Quick check: You're going to be alive tonight, Yuth?
Also we have storms rolling in. Just heads up if I'm late. First storms of the season.
Yes. Alive and headed right for you. I am the storm.
Quote from: Yuthirin on April 25, 2014, 08:25:12 PM
The Oncoming Storm?
So Merc may be joining us. Yay! A few notes, all assuming this goes through. It looks like it as of now.
1. Go ahead and move a copy of Ithea to this topic: http://www.soulriders.net/forum/index.php/topic,102879.0.html Keep the end of B3 Ithea sheet pristine in PC sheets and make any changes to the copy. Merge your spells into there from the spells topic.
2. Level up to 22 and post a quick summary of your level up. If you need to make any changes or retraining, now's the time. Ditto with purchases, in case you have some money to blow. Likewise, if you need custom material or help, talk to me and we'll hash something out.
3. If Merc desires, I'll run a combat demo for Ithea. This is just to shake off the rust and get back into the flow of things.
4. The party may wish to consider what tactics Ithea brings to the table. Her current build is: Spellwarped 3/Catfolk 1/Rogue 13/Factotum 4//Duskblade 21. Ithea traded sneak attack for fighter bonus feats, so expect a duskblade styled gish with some factotum tricks and rogue versatility. She uses a glaive, so reach and AoO shenanigans are also a go.
Also, quick hit: Lief, if I deny you SA and mention the enemies aren't flatfooted, ask me if they can see invisible. You should have gotten it against the mirror wolverine twins, but I flat fucked up.
Quote from: Anastasia on April 27, 2014, 03:15:38 AM
Roger. I'll try to remember that.
Ithea Level 22 Summary
Levels: Duskblade 22 // Factotum 5
HP: d8 = 8 (+9 from con: 293 HP > 310 HP)
BAB: Improves to +22
Saves: Nothing new.
Epic Feat: Nothing new.
Racial abilities: +1 SR
Duskblade abilities: Learn Prismatic Touch (level 5 spell). +1 CL
Factotum abilities: Arcane Dilettante improves (can cast level 2 spells now), +1 Inspiration, Gain Opportunistic Piety.
Skills: +16 skill points.
Rukkig:
HP: Improves to 155HP
Saves: Nothing new.
Familiar abilities: +1 SR
Skills: See Ithea
Sheet still needs to be updated/posted in CODA.
Also, I never updated sheet gold for the loot from the slaad dungeon. I'll need to see if there are any gear updates to be made.
Quote from: Merc on March 31, 2013, 11:46:03 PM
Total should be 1109682. You were off by 20 gold. >_>
[21:36] <Merc> I could, I guess? Are any of them interested in anything in particular? I was going to recommend the painting go to Aurora itself, just get hanged somewhere useful. I wasn't particularly interested in anything else myself.
[21:36] <Kotono> Not particularly, no.
[21:36] <Kotono> They'll go along with the painting suggestion.
Total is now 1,044,682 gold.
Split four ways, that's 261,170.5 gold each (Balyss/Sylvie/Simmer/Ithea).
Current Wealth: 13,549.97 gold + Split: 261,170.5 gold = New Wealth: 274,720.47 gold
Everything looks good.
What level 2 spell did you grab for Arcane Dilettante?
How much does Opportunistic Piety heal for you?
I haven't checked what level 2 spell to get yet. Currently I'm keeping old defaults of Nerveskitter and Scholar's Touch. I'll replace Scholar's Touch when I figure what level 2 spell to pick.
OP can be used 9/day, and will heal for 20.
Announcement time.
For all further downtime, away and late posts, use the relevant topic. Since we're back up to three people, I'd rather keep those separated again. I was letting it ride before, but now I'd prefer a bit more organization. Speaking of, there will be a post there shortly.
http://www.soulriders.net/forum/index.php/topic,101749.0.html
CODA sheet has been posted. Ithea turned 20 while she was between B3 and CODA, because why not.
Yulia
HEY LISTEN!
Ithea, have you done any log reading yet?
