The Gossip Board
Started by Dracos, November 23, 2009, 05:02:20 PM
0 Members and 13 Guests are viewing this topic.
(Do it. You don't want her to stab you all in your sleep.)
VySaika
Status updated, marking off the Make Whole I grabbed already and casting it on Kam's boots.(Boots is what you wanted first, yes?)
All About Monks
<Marisa> They're OP as fuck
<Marisa> just by being monks
Yes. :) Thanks.  The others are all a bit more durable (Not that I don't actually have enough for a full day of castings of make whole, but that can happen when we get back)
Level up time! Everyone post what class they're taking and post HP rolls.
Nik, I need to talk to you. You're getting an LA+0 template(Necropolitan) and I want to go over that before you level up. Tomorrow.
Kam is going to be totally mysterious.  He'll strike out far into unknown, picking something totally unexpected.
Another level of Champion of Gwyharwyf.  Yeah, like there's any reasonable other choice for advancement anymore for him.
Nik, keep a copy of your old character sheet handy in case your condition changes. Save it on the board somewhere, say.
Nikkolai is being transformed into a necropolitan. This is a template that makes you one of the living dead, a cursed creature to life without life for all eternity. This has the following effects on Nikkolai:
1. Nikkolai's type changes to undead(augmented humanoid). This type gives Nikkolai several benefits and drawbacks.
- No constitution score. In effect your con is 0. This means you have no modifier to your hit points, just the base hit dice.
- Darkvision out to 60 feet.  http://www.dandwiki.com/wiki/SRD:Darkvision
- Immunity to mind-affecting effects, poison, sleep, stunning, paralysis, disease and death effects.
- Immunity to critical hits, nonlethal damage, fatigue, exhaustion, ability drain and energy drain. Immune to ability damage to your three physical scores. Ability damage to intelligence, wisdom and charisma functions as normal.
- Immune to any effect that requires a fortitude save, unless it works on objects, is harmless or specifically works on undead.
- You use your charisma modifier in place of your constitution modifier for concentration checks.
- When you are reduced to zero hit points you are immediately destroyed. You have no buffer zone of 0 to -9 hp.
- Not effected by raise dead or reincarnate abilities.
- Undead do not breathe, eat or sleep.
2. All of your hit dice become d12.
3. You gain the following special qualities:
Resist Control (Ex)
You gain a +2 profane bonus on will saves to resist Control Undead and similar spells.
Turn Resistance (Ex)
You have +2 turn resistance.
Unnatural Resilience (Ex)
Nikkolai recovers health by resting at his normal rate, as well as ability damage. However, the heal skill has no effect on him. Further, positive energy spells such as cure light wounds do not heal him. They deal damage instead. Negative energy spells like cause light wounds heal Nikkolai instead.
4. As your hit dice have changed, you now reroll all of them. Your first hd is maximum, the rest are rolled again. So you'll go into #elysium and roll 10d12+12 and that's your new HP score. Remember you have no constitution modifier to add to this.
5. Once you've done all that you'll level up as per normal.
Yulia gains 2 levels up for being behind. Beginning now.
> roll 2d8 Yulia
* Hatbot --> "Kotono rolls 2d8 Yulia and gets 13." [2d8=7, 6]
Max HP is now 50. Lucky her.
BAB increases by 1. Archery attack rolls are +17, she's pretty competent and shooting shit for a courre.
All saves rise by +1.
5*2 SP to spend, 10 total. Yulia purchases 5 ranks of Knowledge: Religion...what what? Favored Souls don't get K:R? I'll houserule that since that's intensely retarded.  The other 5 go into heal.
Yulia takes touch of healing for her level 6 feat. Works for me.
Yulia gains energy resistance 1 type. She chooses fire to round out her defenses nicely.
Yulia gains second level spells! She gains 1 0 level spell, 1 1st and 3 2nd. She takes create water for the orison and the rest are TBD.
VySaika
Sacred Fist, obviously.
Got a 1 on hp, rerolled it into a 2. Again.
Bunch of stuff went up, though namely got SACRED FLAMES and third level spells including FELL THE GREATEST FOE. Adail has real damage now! Went over all this in PM with you, can copy/pasta that here if you want I suppose.
Leaving his feat slot empty for the time being.
All About Monks
Sierra
Mari is going to spend some of the enforced downtime reading the book Balance gave her.
The exercises increase Mari's endurance! Her con score rises by 1.
VySaika
Adail will follow suit, since there's not much else to do there.
All About Monks
Adail gains wisdom from his reading! His wisdom rises by 1 point!
Mari, you can remove the pre-req of endurance from master of forms.
Sierra
Noted, and HP roll for the record.
* Hatbot --> "MariofManyForms rolls 1d8+4 and gets 7."12 [1d8=3]
Oh wow, I totally forgot the book.   *goes to see what book he was holding* I'll read that too.
Yeah, I'll read my charismatic book of Doom~.  DOOM FOR THE DOOMBRINGING!
*waits before modifying sheet*
Yeah leveled up last night.
I guess since its downtime we should probably divide that small treasure sitting over in the other thread.  I'll raise it over there.
Also, Woot to see our cleric Courre is improving.  We will need it.  Damn lich and her strategy to use Nikkolai as recruitment bait. :P
Double Woot to see Adail suddenly master dangerous fiery arts.  We are a vicious offense driven force.
Also, Adail, I request 2 Make Whole castings?  :)  For Armor and Shield.
