If I'm missing anything, say so now so I can add it.
Todo
1. Go through nagging, answer/resolve posts.
2. Ilsenine's level up.
3. Loot.
4. Sticky Neph's Aurora fund post.
5. Finnegan rebuild.
6. More spells.
7. More spells.
8. More spells.
9. Secret shop update.
10. Build chart updates.
11. Simmer living spells.
12. Training rooms update.
13. Secret DM thing 1.
14. Surraruthru spellpool.
15. Make sure all feats/spells/epic shieldmate is in appropriate R&S topics.
After some consideration and number tossing, I'm not going to rebuild Finnegan. He's getting the 5 level version of occult slayer grandfathered in and we'll leave him at that. There's a little more to it, but the gist is that it's not a worthwhile way to spend my time, as the benefit's minimal.
Expect random spells, I'm tossing ideas out and hashing them out fast. Some of these will be aimed at Jaela, others will be ones that were aimed at her but diverged. Comments more than welcomed.
I'm gonna need an epic blasting power at some point.
That makes sense. Are you thinking anything in particular? One of the few epic psionics I made is one.
Got a question on feat interactions.
Combat Reflexes: When foes leave themselves open, you may make a number of additional attacks of opportunity equal to your Dexterity bonus.
Improved Combat Reflexes [Epic]: There is no limit to the number of attacks of opportunity you can make in one round. (you still can't make more than one attack of opportunity for a given opportunity.) per d20srd website.
Robilar's Gambit: In return, they provoke attacks of opportunity from you each time they swing. Resolve your attack of opportunity after your foe's attack.
Does this mean that each attack a foe swings at me is treated as an individual opportunity for attacks of opportunity? As in, if they swing at me 10 times, I get 10 separate AoO chances at them in return?
Yes. And, in fact, each AoO resolves after their attack, so it'd be his attack #1, your AoO #1, his attack #2, your AoO #2 and so on.
Updated sheet for the purchases. Moore has a respectable 311 HP and 56 AC now, wow!
Okay, does the AoO from Robilar's Gambit apply only to who's attacking you, or if you're surrounded by four guys and one fires off 10 attacks, do you get 1 AoO on everyone surrounding you for each one of the 10 attacks?
You only AoO the one triggering it. You get an attack of opportunity, which is limited in scale from a normal attack.
Cor's correct.
The only real reason you need improved combat reflexes is if you're running gambit or another gimmick that eats AoOs like candy (see Sealtiel over on the R&S board, he has one).
For consideration and correction, since there are almost no decent buff spells for level 8 Sorc/Wiz:
Insight of the Dragon Princess
Transmutation
Level: Sorc/Wiz 8,
Components: V, S,
Range: Touch
Target: Creature touched
Duration: 24 hours
Saving Throw: Fortitude negates (harmless)
As you cast this spell, the image of Seira wraps around the target's head. The image fades as you bestow your ally with comprehension.
The subject gains a +10 insight bonus to Wisdom.
Agility of the Dragon Princess
Transmutation
Level: Sorc/Wiz 8,
Components: V, S,
Range: Touch
Target: Living creature touched
Duration: 24 hours
Spell Resistance: No
Drawing on the inspiration of Seira, the Dragon Princess, you imbue the target with a drop of her grace, granting them a +10 sacred bonus to Dexterity.
Strength of the Dragon Princess
Transmutation
Level: Sorc/Wiz 8,
Components: V, S,
Range: Touch
Duration: 24 hours
As you cast this spell, a great roar of power sounds in the distance; an echo of Seira's call to battle. The sound fades as you bestow your ally with power inspired by the Dragon Princess, granting them a +10 sacred bonus to Strength.
Mind of the Dragon Princess
Transmutation
Level: Sorc/Wiz 8,
Components: V, S,
Range: Touch
Duration: 24 hours
As you cast this spell, the sound of pages turning sounds and a feeling of understanding settles over you. As the feeling fades your ability to learn about the world increases, granting the target a +10 insight bonus to Intelligence.
Offical post of Surraruthru going insane copying spells from the Library into his Blessed Book.
That's cool. Any particular preferences?
Quote from: Iron Dragoon on January 13, 2017, 08:46:39 PM
Transmutation
Level: Sorc/Wiz 8,
Components: V, S,
Range: Touch
Duration: 24 hours
I'm going to ignore minor formatting problems for this. Those are no big deal and I'll fix them on my end.
Anyway, let's look at a similar spell Jaela uses. It's also level 8 so it's a great one to compare it to.
Quote
Righteous Halo
Transmutation [Good, Light]
Level: Clr 8
Components: V, S, DF
Range: Personal
Target: You
Duration: 1 hour/level (D) or until discharged
Holy light washes over you as you call upon your patron deity's power. This nimbus of divine power coalescing around your form shines brightly, as if daylight had been cast upon your person.
You get a +4 sacred bonus to your Charisma score.
As an immediate action, you can discharge the magic to gain a +8 Sacred bonus to Charisma for 1 round. The spell ends after you use it in this manner.
Divine Focus
The holy symbol of your deity.
In the case of hour/level spells or longer ones, it's less oomph into the power of the spell and more into the duration. I'd suggest using that spell as a measuring stick and go with something like this.
Transmutation
Level: Sor/Wiz 8
Components: V, S
Range: Touch
(Add descriptive sentence here, do not forget) The target of this spell gains a +4 insight bonus to Wisdom.
I consider insight and sacred to be interchangeable here for total power level, as both are non-enhancement bonuses. This one trades it improving to a touch spell over personal/you in exchange for dropping the burst option righteous halo has. The duration differences are trivial at this level. I might include a non-costly material component to slightly rebalance the spell and add some flavor (as in one eschew materials would cover, as well as a spell component pouch). You could use this basic template for the other three spells, since it's basically the same thing with different ability score bonuses.
