Go for it. May as well keep things neat.
Fantastic.
Cor, Sudden Quicken was added to houserules.
Spells. Here we go again.
2nd
Splinterbolt is fine. Ow.
4th
Boreal Wind is fine.
6th level
Fires of Purity is fine.
8th
Picking this up from before, let's not use Frostfell.
Eb, going to replace those with Tepen's attacker and traitors-related questions, or we'll be trying different means to get to them?
I figure Tepen is covered by the questions we have about activities on Lifasa - if we can capture a devil who took part in or who knows another devil that took part in the attack on the Throne (I think that's where Tepen and Adrian were based, if not substitute it for wherever), we can use that to get a solid lead on the pit fiend responsible and take it from there.
Yes, Tepen and Adrian were based around the Ascended Throne of Heaven.
Also, a yes or a no on the Bloodletting Peak question would be appreciated.
Quote from: Anastasia on February 11, 2012, 08:11:37 PM
Is it alright if I remove the Bloodletting Peak questions from the devil questionnaires now?
Yes, go for it.
Yuth: Is your sheet+spells officially done? I'd like to give 'em another look over if everything's supposed to be final. Once I do, I'll want to talk to you about intro stuff.
Yes, I believe I'm satisfied with them.
Yuth's sheet review v999.
Attack and full attack isn't done. At the very least you have your quarterstaff and monk unarmed strike to add.
You trained diplo, okay. Now this probably isn't news to you, but in case you've missed it before, heads up. I don't follow the SRD standard diplomacy DCs and instead assign them on a case by case basis. This is probably something you already know.
Your jump score should have a -6 misc modifier. If your movement rate is below 30ft, you suffer a -6 penalty to jump for every 10ft it is. (-6 for 20ft, -12 for 10ft)
Open Lock was rolled into Disable Device, no need to have that 'round any more.
Your Swim score is missing the +8 racial bonus Tortles receive.
Go ahead and remove Frostfell from 8th level magic and select another spell.
Things look about done otherwise. More on IRC when I catch you.
With the diplomatic trip paid for, Adrian, Misalea and Drena leave for Mechanus. They are officially away until further notice.
Quote from: Anastasia on February 12, 2012, 07:00:36 PM
Done. Added Stunning Fist DC as well.
QuoteYou trained diplo, okay. Now this probably isn't news to you, but in case you've missed it before, heads up. I don't follow the SRD standard diplomacy DCs and instead assign them on a case by case basis. This is probably something you already know.
Yeah, I noticed that. Having it as a representative of my tribe is a good thing. It makes thematic sense and it's still pretty useful.
QuoteYour jump score should have a -6 misc modifier. If your movement rate is below 30ft, you suffer a -6 penalty to jump for every 10ft it is. (-6 for 20ft, -12 for 10ft)
I keep forgetting about Jump. Fixed.
QuoteOpen Lock was rolled into Disable Device, no need to have that 'round any more.
Done.
QuoteYour Swim score is missing the +8 racial bonus Tortles receive.
Realized that last night, yeah.
QuoteGo ahead and remove Frostfell from 8th level magic and select another spell.
I thought I did?
This came up in chat today so I'll put this out there. If any of you are interested in trying to knowledge check any of the nine traitors, speak up and say which one(s) interest you. The most useful skill will be K:L for a Lifasan region, but other skills may be useful as well. The DCs vary considerably depending on which region of Lifasa you come from and other factors, FYI.
Tepen, being knowledgeable and from Lifasa, is going to make some checks.
> roll 7#1d20+33
* Hatbot --> "Kotono rolls 7#1d20+33 and gets 312." [7#1d20+33 = 42, 50, 41, 47, 41, 38, 53]
> roll 1d20+33
> roll 1d20+33
* Hatbot --> "Kotono rolls 1d20+33 and gets 34." [1d20=1]
* Hatbot --> "Kotono rolls 1d20+33 and gets 38." [1d20=5]
Tepen has heard of Harkin. Harkin Banestrom, a wandering human noble. He left a comfortable life to take to the road. There wasn't anything unusual about him when he left, but that was years before Lifasa fell.
Tepen has heard of Mala. A tiefling from far away, he recalls hearing of him/her(Mala's gender is uncertain based on what Tepen recalls, assumed female for now due to names ending in a usually being feminine) as a troublemaker in faraway Janspu. As the tiefling lands had more trouble than is normal in Lifasa, this doesn't mean all that much. In any case, Tepen heard of her from his wizardly studies. Mala is apparently a wizard of some considerable skill.
Well, nobody besides Tepen even has K:L(Lifasa) anyway. I'd figure we'd want to try on all of them either way if there's a relevant skill for them.
I would have definitely tried on the catfolk at least.
Edit: Would Collector of Stories skill trick allow me to make untrained checks in the worst case where another relevant skill wasn't available?
