spicy, but maybe."
20:36 <Skaya> "Just eat it, then help Devar find a nice shiny sword for Rina under the waves. Then we can try to resolve this messed up place and leave, right?"
20:37 <•Kotono> "Ack, fine, fine," Storm's Eye doesn't argue overmuch about it. "Put me on it?"
20:37 <Skaya> "Wait, wait," Skaya cries, covering her eyes and turning away. "Okay, do it."
20:38 <•Kotono> Rina copies that after a moment, grinning.
20:38 <Devar> Devar goes to lift up Ignisia and makes the spears kiss by holding them together.
20:41 <•Kotono> The spears are combined and - woosh! Flame and light surge up, as the spear crumbles away. Storm's Eye glows and glows, before with a soft tink, a three set of tiny little lightning white gems plop down on the ground. WIth a confused groan Storm's Eye manages, "What was in that spear...?" before vanishing. OOC: Loot. On top of a new ability, it rose from +1 to +2.
20:44 <•Kotono> After a long pause, "So...does that mean Storm's Eye is a girl spear?" Sanda says, sounding confused as she picks up the gems.
20:44 <Devar> OOC: It didn't gain the fire spell bonuses, correct? Just what we know about the gemstones and it being +2 now?
20:44 <•Kotono> OOC: IT did not, no.
20:45 <Devar> OOC: awww
20:46 <Devar> "Huh." Devar hums aloud. "I guess he really does get stronger by absorbing things. I'd say let's try that disease armor, but I don't want him to have to eat that. Do you feel like you got any of your memories back?"
20:47 <Skaya> "Some lower creatures propagate by duplicating themselves, so who knows," Skaya responds to Sanda. At Devar's mention, she asks Storm, "Hey, what if you eat the evil Auril-dedicated pendant? Do you think you'll turn evil?"
20:48 <•Kotono> Neither of yo uget an answer at the moment, beyond a pained groan. Then, "Something about that spear was strange," it complains, "Need to lie down and rest it off."
20:48 <Skaya> "I'll ask tomorrow, then!"
20:49 <•Kotono> "Gem'll...make you resist...lightning..." Is one final set of groans, then Storm's Eye gros quiet.
20:49 <•Kotono> *grows
20:49 <Skaya> "Sounds nice. So! Devar, want to go swimming? No time like the present!"
20:49 <Devar> "I guess he has a small tummy." Devar says as he dismisses it for now. "Oh, right, yeah, if you eat these you can become resistant to lightning. I'm fine with passing since I had to take the spear. Oh, yes, I'll go look around."
20:50 <Skaya> "I've always liked to eat strange things. Ah, Anne, do you mind if I also eat a dangerous fire fruit? Could you save me if it burns me?"
20:51 <•Kotono> Anne takes a long breath, "I'll trade you the gems for not complaining if you eat the fruit," Anne offers. "I'd like to increase my own defenses as well."
20:52 <Skaya> "But what if my nature changes from fire to something else? Then I won't be able to even try eating them!"
20:52 <Devar> Devar will (carefully) get the bowl of fire fruit out. "I'll be back, you all be careful." He says.
21:08 <•Kotono> "Fine, I'll heal you," Anne agrees, "It's your choice." she says in an I don't want to argue about it sort of voice.
21:08 — Skaya happily bites on a fire fruit!
21:09 <•Kotono> OOC: What's your fire resistance, 30?
21:10 <Skaya> OOC: Yes
21:10 <•Kotono> The fruit tastes fine. Strong and spicy, almost like hot cinnamon. It's a wonderful taste, one that warms you up to your core and washes away your pains.
21:10 <Skaya> "Oh wow! Rina, you've gotta try this!"
21:10 — Skaya eats another fruit after finishing this one.
21:11 <Devar> "Well, at least you guys can eat them." Devar says.
21:13 <•Kotono> Rina tries one and lets out a surprised noise, "These are amazing!" she cries, biting down faster.
21:14 <Skaya> "Right? Just washes your troubles away!"
21:14 <•Kotono> Anne watches in quiet amusement, but Sanda keeps the gems as she smiles at it.
21:14 <•Kotono> "I almost feel normal again," Rina seconds, chomping donw.
21:15 <Devar> "Well, you guys enjoy the fruit, I will go look for that lake." Devar says.
21:16 <Skaya> "Have fun, don't drink the water."
21:16 <Devar> "I do not plan on it!"
21:17 <•Kotono> OOC: Okay, what's the plan now?
21:17 <Devar> OOC: I will go scout around flying and see if I can see any particular notable bodies of water anywhere that look like they might be "the warm water"
21:19 <Skaya> OOC: We'll stay and chat in the meantime since only one of us can breathe underwater
21:19 <•Kotono> OOC: Okay, and where are you going to go search exactly, Devar? There's a lot of space here. Around the mountain? Somewhere else?
21:20 <Devar> OOC: He'll try just flying up as high as he can above the mountain and see if he can spot it that way, barring that he'll try north first for a bit.
21:26 <•Kotono> OOC: Okay, #dunes.
