0 Members and 15 Guests are viewing this topic.
Hooray!
Final nagging for today (maybe)
I would like to make a homebrew spell or two in addition to the one I currently have:
Inspire Great Metamagic
Enchantment (Compulsion) [Mind-Affecting, Sonic]
Level: Bard 6
Components: V
Casting Time: 1 swift action
Range: Personal
Target: You
Duration: 3 rounds
When you cast this spell, your next use of inspire greatness can be augmented in one of two ways. You may choose to give them the effects of both maximize and empower spell feats or both the quicken and widen metamagic effects. Both of these effects have no effect on the spell level.
These bonuses are in addition to the normal benefits of inspire greatness. If you do not inspire greatness before the spell's duration expires, the effects are lost.
I don't know if this one is too strong for a Bard 6, so if you wanted to make it Bard 7 that'd be fine.
Okay, so before I get really creative with Major Creation, let's set some limits. What is the complexity limit on what can be created in a single casting. I can create simple objects, and moderately complex ones such as with the paintbrush. I'm assuming that so long as the object is unremarkable, not masterwork, and not a precisely-timed clockwork mechanism, I can create anything I like, with actual complexity requiring a skill check. Yes?
Sounds reasonable enough.
Neph: Why quicken and widen together? I get maximize and empower, but not those two.
I was thinking some sort of emergency mass healing or something.
This isn't for Dune, but rather the other PCs. I'd like to know what buffs you all would like me to prep. Everyone's got a ton of magical gear on that give stat bonuses, so I'm not sure what I can prep that'll stack. Toss me some suggestions.
What spellcasting do you have access to?
Dune, am I okay to take Portal Dissonance (Planar Handbook, page 29), in place of Mass Suggestion at 18 (I replaced Suggestion earlier in leveling)?
What did you replace it with?
Haunting Melody replaced Suggestion.
#3656
Can I take Obscure Lore to get a +2 bonus to Bardic Knack instead?
EDIT: Question, since the reroll aspect of Lore of the Gods was removed, is it still present on Spiritual Advisor?
I'd rather you just make a new feat to do that, Neph.
What's spiritual advisor?
It's in Complete Champion, page 127.
But the summary is As long as the spiritual advisor is present, it helps you recall bits of trivia, history, or other knowledge. This knowledge can be as general or specific as is required, and the information gained grants you a +4 insight bonus on all Knowledge checks while the spell is in effect. You can even attempt checks with Knowledge skills in which you have no skill ranks or retry a Knowledge check you failed before casting the spell.
As for the feat, sure, I think that's easy enough.
Bardic Forte [General]
Prerequisite: Bardic knack alternative class feature, cha 20
Benefit: You gain a +2 insight bonus on checks using your bardic knack class feature.
Also, here are Moore's levels from 18 to 23 for posterity. I still need to pick a level 18 as well as level 23 feat.
Moore reaches level 18! Bard 18 and Fatesinger 4
[13:24] <Nephrite> roll 1d6+1+7 Level 18
[13:24] <Kobot> Nephrite rolled 1d6+1+7 Level 18 --> [ 1d6=1 ]{9}
203 + 9 = 212
Feat gained, pick later
+1 BAB (15/9/5), +1 to all saves, mass suggestion (replaced with Portal Dissonance? Planar Handbook, page 29), nothing on the Fatesinger side
17 Skill points
+1 3rd level spell known for Bard
+1 6th level spell per day for Bard
Fatesinger 4 increases the ECL of Favored Soul to 7
+1 1st level known
+1 3rd level per day
Moore reaches level 19! Bard 19 and Fatesinger 5
[13:43] <Nephrite> roll 1d6+1+7 Level 19
[13:43] <Kobot> Nephrite rolled 1d6+1+7 Level 19 --> [ 1d6=4 ]{12}
212 + 12 = 224
+1 BAB (16/10/6/1), saves don't go up (boo), Fated Failure
17 Skill points
+1 4th and 6th level spells known
Fatesinger 5 increases ECL of Favored Soul to 8
Gain access to 4th level spells, 3 of them
+1 3rd and +3 4th level spells per day
Moore reaches level 20! Bard 20 and Fatesinger 6
[13:58] <Nephrite> roll 1d6+1+7 Level 20
[13:58] <Kobot> Nephrite rolled 1d6+1+7 Level 20 --> [ 1d6=3 ]{11}
224 + 11 = 235
+1 BAB (17/11/7/2), +1 to all saves, Destined Strike improvement
Level 20 ability point goes into Charisma for 26
17 skill points
+1 5th level spell known
+1 level 6th spell
Fatesinger 6 improves ECL of favored soul to 9
Moore reaches level 21! Bard 21 and Fatesinger 7
<Nephrite> roll 1d6+1+7 Level 21
[14:19] <Kobot> Nephrite rolled 1d6+1+7 Level 21 --> [ 1d6=2 ]{10}
235 + 10 = 245
+1 BAB, no saves (boo), song of fortune up to 3 targets
17 skill points
Epic feat goes into Epic spell capacity
+1 Level 7th known
+0 7th spells per day
Fatesinger 7 improces ECL of favored soul to 10
Moore reaches level 22! Bard 22 and Fatesinger 8
[14:44] <Nephrite> roll 1d6+1+7 Level 22
[14:44] <Kobot> Nephrite rolled 1d6+1+7 Level 22 --> [ 1d6=1 ]{9}
245 + 9 = 254
+1 BAB (19/13/9/4), +1 to Will, Defensive Manipulation to Reflex/Initiative
17 Skill points
+1 7th level spell known
+1 7th level spell per day
Fatesinger 8 Improves ECL of Favored Soul to 11
Moore reaches level 23! Bard 23 and Fatesinger 9
[14:52] <Nephrite> roll 1d6+1+7 Level 23, let's make this a good one v2
[14:52] <Kobot> Nephrite rolled 1d6+1+7 Level 23, let's make this a good one v2 --> [ 1d6=3 ]{11}
254 + 11 = 265
17 Skill points
+1 level 7th spell known
+1 level 7th spell per day
Fatesinger 8 improves caster level of Favored Soul to 12
