Floor 1 "Wheel": 1-2
With a bunch of wiggling and scraping of armor against stone, Sacchin reaches the bag! She can brace against the walls and grab it if she so desires!
Does the chimney still go up?!
The chimney goes up another one hundred feet. At the edge of your vision, you can juuuuuuuuust make out what looks to be a metal grating blocking off...something. You can't see from here.
For the time being, then, Sacchin simply tries to grab the bag with one hand, hoping her legs and other arm can keep her steady!
This is quite easy! The bag is gotten! Ooooh, it's a bit heavy, like something worthwhile is in it!
Sacchin shakes it a little and tries to peer inside!
There are two things inside. One is a dark, smoothly polished stone. The other is a steel plated key.
Pocketing them should be simple enough, and then Sacchin faces the daunting prospect of trying to climb towards the grate at the top- although that might be impossible (and in the end it may all be for nothing.)
As Sacchin begins to climb, she feels funny. She feels heavy, very heavy. Like she's carrying a huge load on her back. It makes climbing slower, though not impossible at about half of her previous rate.
She must be tired. It's not unreasonable, and she continues trying to reach the very top of the chimney!
It takes a lot of time and effort, but Sacchin reaches the top! A thick, well made mesh grating blocks further progress. As Sacchin's muscles strain to keep her up, she can peer past it. She can see nothing but darkness, an inky black darkness.
Sacchin pounds on the mesh a couple of times, hope fading as she realises it's probably well-made (where's shoddy craftsmanship when you need it?)
It's every so slightly loose to a weak pounding. Perhaps, just perhaps if you hit it hard enough...!
Sacchin is certainly willing to try bashing it harder!
* Hatbot --> "Ko-KurseofKo rolls 1d20+2 STR SACCHIN STR! and gets 8." [1d20=6]
Sacchin hits it! It doesn't budge to this attempt!
