Dragomir Omake
Started by Asrana, May 30, 2002, 06:38:36 PM
Danax
Mike paused for a second "You don't lover her? But I thought...ah well.." He shooke hs head as a smirk appeared on his face "And your damn rights I wanna fight! How are we martial artists gonna improve if we don't fight?"
With that Mike eyes brightened in color until they were a brilliant emerald green. He could feel the psionic energy racing down his limbs, and his smirk gre intoa  grin. "Besides I think we could both use it."
Then Mike was airborn, rocketing at Kei at an insane speed, his right leg tucked in, ready to be lashed out in a brutal side kick.
rnest Hemingway once wrote, 'The world is a fine place and worth fighting for.'
I agree with the second part.
Kwokinator
"What's the point of improving?" Kei looked down. "There's always going to be someone better than you."
"But I never back down from a fight," he smirked.
Breaking out of the Ali Shuffle, he lunged to his right quickly to let Mike whiz harmlessly past him, then delivered a roundhouse at the back of the airborne Mike.
Bean Bandit
Wraith's eyes snapped open as the first faint rays of sun began to peek over the horizon, reflecting off into the still heavy clouds and sending shimmering spears of red across the sky.
Despite the temptation to simply leap out the window and into the trees to continue his journey, He headed downstairs to the dining room to see if he could purchase a small amount of food to tide hime over on the trip...
Danax
Mike spun in the air as he flew past Kei, letting the roundhouse pass harmlessly beneath him, and stuck out a foot, halting his forward movement.
Mike, now firmly on the ground, launched forward firing two quick backhands before dropping down into a heel sweep.
Kwokinator
Kei held his arms high in front of his face to block the backhands, but was caught unaware with the heel sweep, his own arms blocking his visions, and slams onto the ground.
"Grr..." he growled as he pushed himself back up with a handspring, executing a mid roundhouse in mid-air before he landed.
Danax
Mike barely got his arm in the way as kei literally bounced off the ground, and slammed a foot into his side.
"Well shit, you're really good." Was all Mike said as he quickly lifted his right leg and snapped it out twice in rapid sucession, the first at stomach level, the second at head height. Then he quickly rotated his hips and shoulders into an inverted axe kick.
Kwokinator
Kei just smirked without reply.
"What, a snap kick?" he grinned after easily blocking. "You're getting sl-"
He was interrupted by the second snap kick that landed on his temple.  Stumbling slightly to the left, his eyes widened as he caught sight of Mike whipping his foot in an inverted axe kick.
Reaching an arm out to block and grab the kick, he increased the stumbling momentum into a full fall, twisting horizontally in the air for a cockscrew takedown.
Danax
Mike's jaw dropped as he was propelled up and over Kei, spinning hard into the ground. His breath blasted out of his lungs as his back impacted.
Unable to breath right mike simply shot his left foot straight down at Kei's head and face, hopeing to use the move to both injure Kei and roll away.
Kwokinator
Kei grinned as Mike shot his foot out at him.
Locking an arm around Mike's right knee, he reached a hand out to block and then grab onto Mike's left foot, then quickly rolled on the ground, stood up to a squat and spun to almost sit on Mike's behind, pulling the legs back as far as painfully possible.
Danax
Mike barely let out a "Oh shit" before he was flipped onto his stomach, and being forcefully bent into a  horseshoe...backwards.
He gritted his teeth against the pain as his back and legs were being forced beyond there limit. "Oh no you don't!" He thought as he set as he set his palms into the ground, and began flexing against Kei.
He felt the pressure Kei was applying increase as he began to force his legs straight slowly. He pushed as hard as he could against kei, shaking his head and finally opening his mouth and yelling in exertion as he felt several tearing sensations from his lower body, but he ignored the as he forced his body straight again.
He felt Kei give slightly to Mike's counter preassure as Kei's feet slid along the ground. Then Mike was traight enough to spin his upper body and quickly send a pummel into Kei's back, sending him stumbling away.
Mike slowly, and painfull climbed to his feet, the torn tendons obviously affecting him alot. "So you wanna play it that way do you?" Mike said as he drew a quarter circle in the ground infront of him with his right toe, and began tapping his foot against the ground. "Then come on!"
Kwokinator
Kei rolled out of the stumble and spun back towards Mike, then smirked as he noticed Mike's sluggish motion.  His plan worked.
Walking to just beyond the quarter circle, he switched to a southpaw stance, dropping his right into a horizontal hook at his waist and the left hand in a loose fist by his chin in a flicker stance.  Bobbing up and down on the balls of his feet, he began circling Mike, flickering out lightning-quick jabs at his head.
Danax
Mike stood there calmly, doing his best to ignore the pain in his legs, and tapped his right foot against the ground.
Mike simply stood there, tapping, and rotated slightly to keep Kei infront of him, waiting for the first attack. He almost smiled as Kei threw a quick Jab at his head...its was all over.
Mike's foot touched ground and launched towards Kei at insane speeds, hitting the side of Kei's knee before the Jab reached him. Mike then leaned back slightly as his foot danced up and down Kei's body at unbelievable speeds, striking vital, and painfull spots several times each before Kei went flying away.
"No Shadow Kick." Mike whispered as he put his leg down, only to have pain wash over him, originating from his right leg. Mike fell to his ass, clutching his leg, and gritting his teeth in pain. "Ok so that was a really, really bad idea." He thought to himself as he writhed.
Asrana
Seraya, Folkan, and their three guards sat in the dimly lit common room of the inn, apparently waiting.
As Wraith entered, all stood and Seraya stepped forward, "Since it is a long ways to Cebos and we have spare mounts, we were wondering if you would care to join us, Wraith?"
Bean Bandit
Wraith blinked in surprise, considering briefly. Horses would cut the traveling time in half...but he couldn't remember if he'd ever ridden before.
He nodded tentatively.
"Uhm...Thank you, yes, that'd help..."
Asrana
Seraya smiled as her husband chuckled, "No problem, Wraith. I'm sure both you and my daughter are a tad anxious to see each other again..."
