Yes, I just forgot to change over that part. I copied the format of the last one - most serial books like that do that to a degree. The Lost Lore of the Abyss ones come to mind, though that's also since a rigid order helps contain the chaos within them.
Sylvie is the queen of making good choices.
Mental note: I revised voice of the triune over in rules and setting's homebrew topic. Adjust Mei up to compensate.
The Master reaches level 22!
- Monk 21 and Battle Dancer 11.
- 3 on a d8 for a total of 9 hit points and a grand total of 295 hit points.
- +10ft to movement speed for a total of 120ft land movement speed.
- Stunning fist DC rises by 1 to 35, another daily use as well.
- Wholeness of body rises to 42/day. Truly worthwhile.
- +1 spell resistance for a total of 31.
- AC bonus from battle dancer rises by +1.
- Gains dance of the furious unicorn. It's a charge doubler so it's quite good.
- No change to saves.
- Skills go up as normal.
Solid level. The charge booster helps, though he's mainly a defensive brick still.
Note to self: Remember to add Stille's PW1 feat.
Quote from: Yuthirin on December 16, 2015, 01:47:02 AM
She's talented at everything she does, even when it would be better if she wasn't.
I'd say that means wisdom is her dump stat but her sheet says its actually strength. Its a close second though!
She's not nearly wise enough for her level of talent. Few people would be. Too much talent can be as much of a curse as too little.
She should've stuck with the mascot business and kept clear of adventuring!
She'd likely be far happier at least. Having an epic destiny doesn't mean it's the most fulfilling destiny.
In another tangent, Adrian's finally settled into his role of general. He'd done that in his previous Coda appearances and he's running with that. It has been his goal for awhile, so nice to see that working out.
Calleigh will do her best to unsettle him.
He's working on giving no fucks right now, so good luck.
Just to double check, does Cloaked Casting also affect my wizard spells?
I checked. RAW it doesn't specify and just says spells. There's no errata on the issue so it's a DM call. An article related to the beguiler adds that it works only for beguiler spells, but this isn't a source I put all that much stock into. Let me sleep on it and ask again tomorrow, need some time to think about it.
http://archive.wizards.com/default.asp?x=dnd/errata <-- That has PHB2 errata, if you want to grab official errata.
Here's the wording I saw in the book myself (and didn't see any changes here from errata either):
Cloaked Casting (Ex): Starting at 2nd level, a beguiler's spells become more effective when cast against an unwary foe. You gain [...] At 20th level, you become able to automatically overcome the spell resistance of any affected target.
Underlined the part where I assumed it would not affect Iddy's wizard spells, from discussion we had before he posted to verify. Although it's written in the 2nd level part, the whole thing is one single ability. So for me, RAW it does specify beguiler's spells.
