General chatter
Started by Anastasia, March 23, 2013, 11:16:35 PM
Retraining prior to level up!
Swapping Deflect Arrows for Combat Reflexes
Swapping out Water Devotion for Wild Talent
Swapping sleight of hand skill for concentration
Druid to 7, Monk to 6.
HP goes to 63
Saves all go up by +1 from the Monk side of things.
Retraining Improved Initiative into Improved Natural Attacks for Unarmed strikes.
Taking Improved Trip from the 6th level free feat.
BAB goes up by... 1, I think?
I gain a 4th level spell!
Myann levels up!
- Dragonslayer 1 and Ranger 6.
- 6 on a d10 for 10 hit points total and a grand total of 52 hit points.
- BAB rises to +6. Myann gains a second iterative attack.
- Gains aura of courage. Handy in case fear shows up.
- Gains a +1 bonus to damage rolls against dragons. Useful in case another dragon shows up.
- Myann gains 6th level witch spellcasting. She gains 1 2nd level spell charge and 3 3rd level spell charges. She gains a new cantrip and a new 3rd level spell. She selects dancing lights and fire mushroom.
- +1 to all saves.
- Myann invests several ranks into appraise. I'm also treating it as a class skill for dragonslayers. This is partially a personal preference and partially because the class skill list gets torn up by Pathfinder. I admit I'm cheating a bit here, but I figure y'all are tired of hauling gear to appraisers by now.
- Myann retrains weapon focus into dodge. She selects iron will with her 6th level feat. This means +1 AC and +2 will saves.
- Myann's Still Spell feat is lost. In exchange, she gains the following: Fey Eyes (Su) Myann constantly sees invisible creatures, as if by a see invisibility spell with a caster level equal to her hit dice.
Pretty good level for her.
Fire Mushroom
Evocation [Fire]
Level: Sor/Wiz 3
Components: V, S, Special
Range: Close (25ft + 5ft/2 levels)
Target: One creature
Duration: 1 min/level (D)
Spell Resistance: No
For the duration of this spell, the target can emit orbs of fire as a standard action. These orbs require a ranged touch attack and have a range of 50ft. A successful hit deals 4d6 points of fire damage. Whenever the target of this spell next takes damage, the damage is negated and this spell ends.
If the target is under the effects of the Super Mushroom and Fire Mushroom spells at the same time, he loses the benefits of this spell first.
Special
This spell can only be cast by a creature that has a bond to mushrooms, such as a fey mantle relating to mushrooms.
Okay level, but the gains are mostly boringly mechanical. +1 to skirmish ac, bab, fort and ref. +5ft to speed. A bit longer duration on the dance since I forgot to calculate the class skill bonus last level. That's about it.
9hp, +2 ref/will, psionics, which is just casting inertial barrier all day erry day. Gonna take a while to warm this shit up.
Wait, what?
Isn't inertial barrier a 4th level power?
Inertial armour, rather. I do the same thing with divine power and divine favour.
Oh. That makes good sense for you.
Do me a favor and do an audit on my sheet please. I'm pretty sure I've got the HP right, but I'm honestly not sure if I ever totaled it up correctly from the beginning.
Sure. I'll do that and your spell question (higher up/last page, mental note) tonight-ish.
Make that this evening since I crashed super early.
Neph wanted a sheet audit so here we go.
- Running the numbers, your HP seems off by one. I came up with 62, not 63. Is there a +1 bonus I'm missing somewhere? If not, it's probably a minor math error.
- Your movement speed is wrong. Monk 6 grants the next increment of fast movement, up +20. This stacks with the other +10 you got for a total of +30 to movement. Remember that monk's speed bonuses apply to all modes of movement.
- Add improved trip or improved disarm for your level 6 monk bonus feat, unless you traded it out and I missed that.
- Add slow fall from monk.
- Saves check out, as do attack rolls and armor class.
- You haven't updated your spells yet, either. Really, it looks like your sheet isn't finished leveling, so get that done.
I believe everything is updated.
Whoops, forgot Myann's fey bloodline spell. She gains Mass Blockade as her 3rd level fey bloodline spell.
Mass Blockade
Conjuration (Creation)
Level: Drd 3, Rgr 3, Sor/Wiz 3
Range: Short (30ft + 5ft 2/levels)
Effect: 1 5ft cube of wood/level
Duration: 7 rounds
This spell functions as improved blockade, except that it conjures one block per caster level. Blocks may appear stacked on one another.
Could someone tally up all the treasures the party has to sell or otherwise sort from the last adventures?
