"Destiny Challenged us and so we chose to end the world.  There was nothing to regret.  Nothing."
Deep into the Infinite Stair
Started by Anastasia, November 08, 2019, 02:58:54 PM
Blow after blow tears into the nothingness. You manage to shred it apart, ripping it asunder from top to bottom. It fades away, the way out revealed again. The air hums low, heard faintly beneath the icy winds coming against you all the while.
No many moments needed. Anything else for your turn?
Alicia follows that up by sending a bolt of divine lightning at the guardian to signal her displeasure!
Quickened/maximised/vivacious moonbow.
[17:56] <@Ebiris> roll 3#1d20+60 ranged touch
[17:56] <Penuche> Ebiris invokes Penuche's magic: < 62, 78, 66 >
[17:56] <@Ebiris> roll 1d20+47 SR
[17:56] <Penuche> Ebiris invokes Penuche's magic: < 58 > [d20=11]
Each hit does 60 divine damage.
Alicia HP: 889/1044
Active spells: Extended mind blank (CL 35), extended nondetection (CL 35), greater heroism (CL 34), sensual blessing (CL 34), recitation (CL 34), righteous wrath of the faithful (CL 34), foresight (CL 34), extended spell turning (CL 35), extended freedom of movement (CL 35), keen edge (CL 34), repelling shield (CL 34), extended ray deflection (CL 35), greater visage of the deity (CL 34), many moments of prescience (CL 34), Seira's arcane thesis (CL 34)
Defences: AC 97, CMD 137, spell resistance 49, energy immunity (fire and cold), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 49)
Stat buffs/penalties: +4 morale skills, +25 competence perception, +3 luck AC/attack/saves, +2 insight AC/reflex, +9 shield AC, +36 str, -2 dex, +20 con, +2 int, +4 wis, +4 cha, +15 natural armour, -8 size, +10 morale attack/damage, +8 morale saves, +8 dodge AC, +5 spell DCs, +10 SR checks
Perceptions: Arcane sight, perception +82
Sorcerer spell slots: 6/16/16/11/8/9/12/9/8/5/7/7/5/3/2
Duskblade spell slots: 6/23/23/19/11/7/8
The moonbow flies well - but the wind deflects it at the last minute, the ranged attack blown aside.
Do you have anything that would prevent this, like a power or anything? I don't think so, but enough moving pieces that I'll check real quick.
No, ranged attacks aren't really Alicia's thing.
Jessica barrels forward at this, coming at the icy foe before her in a deft blur, gliding over the ground. She goes to meet it head on, not allowing a single chance for matters to go wrong.
> roll 1d20+66 (+13 various)
<Penuche> Kotono invokes Penuche's magic: < 76 > [d20=10]
> roll 1d6+42+23d6
<Penuche> Kotono invokes Penuche's magic: < 122 > [d6=2,2,6,4,3,5,4,2,2,4,1,2,2,4,4,3,4,4,3,1,4,5,6,3]
Jessica stabs out, a blow into your foe's arm. It draws icy blood as the Queen calls, "Be stronger!"
Spell of Queen's Might. +8 morale Strength both of you.
The frozen woman reaches out for Jessica and...
> roll 1d20+56 touch AC Jessica
<Penuche> Kotono invokes Penuche's magic: < 65 > [d20=9]
> roll 44d12+44
<Penuche> Kotono invokes Penuche's magic: < 314 > [44d12=270]
An icy touch - Jessica begins to shatter, frozen, but the ice melts. She is bloodied all over, cracks all over her, but not broken. The little leaves all over her warm her up, stop a worse fate.
Go. Wasn't ID despite appearances, but it's still nasty.
[spoiler]
Jessica
HP: 359/653
Negative Conditions:
Aura: Telepathic Block 20ft (Stops telepathy/summons) Magic Circle Against Evil 10ft (Protection from Evil)
Bonuses: Attack+13 (+10 morale, +3 luck), Damage+10 (+10 morale) AC+13 (+8 dodge, +2 insight, +3 luck), Saves+11 (+13 Ref) (+8 morale, +3 luck), Skills+4 (+4 morale), Checks+0 Extra attack as if hasted.
Resources: Defensive Roll 1/1 Plane Hop 1/1 Superior Invisibility 3/3 Ghost Form 3/3 Shadow Form 2/2
Spells Used:
SLAs Used:
Spells Active: Recitation(CL34), Righteous Wrath of the Faithful(CL34), Foresight(CL34), Freedom of Movement(CL34), Greater Heroism(CL34)
Notes: +4 bonus to people who flank with her instead of +2.
Inspire Courage, +10 morale to attack rolls, weapon damage rolls and saves vs fear. Inspire Heroics, +8 morale to saves and +8 dodge to AC.
#545
It still seems perfectly vulnerable to melee, so Alicia surges over to join Jessica while she summons several devas to heal her sister!
Quickened lightning leap to get into melee, quickened SMX to summon 1d4+1 hollyphants.
[18:38] <@Ebiris> roll 1d4+1 hollyphants
[18:38] <Penuche> Ebiris invokes Penuche's magic: < 5 > [d4=4]
"You heal me, the rest heal her!" she quickly orders them before attacking with a flurry of now fiery sword-slashes!
4 heals on Jessica for +600 hp, 1 heal on Alicia for +300 hp (since she has sensual blessing to double it)
[18:42] <@Ebiris> roll 1d20+88 flanking, blinding speed, 6th level arcane strike, channelled maximised/vivacious combust
[18:42] <Penuche> Ebiris invokes Penuche's magic: < 92 > [d20=4]
[18:42] <Penuche> Ebiris invokes Penuche's magic: < 91 > [d20=3]
[18:42] <Penuche> Ebiris invokes Penuche's magic: < 105 > [d20=17]
[18:42] <Penuche> Ebiris invokes Penuche's magic: < 101 > [d20=13]
[18:42] <@Ebiris> roll 1d20+83 flanking, blinding speed, 6th level arcane strike, channelled maximised/vivacious combust
[18:42] <Penuche> Ebiris invokes Penuche's magic: < 90 > [d20=7]
[18:42] <Penuche> Ebiris invokes Penuche's magic: < 84 > [d20=1]
[18:42] <@Ebiris> roll 1d20+78 flanking, blinding speed, 6th level arcane strike, channelled maximised/vivacious combust
[18:42] <Penuche> Ebiris invokes Penuche's magic: < 98 > [d20=20]
[18:42] <Penuche> Ebiris invokes Penuche's magic: < 88 > [d20=10]
[18:42] <@Ebiris> roll 1d20+73 flanking, blinding speed, 6th level arcane strike, channelled maximised/vivacious combust
[18:42] <Penuche> Ebiris invokes Penuche's magic: < 85 > [d20=12]
[18:42] <Penuche> Ebiris invokes Penuche's magic: < 86 > [d20=13]
[18:42] <@Ebiris> roll 1d20+88 crit check
[18:42] <@Ebiris> roll 1d20+78 crit check
[18:43] <@Ebiris> roll 6d6+48+17+2d6+6d4+80+3d6 last 3d6 is holy, 17 is fire, 80 is divine
[18:43] <Penuche> Ebiris invokes Penuche's magic: < 203 > [d6=2,1,5,3,6,3,6,6][d4=3,4,4,2,3,1][d6=2,6,1]
[18:43] <Penuche> Ebiris invokes Penuche's magic: < 185 > [d6=2,3,1,1,1,4,4,5][d4=3,1,3,1,1,1][d6=5,2,2]
[18:43] <Penuche> Ebiris invokes Penuche's magic: < 201 > [d6=3,1,5,2,1,3,2,6][d4=4,4,3,3,3,4][d6=5,3,4]
[18:43] <Penuche> Ebiris invokes Penuche's magic: < 196 > [d6=1,4,1,3,1,5,2,3][d4=4,4,4,1,4,2][d6=4,4,4]
[18:43] <Penuche> Ebiris invokes Penuche's magic: < 206 > [d6=6,2,6,5,3,2,6,4][d4=3,2,2,1,4,4][d6=4,5,2]
[18:43] <Penuche> Ebiris invokes Penuche's magic: < 203 > [d6=4,3,5,4,3,1,3,4][d4=4,2,2,3,3,4][d6=1,6,6]
[18:44] <Penuche> Ebiris invokes Penuche's magic: < 191 > [d6=6,1,1,1,4,2,2,6][d4=4,3,1,2,2,1][d6=4,1,5]
[18:44] <@Ebiris> roll 6d6+48+17+2d6+6d4+80+3d6 last 3d6 is holy, 17 is fire, 80 is divine
[18:44] <Penuche> Ebiris invokes Penuche's magic: < 191 > [d6=1,3,6,4,3,1,1,5][d4=2,1,1,2,3,2][d6=4,6,1]
[18:44] <@Ebiris> roll 12d6+96+34+2d6+6d4+160+3d6 last 3d6 is holy, 17 is fire, 80 is divine if 105/101 is a crit
[18:44] <Penuche> Ebiris invokes Penuche's magic: < 363 > [d6=4,3,3,6,6,5,4,3,6,1,6,1,3,6][d4=1,1,1,1,4,2][d6=2,2,2]
[18:44] <@Ebiris> roll 6d6+48+17+2d6+6d4+80+3d6 last 3d6 is holy, 17 is fire, 80 is divine if it isn't
[18:44] <Penuche> Ebiris invokes Penuche's magic: < 193 > [d6=3,6,1,2,1,6,4,3][d4=1,1,1,2,4,2][d6=5,1,5]
[18:44] <@Ebiris> roll 12d6+96+34+2d6+6d4+160+3d6 last 3d6 is holy, 17 is fire, 80 is divine if 98/88 is a crit
[18:44] <Penuche> Ebiris invokes Penuche's magic: < 357 > [d6=3,1,1,2,1,5,4,4,5,3,3,3,1,6][d4=2,1,1,4,4,1][d6=4,2,6]
[18:44] <Penuche> Ebiris invokes Penuche's magic: < 194 > [d6=1,5,5,5,2,1,2,2][d4=3,4,2,3,4,1][d6=3,2,4]
+4 attack and damage on all of those. Forgot to add Queen's latest buff in.
Alicia HP: 1044/1044
Defences: AC 97, CMD 141, spell resistance 49, energy immunity (fire and cold), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 49)
Stat buffs/penalties: +4 morale skills, +25 competence perception, +3 luck AC/attack/saves, +2 insight AC/reflex, +9 shield AC, +36 str, -2 dex, +20 con, +2 int, +4 wis, +4 cha, +15 natural armour, -8 size, +10 morale attack/damage, +8 morale saves, +8 dodge AC, +5 spell DCs, +10 SR checks, +8 morale strength
Sorcerer spell slots: 6/16/16/11/7/9/11/8/8/5/7/7/4/3/2
Quick Fort save, Alicia.
[spoiler]
Jessica
HP: 653/653
Spells Used:
SLAs Used:
Notes: +4 bonus to people who flank with her instead of +2. +8 strength in case it matters, but she's dex based.
[18:53] <@Ebiris> roll 1d20+83 mettle
[18:53] <Penuche> Ebiris invokes Penuche's magic: < 98 > [d20=15]
With blade and might, Alicia cleaves apart the foe. Snow and blood are sent down as she slices - and for a moment, as she falls, all the cold in the multiverse feels focused on her. Yet the feeling subsides and you stand firm. All of you are together now, the sky above dark and empty - save for one distant star, radiant.
"Continue," The Guardian intones. "Continue to try and survive. You have not yet impressed me."
Init is Alicia (Supreme Init) > Jessica (38) > Queen (36) > Star (35) > Jessica (25)
Anything else on your turn now, Alicia?
Jessica gazes up, "Now the heavens themselves rebel against us," she says, "Sister, can you speed us along?"
"We'll make it," Queen says, "We'll make it, this time I'll prove it to you, Guardian!"
More than 3 miles, the limit of your divine vision.
"Lets see if this works again..."
Space compression to link a spot between us with one 3400 feet up.
It's not your turn yet, Jessica's just asking if you plan to use space compression so she can stay put if needed. She'll hold if asked.
