#4980
Some ideas for Dune/Cor, not sure these are balanced/good/whatever
This is just an upscaled Sunburst with extra effects that work on evil creatures. It might be too strong as 11th? I dunno.
Searing Radiance
Evocation [Light]
Level:   Drd 11, Sor/Wiz 11, Clr 11 (Sun?)
Components:   V, S, M/DF
Casting Time:   1 standard action
Range:   Long (600 ft. + 60 ft./level)
Area:   120-ft.-radius burst
Duration:   Instantaneous
Saving Throw:   Fortitude; see text
Spell Resistance:   Yes
Searing Radiance greates a sudden burst of radiant light in the area you designate. All evil creatures in the radius are blinded and take 9d6 points of damage. Creatures to which light, such as sunlight, is harmful or unnatural take double damage. A successful fortitude save negates the blindness and reduces the damage by half.
An undead creature caught within the globe takes 1d6 points of damage per caster level (maximum 30d6), or half damage if a Fortitude save is successful. In addition, the burst results in the destruction of any undead creature specifically harmed by bright light if it fail its save.
In addition, the radiant light heals any good creatures in the area affected for the same amount as the damage roll on the spell.
Searing Radiance also dispels any darkness spells of level 11th or lower.
Illuminated Wall
Conjuration [Light]
Level: Clr 11, Drd 11, Sor/Wiz 11
Component: V, S, F
Range: Medium (75 ft. + 5 ft./level)
Area: 20 ft (+4 ft./level)
Duration: 1 round/level
Saving Throw: None; see text
Spell Resistance: None
This spell functions as a wall of force except as noted here.
This wall is also not invisible, and appears as a sparkling array of bright light.
If the wall is destroyed by a disintegration effect, it will explode in a blinding array of light. Any creature within 30 feet of the wall must succeed on a Fortitude save or be blinded for 4 rounds.
Quote from: Corwin on January 09, 2017, 03:42:25 PM
[21:16] <@Rin> I'm hoping to chat about stuff and maybe get some ideas, so whenever you're up for it
[21:21] <@Kotono> Okay, do you at least have any niches or things you need?
[21:30] <@Rin> Last time we took care of an anti-devil spell and a 'stop running away' spell
[21:31] <@Rin> Gae Assail is pretty good for a single target, especially with targets I don't like
[21:33] <@Rin> A large-scale anti-army spell might be nice
[21:33] <@Rin> Something with earthquake and sunburst's range or beyond
From IRC, this is clarified to be more meaning area of effect. So wide area of effect spells, okay. Let's take this one since it's also an 11th level spell and look at it.
QuoteSharran Nightfall
Necromancy [Evil]
Level: Clr 11
Components: V, S, DF
Range: 1 mile radius centered on you
Saving Throw: Fortitude negates
All living creatures within the radius (except for worshipers of Shar and servants of Shar) are permanently blinded and deafened. Those blinded forever see the unholy symbol of Shar and nothing else, while those deafened only hear a song that beckons everything towards oblivion. Creatures subjected to either of these for over a month's time inevitably turn suicidal and seek to act on those urges.
Ignoring that the spell is horrifying a sec, is this what you had in mind for range/area of effect? Smaller? Bigger?
Also this spell is borderline a vile spell, I may revise that. Note to self.
Quote[21:34] * @Kotono nods.
[21:34] <@Kotono> So something anti army. Anything else?
[21:34] <@Rin> Maybe light?
[21:35] <@Rin> Say battlefield control with light?
A little more direction there would help. What do you want to do with light? Blinding is the most obvious application, though that reminds me of the spell blinding glory or whatever from the BoED. 9th level, same thing you want, just on a slightly smaller scale. I do mean slightly, since it's 100ft/level if I recall. Ebony used it to hold back all the unpleasant darknesses Secretus's domain had.
If you have something more exotic in your head, say so.
Quote[21:35] <@Rin> Vul'lath made that multiple moments of prescience spell
[21:35] <@Rin> So something that lets me make walls of force for the duration?
[21:35] <@Kotono> That's an idea too.
[21:35] <@Rin> Or prismatic ones? Or whichever
[21:36] * @Kotono nods.
[21:36] <@Rin> Like maybe one per round, free action
[21:36] <@Rin> Or an actual action, but controls/creates more than one
[21:36] * @Kotono nods again.
[21:38] <@Kotono> Okay, toss this conversation into nagging and I'll have it there when I get to this then.
As a general rule, I'm not going to approve anything that further abuses the action economy.
For reference, the barebones of what you suggest is one of Mei's warlock powers. You know the one. Depending on duration I'd put that at 7th to 8th level. Can be narrowed down from there a little more, so go ahead and make a choice between prismatic, force or another type of wall.
I greatly appreciate the input, even if I'm a little rough on them below.
Quote from: Nephrite on January 16, 2017, 01:27:07 PM
Searing Radiance
Evocation [Light]
One relevant problem and why I didn't just make a sunburst+3 spell: Sunburst isn't a cleric spell. It's available to the sun domain, but it's no a mainline cleric spell. It's a druid spell, a sorcerer/wizard spell and a sun domain spell, but not a cleric spell.
It's also likely irrelevant with sunlance around, though I'd have to compare the spells to see how they stack up.
QuoteIlluminated Wall
Conjuration [Light]
Component: V, S, F
That's a neat idea, though not close to an 11th level spell. Probably 7th or so, maybe? That's only because disintegration is one of the go-to ways of beating wall of force.
Also medium range is 100ft + 10ft/level.
What's the focus supposed to be?
How come it's a cleric, druid and sorcerer/wizard spell, when the original is purely a sorcerer/wizard spell?
I forgot to remove the Focus aspect, since I simply borrowed it from the Dire Winter spell, so it probably shouldn't have one.
As for the rest, a big shrug on that since it feels like Sunburst ought to just fall into a Cleric's repertoire without too much fuss.
Here's another badly formatted spell.
Wall of Greater Dispel Magic, Mass
Abjuration
Level: Clr 11, Sor/Wiz 11
Component: V, S
Effect: One 10ft. square wall/level
This spell functions as Wall of Greater Dispel Magic except as noted here. The caster may choose to create the walls in any pattern they wish, including making a cube of walls (this would require 6 uses to cover a 10ft area, for example).
Quote from: Nephrite on January 16, 2017, 01:54:20 PM
Abjuration
Component: V, S
This sounds like something that can't be dispelled. Can you dispel a dispel?
The entry for Wall of Dispel Magic doesn't mention anything about it acting like a wall of force, so I would presume you could just dispel it, yes.
Quote from: Anastasia on January 16, 2017, 01:00:41 PM
I consider insight and sacred to be interchangeable here for total power level, as both are non-enhancement bonuses. This one trades it improving to a touch spell over personal/you in exchange for dropping the burst option righteous halo has. The duration differences are trivial at this level. I might include a non-costly material component to slightly rebalance the spell and add some flavor (as in one eschew materials would cover, as well as a spell component pouch). You could use this basic template for the other three spells, since it's basically the same thing with different ability score bonuses.
How do these look:
Insight of the Dragon Princess
Transmutation
Level: Sor/Wiz 8
Components: V, S
Range: Touch
Target: Creature touched
Duration: 1 hour/level
Saving Throw: Fortitude negates (harmless)
As you cast this spell, the image of Seira wraps around the creature touched's head. The target of this spell gains a +4 insight bonus to Wisdom.
Agility of the Dragon Princess
Transmutation
Level: Sor/Wiz 8
Components: V, S
Range: Touch
Drawing on the inspiration of the Dragon Princess Seira, you imbue the creature touched with a drop of her draconic grace. The target of this spell gains a +4 sacred bonus to Dexterity.
Strength of the Dragon Princess
Transmutation
Level: Sor/Wiz 8
Components: V, S
Range: Touch
As you cast this spell a great roar of power sounds in the distance; an echo of Seira's call to battle. The target of this spell gains a +4 sacred bonus to Strength.
Mind of the Dragon Princess
Transmutation
Level: Sor/Wiz 8
Components: V, S
Range: Touch
As you cast this spell the sound of pages turning sounds and a feeling of understanding settles over you. The target of this spell gains a +4 insight bonus to Intelligence.
Quote from: Anastasia on January 02, 2017, 09:10:58 AM
Quote from: Iron Dragoon on December 21, 2016, 12:14:12 AM
Dune, what do you think of this? It's just a copied/upgraded version. I wasn't sure what level to make it, seeing as how you disliked the hijinks of the uncapped version.
Mighty Wallop, Superior
Transmutation
Level: Sorcerer 10, Wizard 10, Spellthief 10
Components: V, S, AF,
Range: Touch
Target: One bludgeoning melee weapon
Duration: 24 hours
Saving Throw: None (object)
Spell Resistance: No (object)
As Mighty Wallop (Greater), except that the bludgeoning melee weapon damage increases by four size categories.
Focus: A melee weapon.
Something like that's okay. I'll work up a version of it in a little bit, need to crunch a few things.
Did you get around to finishing this? Relevant because war.
Everyone attached to the tapestry, I need you to tell me which of these elemental benefits you want (Afina excluded, she gets them all already anyway):
Abjuration
Component: V, S
That's a pretty neat idea for a mass wall spell. Lemme try.
Mass Wall of Greater Dispel Magic
Abjuration
Level: Clr 11 Sor/Wiz 11
Effect: One wall/two levels up to 10ft square in area per level per wall; see text
This spell creates many walls of greater dispel magic, one per two caster levels (maximum 15). The caster may choose to create the walls in any pattern they wish, including making a cube of walls to trap a creature within them. Each wall is independent and does not need to touch the other walls, though walls that touch become one contiguous wall.
This might need a bit more clarifying text, but it works. It's largely overkill, but it works. Neat.
Quote from: Nephrite on January 16, 2017, 07:08:10 PM
That's correct. You can dispel a wall of dispel magic normally.
Quote from: Iron Dragoon on January 16, 2017, 07:22:58 PM
How do these look:
Transmutation
Level: Sor/Wiz 8
Components: V, S
Range: Touch
Transmutation
Level: Sor/Wiz 8
Components: V, S
Range: Touch
Transmutation
Level: Sor/Wiz 8
Components: V, S
Range: Touch
Transmutation
Level: Sor/Wiz 8
Components: V, S
Range: Touch
Why is one spell SR: Yes (harmless) and the other three aren't? Should be the same for consistency.
That's fine. I'd suggest using insight bonuses across the board or making the ones with a sacred bonus have the good descriptor.
It has it on one because I dunno. I C/P'd something and I think I messed it up, but yeah. SR: Yes (Harmless) is fine across the board.
I'm good with changing them all to insight as well.
Quote from: Iron Dragoon on January 16, 2017, 07:31:43 PM
Transmutation
Range: Touch
Duration: 24 hours
Superior Mighty Wallop
Transmutation
Level: Sor/Wiz 10, Spellthief 10
As greater mighty wallop, except the bludgeoning melee weapon damage increases by four size categories.
Transmutation
Level: Sor/Wiz 8
Components: V, S
Range: Touch
Transmutation
Level: Sor/Wiz 8
Components: V, S
Range: Touch
Drawing on the inspiration of the Dragon Princess Seira, you imbue the creature touched with a drop of her draconic grace. The target of this spell gains a +4 insight bonus to Dexterity.
Transmutation
Level: Sor/Wiz 8
Components: V, S
Range: Touch
As you cast this spell a great roar of power sounds in the distance; an echo of Seira's call to battle. The target of this spell gains a +4 insight bonus to Strength.
Transmutation
Level: Sor/Wiz 8
Components: V, S
Range: Touch
