Sylvie reaches level 21!
- Factotum 21 and Chameleon 11.
- 2 on a d8 for a total of 10 and a grand total of 278 hp.
- +1 BAB for 21 BAB.
- Caster level for arcane dilettante rises to 21.
- Sylvie gains a 5th and 6th level chameleon spell slot and her caster level rises to 21. She'll grab Wall of Force and Disintegrate for arcane and Spell Resistance and another Heal for divine.
- No change to saves.
- Skills go up as normal.
- Epic Spell Capacity(21) as her feat. I forget if she needs it with Chameleon but I'm assuming she does. I'll check my notes for the epic progression since it doesn't mention it in the custom material post.
Massively underwhelming level for her. No surprise, it was expected.
Remind me: Saves don't rise after 20, right?
Yes they do! Read the house rules! =p
Lazy turtle! =p
Saves go up at 23 and every 3 levels. You gain +1 to each save at 23, 26, 29 and so on. Pre-epic save progressions aren't used any more.
Tepen reaches level 21!
- Wizard 21 and Factotum 1. The Factoti are spreading. Terrifying!
- 5 on a d8 for a total of 13 hp and a grand total of 236 hp.
- Gains 2 points of inspiration.
- Gains cunning insight. This is the mechanical draw of taking the class, letting him boost his saves in an emergency.
- Gains cunning knowledge. +1 to a skill check is exceedingly mediocre, but every little bit helps.
- Tepen gains the casting of a 21st level wizard. He gains 1 10th level spell slot plus 1 bonus 10th level spell. He'll grab Vitrification Bombx2 for now, custom material later.
- Saves do not increase.
- Skills go up as normal, except for putting a point into disable device instead of concentration. Tepen's expanding his skill base this level.
- Epic Spell Capacity(21). No surprise here.
Okay level. Taking Factotum reflects that Tepen has access to an absurd amount of knowledge in Aurora. He can learn from an incredibly well stocked library or powerful masters of almost any art he can dream of. Gaining some experience in a class that emphasizes cross-training and being able to do anything makes sense from there.
Adrian reaches level 21!
- Dragon Devotee 5 and Fighter 11.
- 2 on a d10 for a total of 11 and a grand total of 314 hit points.
- +1 BAB for a total of 21.
- Spell resistance rises to 32.
- +2 Strength from Dragon Devotee, for a total Strength of 32. Any level where he gains Strength is a good one.
- The rest of the draconic creature template. This boosts his darkvision to 120ft and gives him a +2 bonus to spot and intimidate.
- Adrian gains 2nd level sorcerer casting. He gains a 0 and 1st level spell charge and a new 0 level spell known. He selects Amanuensis since why not?
- No change in saves.
- Great Strength(21) as his new feat. Yay, more Strength!
+4 Strength on a fighter-type is always an excellent level. Everything else is just icing.
Misalea reaches level 21!
- Arcane Duelist 11 and Sentinel 9.
- 1 on a d10 for a total of 5 and a grand total of 181 hit points.
- Enchant chosen weapon rises to +5.
- Epic Divine Might(21) as a new feat. She needs the damage boost.
Eh level. I'll probably straighten out her sheet and maybe do a rebuild soon.
This spell has been developed by Tepen and Vul'lath to aid their studies. Tepen will replace a Vitrification Bomb with it.
Bibliotheca Arcana
Divination
Level: Clr 10, Sor/Wiz 10
Components: V, S, M
Casting Time: 1 minute
Range: Personal
Target: You
Duration: 24 hours
You establish a connection with the platonic ideal of a library and fill your mind with lore. You gain a +15 insight bonus to all knowledge checks and may make knowledge checks untrained. This knowledge extends to knowledge of your own life. You you have perfect recall of your own memories for the duration of the spell. Effects that change your memories, such as modify memory or mindrape, are suppressed for the duration of the spell. You gain the ability to read and speak all languages during this time, as if affected by a comprehend languages and tongues spell. Finally, you may instantly absorb the information of any written material you touch, as if by a scholar's touch spell. For the duration of the spell, you have perfect recall of the material read in this manner.
Material Component
A miniature book.
The material book should be a little black book. Just saying.
Quote from: Merc on August 18, 2013, 12:07:31 AM
Not quiiiite the connotations I want, kitty.
Oh come on! It totally is!
Is not! Bad! Bad! There's nothing remotely sensual about the spell!
You realize, little black books are also used to keep blackmail material right? It's not -just- for girls phone numbers!
Less that and more that I associate it with the Heidi Fleiss scandal and her little black book.
I have no idea who that is! Even after wiki'ing it, as I kinda didn't stick around to read the article in full!
But fine, what about a complete set of encyclopedia brittanica then? =p
