Discussion/Questions/OOC Blather
Started by Dracos, October 11, 2011, 09:44:30 PM
Still feeling out the two front-runners for class ideas, but just a question:
Would it be possible for Spirit Shaman to just use Wis for Druidic spells (similar to druid/cleric/sorc/wiz) instead of Wis and Cha?   Just looking at it possibly being an 'all stats but int needed' setup there in gestalt (as much as multi-stat casters are generally more sensible for limitations).
Wait, so bad guys can't just go 'ha ha, better luck next time...WARP'?  (same with us)  That's awesome :3
VySaika
Dimension Door is still an option! But if they use that, at least you know they are still in this area SOMEWHERE for the next 10 minutes at the very least.
All About Monks
<Marisa> They're OP as fuck
<Marisa> just by being monks
VySaika
Also, did not mean for Houserules to actually be a thread that was discussed in. So split the commentary into it's own topic.
All About Monks
I can blather at a thousand *sleeps* :)
