Blown away (Moore)
Started by Anastasia, December 31, 2015, 05:50:06 PM
[12:16] <Nephrite> roll 1d20+20+4 Spot
[12:16] <Kobot> Nephrite rolled 1d20+20+4 Spot --> [ 1d20=6 ]{30}
There's a few cave entrances along the slopes. They're fairly visible, as slats of steel jut out from above the entrance, shielding them.
No harm in checking one out! Although... just to be on the safe side...
Moore's going to cast Safety on himself. It will last for 1 hour and he'll be able to find the shortest and most direct route to safety, which is "where the individual is not taking immediate damage from the environment, and immediate damage is not imminent." so it may not actually even do anything at all!
The spell has no immediate effect.
You're not taking damage or in imminent danger of taking damage, so no result for now. If that changes during the duration of the spell, you'll know.
Moore nods to himself. So no hidden assassins. Good!
He'll fly towards the first cave he can see!
The first cave you can see is about 3/4ths of the way to the top of the mountain. It's an unremarkable cave entrance, barring the metal slab keeping it shielded. It goes into the cave, quickly sloping downwards at a rather sharp angle.
Moore rubs his chin thoughtfully about that slope, but decides to fly in anyway and see where it goes!
Low light or darkvision, or any other way of seeing in darkness?
Low-light vision and I can cast Light if necessary.
Moore soon casts Light, the path pitch dark ahead. He follows the path, a sharp downward slope that winds around to the left. He's at this only a few minutes before he sees another source of light coming his way. A humanoid of some sort robed in blue, a white mask with swirls of green and blue decorating it. It floats just above the ground rather than walking. Light comes from its mask, shedding radiance all around it.
Well, the Light probably gives him away even if he's invisible, so he decides to make himself visible but keep a respectful distance.
"Greetings and salutations!" Moore will call out and offer a small bow. "Is this demiplane your handiwork?"
The creature advances, now only 30ft away. A voice comes from behind you, "Intruder. Exterminate."
Initiative here.
Oh dear.
[13:11] <Nephrite> roll 1d20+16 init
[13:11] <Kobot> Nephrite rolled 1d20+16 init --> [ 1d20=16 ]{32}
