Floor 1 "Wheel": 1-2
Sacchin squints towards the top of the crushers to check if it would be strong enough to walk or clamber across.
The top of the crushers are sloped but they're made of metal. It looks possible, but balancing atop them would be a trick.
Sacchin glances even higher to see just what's suspending the crushers above the ground.
The crushers have a single linked chain suspending them up, going up too high and into the mist to tell what it connects to.
Following that, Sacchin tries to identify any segment of the platform that seems different to the others, whether raised slightly off the ground or something like that.
* Hatbot --> "KotonoIbis rolls 1d20-1 spot seems relevant and gets 9." [1d20=10]
The two crushers and the ground beneath them don't look altered or out of sorts at all. Sacchin doesn't see anything like that.
#156
"Do you think you could swing one of those things if you had enough time?" Euphemia asks their tagalong, indicating the crushers. "Or, alternately, cut through the chain suspending one of them if you borrowed a sword from us?"
She considers her options further. "If all else fails, maybe we could get a rope around that linked chain and just climb over this obstacle."
"Maaaybeee...." Hesitating as he looks up, "It's daaaaaaangerous....." He flutters here and there, vacillating.
"Oh, fie on danger!" Flasheart declares heartily. "You can fly around the sides so it's not as if the crusher can come down on you, and if any of those flying snake faces come along you can be sure they'll be shot away before they can hurt you!" he tries to encourage their little friend to do the right thing.
<Kobot> Kodinner rolled 1d20+21 --> [ 1d20=20 ]{41}
Well.
The steamy flier flutters about, listening to Sir Flasheart's rousing words! "Ooooohhhh all riiiight. Whaaaat do you waaant me to doooo?"
"Take that big sword of Sacchin's there and see if you can cut through those weak looking chains holding the crushers up," Flasheart instructs. "Then we can just walk right over the top of them."
Sacchin hugs the sword protectively. "This for people, not things," she says, firmly. Then she pulls out a crowbar from... somewhere instead. "This for things, not people."
"Sssssssssswooord tooo biiiiig for meeee," The steamy one agrees, taking the crowbar heroically! He sags in the air as he holds it, but he slowly begins to fly up towards the top of the crushers! Wobbling in the air he takes a swing at the chain! The crowbar clatters against the steel as he wobbles, nearly losing his grip! He swings again and again - the sound of metal on metal! However, the crowbar doesn't seem to have enough oomph to do the job. The crusher swings a bit back and forth, but the chain isn't seriously damaged.
"Well, if that's not going to work..." Flasheart takes out a length of rope from his pack and tosses one end on top of the crusher. "Here, little chap! Tie one end of that around the chain so we can climb up and walk over the top of those things!"
<Kobot> Kotono rolled 1d20+1 --> [ 1d20=6 ]{7} use rope?!?!?!?!?!?
The little flying steamer does just that! He takes the rope up and ties it to the top of the crusher ten feet above, the chain carefully knotted!
