0 Members and 14 Guests are viewing this topic.
Quote from: Merc on March 04, 2012, 07:49:06 PM
Alrighty. I'll bug you again in a week if I haven't heard~
Other ACF options:
-Let her add Int to her Con/Wis/Cha skills, not just Str/Dex?
-Spend inspiration to naturally let her take 13 (taking 10 is boring!) on a skill roll, regardless of situation? (And she'd still be able to boost it through cunning knowledge as well)
-Since factotum learn a little bit of everything and have arcane/divine-flavored abilities, something that grants psionic/incarnum-flavored abilities?
Second is redundant with Exemplar rather horribly, and probably not good enough to justify the trade off in the first place. Third runs into the problem of adding yet more things to keep up with her. I like the first a lot - I need to review it to make sure it doesn't have any broken or stupid application - but it's probably the best of the lot and I'll run with it.
Anyone see anything grossly wrong or abusable here?
Alternate Class Feature: Brains Over Everything
Not content with merely outthinking athletics, you apply your formidable intellect to myriad pursuits.
Class: Factotum
Level: 16th.
Replaces: If you select this alternate class feature, you do not gain improved cunning defense.
Benefit: You gain your Intelligence bonus to skill checks based on Wisdom, Charisma and Constitution.
I don't think it's a problem.
It does boost 8 of her skills by +12, and pretty much means she makes all of her untrained check at +12 minimum because of Jack of all Trades, but she's focused on upping her intelligence and her build is centered around skills, so I think it's fine for a high level ability.
http://www.soulriders.net/forum/index.php/topic,101739.msg1029548.html#msg1029548
This post now has information about what constitutes an epic magical item. Remember that epic magical items are not artifacts. The only serious change from the ELH are that skill boosters are capped at +15 instead of +30.
Per your request, reposting this.
SC has Hand of the Faithful (page 109), and I wanted to know if it could be Permanency'd. And if so, whether it could be suppressed at will, much like SR is handled, since it'd be pretty annoying to other people outside of any fight.
Haven't really thought about its balance/level (waiting at doc on phone), but one thing stood out for me. The damage is weird for a level 9 spell. Its scale means it'd reach its max damage before you'd get access to the spell. Either make it a flat 15d6 or something like 5d6+1d6/2 levels and then set a maximum of 15d6 dmg.
Quote from: Corwin on March 05, 2012, 04:32:29 AM
One question - where precisely are you planning on casting this? I got the impression you wanted it on yourself, but it's a spell that targets a point in space.
Quick question for Yuth: How many tortles are there? I had it in my notes but I can't find it.
Somewhat less than fifty. I believe I said 43, including Kole and myself.
Okay. Tentative heads up. I'm thinking of running 5 days per week: Friday, Saturday, Sunday and two other days TBA. Of the remaining days, which two do each of you prefer? I'm aware Saturday isn't best for Eb/Cor due to GF and may require some misses there, likewise I know Friday is every other for Merc coming up and Yuth is a question mark there.
Saturday would HAVE to afternoon for me. There is no compromise on my part for that. I can't get out of Saturdays.
How late in the afternoon?
