Quote from: Corwin on December 12, 2015, 05:43:54 AM
Quote from: Anastasia on December 11, 2015, 11:06:03 PM
Quote from: Merc on December 11, 2015, 11:00:24 PM
Can we make things faster in any way?
Not really. There's a tremendous amount of grunt work and spell casting to be done.
Can we upgrade several things in parallel? I can't recall if we ever did.
One project at a time, as I recall. I'd have to check, could be wrong.
Ah, really? So we can only do one any thing. Ah well.
Arrel reaches level 21!
Leftovers from last level:
- Arrel selects toughness as his F6 feat. He retrained the freed up level 9 slot into improved flyby attack.
- Giant Eagle 12 and Aerial Avenger 11.
- 6 on a d8 for a total of 14 hit points and a grand total of 332 hit points.
- +1 BAB for a total of 19.
- +1 spell resistance.
- Momentum increases to +4.
- Darkvision improves to 120ft.
- Damage reduction becomes 10/adamantine and epic.
- Energy resistances increase to 20.
- No change to saves.
- Skills go up as normal.
- Visions of the Skies(21) as his feat. Yes, he'd like blindsight 120ft.
Okay level. Blindsight makes it a winner.
Quote from: Merc on December 12, 2015, 01:32:54 PM
If you wanna check and find out I'm wrong - I might be - feel free.
Arrel reaches level 22!
- Giant Eagle 13 and Aerial Avenger 12.
- 3 on a d8 for a total of 11 hit points and a grand total of 343 hit points.
- +1 BAB for a total of 20.
Hello filler level. 22 is such a filler level for almost everyone.
Quote from: Anastasia on December 12, 2015, 01:37:42 PM
Honestly, I'm not even sure where to begin searching for that. I'd rather just assume that you're right, and that other times that we've done a lot of upgrades at once its been because we haven't been on the clock.
Mirajane's spells are up. The cleric spells are a blend of Hanna and Jaela's spell lists, as is only fitting for grandmother and mother. Her sentinel spells are a placeholder for now. She'll select a proper set later.
Let's just focus on this:
Create Worldmeet Glade: 75,000 gold; 3 DC 40 K:N checks; 1 DC 35 K:A&E check; 5 days.
I'll post about the people who have good K:N and K:A&E bonuses.
Sure, get that in order real quick.
Quote from: Corwin on December 12, 2015, 02:26:36 PM
Okay, so there's a snag explaining why we don't actually build some things. Only Tepen, Sylvie and I can actually roll K:A&E and only Tepen can do it without magic. Luckily, I'm at a point where I can cast the spells daylong. I presume so is Sylvie if she focuses on it. No one to aid, but DC35 is doable anyway.
K:N is far easier. I'd suggest Queen Ilsenine did it to honor Muirfinn (and because she has the best mod and because it's an enchantment awesome for fey and her personal involvement might just finally push them to 100). Misalea, Crystal and Finnegan have high enough K:N to aid and are idling at the Aurora for now, so two of them could do it.
Thoughts, PCs?
Ithea's got K:A&E as well actually, her modifier is +22. If she can add inspiration (forget if we can or not), then its +28.
Not sure how it compares to Sylvie's modifier since it looks like it's a Jack of All Trades skill for her. Probably Ithea is higher without inspiration, while Sylvie's should be higher with it.
Yeah, my bad. I only combed the NPCs, though I do know my own skills!
I'd like to confirm that Refreshment (Book of Exalted Deeds) works not just on others, but also the caster. It says it's a burst centered on the caster so wanted to double check.
