General chatter
Started by Anastasia, March 23, 2013, 11:16:35 PM
Rogue 10/psionic fist 4
+1 bab, +1 ref/will, crippling strike, 18 pp, strength of my enemy
And skills.
Push Myann stuff back to this weekend, since it'll take some doing on my end.
Let's get Myann's spells done.
First of all, she gets a new 3rd and 4th level spell charge. For spells known, she gets a new 2nd, 3rd and 4th level spell. She selects close wounds, jump block and restoration.
Jump Block
Conjuration (Creation)
Level: Drd 3, Rgr 3, Sor/Wiz 3
Range: Short (30ft + 5ft 2/levels)
Duration: 7 rounds
This spell functions as levitating blockade. In addition, this block is extremely bouncy. If leaped on as part of a jump check, it grants a +30 bonus to that check.
Two more potential custom spells with an ice theme. I have no idea if the damage/duration/whatever is appropriate.
Infusion of the Frozen North
Transmutation [Cold]
Level: Cleric 5, Sorcerer 5, Wizard 5, Druid 5, Ranger 5
Components: V, S,
Range: Touch
Target: One weapon
Duration: 1 round/level
Saving Throw: Fortitude negates (object, harmless)
Spell Resistance: Yes (harmless, object)
This spell adds bonus cold damage to a weapon, either naural or manufactured. In addition to whatever damage the weapon normally does, it now does an extra 2d6 cold damage on a successful hit. If the hit is a critical, it does <math>, if the critical is 3x, it does <math> and if 4x, <math>.
Ice Block Shot
Level: Drd 5, Rgr 5, Sor/Wiz 5
Components: V, S, M
Range: Medium (60ft + 5ft/level)
Effect: 1 10ft cube of ice
Duration: Instantaneous
Saving Throw: Ref partial; see text
Spell Resistance: No
This spell conjures a huge block of ice, much like a blockade spell. This block of ice appears and can be fired at a target as a free action at any point after its creation. If the block hits a target, it does 1d6 cold damage per caster level (Max 15d6) and must make a Reflex save or be knocked prone. After the block strikes a target, it shatters and leaves an area of 10 ft around the impact point slippery, requiring a DC 20 Acrobatics check to move into or out of the area or else the subject falls prone.
Level: Clr 5, Drd 5, Sor/Wiz 5
Components: V, S
Range: Touch
Target: One weapon
This spell adds bonus cold damage to a weapon, either naural or manufactured. In addition to whatever damage the weapon normally does, it now does an extra 2d6 cold damage on a successful hit. If the hit is a critical, it does 1d10 extra cold damage, if the critical is 3x, it does 2d10 extra cold damage and if 4x, 3d10 extra cold damage.
Ice Block Shot
Conjuration (Creation) [Cold]
Level: Drd 5, Sor/Wiz 5
Components: V, S
This spell conjures a huge block of ice, much like a blockade spell but made of ice. This block of ice appears and is fired at at a creature within range, this requires a ranged touch attack roll. If the block hits a target, it does 1d6 cold damage per caster level (Max 15d6) and the target must make a Reflex save or be knocked prone. After the block strikes a target, it shatters and leaves a 10ft area around the impact point slippery, requiring a DC 20 Acrobatics check to move into or out of the area or else the subject falls prone.
The changes to the first spell were mostly stylistic. It's basically a grow up version of a weapon of energy, without the choice but with more base damage. The second spell had some reorganization to make it work. I also dropped the 5th level ranger casting from both, as that's epic casting for a ranger and outside the scope of this game.
This look good for you, Neph?
That's fine and dandy.
Gildas is going to cast Lay of the Land in the morning, since the party is camped out at the moment.
There's no rivers above ground. You can sense belowground rivers - for whatever reason this segment of the Sidhe realm likes underground rivers, apparently.
21 miles west/northwest: Dannan Tathan. The home of Lady Valisha and her court.
47 miles south: Grailholm. A small city dedicated to nymphs.
18 miles south: Nameless lake. Filled with strange creatures of water, like John's previous summoned water elemental.
21 miles west: Lake Dravia. Home to the Endless Sisters.
4 miles east: Fairy Circle.
49 miles west: Fairy Circle.
19 miles southwest: Fairy Circle.
At the earliest opportunity John will retrain improved initiative for water devotion.
Whenever I can, I'd happily retrain the two weapon pounce into better TWF.
Yulia
HEY LISTEN!
I'd like to do a few more flavor posts for this game. You know, some things during the last arc. Are there any things y'all would like expanded on?
Maybe some on the paths we might not have taken? Off the top of my head, Crystal Spiders since that might've led us somewhere (maybe they're like the ants?). Maybe something on vampires, since we did sort of run across a really good-natured one...
Incidentally, Vasili's back. You may want to look into that.
Oh good, I can go bother him about things!
Yes, you can go bother him about things now. Yay!
