A journey to the Temple of Fiends
Started by Dracos, September 20, 2004, 09:55:11 PM
Helena lapses into mumbles, kneeling down and pressing her hands against the ground..
Olvelsper
Only Craig's elven reflexes saved him as he reacted far quicker than most humans could have as he swept low under the blade. Knowing he couldn't take on this towering menace in a contest of strength, he used his flexibility and speed to slash at Garland's leg before pulling sharply away.
Hearing Helena mumble, he decided to quickly begin poking at the knight's defense to keep him unstable and away from the caster..
http://www.fanfiction.net/u/2589971/Ol%27Velsper : Then we will write in the shade.
Garland, showing the skill of a thousand hard won battles, shifted his legs back just slightly, dodging the slash.
Garland's blade was quick as lightning though, Alex's blade barely getting there in time to help.  It was far more keeping from getting skewered than keeping him on the defensive.
Olvelsper
Regardless, Craig gave it his all as he used Alex's help in forcing Garland away from Helena and Patricia to its utmost. As he contorted and jived from side to side, knives flashing through the damp dungeon air, the pirate used his keen senses to allow him to sneak in a jab here, a slash there. Whenever Garland attacked, he pulled away or helped Alex defend.
A flare of light emnated for Helena's position, and a series of jagged rocky spikes lashed through the grounds of the temple, carving a trail heading straight to Garland!
Aww crap! Craig is in the way!
From his position, Alex pushes off, seeing the jagged rocks coming. Knowing if that they hit is was a good oppourtunity, he plans to make a jumping vertical slash as they hit, to cleave the evil knight in twain!
The ground rumbled as the spikes slowly traversed the range towards the embattled warriors, Craig sidestepped with swift roguish grace as they appoached, breaking into a roll to get out of the way.
Alex, meanwhile, attempted to surmount them and take advantage of the opening they'd provide for the obviously skilled captain of the guard.  Garland didn't get his reputation though from simply being skilled.  He followed quickly with his eyes Alex's motions and leaped up to follow, his blade coming up in a powerful parry that pushed Alex higher into the air, followed by a spinning slash...
Seeing the slash coming, Alex moves to carefully parry it and use the force of that to give Garland a push down. If all goes well, he should land hard and be open for the ones below.
Hopefully.
Grunting, Alex puts all of his bulk behind it! "Grargh!"
Alex's blade clashes hard against the steely warrior's sword, ringing out as they struggle briefly. Garland adjusts, angling himself as he lands hard on the ground flinging Alex back with a hard push against the blade as his feet touch ground.  Unfortunately, their leaps had taken them outside the spikey earth torn area Helena's spell had made.
Helena stops for a moment, and eyes the Dark Orb that hovers with some trepidation.
"Well, I guess it's gotta be good for something," she mumbles, producing her Light Orb. With an overarm throw, she slings it at the dark-magic-thing!
Olvelsper
Craig had made his way behind the two dualing fighters all the while, adding his contribution by attacking Garland while his attention was drawn away from him for a moment.
The light orb flew forth, spinning through the air...
to bang with a noisy crystal clink against the other orb and fall to the ground.
Meanwhile...
Craig got a near-miss on Garland, his blow slashing and cutting into his armor and leaving a sliced open groove, just barely missing slicing deeply into his flesh, before the large man could turn to parry the blow, drawing his full attention as he spun around quickly to attack.
Well, it was worth a shot.
Scooting around the ensuing battle between Alex, Garland, and Craig, Helena tries to get closer to Sara!
Olvelsper
Craig's eyes narrowed as he quickly backpedalled from the knight's furious strikes, occasionally diverting the giant man's attacks testingly as he waited for an opportunity to attack once again.
Helena dashed around the dueling fighters, getting closer to Sara.
