Ithea pulls away from the rock-hard fist even as she begins swinging the mace at the elemental, the mace crackling with arcane might. "Oh no you don't!"
Arcane Strike of a level 5 spell.
[20:08] <@Mercury> roll d20+47 K:P (devotion)
[20:08] <Kobot> Mercury rolled d20+47 K:P (devotion) --> [ 1d20=13 ]{60}
Attack rolls below include +5 from devotion.
[20:08] <@Mercury> roll d20+51 attack #1
[20:08] <Kobot> Mercury rolled d20+51 attack #1 --> [ 1d20=2 ]{53}
[20:08] <@Mercury> roll d20+46 attack #2
[20:08] <Kobot> Mercury rolled d20+46 attack #2 --> [ 1d20=19 ]{65}
[20:08] <@Mercury> roll d20+41 attack #3
[20:08] <Kobot> Mercury rolled d20+41 attack #3 --> [ 1d20=16 ]{57}
[20:08] <@Mercury> roll d20+36 attack #4
[20:08] <Kobot> Mercury rolled d20+36 attack #4 --> [ 1d20=8 ]{44}
[20:08] <@Mercury> roll d20+46 confirm attack #2
[20:08] <Kobot> Mercury rolled d20+46 confirm attack #2 --> [ 1d20=14 ]{60}
[20:10] <@Mercury> roll d8+21+5d4 attack #1 (if hits)
[20:10] <Kobot> Mercury rolled d8+21+5d4 attack #1 (if hits) --> [ 1d8=8 5d4=11 ]{40}
[20:10] <@Mercury> roll d8+21+5d4 attack #2  (if hits)
[20:10] <Kobot> Mercury rolled d8+21+5d4 attack #2 (if hits) --> [ 1d8=1 5d4=12 ]{34}
[20:10] <@Mercury> roll d8+21+5d4 attack #3   (if hits)
[20:10] <Kobot> Mercury rolled d8+21+5d4 attack #3 (if hits) --> [ 1d8=3 5d4=12 ]{36}
[20:10] <@Mercury> roll d8+21+5d4 attack #4 (if hits)
[20:10] <Kobot> Mercury rolled d8+21+5d4 attack #4 (if hits) --> [ 1d8=6 5d4=13 ]{40}
Just a reminder, you can't critical elementals.
Ithea's mace strikes true, beating the face and hand of the elemental back. Great, deep gouges are torn into it from those strikes, pounding craters into it dead on. But it doesn't stop the elemental, whose fist hurtles hard at Ithea.
> roll 1d20+70 vs Ithea's CMD of 77
<Kobot> Kotono rolled 1d20+70 vs Ithea's CMD of 77 --> [ 1d20=17 ]{87}
Ithea is hit hard by the hand, an open palm strike that picks up and carries Ithea to a crushing meeting with the elemental's forehead.
> roll 16d6+48 bludgeoning damage, DR applies
<Kobot> Kotono rolled 16d6+48 bludgeoning damage, DR applies --> [ 16d6=62 ]{110}
The impact leaves Ithea kneeling on the ground, the hand withdrawing after painfully crushing her against the elemental's body. She's seeing stars, dizzied and dazed.
You suffer a -2 penalty to attack rolls due to being shaken up, Ithea. Go.
Fun times. Also, I forgot to apply fatigue penalty, so I should technically have -1 to those attack rolls and damage if it matters. Which is now -3 to attack rolls!
"Ithea": ShowHide
HP: 257/346
AC/Touch/Flat-Footed: 56/39/56
Effects: Heroes Feast (CL 20), GMW (CL 25), Shaken, Fatigued
Qualities: DR 10/silver, SR 34, Darkvision, Low-Light Vision, +4 CMD vs Trip/Overrun/Bullrush, Evasion, Uncanny Dodge, Immunity to Frightful Presence, +4 vs Fear, Spellwarped
Inspiration: 1/6
Abilities:
Racial: Healing Touch 0/1
Rogue: Mimic 0/1
Factotum: Inspiration 0/6, Nerveskitter 0/1, Heroics 0/1, Piety 0/9
Duskblade: Attunement 0/14, Quick Cast 0/4
Feats: Chaos Devotion 0/1
Gear: Counterstrike 0/2, Greatreach 0/3, Reciprocate 0/2, Haste 0/10 (rounds), Daylight 0/1, See Invis 0/1, +2d6 electric damage 0/3, Gate 2/3
Spells:
Lv 0 - 0/6
Lv 1 - 0/23
Lv 2 - 0/23
Lv 3 - 1/23
Lv 4 - 2/18
Lv 5 - 1/14
"Balyss": ShowHide
HP: 228+16/228
AC/Touch/Flat-Footed: 51/38/48
Qualities: Darkvision, low-light vision, RE(Fire) 20, RE(cold) 15, RE(sonic) 10, RE(acid/electricity) 5, prophet's sight 3/day, Evasion, trap sense+2,  uncanny dodge, DR 10/cold iron and evil, Regen 1/cold iron and evil.
Spells Used:
9 - Gate (x1)
http://www.soulriders.net/forum/index.php/topic,102879.msg1046029.html#msg1046029
"Crystal/Hope": ShowHide
Crystal
HP: 223+14/223
AC/Touch/Flat-Footed: 43 / 39 / 31
Qualities: Low-light vision, DR 10/cold iron, greater invisibility, SR 36, evasion
http://www.soulriders.net/forum/index.php/topic,102879.msg1059605.html#msg1059605
Hope
HP: 484/484
AC/Touch/Flat-Footed: 51 / 21 / 41
Qualities: Improved Evasion, +4 will vs enchantment, DR 15/epic, SR 32, immunity to sleep and paralysis, RE(acid/cold/electricity) 20, darkvision, low-light vision, water breathing, fast healing 3.
http://www.soulriders.net/forum/index.php/topic,102879.msg1059616.html#msg1059616
Ithea winces and decides to focus her defenses against the elemental as she attacks back in full.
Inspiration to add INT to AC.
[21:12] <@Mercury> roll d20+51-3 attack #1
[21:12] <Kobot> Mercury rolled d20+51-3 attack #1 --> [ 1d20=11 ]{59}
[21:12] <@Mercury> roll d20+46-3 attack #2
[21:12] <Kobot> Mercury rolled d20+46-3 attack #2 --> [ 1d20=11 ]{54}
[21:12] <@Mercury> roll d20+41-3 attack #3
[21:12] <Kobot> Mercury rolled d20+41-3 attack #3 --> [ 1d20=12 ]{50}
[21:12] <@Mercury> roll d20+36-3 attack #4
[21:12] <Kobot> Mercury rolled d20+36-3 attack #4 --> [ 1d20=11 ]{44}
[21:12] <@Mercury> roll d8+21+5d4 attack #1 (if hits)
[21:12] <Kobot> Mercury rolled d8+21+5d4 attack #1 (if hits) --> [ 1d8=8 5d4=13 ]{42}
[21:12] <@Mercury> roll d8+21+5d4 attack #2 (if hits)
[21:12] <@Mercury> roll d8+21+5d4 attack #3 (if hits)
[21:12] <Kobot> Mercury rolled d8+21+5d4 attack #2 (if hits) --> [ 1d8=3 5d4=13 ]{37}
[21:12] <Kobot> Mercury rolled d8+21+5d4 attack #3 (if hits) --> [ 1d8=5 5d4=15 ]{41}
[21:12] <@Mercury> roll d8+21+5d4 attack #4 (if hits)
[21:12] <Kobot> Mercury rolled d8+21+5d4 attack #4 (if hits) --> [ 1d8=8 5d4=15 ]{44}
-1 to the damage rolls.
Ithea's heavy strikes batter the elemental repeatedly, craters all over its head and hand. Parts of it are scorched from her arcane fire fueled assaults, enough to finally get the elemental to withdraw. Only for a moment later for everything around Ithea to begin to shake violently.
Balance check. However, the DC is 25 and your modifier is +28, so a roll is not required.
Fortunately, Ithea is able to keep her balance. Little bits of rubble and rock are starting to fall from the ceiling.
Go Ithea.
Ithea takes a brief moment to try and tell if the tremors will be extending to where the others are waiting. If not, she'll push on towards where the original cave in occured, and dive through the rock to check out the other side for a clear path forward.
knowledge architecture? Dungeoneering?
A&E or Dungeoneering are possible, whichever you prefer. Do note that standing around a moment to think wastes time here. Your call if it's worth it.
Ithea shall do her best to evade falling rocks! Can she heal herself while doing the skill roll, or is the skill roll going to be a standard action essentially?
[19:44] <Merc> roll d20+35 K:D
[19:44] <Kobot> Merc rolled d20+35 K:D --> [ 1d20=11 ]{46}
Hmmm. Yes. This place is about to come down all around you. Moving would be good. Quite good, as a matter of fact. Fast.
Act as you please, though you took up a bit of time.
Clarification: Ithea wanted to know if the falling down was going to extend towards where the others are. If it's mostly just the area past the crack, then she wanted to keep moving forward, but if the others were going to be at risk, she'd want to double back.
She doesn't think it'll go that far, at least. A ways but not all the way back.
Ithea continues forward towards where she was heading before she was jumped by some upstart earth monolith! Once she reaches the spot where Crystal and Moore were stopped, she'll use the mace's power to glide through and keep exploring, hopefully finding a safe location to teleport the others too.
If I can heal without increasing likelyhood of rocks falling, I'll use up a pair of charges of Opportunistic Piety. But I'll focus on not getting hit by rocks more if that requires concentration.
Ithea advances forward, before with a shudder, the roof above her caves in.
Ref save. No save would normally be possible (and you'd be taking damage that would kill a normal person many times over at best), but your mace allows earth glide, so you could very well dodge unconventionally.
[20:15] <Merc> roll d20+31+11 evasive mace inspiration
[20:15] <Kobot> Merc rolled d20+31+11 evasive mace inspiration --> [ 1d20=20 ]{62}
Going down? Going down. Ithea sinks right into the ground as fast as the rocks come down, plunging into the ground a good 50ft. It saves her from being crushed into a fine paste, even though the stones around her are shaking. Less than before, at least.
Not gonna lie, you got away with one there. When a cave in happens, the correct answer usually isn't rolling with it like that and instead fleeing.
I had faith in Lady Sunnis' mace!
Ithea isn't even sweating! She continues gliding through the earth in the direction she was headed.
