Wolfwood, Mihoshi and Kiyone: Strength in Numbers!
Started by Bean Bandit, December 02, 2002, 01:45:45 AM
Bean Bandit
OOC: M+K
IC:
The peculiar looking robot scuttled over in Mihoshi and Kiyone's direction, stopping directly in front of the pillar.
"Please state your identification code now." it announced, in a pleasant, feminine voice.
calendar
Calendar looked at Cy, then shrugged.  Might as well take this one...
"What happens if we don't have identification codes?"
 Princess_Herb turns into the sexy girl soldier, Sailor_Dragon
*** Princess_Herb is now known as Sailor_Dragon
* Unseen is vaguely creeped out
<Calendar> Only vaguely?
Ginnezumusha
"Errr... you're gonna be alright, ne?  You're not going to double up and throw up when we mow them down, right?  Did you see if what kind of weaponry they possess?"
Bean Bandit
OOC: Wolfwood
IC: With visible effort, Vash shook off his discomfort. "It's nothing. Anyway, each of them has a sensor on their heads, which detect objects that radiate heat." he explained. "And, just under that is a small port that fires a laser...." Vash trailed off, wondering if he'd need to explain that....
Bean Bandit
OOC: M+K
IC:
The robot didn't miss a beat at Mihoshi's question.
"ID codes not recieved, please leave the premises immediately, or you will be removed...."
The head of the robot began to hum ominously.
"...by force."
CyMage
Kiyone decided to pull a Ryoga.  "We're lost.  Could you show us to the exit?"
Ginnezumusha
Bean Bandit
OOC: Wolfwood
IC: Vash drew his gun slowly, leaning against the dune.
"There's five clustered together in a central location, and the other five are making random sweeps." he replied.
Ginnezumusha
"Hmm... if you think you're a better shot, I'll let you pick of all the outer ones, while I mow down the middle ones, ok?"
Bean Bandit
OOC: Wolfwood
IC: Vash raised an eyebrow, but nodded. "Sounds fair. What's your ammunition load?"
Bean Bandit
OOC: M+K
IC: The robot appeared to consider this for a moment.
"Request to leave the premises met with not compliance. Preparing countermeasures...."
The omonous humming grew louder.
calendar
Mihoshi blinked.  "But you said you'd remove us from the premises by force.  What are countermeasures?"
Bean Bandit
OOC: M+K
IC: Mihoshi got her answer, a split second later, as a laser beam erupted from the head of the robot, fired straight at her.
However, by some bizarre stroke of luck, Mihoshi managed to stumble forward, just at that moment, unfortuantely banging her head on the pillar they were behind, but luckily avoiding being beheaded by the laser beam which struck the pillar, and burned through, carving a small groove through the metal, where her head had been moments before, doing no more damage than burning a few hairs...
Noting that in had missed, the robot whirred slightly and began to advance on the hiding place of the two women.
calendar
Oh.  Good answer, really.  Although the robot was being stupidly contradictory.
Mihoshi grabbed Kiyone's arm and ran past the robot, hoping the time it would take the huge thing to turn around would buy them enough time to hide or find a convenient door.
Ginnezumusha
"Well, I got these two .45s, which should have 8-10 shots a piece *Ginn checks on the spot*, and I always have the cross, which has quite a bit of firepower."
