0 Members and 13 Guests are viewing this topic.
Quote from: Iron Dragoon on January 16, 2017, 08:26:38 PM
Casting these before we leave Aurora, so everyone connected to the tapestry gains them, the minutes/level duration spells will be cast last in order to make them extend the longest, listed at the end:
+1 Luck Bonus on Attack Rolls
Subject gains Resistance 10 against all five energy types: Acid, Cold, Electricity, Fire, and Sonic.
The subject is protected from all devices and spells that detect, influence, or read emotions or thoughts. This spell protects against all mind-affecting spells and effects as well as information gathering by divination spells or effects. Mind blank even foils limited wish, miracle, and wish spells when they are used in such a way as to affect the subject’s mind or to gain information about it. In the case of scrying that scans an area the creature is in, such as arcane eye, the spell works but the creature simply isn’t detected. Scrying attempts that are targeted specifically at the subject do not work at all.
Additionally, the below are pre-loaded into the Tapestry for activation as Quiescent Weaving:
Resist Energy, CL 26, Duration 260 Minutes. (4 castings)
Subject gains energy resistance to: Acid, Electricity, Fire, Sonic of 30 points.
This is relevant for all active PCs.
Quote from: Iron Dragoon on January 16, 2017, 08:01:47 PM
Everyone attached to the tapestry, I need you to tell me which of these elemental benefits you want (Afina excluded, she gets them all already anyway):
Moore would take the water one.
Dropping OOC notes in Cor/Eb's threads so they don't miss this.
Lesson learned: Including tapestry-ing in prep, so it isn't done at the last minute like this. This army battle has enough moving parts, so that should be one settled before I start making topics.
This is as much a note for myself as it is for Iddy.
> So on the Contingency thing. Could I have a single Contingency spell activate different spells for different people since I have that class ability that lets me make decisions for different people?
<Kotono> I'd need to check contingency. Post that in nagging.
Class ability:
Flexible Tapestry (Su)
At 5th level, the grand weaver gains a greater control over his eldritch tapestry. When a spell requires decision making on your part, you may make the choice separately for each member of the tapestry.
There's a a handful of favored soul ACFs posted to homebrew over on the R&S board. They're for followers of Alicia, Chauntea, Auril, Mephisto and Asmodeus. They're leftovers from a booster pack that didn't work out, hence being a bit scattershot and not directly related to B3.
Speaking of, any suggestions for a booster to work on? A theme, a class or mechanic is usually what it works around. The previous ones I've done are exalted feats, factotums, polymorph subschool spells and anti-teleportation measures.
Quote from: Iron Dragoon on January 22, 2017, 02:01:25 PM
Class ability:
RAW yes. However, contingency consumes the spell it makes contingent. Therefore each spell you apply would be expended.
The main thing isn't balance (it's a concern but the cap on spell level for contingency likely solves that), but slowdown in play. A bunch of different contingencies are going to slow you down to set up and slow me down to adjudicate.
Quote from: Anastasia on January 23, 2017, 01:22:28 AM
Alrighty!
#5003
Is it possible to make a Greater and Superior version of Spell Theft? (Complete Scoundrel, page 104)
Also, do you think we could make a Greater version of Harmonic Void?
Also, I'm looking into getting some more utility spells -- I'm not really worried too much about them being inaccessible right now, but here's a general idea:
*No SR
*No Save (I realize this will probably put it already in 10th or higher category)
*Some sort of short-term disable (stun for 1 round?)
*Some sort of drawback so it isn't just overpowered, like maybe it stuns the user for 2 rounds or something?
I'm willing to work with whatever, I could live with SR but no save if that might make it more in line.
EDIT: Also, are the Aurora projects still in progress? Do we need rolls there or something?
Quote from: Nephrite on January 25, 2017, 07:58:27 PM
Reaving Dispel.
Dune: Would it be reasonable to make Reaving Dispel a Brd 8 spell? Spell Thief is Brd 4 to Sorc/Wiz 5.
I want to summon Cthulhu.
Quote from: Nephrite on January 25, 2017, 08:55:02 PM
That's cool, it fits how dispels work for bards. Consider it a Brd 8 spell.
Quote from: Yuthirin on January 25, 2017, 09:40:49 PM
Cthulhu doesn't exist in Balmuria. Something reasonably similar to him could perhaps be pulled from the Far Realm, though this introduces a plethora of difficulties. Creation's designed to keep the Far Realm out, as the Far Realm unravels reality. Spells and rituals to do so are the province of the maddest of madmen, many of whom are obliterated without warning as they follow this path. Those that succeed find their success extremely short lived, as being confronted with something like the Angel of Last Resort, Zaphkiel's Blessing or Salandariel is the likely outcome. Should you somehow overcome those, you'll likely face deities themselves taking the battlefield, even if destroys a Prime Material world.
If you succeed in spite of that and triumph over those odds, your reward is watching reality crumble and getting a fist bump from Shar before you return to oblivion forever.
That image made that entire bit of wordiness worth it.
Quote from: Anastasia on January 25, 2017, 09:53:56 PM
No no! No! You've got it all wrong! Cthulhu just wants to be your friend!
It's the ponies you have to watch out for.
