035. Operation Black Cloud
Started by Corwin, April 29, 2012, 05:34:33 PM
[19:08] <Kotono> Aurora is prepared. The armies are ready, the spells are cast. The entire fortress is taut as a bowstring, prepared at last! The armies are assembled in the courtyard, songs of glory being sung by some. Others stand in patience waiting, while others yet exude a nervous energy. But all are here, all are prepared. It's time. OOC: Go ahead and set yourselves up since you're commanding this.
[19:12] <Afina> The Feint Team is at the gate, ready to take the fore with the armies directly behind to follow them. Afina and the other members of the Rescue Team wait just behind that, ready to leave the gate and plane shift to their goal once the assault is fully underway. Vul'lath should be opening the Gate momentarily... "Almost..." the fairy whispers, foating up so she can see above the armies and the
[19:12] <Afina> walls so she can see Lifasa as soon as they transition, for better or worse.
[19:13] * Jaela happens to be one of those waiting in patience. It seems incredible that they have this chance to return and fight the devils properly on their lost world. She nods slightly at Afina's words, and summons Gae Bolg and her floating triangular shield. This battle will be taken with the utmost seriousness from the very start.
[19:13] * Muirfinn speaks quietly with the tortles preparing to fight, hoping to bolster their confidence as he practically drags his water elemental behind him. He finishes speaking and strolls up to the group. "My people are prepared." He says quietly.
[19:14] <Kotono> Adrian stares out ahead, sword drawn. Occasionally his hand goes to his amulet, but his gaze is fixed ahead. "We're all prepared. To victory, because we can't accept anything else."
[19:14] * Muirfinn nods.
[19:15] <Kotono> roll 1d20+17
[19:15] * Hatbot --> "Kotono rolls 1d20+17 and gets 18." [1d20=1]
[19:17] <Kotono> Silence stretches, as...
[19:17] <Kotono> roll 1d20+17
[19:17] * Hatbot --> "Kotono rolls 1d20+17 and gets 31." [1d20=14]
[19:18] <Kotono> There is a long pause before at last, Sage Vul'lath conjures up the gate so desired! Immediately Aurora begins to work, opening the gate wide and starting to pass ahead!
[19:19] <Muirfinn> As the Aurora moves, Muirfinn quickly taps Ithea with a wand, seeing her deflective aura as slightly lacking. A thin whirlwind of sand sprays up around her, bolstering her defenses. "Anyone else need a bit of extra protection?"
[19:21] * Ithea blinks and gives a short nod of thanks to Muirfinn for the slight bit of extra aid. Every bit helps. Her eyes go back to focusing on the gate though, as she grips her glaive tightly in anticipation, knowing battles will follow soon enough.
[19:24] <Kotono> The sensation is that of passing through molasses. It is as if Aurora slows down for an inperceptably slow moment, a shudder passing through each of you. Sulphur. The air reeks of sulphur, smoke and ash. What draws your eyes are the sky. Thick, dark yellow clouds blot out the sky above, pregnant and heavy with crackles of red fire. On the horizon you can far below see a blasted, cracked land.
[19:24] <Kotono> The ruins of a world, dotted craters and scenes of devastated villages and cities. Directly below you is a large island, with a great, burning city of furnaces and volcanic spires. Below the surface you can see that it is like an iceberg - just the tip of it is above you. It's like an upside down mountain, lava weeping from dozens of waterfalls in the Lower Polis. In a few places, gaps can be
[19:24] <Kotono> seen, cave-cities broken apart and glimpsed.
[19:25] * Afina grits her teeth. "Go!" she hisses, willing the lead elements to take the field and punish the monsters that have violated her word so, if only to speed the time when she to gets to enter the fray.
[19:26] <Jaela> Can this world even be saved? The question occupies Jaela as she waits for her debute.
[19:27] * Muirfinn grimaces, his beak curving sharply. "Disgusting. We will recover our home, even if we must do it bit by bit." Muirfinn says as he prepares himself.
[19:27] <Kotono> With this, the gates of Aurora surge open, the armies passing out! Adrian watches on, jaw clenched. He exhales through his nose as the roar of battle commences! OOC: All of you just going to be watching and waiting for your moment?
[19:28] <Afina> OOC: Yes. We'll order the retreat or dispatch reserves if shit hits the fan, but otherwise we're waiting for our step in the plan.
[19:32] <Kotono> Before you, the battle is joined! The armies of Aurora cascade down like the wrath of all the Gods, plummeling ahead! At this the Aeropolish glows red, great bursts of fire and brimstone fired out! You can see the army advancing on, enduring and pressing! As this goes on, Tepen is heard in all your minds, "The armies are advancing well and dealing with the artillery. Losses are minimal so far
[19:32] <Kotono> - suggestion is that we caught them off guard."
[19:33] <Jaela> "That's good," Jaela responds, looking on.
[19:33] <Afina> "Everyone's probably fighting over who's in charge right now," Afina thinks with some satisfaction. "Lets move forward, now. Once the defences are stripped it's our turn."
[19:33] <Muirfinn> "We should press the advantage, then." Muirfinn responds. "Do not give them time to regroup and push us back."
[19:35] <Kotono> 'Understood,' Tepen replies, 'We are pressing the advantage.' The armies rush ahead, pressing through the brimstone cannons and returning fire! On they rush, streaming down! After another few minutes the brimstone cannons begin to dim and slow, stopping! In your mind, 'Report - the insides are in chaos!' Tepen calls, 'There's some sort of inter-devil conflict going on, as well as unconfirmed
[19:35] <Kotono> reports of some sort of battle in the Lower Polis. Details sketchy. Also, Dana's down, maybe dead. She had to disable a cannon herself, and it exploded in her face.'
[19:36] * Ithea inhales a deep breath of air at that, biting the lower part of her lip with concern for the crazed princess.
[19:37] <Jaela> "Make sure she's recovered," Jaela voices, thinking to the others as well, before turning towards Afina. "Want to move out now?"
[19:37] <Afina> "Get that confirmed, they have healers there! Make sure her body is recovered if nothing else can be done," Afina insists, heading out the gate, "Come on it's our turn. Jaela, you have our destination?"
[19:37] * Muirfinn shakes his head. "Damn. If she is truly dead, we must honor her sacrifice. I am ready."
[19:38] <Kotono> Adrian bites off a curse, "At worst, they'll reward her for bravery," he mutters, shaking his head. Holding his amulet tight, nodding. 'Report,' Tepen adds quickly, 'The sphere of dragonfire is unmanned right now, attempting to destroy or procure.'
[19:39] <Jaela> It only takes a step to get past the gates, and then Jaela focuses on their target. "I'm bringing us over," she informs Tepen, and then her magic is invoked!
[19:39] <Afina> "Give priority to siezing it, but if that's impossible then deny it to the devils," Afina reiterates her orders as they shift to the prison.
[19:41] <Kotono> It is smoky here. It's painfully hard to breathe, the air stale, foul and miserable. You stand in a small chamber, dark and forgotten. A door is ahead of you, carved of stone. The walls are warm enough to glow red, providing illumination.
[19:41] <Muirfinn> "May the Mother Ocean hold us in her embrace." Muirfinn utters the brief prayer as they shift. Immediately he looks around, looking for threats. OOC: True Seeing on!
[19:42] * Jaela looks about for magic, to better understand any mechanisms the devils might have for controlling the place.
[19:42] <Kotono> OOC: Spellcraft, Jaela.
[19:42] <Afina> "Hanna, bring down that door!"
[19:42] <Jaela> roll 1d20+28
[19:42] * Hatbot --> "Jaela rolls 1d20+28 and gets 32." [1d20=4]
[19:44] <Jaela> "Magic's in flux," she says curtly afterwards. "Let's hurry."
[19:45] <Kotono> Hanna goes forward, striking at the door again and again! With her axe and all of her power, the door is easily battered down! Ahead of you is a dim hall. To the left it extends out into a larger hall, pillared and glowing red. To the right you can see a doorway, made of rusted iron with a small, barred window in it. There is writing in Infernal above the door. As you step up, you can hear
[19:45] <Kotono> clamoring and clattering from the hall to the left.
[19:45] * Muirfinn looks left!
[19:45] * Afina quickly scans the writing.
[19:46] <Kotono> You can see four of them - orthons, the same creatures you battled with Ithea in Earth. They are fighting a pair of black winged cornugons, locked in vicious combat! The writing above the door stays 'Redemption and education center'.
[19:47] * Jaela heads for the right!
[19:47] * Muirfinn follows! Let the devils destroy each other!
[19:47] <Afina> Letting someone else do door-breaking duties, Afina hurries into the education center!
[19:48] * Muirfinn whips out a wand and taps the door! OOC: Crumble! Nice and quiet! Ignores hardness. 10d8 damage. Door have SR?
[19:49] * Ithea silently follows after the others, just keeping her ears and eyes open and watching their backs.
[19:50] <Muirfinn> roll 10d8
[19:50] * Hatbot --> "Muirfinn rolls 10d8 and gets 47." [10d8=7, 5, 3, 5, 5, 7, 2, 1, 6, 6]
[19:50] <Kotono> With a few words of magic, the door crumbles! Ahead is a small anteroom, another door 10ft away. But before you, throughly blocking the way? Two more orthons, each with hellspears in hand! In Infernal they roar, "Glory for Gramath!" they shout! OOC: Init. Door's 5ft wide and right past it are the two orthons, so getting in and range will be a concern.
[19:50] <Kotono> roll 1d20+14 Adrian (+3 Lief)
[19:50] * Hatbot --> "Kotono rolls 1d20+14 Adrian (+3 Lief) and gets 28." [1d20=14]
[19:50] <Kotono> roll 1d20+1 Orthon 1
[19:50] * Hatbot --> "Kotono rolls 1d20+1 Orthon 1 and gets 7." [1d20=6]
[19:50] <Jaela> roll 1d20+11+6
[19:50] <Kotono> roll 1d20+1 Orthon 2
[19:50] * Hatbot --> "Kotono rolls 1d20+1 Orthon 2 and gets 2." [1d20=1]
[19:50] * Hatbot --> "Jaela rolls 1d20+11+6 and gets 25." [1d20=8]
[19:50] <Muirfinn> roll 1d20+10+3+3
[19:50] * Hatbot --> "Muirfinn rolls 1d20+10+3+3 and gets 36." [1d20=20]
[19:51] <Jaela> roll 1d20+10+6 Hanna
[19:51] * Hatbot --> "Jaela rolls 1d20+10+6 Hanna and gets 20." [1d20=4]
[19:51] * Kotono changes topic to 'Adrian(28)>Orthon 1(7)>Orthon 2(2)'
[19:51] <Afina> roll 1d20+26 Afina
[19:51] * Hatbot --> "Afina rolls 1d20+26 Afina and gets 36." [1d20=10]
[19:51] <Ithea> roll d20+21
[19:51] * Hatbot --> "Ithea rolls d20+21 and gets 28." [d20=7]
[19:51] <Muirfinn> roll 1d20+4+3+3 elemental
[19:51] * Hatbot --> "Muirfinn rolls 1d20+4+3+3 elemental and gets 30." [1d20=20]
[19:51] <Afina> roll 1d20+15 Lief
[19:51] * Hatbot --> "Afina rolls 1d20+15 Lief and gets 28." [1d20=13]
[19:51] * Kotono changes topic to 'Afina=Muirfinn(36)>Adrian(28)>Jaela(25)>Hanna(20)>Orthon 1(7)>Orthon 2(2)'
[19:51] * Kotono changes topic to 'Afina=Muirfinn(36)>Ithea=Adrian(28)>Jaela(25)>Hanna(20)>Orthon 1(7)>Orthon 2(2)'
[19:51] * Kotono changes topic to 'Afina=Muirfinn(36)>Elemental(30)>Lief=Ithea=Adrian(28)>Jaela(25)>Hanna(20)>Orthon 1(7)>Orthon 2(2)'
[19:52] <Kotono> OOC: Open, Afina'n'Muirfinn.
[19:52] <Afina> Tiny as she is, Afina can easily get past the brutish and ugly devils, flying in past themn towards the next door and giving both a stab for their trouble!
[19:52] <Afina> roll 1d20+42 haste orthon 1
[19:52] * Hatbot --> "Afina rolls 1d20+42 haste orthon 1 and gets 50." [1d20=8]
[19:52] <Afina> roll 1d20+37 haste orthon 2
[19:52] * Hatbot --> "Afina rolls 1d20+37 haste orthon 2 and gets 55." [1d20=18]
[19:53] <Kotono> OOC: Both hit.
[19:53] <Afina> roll 1d4+19+5d6+2d6+2d6+2d6
[19:53] * Hatbot --> "Afina rolls 1d4+19+5d6+2d6+2d6+2d6 and gets 61." [1d4=3][5d6=3, 6, 6, 6, 3][2d6=1, 2][2d6=6, 2][2d6=3, 1]
[19:53] * Hatbot --> "Afina rolls 1d4+19+5d6+2d6+2d6+2d6 and gets 56." [1d4=3][5d6=2, 3, 5, 1, 3][2d6=2, 5][2d6=6, 3][2d6=2, 2]
[19:53] * Muirfinn abruptly shifts into the massive stony form of an earth elemental, reaching in through the doorway and smacking them profusely! OOC Reach 15ft
[19:53] <Kotono> The orthons are both wounded, maggot filled bodies leaking blood and vermin out as they are sliced! OOC: Go for it.
[19:53] <Muirfinn> roll 1d20+31
[19:53] * Hatbot --> "Muirfinn rolls 1d20+31 and gets 33." [1d20=2]
[19:53] * Hatbot --> "Muirfinn rolls 1d20+31 and gets 35." [1d20=4]
[19:53] * Hatbot --> "Muirfinn rolls 1d20+31 and gets 44." [1d20=13]
[19:53] <Muirfinn> roll 1d20+26
[19:53] <Muirfinn> roll 1d20+21
[19:53] * Hatbot --> "Muirfinn rolls 1d20+26 and gets 42." [1d20=16]
[19:53] * Hatbot --> "Muirfinn rolls 1d20+21 and gets 23." [1d20=2]
[19:54] <Kotono> OOC: Three hits.
[19:54] <Muirfinn> roll 22d+4+14
[19:54] * Hatbot --> "Muirfinn rolls 22d+4+14 and gets Error: Number of sides must be integer greater than 0."
[19:54] <Muirfinn> roll 2d8+4+14
[19:54] * Hatbot --> "Muirfinn rolls 2d8+4+14 and gets 22." [2d8=3, 1]
[19:54] * Hatbot --> "Muirfinn rolls 2d8+4+14 and gets 26." [2d8=2, 6]
[19:54] * Hatbot --> "Muirfinn rolls 2d8+4+14 and gets 23." [2d8=1, 4]
[19:54] <Kotono> OOC: Which Orthon are you smacking?
[19:54] <Muirfinn> OOC: Lefty.
[19:54] <Kotono> OOC: What does your unarmed strike count as for DR?
[19:55] <Muirfinn> OOC: Magic
[19:56] <Kotono> The orthon is beaten and battered, resisting the blows and staying up! Behind you the din of war continues, as in your minds, 'Update. Dragonfire sphere destroyed,' Tepen reports, 'Ebony severely wounded, perhaps dead. Reports unclear due to Canderella summoning a massive storm.' OOC: Elemental, go.
[19:57] <Muirfinn> The elemental reaches forward as well, eagerly smashing the orthons, as they do not seem to have fire on them!
[19:57] <Muirfinn> roll 1d20+18
[19:57] * Hatbot --> "Muirfinn rolls 1d20+18 and gets 25." [1d20=7]
[19:57] * Hatbot --> "Muirfinn rolls 1d20+18 and gets 26." [1d20=8]
[19:57] * Hatbot --> "Muirfinn rolls 1d20+18 and gets 36." [1d20=18]
[19:57] <Kotono> OOC: One hit.
[19:58] <Muirfinn> roll 2d10+7 physical
[19:58] * Hatbot --> "Muirfinn rolls 2d10+7 physical and gets 23." [2d10=6, 10]
[19:58] <Kotono> Two blows, but both bounce off the orthon and the last staggers it further! OOC: Lief'n'Ithea'n'Adrian. Go, trio.
[19:59] <Afina> Nocking his bow, Lief fires a spray of arrows at the two devils blocking their path, splitting them equally!
[19:59] <Afina> roll 1d20+32 orthon 1
[19:59] * Hatbot --> "Afina rolls 1d20+32 orthon 1 and gets 44." [1d20=12]
[19:59] <Afina> roll 1d20+32 orthon 2
[19:59] <Kotono> For a moment, the ground beneath you quivers, as if in the palm of a moment's earthquake!
[19:59] * Hatbot --> "Afina rolls 1d20+32 orthon 2 and gets 42." [1d20=10]
[19:59] * Hatbot --> "Afina rolls 1d20+32 orthon 1 and gets 35." [1d20=3]
[19:59] <Afina> roll 1d20+27 orthon 2
[19:59] * Hatbot --> "Afina rolls 1d20+27 orthon 2 and gets 29." [1d20=2]
[19:59] <Afina> roll 1d20+22 orthon 1
[19:59] * Hatbot --> "Afina rolls 1d20+22 orthon 1 and gets 27." [1d20=5]
[19:59] <Kotono> OOC: Three hits.
[19:59] <Afina> roll 1d6+20+4d6+2d6
[19:59] * Hatbot --> "Afina rolls 1d6+20+4d6+2d6 and gets 40." [1d6=1][4d6=4, 3, 1, 3][2d6=4, 4]
[19:59] * Hatbot --> "Afina rolls 1d6+20+4d6+2d6 and gets 45." [1d6=5][4d6=5, 2, 5, 6][2d6=1, 1]
[19:59] * Hatbot --> "Afina rolls 1d6+20+4d6+2d6 and gets 49." [1d6=6][4d6=2, 6, 1, 5][2d6=4, 5]
[20:00] <Kotono> OOC: What do his arrows count as for DR?
[20:00] <Afina> OOC: I've no idea what material he uses, but otherwise just magic.
[20:01] <Kotono> Under that hail of arrows, the first orthon stumbles and falls! His body shudders and erupts in maggots, gnawing and biting everyone around! OOC: Only Afina's within range, sinc eeveryone else is using ranged attacks.
[20:01] <Kotono> roll 2d6 Afina
[20:01] * Hatbot --> "Kotono rolls 2d6 Afina and gets 8." [2d6=3, 5]
[20:02] * Ithea focuses her attacks on the remaining orthon, not even bothering to enhance her attacks with arcane power.
[20:02] <Ithea> roll d20+35
[20:02] * Hatbot --> "Ithea rolls d20+35 and gets 46." [d20=11]
[20:02] * Hatbot --> "Ithea rolls d20+35 and gets 53." [d20=18]
[20:02] <Ithea> roll d20+30
[20:02] * Hatbot --> "Ithea rolls d20+30 and gets 34." [d20=4]
[20:02] <Ithea> roll d20+25
[20:02] * Hatbot --> "Ithea rolls d20+25 and gets 45." [d20=20]
[20:02] <Ithea> roll d20+20
[20:02] * Hatbot --> "Ithea rolls d20+20 and gets 40." [d20=20]
[20:02] <Ithea> roll d20+25 crit?
[20:02] * Hatbot --> "Ithea rolls d20+25 crit? and gets 43." [d20=18]
[20:02] <Ithea> roll d20+20 crit?
[20:02] * Hatbot --> "Ithea rolls d20+20 crit? and gets 39." [d20=19]
[20:02] <Kotono> The maggots get on Afina, hungrily gnawing on her! OOC: Full success. Pain train.
[20:03] <Ithea> roll 9d10+189+10d6
[20:03] * Hatbot --> "Ithea rolls 9d10+189+10d6 and gets 271." [9d10=10, 2, 8, 5, 1, 6, 3, 2, 5][10d6=6, 3, 3, 6, 3, 3, 6, 5, 4, 1]
[20:03] <Kotono> Under a blisteringly fast assault, Ithea stabs and slices the surviving orthon! It collapses, run through thrice! Maggots explode out from it, again landing on Afina!
[20:03] <Kotono> roll 2d6
[20:03] * Hatbot --> "Kotono rolls 2d6 and gets 9." [2d6=5, 4]
[20:03] <Kotono> OOC: Free act.
[20:03] * Jaela rushes past the disgusting devils as they collapse, trying to open the door ahead!
[20:04] * Muirfinn hesitates, then shifts back to his natural form. Ducking through the doorway, he says, "Not so tough when you're not ambushing folks, eh?"
[20:05] * Ithea just shakes her head as she moves past the maggots and keeps moving.
[20:06] <Kotono> The door ahead opens! Ahead is a long, dark hall. Each side of the hall has a dozen doors, locked tightly shut. 15ft ahead are two more orthons, barring the way! 10ft past that a humanoid. A human, painted in red. He wears naught but pants, eyes focused and fixed ahead. Pointing, "We shall be the ones to convert the prisoners!" he howls, "For the glory of Gramath!" OOC: Init.
[20:06] <Jaela> roll 1d20+10+6 Hanna
[20:06] * Hatbot --> "Jaela rolls 1d20+10+6 Hanna and gets 36." [1d20=20]
[20:06] <Jaela> roll 1d20+11+6
[20:07] * Hatbot --> "Jaela rolls 1d20+11+6 and gets 32." [1d20=15]
[20:07] <Muirfinn> roll 1d20+10+6 Muirfinn
[20:07] <Afina> roll 1d20+26 Afina
[20:07] * Hatbot --> "Muirfinn rolls 1d20+10+6 Muirfinn and gets 33." [1d20=17]
[20:07] * Hatbot --> "Afina rolls 1d20+26 Afina and gets 35." [1d20=9]
[20:07] <Kotono> roll 1d20+14 Adrian
[20:07] * Hatbot --> "Kotono rolls 1d20+14 Adrian and gets 18." [1d20=4]
[20:07] <Afina> roll 1d20+15 Lief
[20:07] * Hatbot --> "Afina rolls 1d20+15 Lief and gets 18." [1d20=3]
[20:07] <Ithea> roll d20+16
[20:07] * Hatbot --> "Ithea rolls d20+16 and gets 18." [d20=2]
[20:07] <Kotono> roll 1d20+1 Orthon 1
[20:07] * Hatbot --> "Kotono rolls 1d20+1 Orthon 1 and gets 7." [1d20=6]
[20:07] <Muirfinn> roll 1d20+4+6 elemental
[20:07] * Hatbot --> "Muirfinn rolls 1d20+4+6 elemental and gets 29." [1d20=19]
[20:07] <Kotono> roll 1d20+1 Orthon 2
[20:07] * Hatbot --> "Kotono rolls 1d20+1 Orthon 2 and gets 10." [1d20=9]
[20:07] <Kotono> roll 1d20+16 man
[20:07] * Hatbot --> "Kotono rolls 1d20+16 man and gets 34." [1d20=18]
[20:07] * Kotono changes topic to 'Hanna(36)>Afina(35)>Muirfinn(33)>Jaela(32)'
[20:08] * Kotono changes topic to 'Hanna(36)>Afina(35)>Muirfinn(33)>Jaela(32)>Adrian=Lief=Ithea(18)'
[20:09] * Kotono changes topic to 'Hanna(36)>Afina(35)>Fanatic of Gramath(34)>Muirfinn(33)>Jaela(32)>Elemental(29)>Adrian=Lief=Ithea(18)>Orthon 2(10)>Orthon 1(7)'
[20:09] <Kotono> OOC: Hanna opens. Go.
[20:09] <Muirfinn> roll 1d20+24 Arcana wtf mate?
[20:09] * Hatbot --> "Muirfinn rolls 1d20+24 Arcana wtf mate? and gets 29." [1d20=5]
[20:10] <Ithea> roll d20+33 K:A who's the fanatic?
[20:10] * Hatbot --> "Ithea rolls d20+33 K:A who's the fanatic? and gets 37." [d20=4]
[20:10] <Jaela> A burst of holy light erupts around their Gramath-following enemies!
[20:10] <Jaela> roll 10d6 will DC20
[20:10] * Hatbot --> "Jaela rolls 10d6 will DC20 and gets 42." [10d6=4, 3, 1, 6, 2, 6, 5, 6, 6, 3]
[20:10] <Kotono> OOC: SR check.
[20:11] <Muirfinn> "One of Yian's students, then." Muirfinn deduces.
[20:11] <Jaela> roll 1d20+16
[20:11] * Hatbot --> "Jaela rolls 1d20+16 and gets 32." [1d20=16]
[20:11] <Jaela> roll 5d8
[20:11] * Hatbot --> "Jaela rolls 5d8 and gets 13." [5d8=2, 5, 1, 2, 3]
[20:11] <Kotono> roll 1d20+15 Orthon 1
[20:11] <Kotono> roll 1d20+15 Orthon 2
[20:11] * Hatbot --> "Kotono rolls 1d20+15 Orthon 1 and gets 27." [1d20=12]
[20:11] * Hatbot --> "Kotono rolls 1d20+15 Orthon 2 and gets 28." [1d20=13]
[20:11] <Kotono> roll 1d20+17 Fanatic
[20:11] * Hatbot --> "Kotono rolls 1d20+17 Fanatic and gets 35." [1d20=18]
[20:11] * Ithea nods in agreement. "Should be a joke, given what his master was like."
[20:12] <Kotono> The burst of holy light momentarily dazes the fiends, but nothing more! OOC: Afina, go.
[20:12] <Kotono> At that light and noise, you begin to hear it. From the cells, feeble cries. Common. Dwarven. Elven. Celestial. Other languages. One word, one theme. "Help!"
[20:13] * Afina zips forward, stabbing both orthons and stopping directly behind the painted man. "For Lifasa!" she cries in her cute high pitched voice in response to those cries.
[20:13] <Afina> roll 1d20+41 orthon 1
[20:13] * Hatbot --> "Afina rolls 1d20+41 orthon 1 and gets 43." [1d20=2]
[20:13] <Afina> roll 1d20+36 orthon 2
[20:13] * Hatbot --> "Afina rolls 1d20+36 orthon 2 and gets 52." [1d20=16]
[20:13] <Kotono> OOC: Two hits.
[20:13] <Afina> roll 1d4+19+5d6+2d6+2d6+2d6
[20:13] * Hatbot --> "Afina rolls 1d4+19+5d6+2d6+2d6+2d6 and gets 61." [1d4=1][5d6=2, 3, 6, 1, 4][2d6=5, 3][2d6=6, 6][2d6=2, 3]
[20:13] * Hatbot --> "Afina rolls 1d4+19+5d6+2d6+2d6+2d6 and gets 57." [1d4=1][5d6=4, 6, 5, 1, 3][2d6=2, 6][2d6=1, 1][2d6=5, 3]
[20:15] <Kotono> Both fiends are ripped open, as weak, hopeful cheers erupt out! A few also cry, "Makaril! It's the day of rebellion! Finally! Save us!" OOC: Fanatic is up.
[20:16] <Kotono> The fanatic grins ear to ear, blows striking out, "Die! Offer your spirits!" With that a flurry of punches and kicks follow~
[20:16] <Kotono> The fanatic grins ear to ear, blows striking out, "Die! Offer your spirits!" With that a flurry of punches and kicks follow!
[20:16] <Kotono> roll 1d20+23 vs Afina's AC
[20:16] * Hatbot --> "Kotono rolls 1d20+23 vs Afina's AC and gets 36." [1d20=13]
[20:16] * Hatbot --> "Kotono rolls 1d20+23 vs Afina's AC and gets 39." [1d20=16]
[20:16] * Hatbot --> "Kotono rolls 1d20+23 vs Afina's AC and gets 38." [1d20=15]
[20:16] <Kotono> roll 1d20+18
[20:16] * Hatbot --> "Kotono rolls 1d20+18 and gets 33." [1d20=15]
[20:16] <Kotono> roll 1d20+13
[20:16] * Hatbot --> "Kotono rolls 1d20+13 and gets 32." [1d20=19]
[20:16] <Afina> OOC: AC 51
[20:16] <Kotono> Yet his vented fury is effortlessly dodged by Afina, sidestepped swiftly! OOC: Muirfinn, go.
[20:17] <Muirfinn> Swiftly, Muirfinn takes the form of an earth elemental again and reaches out to pound on the man before him!
[20:17] <Muirfinn> roll 1d20+32 magic
[20:17] <Muirfinn> roll 1d20+27 magic
[20:17] <Muirfinn> roll 1d20+22 magic
[20:17] * Hatbot --> "Muirfinn rolls 1d20+32 magic and gets 47." [1d20=15]
[20:17] * Hatbot --> "Muirfinn rolls 1d20+32 magic and gets 48." [1d20=16]
[20:17] * Hatbot --> "Muirfinn rolls 1d20+32 magic and gets 37." [1d20=5]
[20:17] * Hatbot --> "Muirfinn rolls 1d20+27 magic and gets 36." [1d20=9]
[20:17] * Hatbot --> "Muirfinn rolls 1d20+22 magic and gets 31." [1d20=9]
[20:17] <Muirfinn> OOC: 15ft reach
[20:17] <Kotono> OOC: Five hits. Ow.
[20:18] <Muirfinn> OOC Nice!
[20:18] <Kotono> OOC: Though yes, 25ft away. You have reach, but not that much reach.
[20:18] <Kotono> OOC: You can just hit the orthons if you want, you're in reach of them.
[20:18] <Muirfinn> OOC: Oh blast. I'll hit an orthon then.
[20:19] <Muirfinn> roll 5#2d8+4+14
[20:19] * Hatbot --> "Muirfinn rolls 5#2d8+4+14 and gets 125." [5#2d8+4+14 = 27, 22, 26, 21, 29]
[20:19] * Kotono changes topic to 'Hanna(36)>Afina(35)>Fanatic of Gramath(34)>Muirfinn(33)>Jaela(32)>Elemental(29)>Adrian=Lief=Ithea(18)>Orthon 2(10)'
[20:20] <Kotono> Under that assault the first orthon crumbles away, exploding into maggots, but no one close enough to be a victim! A moment later, 'Alert! Report,' Tepen sounds in your minds, 'Reports of two possible Nessian Pit Fiends seen. Repeat, two possible Nessian Pit Fiends.' OOC: Jaela, go.
[20:21] <Jaela> 'Were Ebony and Dana recovered?' Jaela thinks back, lashing out at the remaining orthon. 'Is anyone stranded?'
[20:21] <Jaela> roll 1d20+23 planes devotion
[20:21] * Hatbot --> "Jaela rolls 1d20+23 planes devotion and gets 33." [1d20=10]
[20:22] <Kotono> 'Working on extracting them,' Tepen sends back. 'What about the Jarl? Are you falling back or what?'
[20:22] <Jaela> roll 1d20+32+8-17 PA
[20:22] * Hatbot --> "Jaela rolls 1d20+32+8-17 PA and gets 31." [1d20=8]
[20:22] * Hatbot --> "Jaela rolls 1d20+32+8-17 PA and gets 41." [1d20=18]
[20:23] <Jaela> roll 1d20+27+8-17 PA
[20:23] * Hatbot --> "Jaela rolls 1d20+27+8-17 PA and gets 31." [1d20=13]
[20:23] <Jaela> roll 1d20+22+8-17 PA
[20:23] <Kotono> OOC: All hit. It's gonna die.
[20:23] * Hatbot --> "Jaela rolls 1d20+22+8-17 PA and gets 17." [1d20=4]
[20:23] <Jaela> roll 3#1d8+26+4+4+8d6
[20:23] * Hatbot --> "Jaela rolls 3#1d8+26+4+4+8d6 and gets 208." [3#1d8+26+4+4+8d6 = 64, 75, 69]
[20:23] * Kotono changes topic to 'Hanna(36)>Afina(35)>Fanatic of Gramath(34)>Muirfinn(33)>Jaela(32)>Elemental(29)>Adrian=Lief=Ithea(18)'
[20:24] <Afina> "Prison has minimal resistance," Afina relays. "Begin withdrawal of all forces and retreat once they're aboard. Send the Jarl and we'll evacuate to Ysgard with everyone we can grab."
[20:24] <Kotono> In a pure, holy fury Jaela tears into the last Orthon, ripping it to shreds and maggots, before it can even act! OOC: Elemental, go.
[20:24] <Kotono> 'Understood.'
[20:24] <Muirfinn> The elemental surges forward over the corpses of the orthons, swinging madly at the red human!
[20:25] <Muirfinn> roll 1d20+18
[20:25] * Hatbot --> "Muirfinn rolls 1d20+18 and gets 38." [1d20=20]
[20:25] <Muirfinn> OOC: DOUBLE CRIT
[20:25] <Kotono> OOC: Pain train city today.
[20:26] <Muirfinn> roll 4d10+14
[20:26] * Hatbot --> "Muirfinn rolls 4d10+14 and gets 38." [4d10=6, 4, 5, 9]
[20:26] <Muirfinn> OOC: Alas, only the one hit
[20:26] <Kotono> The human catches the blow dead on, rocked back! OOC: Adrian'n'Lief'n'Ithea, go.
[20:26] <Ithea> With a flick of her hand, Ithea's reach extends even more than usual, as her glaive tears into the fanatic's flesh with furious strikes, planning to finish the man off right there and then. (ooc: using greatreach bracers to get 25ft reach)
[20:26] <Ithea> roll d20+35
[20:26] * Hatbot --> "Ithea rolls d20+35 and gets 46." [d20=11]
[20:26] * Hatbot --> "Ithea rolls d20+35 and gets 51." [d20=16]
[20:26] <Ithea> roll d20+30
[20:26] * Hatbot --> "Ithea rolls d20+30 and gets 41." [d20=11]
[20:26] <Ithea> roll d20+25
[20:26] * Hatbot --> "Ithea rolls d20+25 and gets 37." [d20=12]
[20:26] <Ithea> roll d20+20
[20:26] * Hatbot --> "Ithea rolls d20+20 and gets 23." [d20=3]
[20:28] <Kotono> OOC: Four hits.
[20:28] <Ithea> roll 4d10+76+8d6
[20:28] * Hatbot --> "Ithea rolls 4d10+76+8d6 and gets 129." [4d10=5, 3, 6, 6][8d6=6, 1, 4, 5, 1, 4, 6, 6]
[20:29] <Kotono> The man is impaled and battered down, run through! He falls to his knees and collapses with a curse, slain! OOC: No free act. Lief, go.
[20:29] <Kotono> Adrian looks about, going to the nearest prison door. He gives it a pull, "Needs a key," he calls over his shoulder, "Check the corpses!"
[20:30] <Afina> Lief zips over to see if either of them possess keys for the cells.
[20:30] <Afina> roll 1d20+21 search?
[20:30] * Hatbot --> "Afina rolls 1d20+21 search? and gets 29." [1d20=8]
[20:31] <Kotono> Lief finds a key on the dead man! At that...(More)
[20:34] <Kotono> 30ft away from the slain man, the floor glows red and erupts out! The floor shudders an dshakes, contorting and growing bigger and bigger! At last the ground itself screams in agony, hissing, burning magma erupting in all directions! What comes through is 27 feet tall. It looms over you like a mountain, somehow managing to fit itself seamlessly into the hall. It is a pit fiend, clad in darkness,
[20:34] <Kotono> wearing it like armor. Its claws and mouth crackle with hellfire, a horrible sense of oppression and pure hatred battering against each of you like a ram. In a voice from the depths of damnation, it lets out a mighty battle cry that shakes all the ground, and advances! OOC: It's joining init.
[20:34] <Kotono> roll 1d20+17
[20:34] * Hatbot --> "Kotono rolls 1d20+17 and gets 26." [1d20=9]
[20:34] * Kotono changes topic to 'Hanna(36)>Afina(35)>Fanatic of Gramath(34)>Muirfinn(33)>Jaela(32)>Elemental(29)>Nessian Pit Fiend(26)>Adrian=Lief=Ithea(18)'
[20:34] <Kotono> OOC: Hanna, go.
[20:35] <Kotono> OOC: 20ft fear aura, make a save if you're not immune and get that close.
[20:35] * Kotono changes topic to 'Hanna(36)>Afina(35)?Muirfinn(33)>Jaela(32)>Elemental(29)>Nessian Pit Fiend(26)>Adrian=Lief=Ithea(18)'
[20:35] * Kotono changes topic to 'Hanna(36)>Afina(35)>Muirfinn(33)>Jaela(32)>Elemental(29)>Nessian Pit Fiend(26)>Adrian=Lief=Ithea(18)'
[20:35] <Jaela> OOC: Hanna and myself have greater heroism
[20:35] <Ithea> roll d20+30+6 (using inspiration)
[20:35] * Hatbot --> "Ithea rolls d20+30+6 (using inspiration) and gets 46." [d20=10]
[20:36] <Kotono> OOC: If you get that close, Ithea. You aren't yet.
[20:36] <Muirfinn> "I believe we have been located by a Nessian Pit Fiend." Muirfinn relays back to Tepen and the others.
[20:37] <Kotono> Screams of horror sound, replacing the cheers of salvation from the cells!
[20:41] <Jaela> Hanna charges the emerging pit fiend down with a roar!
[20:42] <Kotono> OOC: What's Hanna's reach?
[20:42] <Jaela> OOC: She's large, so 10ft
[20:42] <Kotono> OOC: She'll eat an AoO going in, okay with that?
[20:42] <Jaela> OOC: Yes
[20:43] <Kotono> roll 1d20+57
[20:43] * Hatbot --> "Kotono rolls 1d20+57  and gets 62." [1d20=5]
[20:43] <Kotono> roll 4d8+17+2d6 (2d6 is hellfire, beats her DR)
[20:43] * Hatbot --> "Kotono rolls 4d8+17+2d6 (2d6 is hellfire, beats her DR) and gets 40." [4d8=8, 6, 1, 5][2d6=2, 1]
[20:43] <Kotono> OOC: Attack.
[20:44] <Jaela> roll 1d20+31+4+3+6+2 smite, rage, charge
[20:44] * Hatbot --> "Jaela rolls 1d20+31+4+3+6+2 smite, rage, charge and gets 56." [1d20=10]
[20:44] <Kotono> OOC: Hit.
[20:44] <Kotono> OOC: Make a fort save after damage.
[20:45] <Jaela> roll 3d6+21+4+10
[20:45] * Hatbot --> "Jaela rolls 3d6+21+4+10 and gets 45." [3d6=3, 2, 5]
[20:45] <Jaela> roll 1d20+25+4 (+4 vs evil, +4 vs poison)
[20:45] * Hatbot --> "Jaela rolls 1d20+25+4 (+4 vs evil, +4 vs poison) and gets 39." [1d20=10]
[20:45] <Kotono> The two trade blows, the Nessian striking first! It rips into Hanna's shoulder, cauterizing the wound instantly! It's still a horrible gash of burnt flesh, as she brings her axe down! It has trouble penetrating the fiend, but still manages to draw across the front of his scales! OOC: Afina, go.
[20:45] <Jaela> roll 3d10+10 heal
[20:45] * Hatbot --> "Jaela rolls 3d10+10 heal and gets 25." [3d10=2, 6, 7]
[20:45] <Kotono> OOC: Fortitude save.
[20:46] <Kotono> OOC: Oh wait, already made it. Dur.
[20:46] <Kotono> OOC: Afina.
[20:46] * Kallen (Kallen@ppp59-167-140-198.static.internode.on.net) Quit (Ping timeout)
[20:47] <Afina> "We're engaging the Nessian!" Afina relays to Tepen. "Continue the retreat and wish us luck! Hanna's wounded it!" she concludes that last on a pleased note, seeing they're not invincible. Charging forward herself to join the assault, she stabs the Nessian twice once in the chest the next in the neck as she ascends to the level of its head!
[20:47] <Afina> roll 1d20+49 7th level arcane strike
[20:47] * Hatbot --> "Afina rolls 1d20+49 7th level arcane strike and gets 63." [1d20=14]
[20:47] <Afina> roll 1d20+44 7th level arcane strike
[20:47] * Hatbot --> "Afina rolls 1d20+44 7th level arcane strike and gets 51." [1d20=7]
[20:47] <Kotono> OOC: Two hits.
[20:47] <Afina> roll 1d4+21+5d6+2d6+2d6+2d6+7d4
[20:47] * Hatbot --> "Afina rolls 1d4+21+5d6+2d6+2d6+2d6+7d4 and gets 85." [1d4=1][5d6=3, 2, 2, 4, 5][2d6=5, 5][2d6=4, 3][2d6=4, 3][7d4=4, 3, 3, 4, 3, 2, 4]
[20:47] * Hatbot --> "Afina rolls 1d4+21+5d6+2d6+2d6+2d6+7d4 and gets 81." [1d4=1][5d6=3, 5, 5, 2, 4][2d6=6, 1][2d6=2, 4][2d6=2, 3][7d4=1, 4, 4, 2, 4, 4, 3]
[20:48] <Kotono> Afina manages to scrape at it, opening deeper wounds with her two slashes! It seems only mildly wounded by the savaging, unbowed and unbloodied! OOC: Okay. Muirfinn, go.
[20:50] <Muirfinn> Muirfinn cautiously wades in closer to the pit fiend. OOC: Roll will vs. fear?
[20:50] <Kotono> OOC: Yes.
[20:51] <Muirfinn> roll 1d20+36
[20:51] * Hatbot --> "Muirfinn rolls 1d20+36 and gets 54." [1d20=18]
[20:51] <Kotono> OOC: Success.
[20:51] <Muirfinn> roll 1d20+31+1
[20:51] * Hatbot --> "Muirfinn rolls 1d20+31+1 and gets 44." [1d20=12]
[20:51] <Kotono> IOOC: Hit.
[20:52] <Muirfinn> roll 2d8+4+14 magic
[20:52] * Hatbot --> "Muirfinn rolls 2d8+4+14 magic and gets 30." [2d8=7, 5]
[20:53] <Kotono> Muirfinn closes in, slamming the fiend hard! It doesn't even buckle at the blow, barely  moved at all! OOC: Okay. Jaela, go.
[20:53] <Kotono> 'We're extracting successfully, Jarl is positioning,' Tepen is heard.
[20:54] * Jaela charges in after her mother with Gae Dioltas, a golden light settling around her to bolster everyone's defenses! Once her strike finds purchase, she settles into her familiar stance to trade blows with the fiend, Gae Bolg ready to respond to its attacks!
[20:54] <Kotono> OOC: Reach?
[20:55] <Jaela> roll 1d20+33+8+11 charging smite, divine might, protection devotion as swift, reach 10ft
[20:55] * Hatbot --> "Jaela rolls 1d20+33+8+11 charging smite, divine might, protection devotion as swift, reach 10ft and gets 63." [1d20=11]
[20:55] <Kotono> OOC: You'll eat an AoO, lemme resolve that real quick.
[20:55] <Kotono> roll 1d20+57
[20:55] * Hatbot --> "Kotono rolls 1d20+57 and gets 69." [1d20=12]
[20:55] <Kotono> roll 4d8+17+2d6 (2d6 is hellfire, beats your DR)
[20:55] * Hatbot --> "Kotono rolls 4d8+17+2d6 (2d6 is hellfire, beats your DR) and gets 42." [4d8=3, 2, 6, 7][2d6=4, 3]
[20:56] <Kotono> OOC: Hit, damage.
[20:56] <Jaela> roll 3d8+144+33 silver/good
[20:56] * Hatbot --> "Jaela rolls 3d8+144+33 silver/good and gets 197." [3d8=8, 5, 7]
[20:57] <Kotono> Jaela charges in, managing stab deep into the fiend! Pure black blood comes from the wound, already starting to mend itself! OOC: Elemental, go.
[20:58] <Muirfinn> The elemental wades in as well, heedless of danger! Things are going so well!
[20:58] <Muirfinn> roll 1d20+7 vs. fear!
[20:58] * Hatbot --> "Muirfinn rolls 1d20+7 vs. fear! and gets 9." [1d20=2]
[20:59] <Muirfinn> OOC: SHocking!
[20:59] <Kotono> OOC: Feared. It's panicked.
[20:59] <Jaela> roll 1d20+40 fort
[20:59] <Muirfinn> The elemental abruptly turns and flees at speed!
[20:59] * Hatbot --> "Jaela rolls 1d20+40 fort and gets 41." [1d20=1]
[20:59] <Kotono> roll 1d6 str damage Jaela
[20:59] * Hatbot --> "Kotono rolls 1d6 str damage Jaela and gets 4." [1d6=4]
[20:59] <Muirfinn> roll 1d20+30+6 fort
[20:59] * Hatbot --> "Muirfinn rolls 1d20+30+6 fort and gets 38." [1d20=2]
[21:00] <Afina> roll 2#1d20+23
[21:00] * Hatbot --> "Afina rolls 2#1d20+23 and gets 60." [2#1d20+23 = 31, 29]
[21:00] <Kotono> As the elemental flees, the great fiend before you roars! It holds upt a fist, a sun-bright burst of hellish energies erupting out around it! OOC: Sr check first.
[21:00] <Kotono> roll 1d20+37 don't think this fails to beat anyone's SR.
[21:00] * Hatbot --> "Kotono rolls 1d20+37 don't think this fails to beat anyone's SR. and gets 53." [1d20=16]
[21:01] <Kotono> OOC: Reflex saves, everyone but Adrian, Lief and Ithea.
[21:01] <Jaela> OOC: Is he casting? Can I try to interrupt?
[21:01] <Kotono> OOC: You can try.
[21:01] <Jaela> "Fuck no!" Jaela cries out as hellish energies start gathering all around them.
[21:01] <Jaela> roll 1d20+25
[21:01] * Hatbot --> "Jaela rolls 1d20+25 and gets 26." [1d20=1]
[21:02] <Afina> roll 1d20+38 Afina reflex
[21:02] * Hatbot --> "Afina rolls 1d20+38 Afina reflex and gets 48." [1d20=10]
[21:02] <Kotono> OOC: Hatebot today. 2nd 1 in a row. Reflex saves, all. Note if you have evasion as normal.
[21:02] <Afina> OOC: Evasion
[21:02] <Jaela> roll 1d20+38
[21:02] * Hatbot --> "Jaela rolls 1d20+38 and gets 39." [1d20=1]
[21:02] <Kotono> OOC: 3rd 1 in a row. Wow.
[21:02] <Muirfinn> roll 1d20+25+6 evasion Muirfinn
[21:02] * Hatbot --> "Muirfinn rolls 1d20+25+6 evasion Muirfinn and gets 44." [1d20=13]
[21:02] <Jaela> roll 1d20+29 (+4 vs evil) Hanna
[21:02] * Hatbot --> "Jaela rolls 1d20+29 (+4 vs evil) Hanna and gets 42." [1d20=13]
[21:02] <Muirfinn> roll 1d20+9 elemental if still in range
[21:03] * Hatbot --> "Muirfinn rolls 1d20+9 elemental if still in range and gets 21." [1d20=12]
[21:03] <Kotono> OOC: 30 fire + 30 vile untyped + 30 sonic + 30 vile untyped + 30 acid + 30 vile untyped +30 electricity + 30 vile untyped. Jaela takes full, Afina and Muirfinn evade. Hanna takes half.
[21:08] <Kotono> Amid the burst of elemental fury the Nessian stands unharmed! Somehow Afina is too fast and Muirfinn too fluid to be routed, but Hanna is caught and burned and infected with evil, as Jaela is painfully tossed about by the energies! A moment later the beast erupts around you, a flurry of utter devastation and destruction in martial form! OOC: Attacking.
[21:09] <Kotono> roll 1d20+47 (-10 PA) claw 1 Jaela
[21:09] * Hatbot --> "Kotono rolls 1d20+47 (-10 PA) claw 1 Jaela and gets 67." [1d20=20]
[21:09] <Kotono> roll 1d20+47 (-10 PA) claw 1 Jaela ow
[21:09] * Hatbot --> "Kotono rolls 1d20+47 (-10 PA) claw 1 Jaela ow and gets 64." [1d20=17]
[21:09] <Kotono> OOC: +4 hit/damage due to gambit. Make your AoO while I tally the damage.
[21:10] <Jaela> roll 1d20+32+8+4-2+6 still divine might, Gae Bolg
[21:10] * Hatbot --> "Jaela rolls 1d20+32+8+4-2+6 still divine might, Gae Bolg and gets 54." [1d20=6]
[21:10] <Kotono> OOC: Hit.
[21:11] <Jaela> 1d8+26+4+11+4+8d6-3+2 chaotic/good/silver/epic
[21:11] * Hatbot --> "Jaela rolls 1d8+26+4+11+4+8d6-3+2 chaotic/good/silver/epic and gets 79." [1d8=5][8d6=2, 5, 6, 1, 5, 1, 4, 6]
[21:11] <Kotono> roll 8d8+62+2d6 (2d6 is hellfire, beats DR, update HP since I'll do these blow by blow, this should trigger fortunate fate since you're HP with the vile damage is around 30ish.
[21:11] * Hatbot --> "Kotono rolls 8d8+62+2d6 (2d6 is hellfire, beats DR, update HP since I'll do these blow by blow, this should trigger fortunate fate since you're HP with the vile damage is around 30ish. and gets 109." [8d8=2, 6, 8, 1, 5, 2, 8, 5][2d6=4, 6]
[21:13] <Kotono> roll 1d20+47 (-10 PA, +4 gambit) claw 1 Jaela
[21:13] * Hatbot --> "Kotono rolls 1d20+47 (-10 PA, +4 gambit) claw 1 Jaela and gets 60." [1d20=13]
[21:13] <Kotono> roll 4d8+31+2d6
[21:13] * Hatbot --> "Kotono rolls 4d8+31+2d6 and gets 63." [4d8=4, 7, 8, 3][2d6=4, 6]
[21:14] <Jaela> roll 1d20+32+8+4-2+6+11 AoO, smite
[21:14] * Hatbot --> "Jaela rolls 1d20+32+8+4-2+6+11 AoO, smite and gets 60." [1d20=1]
[21:14] <Kotono> OOC: Mother of God, Hatbot.
[21:14] <Kotono> roll 1d20+42 (-10 PA, +4 gambit) claw 1 Jaela
[21:14] * Hatbot --> "Kotono rolls 1d20+42 (-10 PA, +4 gambit) claw 1 Jaela and gets 44." [1d20=2]
[21:14] <Kotono> OOC: AC?
[21:15] <Jaela> OOC: 47, 45 after charging
[21:15] <Jaela> roll 1d20+32+8+4-2+6+11 AoO, smite2
[21:15] * Hatbot --> "Jaela rolls 1d20+32+8+4-2+6+11 AoO, smite2 and gets 61." [1d20=2]
[21:15] <Kotono> OOC: Hit.
[21:15] <Jaela> 1d8+26+4+11+4+8d6-3+2+7 chaotic/good/silver/epic
[21:15] * Hatbot --> "Jaela rolls 1d8+26+4+11+4+8d6-3+2+7 chaotic/good/silver/epic and gets 88." [1d8=8][8d6=2, 1, 5, 3, 4, 4, 4, 6]
[21:15] <Kotono> roll 1d20+37 (-10 PA, +4 gambit) claw 1 Jaela
[21:15] * Hatbot --> "Kotono rolls 1d20+37 (-10 PA, +4 gambit) claw 1 Jaela and gets 50." [1d20=13]
[21:16] <Kotono> roll 4d8+31+2d6
[21:16] * Hatbot --> "Kotono rolls 4d8+31+2d6 and gets 68." [4d8=8, 7, 8, 8][2d6=3, 3]
[21:16] <Kotono> OOC: You know Hatbot, one off max damage from the claw is really just trolling.
[21:17] <Kotono> In that first flurry of claws Jaela is ripped open, magic working to seal her wounds! For a few moments it saves her, as she strikes back! She scores a pair of deep wounds on the beast, but its fury undimished! With a thrust it pierces Jaela's heart, sending her tumbling in a spray of blood! It's other claw strikes out now, going for Hanna!
[21:17] <Kotono>  roll 1d20+47 (-10 PA) claw 2 Hanna
[21:18] <Kotono> roll 1d20+47 (-10 PA) claw 2 Hanna
[21:18] * Hatbot --> "Kotono rolls 1d20+47 (-10 PA) claw 2 Hanna and gets 48." [1d20=1]
[21:18] <Kotono> roll 1d20+42 (-10 PA) claw 2 Hanna
[21:18] * Hatbot --> "Kotono rolls 1d20+42 (-10 PA) claw 2 Hanna and gets 49." [1d20=7]
[21:18] <Kotono> OOC: Hanna's AC?
[21:19] <Jaela> OOC: 45
[21:19] <Kotono> roll 4d8+31+2d6
[21:19] * Hatbot --> "Kotono rolls 4d8+31+2d6 and gets 56." [4d8=4, 8, 6, 2][2d6=2, 3]
[21:19] <Kotono> roll 1d20+37 (-10 PA) claw 2 Hanna
[21:19] * Hatbot --> "Kotono rolls 1d20+37 (-10 PA) claw 2 Hanna and gets 49." [1d20=12]
[21:19] <Kotono> roll 1d20+32 (-10 PA) claw 2 Hanna
[21:19] * Hatbot --> "Kotono rolls 1d20+32 (-10 PA) claw 2 Hanna and gets 33." [1d20=1]
[21:19] * Hatbot --> "Kotono rolls 4d8+31+2d6 and gets 60." [4d8=8, 5, 2, 2][2d6=6, 6]
[21:20] <Kotono> roll 1d20+47 (-10 PA) bite
[21:20] * Hatbot --> "Kotono rolls 1d20+47 (-10 PA) bite and gets 56." [1d20=9]
[21:20] <Kotono> OOC: Hanna again.
[21:20] <Kotono> roll 6d6+8+2d6 and two fort saves, Hanna.
[21:20] * Hatbot --> "Kotono rolls 6d6+8+2d6 and two fort saves, Hanna. and gets 29." [6d6=1, 6, 1, 1, 3, 1][2d6=2, 6]
[21:21] <Jaela> roll 2#1d20+26+7
[21:21] * Hatbot --> "Jaela rolls 2#1d20+26+7 and gets 86." [2#1d20+26+7 = 52, 34]
[21:22] <Kotono> roll 2d6 str damage Hanna, diseased.
[21:22] * Hatbot --> "Kotono rolls 2d6 str damage Hanna, diseased. and gets 8." [2d6=3, 5]
[21:22] <Kotono> roll 1d20+47 (-10 PA) wing 1
[21:22] * Hatbot --> "Kotono rolls 1d20+47 (-10 PA) wing 1 and gets 48." [1d20=1]
[21:22] <Kotono> roll 1d20+47 (-10 PA) wing 2
[21:22] * Hatbot --> "Kotono rolls 1d20+47 (-10 PA) wing 2 and gets 57." [1d20=10]
[21:22] <Kotono> roll 3d6+8+2d6 Hanna gain
[21:22] * Hatbot --> "Kotono rolls 3d6+8+2d6 Hanna gain and gets 23." [3d6=4, 6, 2][2d6=2, 1]
[21:22] <Kotono> roll 1d20+47 tail
[21:22] * Hatbot --> "Kotono rolls 1d20+47 tail and gets 50." [1d20=3]
[21:23] <Kotono> roll 3d8+8+2d6
[21:23] * Hatbot --> "Kotono rolls 3d8+8+2d6 and gets 28." [3d8=1, 6, 6][2d6=1, 6]
[21:23] <Kotono> A moment later, Hanna is savaged and beaten! Her body is broken twice over, bloodied and given new holes in her chest and stomach! How she lives is a matter of pure motherly rage and wrath, enduring wounds that would kill a normal man a thousand times over! OOC: Ow. Adrian'n'Lief'Ithea.
[21:24] <Kotono> "Shit!" Adrian curses low, "Jaela!"
[21:25] * Muirfinn shakes his rocky head. Nothing can be done for her right now. They must keep the rest alive for the time being, then ressurrections can be seen to.
[21:25] <Afina> Silently, Lief unleashes another storm of arrows at the pit fiend to try and somehow help!
[21:25] <Afina> roll 1d20+37
[21:25] * Hatbot --> "Afina rolls 1d20+37 and gets 45." [1d20=8]
[21:25] * Hatbot --> "Afina rolls 1d20+37 and gets 57." [1d20=20]
[21:25] * Hatbot --> "Afina rolls 1d20+37 and gets 49." [1d20=12]
[21:25] <Afina> roll 1d20+32
[21:25] * Hatbot --> "Afina rolls 1d20+32 and gets 42." [1d20=10]
[21:25] <Afina> roll 1d20+27
[21:25] * Hatbot --> "Afina rolls 1d20+27 and gets 38." [1d20=11]
[21:25] <Afina> roll 1d20+37 crit check
[21:25] * Hatbot --> "Afina rolls 1d20+37 crit check and gets 56." [1d20=19]
[21:25] <Kotono> OOC: One hit, but it's ac rit.
[21:26] <Afina> roll 3d6+60+5d6+2d6
[21:26] * Hatbot --> "Afina rolls 3d6+60+5d6+2d6 and gets 85." [3d6=3, 3, 1][5d6=4, 1, 3, 1, 4][2d6=1, 4]
[21:26] * Ithea hisses at the sight resulting from the devil's attack, a mixture of shock and fury as she sees Jaela fall, but refusing to let this turn them back as she immediately attempts to make an appearance right behind the devil, flanking the creature with Hanna, so that if she can't finish it off, Hanna has a chance to do so. But she'll certainly do her damnest to be the one to make it fall! (OOC: dimension hop, vampiric touch, AS 5)
[21:27] <Ithea> roll d20+42
[21:27] <Afina> "Jaela's down. We're having trouble here," Afina reports to Tepen, grimly setting herself to make sure Jaela's death and all the other deaths endured today will mean something.
[21:27] * Hatbot --> "Ithea rolls d20+42 and gets 46." [d20=4]
[21:27] * Hatbot --> "Ithea rolls d20+42 and gets 45." [d20=3]
[21:27] <Ithea> roll d20+37
[21:27] * Hatbot --> "Ithea rolls d20+37 and gets 53." [d20=16]
[21:27] <Ithea> roll d20+32
[21:27] * Hatbot --> "Ithea rolls d20+32 and gets 34." [d20=2]
[21:27] <Ithea> roll d20+27
[21:27] * Hatbot --> "Ithea rolls d20+27 and gets 34." [d20=7]
[21:28] <Kotono> OOC: One hit.
[21:28] <Ithea> roll d20+25 SR
[21:28] * Hatbot --> "Ithea rolls d20+25 SR and gets 39." [d20=14]
[21:29] <Kotono> OOC: No joy there.
[21:29] <Ithea> roll d10+21+2d6+5d4
[21:29] * Hatbot --> "Ithea rolls d10+21+2d6+5d4 and gets 46." [d10=3][2d6=3, 6][5d4=4, 4, 3, 1, 1]
[21:30] <Kotono> Ithea teleports in, savaging the beast with her slashes! She only manages one hit, a scraping blow! A moment later Adrian takes a breath and charges in, even as the Nessian strikes at him!
[21:30] <Kotono> roll 1d20+47 AoO
[21:30] * Hatbot --> "Kotono rolls 1d20+47 AoO and gets 53." [1d20=6]
[21:30] <Kotono> roll 4d8+27+2d6 OOC: Also, refund Hanna 4 HP from each hit, I had the gambit damage boost still in there.
[21:30] * Hatbot --> "Kotono rolls 4d8+27+2d6 OOC: Also, refund Hanna 4 HP from each hit, I had the gambit damage boost still in there. and gets 57." [4d8=4, 8, 5, 8][2d6=4, 1]
[21:31] <Kotono> roll 1d20+20 will save, also, for fear
[21:31] * Hatbot --> "Kotono rolls 1d20+20 will save, also, for fear and gets 25." [1d20=5]
[21:31] <Ithea> roll d20+30+6 oh yeah, I didn't roll my will save.
[21:31] * Hatbot --> "Ithea rolls d20+30+6 oh yeah, I didn't roll my will save. and gets 37." [d20=1]
[21:31] <Ithea> ooc: Goddammit Hatbot
[21:31] <Kotono> OOC: You can keep the previous one you rolled, at least.
[21:32] <Ithea> ooc: oh, thank you then
[21:32] <Kotono> Adrian charges in, but as he gets close, his eyes widen and he breaks! With a scream he whirls around and flees! OOC: Strike the AoO, fleeing triggers before the AoO. OOC: Hanna.
[21:33] * Kotono changes topic to 'Hanna(36)>Afina(35)>Muirfinn(33)>Elemental(29)>Nessian Pit Fiend(26)>Adrian=Lief=Ithea(18)'
[21:34] <Kotono> OOC: Also will again for the unholy aura, Ithea. I'm terrible about remembering that ability.
[21:34] <Jaela> Displaying a rage unlike she had ever shown before, Hanna cuts into the pit fiend's flanks with her axe!
[21:34] <Kotono> OOC: Fort, excuse me.
[21:35] <Jaela> roll 1d20+31+6
[21:35] * Hatbot --> "Jaela rolls 1d20+31+6 and gets 41." [1d20=4]
[21:35] * Hatbot --> "Jaela rolls 1d20+31+6 and gets 42." [1d20=5]
[21:35] <Jaela> roll 1d20+26+6
[21:35] * Hatbot --> "Jaela rolls 1d20+26+6 and gets 36." [1d20=4]
[21:35] <Jaela> roll 1d20+21+6
[21:35] * Hatbot --> "Jaela rolls 1d20+21+6 and gets 30." [1d20=3]
[21:35] <Jaela> roll 1d20+16+6
[21:35] * Hatbot --> "Jaela rolls 1d20+16+6 and gets 29." [1d20=7]
[21:35] <Ithea> roll d20+28 fort
[21:35] * Hatbot --> "Ithea rolls d20+28 fort and gets 48." [d20=20]
[21:35] <Kotono> Hanna strikes and strikes and strikes! Yet with the fiend's guard up, none of them can successfully land! OOC: Afina.
[21:38] <Afina> Stabbing the pit fiend twice, Afina then flies back towards Adrian, intending to fix his fear problem quickly before he gets lost in the Aeropolis.
[21:38] <Afina> roll 1d20+49 7th level arcane strike
[21:38] * Hatbot --> "Afina rolls 1d20+49 7th level arcane strike and gets 55." [1d20=6]
[21:38] <Afina> roll 1d20+44 7th level arcane strike
[21:38] * Hatbot --> "Afina rolls 1d20+44 7th level arcane strike and gets 60." [1d20=16]
[21:38] <Kotono> OOC: Two hits.
[21:38] <Afina> roll 1d4+21+5d6+2d6+2d6+2d6+7d4
[21:38] * Hatbot --> "Afina rolls 1d4+21+5d6+2d6+2d6+2d6+7d4 and gets 86." [1d4=3][5d6=6, 1, 6, 4, 2][2d6=3, 1][2d6=6, 3][2d6=5, 5][7d4=4, 1, 4, 1, 3, 4, 3]
[21:38] * Hatbot --> "Afina rolls 1d4+21+5d6+2d6+2d6+2d6+7d4 and gets 82." [1d4=3][5d6=3, 4, 5, 4, 1][2d6=3, 5][2d6=4, 6][2d6=1, 4][7d4=2, 2, 4, 1, 1, 4, 4]
[21:38] <Ithea> ooc: using Opportunist after Afina
[21:39] <Kotono> OOC: Go for it.
[21:40] <Ithea> Hanna seemed plagued by the same (actually, probably worse given their relation) shock of Jaela's fall, but Afina's cool and calm collected attacks get Ithea focused again as she tries to dig her glaive into the devil's side from behind.
[21:40] <Ithea> roll d20+44
[21:40] * Hatbot --> "Ithea rolls d20+44 and gets 64." [d20=20]
[21:40] <Ithea> roll d20+44 crit?
[21:40] * Hatbot --> "Ithea rolls d20+44 crit? and gets 48." [d20=4]
[21:40] <Kotono> OOC: Normal hit. Teasebot.
[21:40] <Ithea> ooc: oh yeah, forgot flank
[21:40] <Kotono> OOC: Damage and then fort. Fort as well for yours, Afina.
[21:40] <Kotono> OOC: Crit.
[21:41] <Afina> roll 2#1d20+23
[21:41] * Hatbot --> "Afina rolls 2#1d20+23 and gets 55." [2#1d20+23 = 24, 31]
[21:41] <Kotono> roll 1d6 str damage Afina
[21:41] * Hatbot --> "Kotono rolls 1d6 str damage Afina and gets 2." [1d6=2]
[21:41] <Ithea> roll d20+25 SR
[21:41] * Hatbot --> "Ithea rolls d20+25 SR and gets 27." [d20=2]
[21:41] <Ithea> roll 3d10+63+2d6+5d4
[21:41] * Hatbot --> "Ithea rolls 3d10+63+2d6+5d4 and gets 97." [3d10=4, 7, 9][2d6=1, 2][5d4=2, 2, 4, 1, 2]
[21:42] <Kotono> With a desperate, full on lunge, Ithea impales the back of the beast! She finds the perfect spot, plunging into its heart! The beast stumbles forward and on to a knee, overcome! OOC: Muirfinn, go.
[21:45] <Muirfinn> Muirfinn melts down to proper size in a hurry, pointing at Hanna and muttering a powerful word of healing! OOC: Heal, 30ft range. Ends all ability damage, diseases, etc. 150hp restored.
[21:45] <Kotono> OOC: Okay. Nessian is up.
[21:45] <Kotono> The Nessian Pit Fiend attempts to rise...but falls to its knees, unable to act, bleeding badly! OOC: Adrian, Lief and Ithea. Go.
[21:45] <Kotono> Adrian continues to run, out into the anteroom now!
[21:46] <Afina> "It's down!" Lief celebrates, going to unlock the nearest cell while trusting others to keep the devil that way.
[21:46] <Kotono> Within the cell are dozens of humanoids, filthy. They wear rags, crammed together like clothes in a closet. They stare up at Lief with shocked eyes, "One of the rebels!" A cheer erupts, as they begin to stumble out!
[21:46] <Afina> "Nessian is down," Afina calmly relays to Tepen for her part.
[21:46] <Ithea> "Still not dead for good, so let's make sure that's the case!" Ithea exclaims as she continues attacking the fiend.
[21:47] <Ithea> ooc: vampiric touch+as5 again
[21:47] <Ithea> roll d20+42
[21:47] * Hatbot --> "Ithea rolls d20+42 and gets 52." [d20=10]
[21:47] * Hatbot --> "Ithea rolls d20+42 and gets 53." [d20=11]
[21:47] <Ithea> roll d20+37
[21:47] * Hatbot --> "Ithea rolls d20+37 and gets 53." [d20=16]
[21:47] <Ithea> roll d20+32
[21:47] * Hatbot --> "Ithea rolls d20+32 and gets 33." [d20=1]
[21:47] <Ithea> roll d20+27
[21:47] * Hatbot --> "Ithea rolls d20+27 and gets 29." [d20=2]
[21:47] <Kotono> OOC: Three hits.
[21:48] <Ithea> roll 3#d10+21+2d6+5d4
[21:48] * Hatbot --> "Ithea rolls 3#d10+21+2d6+5d4 and gets 138." [3#d10+21+2d6+5d4 = 53, 41, 44]
[21:48] <Ithea> roll d20+25 SR
[21:48] * Hatbot --> "Ithea rolls d20+25 SR and gets 34." [d20=9]
[21:48] <Kotono> OOC: What's your weapon count as again, real quick?
[21:48] <Ithea> ooc: good+silver
[21:49] <Kotono> The fiend is stabbed again and again! It's still kneeling, dazed but not dead! Meanwhile, Afina can see the Jarl peeking into the anteroom, almost running into Adrian. "The ten-ack!" he grunts as Adrian run sright into him! OOC: Hanna, go.
[21:50] <Jaela> Hanna's rage has not run its course yet, and she continues to exact punishment out of the Nessian.
[21:50] <Jaela> roll 1d20+31+8+2
[21:50] * Hatbot --> "Jaela rolls 1d20+31+8+2 and gets 45." [1d20=4]
[21:50] * Hatbot --> "Jaela rolls 1d20+31+8+2 and gets 55." [1d20=14]
[21:50] <Jaela> roll 1d20+26+8+2+6 smite
[21:50] * Hatbot --> "Jaela rolls 1d20+26+8+2+6 smite and gets 55." [1d20=13]
[21:50] <Jaela> roll 1d20+21+8+2+6 smite
[21:50] * Hatbot --> "Jaela rolls 1d20+21+8+2+6 smite and gets 51." [1d20=14]
[21:50] <Jaela> roll 1d20+16+8+2+6 smite
[21:50] * Hatbot --> "Jaela rolls 1d20+16+8+2+6 smite and gets 43." [1d20=11]
[21:50] <Kotono> OOC: All hit.
[21:51] <Jaela> roll 5#3d6+21
[21:51] * Hatbot --> "Jaela rolls 5#3d6+21 and gets 164." [5#3d6+21 = 35, 25, 36, 33, 35]
[21:51] <Jaela> roll 164+30
[21:51] * Hatbot --> "Jaela rolls 164+30 and gets 194."
[21:51] <Kotono> Hanna further vents on the fiend, inflicting massive amounts of pain and sending it onto the floor - but yet it lives! OOC: Afina.
[21:51] <Afina> "I'll get Adrian, go help get the prisoners loaded, we have a lot of doors to break down!" Afina tells the Jarl, rushing after Adrian and casting greater heroism on him. With that done she momentarily speeds herself up immensely and zips back into the hall, casting metal melt on the door opposite the one Lief just opened.
[21:51] <Ithea> ooc: I'll use opportunist here, why not
[21:52] <Afina> OOC: 6th level spell for 1 round time stop
[21:52] * Ithea joins Hanna in finishing off the pit fiend.
[21:52] <Kotono> OOC: Go for it, Ithea.
[21:52] <Ithea> roll d20+46
[21:52] * Hatbot --> "Ithea rolls d20+46 and gets 48." [d20=2]
[21:52] <Kotono> OOC: Hit.
[21:52] <Ithea> roll d10+21+2d6+5d4
[21:52] * Hatbot --> "Ithea rolls d10+21+2d6+5d4 and gets 44." [d10=3][2d6=4, 3][5d4=2, 3, 1, 4, 3]
[21:52] <Ithea> roll d20+25 SR
[21:52] * Hatbot --> "Ithea rolls d20+25 SR and gets 42." [d20=17]
[21:53] <Kotono> Another door melts down, as the Nessian Pit Fiend eats another stabbing and is torn open further! Inside you can see it has no organs, no bones - only an inky red darkness, leaking out blood.
[21:53] <Kotono> More prisoners flee out, hurrying away! Adrian stares a moment and bites off a savage curse, as...OOC: Muirfinn.
[21:54] <Ithea> roll d20+33 K:P why won't it just die?
[21:54] * Hatbot --> "Ithea rolls d20+33 K:P why won't it just die?  and gets 46." [d20=13]
[21:55] * Muirfinn calls down holy fire during a moment where the hall is clear, hoping that a wash of holy flame will put the thing out of their misery! OOC: Flame Strike, situated so it dosn' hit everybody
[21:55] <Muirfinn> roll 1d20+20 SR check
[21:56] * Hatbot --> "Muirfinn rolls 1d20+20 SR check and gets 26." [1d20=6]
[21:56] <Kotono> But the holy flames sputter against the Nessian, not even harming it in the least! OOC: Elemental is still panicked. OOC: Adrian+Lief+Ithea threesome. Go.
[21:57] <Ithea> "Adrian, grab Jaela's spear and help kill it!" Ithea exclaims to Adrian in frustration, as she attempts to just cut off it's head. (OOC: coup de grace)
[21:57] <Kotono> Adrian turns back around, shame written on his face. Heading back, he gestures, "This way! This way to freedom!" he calls.
[21:57] <Afina> Not stopping to bask in adulation, Lief goes to open the next door! "Follow that guy!" he points at the giant.
[21:58] <Kotono> OOC: Crit confirm, roll the damage.
[21:58] <Ithea> roll 3d10+63+2d6
[21:58] * Hatbot --> "Ithea rolls 3d10+63+2d6 and gets 94." [3d10=10, 7, 7][2d6=2, 5]
[21:58] <Kotono> roll 1d20 needs a 20.
[21:58] * Hatbot --> "Kotono rolls 1d20 needs a 20. and gets 14." [1d20=14]
[21:59] <Kotono> With a final slash the Nessian is beheaded! It's entire form quakes and dissolves into rich red blood, soaking into the ground like fire, melting it down! All that's left in its wake is the scent of Hell, and a pair of fire-scarred iron rings. OOC: Free act.
[21:59] <Kotono> Hanna's rage seems to leave her at once, exhaling heavily. With a quietly blank face she kneels, gently picking up Jaela and her weapon. She strokes her cheek and closes her eyes with her fingers, whispering something to her.
[22:00] <Kotono> Lief flies about, opening door after door! "This way! Hurry!" Lief calls, "Out this way!"
[22:00] <Ithea> "Never mind!" Ithea says to Adrian, stepping over the fiend's body to Hanna's side to...well, how -does- one help with that? Changing her mind, she instead goes help guide the former prisoners out.
[22:00] * Afina helps Lief by melting a few doors herself. "Tepen, what's the situation?" she asks while they do their part.
[22:01] * Muirfinn begins throwing open doors as well, wand at the ready to break down more doors.
[22:02] <Kotono> 'Extraction successful,' he reports, 'We made it. Going through casulaties now. They don't look that bad overall. We lost Dana and Ebony. Ebony and Canderella were together, and Ebony took an assassin devil's blade for her.'
[22:02] <Afina> "Jaela on our side. We'll see about resurrections once we regroup," Afina replies as she continues melting down doors.
[22:03] <Kotono> Prisoners, filthy and stinking, erupt out! Room after room empties, as they hurry out! AS they go, Lief flutters over, "Oooh, battle bounty," he says, "Are the ring safe to take?"
[22:03] <Kotono> 'Understood,' Tepen says after a moment's pause.
[22:03] <Afina> "Just don't wear them," Afina suggests, sheparding the prisoners towards the tent.
[22:04] <Kotono> The rings are taken as the fortress shakes again! The prisoners fill into the tent, soon leaving captivity behind! Coming around the tent and into the anteroom as the PCs see the last of them...a lantern archon? A little lantern archon, flying in. "Oh my!" it calls, "Hello? Hello?"
[22:05] <Kotono> *at the party
[22:05] <Afina> "This way," Afina gestures to it, her grudge against another lantern archon not involved here. "We're leaving any second now."
[22:06] * Muirfinn waves the archon forward as he checks the area once more. "That rumbling came before the last Nessian! We should go!
[22:06] <Muirfinn> "
[22:06] <Ithea> "Anybody else left?" Ithea says with a frown, focusing on any sounds of anybody left around that for whatever reason hasn't come out yet or whatnot, perhaps too injured from torture or whatever deviltry happens here.
[22:07] <Ithea> roll d20+44 listen
[22:07] * Hatbot --> "Ithea rolls d20+44 listen and gets 64." [d20=20]
[22:07] <Kotono> "I'm not a prisoner! I'm not leaving!" It shakes its head, "I'm investigating for Makaril! He's an angel leading a counter movement from the Lower Polis!" It speaks rapidly, "The devils are collapsing into civil war and we've taken several important points of the Lower Polis! We're going to destroy this abomination and have it rain down on all the devils on the surface!"
[22:09] <Ithea> "Guys!" Ithea exclaims as she doesn't hear prisoners left but does hear something else. "Something's coming from below! Fast and heavy! Might be another fiend!"
[22:09] * Muirfinn looks at the archon incredulously. "We have at least one incoming Nessian pit fiend I believe, and we would be hard pressed to take it on without a full company. If you are not joining us, I stronly suggest you leave!" Muirfinn heads toward the tent at all speed!
[22:09] <Afina> "Then it's a good thing we're leaving. We'll be in contact with Makaril soon, until then good luck!" Afina tells the archon before zipping into the tent. "Go!"
[22:10] <Kotono> "Okay!" It bobs in the air once, flying off the way it came, "Good fortune an dmay the Triad bless you!" Off it goes, off and away! OOC: Piling into the tent and shifting post-haste?
[22:10] <Ithea> ooc: yes
[22:10] <Muirfinn> OOC: Let's get the flock outta here
[22:11] <Kotono> Piling into the tent, the magic is activated as soon as the party is in! With a tent full of emancipated prisoners, the ground escapes out! In a moment you are in Ysgard, wounds healing and the bracing cold refreshing you. Cries of joy and disbelief come from the captured, many lying in exhaustion, more bones than skin.
[22:12] <Afina> "Aurora should be here soon. There'll be food and shelter for you there. And safety," Afina calls as she flies around the prisoners, looking out for said fortress, "Tepen, we've evacuated successfully. What's your situation?"
[22:12] <Kotono> 'We're good,' Tepen sends, 'Was the operation a success?'
[22:13] <Afina> "All prisoners were rescued. We made brief contact with a member of Makaril's resistance but had to leave before another Nessian arrived," Afina replies. "Hurry over, we've got a lot of scared and hungry people here."
[22:13] <Muirfinn> "Success enough." Muirfinn responds grimly. "Let's make sure the sacrifices were worth it."
[22:14] <Ithea> "Let's hope they don't remain sacrifices at all," Ithea says with a sigh. "But we'll have to wait and see."
[22:21] <Kotono> From there, the refugees are taken to Aurora and fed. As they're cleaned up, the group gathers in the morgue. Here three bodies lie. One is Dana - covered by a sheet, but the way the sheet lies suggests that her face is largely gone. The second is Ebony, face calm and unbloodied, lying in repose. The third is Jaela, lying in calm repose, face cleaned of blood and sadness. Hanna silently holds
[22:21] <Kotono> her hand. Priest enters and nods, "My services are needed," he says, going to Jaela first. He kneels before her, chanting and calling on the names of the Seladrine! After several long moments Jaela gasps for air, her eyes opening wide!
[22:21] <Kotono> You are somewhere silent and misty. Peaceful, serene, passing. You're taking a long walk and don't know why. Somewhere crystalline, somewhere beautiful...and then, the world returns to you, your eyes opening wide as you gasp for air.
[22:23] * Jaela takes a look about her, before relaxing and laying her head back on the slab.
[22:23] * Afina smiles in relief, fluttering over to join Hanna. "Welcome back, Jaela. We won."
[22:23] <Kotono> Hanna picks Jaela up and hugs her, a suffocatingly tight hug. She doesn't say anything, just holding her.
[22:26] <Kotono> Adrian exhales, "Welcome b ack," he says, as Priest smiles to Jaela, before going to Ebony. He begins to chant around her, invoking the names of the Seladrine!
[22:26] <Kotono> roll 1d100
[22:26] * Hatbot --> "Kotono rolls 1d100 and gets 100." [1d100=100]
[22:28] <Kotono> For long moments Priest chants, before he stops. He shakes his head, reaching out to pull the sheet over Ebony's head. "I couldn't reach her soul. Something intervened...I felt a warmth and love around her."
[22:28] * Jaela hangs her head, resting her cheek on her mother's shoulder.
[22:28] * Afina sighs softly, looking away. "Well, Sylica isn't far from here, is it?"
[22:28] <Kotono> "It isn't," Priest murmurs, "I daresay that perhaps her Goddess or a powerful force has intervened for her. Was she favored in her faith or by her Goddess?"
[22:29] <Kotono> Hanna brings Jaela's head up, and in a whisper, "I'm proud of you," she murmurs.
[22:29] <Jaela> "Yes," Jaela mumbles. "They liked her so much they told me to make sure she doesn't return too early."
[22:30] * Muirfinn winces slightly.
[22:30] * Jaela sighs, and shakes her head at her mother. "For something I did?"
[22:30] <Kotono> "I don't think resurrection spells can reach her now," Priest goes on to Dana, standing before her. "I suspect she is being reborn as a favored servant or blessed servitor to her Goddess." Turning to Dana he begins to chant - and so she sits up with a curse, face knitting! As it is restored from a burnt mess, "Fuck!" she grunts, "Aaaah, that huuuuurt good. Too good."
[22:31] <Afina> Afina likewise winces. "Even if her soul's already there, we can return her body home. I'll organise an honour guard from the Sylican detachment," she muses, perking up slightly as Dana returns to them.
[22:31] <Kotono> "Yes. Anyone can fight. Few can die bravely and selflessly. Martyrdom...well...don't do it, but if you have to, I'm proud of you for standing until the end fearlessly. Few can."
[22:33] <Jaela> "I'll die bravely as much as I need to," Jaela deadpans. "Anyway, screw the honor guard. I'll take her back myself right now, unless you guys need me for anything. I bet they'd want to punch someone for this."
[22:34] <Afina> "So good you had to come back and tell us about it?" Afina asks Dana, deadpan. At Jaela's strong suggestion she shrugs, "Very well, but I'll still come myself. It was my plan that put here there."
[22:35] <Kotono> Dana grins, "Hey, I died?" Shrugging, "At least I got up."
[22:36] <Ithea> "You're crazy, Dana," Ithea says with a shake of her head. "Going to consider that your most impressive death or something, aren't you?"
[22:36] * Muirfinn snorts quietly to himself.
[22:37] <Jaela> "I'm not really gonna wait," Jaela says, coming up to Ebony's body. "Let's go."
[22:42] <Kotono> Thus do Hanna, Jaela, Canderella and Afina gather. Canderella looks a little morose, but is unharmed.
[22:43] <Jaela> "I still have enough in me for a couple plane shifts, so we'll go by that oasis on Astral," Jaela says. She carries Ebony's cleaned and wrapped up body. With a moment for any objections, she calls upon her magic to transport them via that stop to the entrance to Sylica.
[22:45] <Kotono> A pair of hops has the duo before the cave to the portal to Sylica.
[22:46] <Afina> "This is it?" Afina checks with Jaela, flying inside a moment later. "How did it happen, Canderella?" she asks the succubus, her perception of the feint actions rather sketchy thanks to just having Tepen's reports to go on.
[22:47] <Jaela> "Yeah," Jaela responds. "We'll head for that mountain over there." She indicates Antenora's domain. "They already know we're here, so if they want to stop us earlier, it'll happen then."
[22:48] <Kotono> "We were wading in - we got forced forward by the flow of battle," Canderella's voice is a little morose, "Poor little thing. One of those blank faced dogai got behind us somehow and caught me by surprise, hissing about demon scum. Typical." After a moment, "Ebony shouldered me out of the way and begain a spell, smiting the devil even as it got her right in the heart. I think both of them died
[22:48] <Kotono> before they hit the ground." As you step in you enter through the Felic Gate. The Opal Mountain is before you - but as you have time to reflect, there is a ripple of magic. Antenora stands before you, opal eyes luminous. After a moment, "Alicia and Syala sensed you bringing in her mortal shell."
[22:50] * Afina nods, looking up at the angel, "I barely had time to know her, but she was nice... I think that's why she went the way she did, that niceness," she explains for what it's worth.
[22:51] * Jaela steps forward and offers Ebony's body to Antenora. "I'm so sorry. I failed at everything," she apologizes, lowering her head.
[22:51] <Kotono> "She was constantly atoning," Antenora replies, and after a moment, "I know what happened. Alicia called her to the mountain. We all felt her sacrifice." Here she sighs, offering her arms out, "May I have her?"
[22:52] * Jaela complies with Antenora's wishes in silence.
[22:54] <Kotono> Antenora takes the body in her arms, not sagging at the weight of ti in the least. Brushing aside the sheet hiding her face. She leans in, kissing Ebony's forehead, both her cheeks and then her lips. Soft, gentle kisses, and then in a murmur of Celestia, "Go now. You aren't needed anymore." The form of Ebony dissolves into motes of opal light, flying up into the sky above. With Ebony's shroud
[22:54] <Kotono> and clothes in her arm, "Alicia and Syala are both proud of her. In particular, Alicia understands sacrificing something for someone who may not even like you. She'll be reborn as herself, restored and given the form she's earned."
[22:56] <Jaela> "I'm happy she has great patrons like that," Jaela says, straightening up. She looks at Antenora and waits.
[22:58] <Kotono> "You did fail," she goes on, and with a hint of a smile, "Don't do it again. You're forgiven. Ebony will return to Aurora." AFter a moment, "We know your Crusade is a hard and dangerous one, and you need this help."
[22:59] * Jaela stares at her incredulously, before bowing deeply in place of any response.
[23:00] <Afina> Well, it was her plan that led to it... though whatever their losses, they won't reach the 999 rescued today. But she knew Ebony, so she has more prominence in her mind. "We'll welcome her back gladly, and have more care with how we use her," she promises.
[23:01] <Kotono> "It will be a little time," Antenora smiles faintly, "Pass onto our soldiers there that Ebony has passed into the Goddesses hands." Taking to the air, "I need to go now. We're all gathering to welcome Ebony to eternity, and she should awaken soon. Marie will never let me hear the end of it if I'm late, too."
[23:02] <Afina> "Goodbye," Afina waves as the angel ascends into the distance, turning to retreat back through the portal afterwards.
[23:02] <Kotono> Blink-blinking, Canderella stares a moment, before giggling into her hand. "I'd forgotten," she murmurs.
[23:03] <Jaela> "Forgotten what?" Jaela asks, the giggling being enough to cut through her shock.
[23:03] <Afina> "Forgotten what?" Afina asks Canderella curiously.
[23:03] * Jaela gives Afina a sideway glance and snorts.
[23:04] <Kotono> "Marie. Marielle. Alicia's familiar and a courre eladrin. Also Antenora's love and long time consort." Canderella says with a chuckle, "Ebony mentioned them to me."
[23:05] <Jaela> "Yeah. It's a very happy heaven."
[23:05] <Afina> "A courre? Aren't they the same size as me?" Afina asks, blinking. "Well, I suppose even some pixies go that way..."
[23:06] <Kotono> "Yes, and this one can change shape." Canderella waves a hand, "Once you can do that, size differences are a philsophical thing, nothing else."
[23:06] * Jaela carefully avoids looking at her mother. "Some people still can't get past that, you know? Or gender and the like. Anyway, we're going back?"
[23:07] <Afina> "I suppose," Afina shrugs, dismissing it. "Lets return. There's still much to do."
