Void strike (Jaela)
Started by Anastasia, February 03, 2016, 02:05:15 PM
Mirima dashes back the way they came to get out of here!
As Mirajane and the others flee, Jaela hurries back. Just at the corner she is nearly bowled over by Adrian and company - minus Mei. Canderella gets one look at the gap and flies as fast as she can towards the escape, Adrian and the others following. As they pass, he gets out, "Run!" to Jaela, barely heard over a growing vibration and humming.
Imbuing them all with Haste, Jaela follows along in confusion as her fiery crown keeps on clearing the nearby area of ghosts. "Where's Mei?" she asks, casting an eye back.
Vivantha can do naught but continue to fly, so fly she does.
Meanwhile, once they are properly outside where the healing spells worked properly, Mirajane checks whether telepathy has been restored and informs Tepen they are returning before using Greater Plane Shift to send herself, Mirima and Moonlight towards Aurora's gates.
"The rift got her," Adrian shouts as the two rush out, the entire building shuddering behind them.
Meanwhile, Mirajane uses her telepathy. No response - though with what's going on, it would probably count as planar interference.
Still going to shift?
9:26 PM <Rin> roll 1d20+32 K:P
9:26 PM <Serith> Rin roll for Serith < 50 > [d20=18]
With all that's goign on, Mirajane can tell that plane shifting's iffy at best. It might work, it might not and it probably won't be accurate if it does work.
Mirajane decides to risk it, after telling Moonlight and Mirima to hold onto her!
Caster level check, Mirajane.
9:34 PM <Rin> roll 1d20+22
9:34 PM <Serith> Rin roll for Serith < 38 > [d20=16]
> roll 1d100
<Serith> Kotono roll for Serith < 33 > [d100=33]
Mirajane and the others vanish, shaking.
Meanwhile Jaela and the others race out, as the crypt behind them crumbles. It is now mostly an ever expanding void, pulling at them as they escape.
Reflex saves, all.
I'll sort out the other group shortly.
[14:42] <Nephrite> roll 1d20+37+4 evasion (+4 celestial valor)
[14:42] <Serith> Nephrite roll for Serith < 52 > [d20=11]
10:01 PM <Rin> roll 1d20+33+4+2 +4 more vs evil
10:01 PM <Serith> Rin roll for Serith < 40 > [d20=1]
10:02 PM <Rin> roll 1d20+40+1+2+4
10:02 PM <Serith> Rin roll for Serith < 64 > [d20=17]
So Hanna rolled a 1. Can I use a quickened Resurgence to help her reroll?
No, there simply isn't time regardless of anything else.
> roll 1d20+41 Canderella
<Serith> Kotono roll for Serith < 46 > [d20=5]
> roll 1d20+23 Adrian
<Serith> Kotono roll for Serith < 37 > [d20=14]
> roll 1d20+23 Adrian
> roll 40d6 Hanna and Adrian, they'll both survive I think
<Serith> Kotono roll for Serith < 148 > [d6=5,1,3,5,2,3,3,1,4,6,4,6,4,5,2,1,3,6,4,6,5,5,3,6,3,2,3,4,1,3,2,4,5,4,2,4,4,5,4,5]
> roll 1d100
<Serith> Kotono roll for Serith < 93 > [d100=93]
Vivantha and Jaela rush onward, out of this maelstrom and away from the destroyed crypt. Canderella joins them, but Adrin and Hanna aren't so fast. Reality breaks down around this as they're sucked in, torn and ripped as they vanish. But the other two are clear, able to act as the torrent continues.
I'll sort them out as well shortly.
