Gearing up (Moore, Ithea)
Started by Anastasia, December 10, 2015, 04:42:50 PM
"All right. I think we have as much in order as we really can." Moore nods.
From there it's not long for Ithea and Stille to join them, the four meeting...
Go ahead, y'all.
"Hello, Crystal, Moore. Elena mentioned you needed a gate somewhere?" Ithea asks, more of Crystal than Moore, though she turns to the new pixie and gestures between him and Stille.
"Oh, and Moore, have you had a chance to meet Stille before? He's my boyfriend, and Balyss' brother....actually, you've probably not met her yet given she was out all of yesterday from her divination. You're at least familiar with her name, I guess."
"I've heard it mentioned. It's good to meet you, Sir Stille!" Moore nods to him. He'll let Crystal answer Ithea's question since it'd be rather rude to answer on her behalf.
"Ah, Moore the Motivational Speaker!" Stille greets with a wide smile, "Good day, good day."
Crystal meanwhile says, "The Deep Ethereal. We know a location of a treasure hoard thanks to Baleruk." She quickly goes over the situation, ending with, "The closest land mark - as much as those matter three - is a floating set of trees called the Ghost Glade. Aim the portal there."
Ithea nods. "Okay, I can do that. Though before I open the portal, then in case Elena didn't mention it, a fair warning: I can't actually cast the gate spell myself, I use a trinket that's usable once a day. Any issues with being stuck there for a while?"
"That's fine," Crystal says, "Can you get us home if needed, Stille?"
To this Stille shakes his head, "Alas, I do not have the proper magic prepared, and do not refresh it until moonrise."
"Well, moonrise is still sooner than morning, at least. I do typically carry a scroll of sending on me as well. Anyway, if you're fine with it..."
With that, Ithea starts to lead the group to the gates of Aurora so she can open up a portal to where she was directed.
ooc: Did I need to roll K:P or anything to target the Ghost Glade?
I presume you're leaving Aurora first?
ooc: Oh right, yes. Edited post above.
"We'll be fine. I can find us a safe place to wait if we need it." Moore says as he goes along with the others.
No need. Any preparations before going out, y'all? Stille will note that Mind Blank may be a wise choice if possible.
If there is anyone available to cast it before we leave, might as well. Can we assume it gets done and we gate out? If there is a limited number of mind blanks not sure who best options might be though, probably we can discuss that IC then unless Neph or you have preferences there.
Moore would say he has plenty of protections on his own from things like that so if there was a limit then he'd offer it to the others.
> roll 1d4
<Serith> Infinite_Ko_Loop roll for Serith < 4 > [d4=4]
You're in luck, there's enough for everyone.  Anything else?
