The shaking slows as you go under the cave in (you think, anyway) and past it. You think that if you go up, you should be past it now.
You're on the other side of the narrow passage. The shaking has stopped by now and the passage ahead has nothing to stop you from following it.
Ithea heals up first and then does some brief scouting!
Using 3x OP. Am I still shaken?
"Ithea": ShowHide
HP: 326/346
AC/Touch/Flat-Footed: 56/39/56
Effects: Heroes Feast (CL 20), GMW (CL 25), Shaken?, Fatigued
Qualities: DR 10/silver, SR 34, Darkvision, Low-Light Vision, +4 CMD vs Trip/Overrun/Bullrush, Evasion, Uncanny Dodge, Immunity to Frightful Presence, +4 vs Fear, Spellwarped
Inspiration: 0/6
Abilities:
Racial: Healing Touch 0/1
Rogue: Mimic 0/1
Factotum: Inspiration 0/6, Nerveskitter 0/1, Heroics 0/1, Piety 3/9
Duskblade: Attunement 0/14, Quick Cast 0/4
Feats: Chaos Devotion 0/1
Gear: Counterstrike 0/2, Greatreach 0/3, Reciprocate 0/2, Haste 0/10 (rounds), Daylight 0/1, See Invis 0/1, +2d6 electric damage 0/3, Gate 2/3
Spells:
Lv 0 - 0/6
Lv 1 - 0/23
Lv 2 - 0/23
Lv 3 - 1/23
Lv 4 - 2/18
Lv 5 - 1/14
"Balyss": ShowHide
HP: 228+16/228
AC/Touch/Flat-Footed: 51/38/48
Qualities: Darkvision, low-light vision, RE(Fire) 20, RE(cold) 15, RE(sonic) 10, RE(acid/electricity) 5, prophet's sight 3/day, Evasion, trap sense+2,  uncanny dodge, DR 10/cold iron and evil, Regen 1/cold iron and evil.
Spells Used:
9 - Gate (x1)
http://www.soulriders.net/forum/index.php/topic,102879.msg1046029.html#msg1046029
"Crystal/Hope": ShowHide
Crystal
HP: 223+14/223
AC/Touch/Flat-Footed: 43 / 39 / 31
Qualities: Low-light vision, DR 10/cold iron, greater invisibility, SR 36, evasion
http://www.soulriders.net/forum/index.php/topic,102879.msg1059605.html#msg1059605
Hope
HP: 484/484
AC/Touch/Flat-Footed: 51 / 21 / 41
Qualities: Improved Evasion, +4 will vs enchantment, DR 15/epic, SR 32, immunity to sleep and paralysis, RE(acid/cold/electricity) 20, darkvision, low-light vision, water breathing, fast healing 3.
http://www.soulriders.net/forum/index.php/topic,102879.msg1059616.html#msg1059616
[20:36] <Merc> roll d20+59 move silently
[20:36] <Kobot> Merc rolled d20+59 move silently --> [ 1d20=2 ]{61}
That's gone. You're back to normal attack rolls in regards to that.
Ithea scouts ahead. The passage goes on about 1000ft, before opening into a larger cavern. Glancing ahead, you can see it filled with black crystals - black quartz, probably, similar to the tiny black quartz you saw before.
Ithea casts detect magic and glances at them, to see if they'll set off more cave ins or something. Not exactly something she'd want to pull the others into if so, in which case she might want to keep exploring until there's an actual safe spot to bring them to...well, hopefully still within her reachable distance. Mentally she quickly tries to estimate how far she'd be from the others.
There's magic ahead in the cavern, oh yes.
Spellcraft.
[20:47] <Merc> roll d20+40 I don't like that 'Oh yes'...
[20:47] <Kobot> Merc rolled d20+40 I don't like that 'Oh yes'... --> [ 1d20=3 ]{43}
The entire chamber ahead is a dead zone. The crystals will leech the life out of anything living that passes through. They'll wither, sicken and die quite quickly.
Do I think it's safe to destroy them or can I disable them? And can I spot any path forward from the cavern? Also, roughly how far am I from the others? I have a range of 1400ft, so I doubt it'll be a problem, but if I'm gonna go farther than that to the best of Ithea's knowledge, I'd like to know.
Not sure what to roll on knowing to destroy them or disabling them.
Rolling spot for pathing forward.
[20:52] <Merc> roll d20+51 spot
[20:52] <Kobot> Merc rolled d20+51 spot --> [ 1d20=1 ]{52}
K:A on the crystals.
You'd need to walk back a ways for DDing, fi that's your plan, but not terribly much so. Your range is good.
[21:03] <Merc> roll d20+42 K:A
[21:03] <Kobot> Merc rolled d20+42 K:A --> [ 1d20=13 ]{55}
The crystals are focal points the enchantment. Unfortunately, they all probably are. You'd need to destroy all of them to sotp it. An extremely wide range sonic effect might do the trick.
Since they'd prevent enemies from coming at them (probably), and so far it's been pretty safe outside of the crystals, Ithea decides to return to the others and teleport them all past the cave in. They can handle the crystals together. Or she could probably with just some shout spells, though as a bard, Moore probably had something as effective.
I shall go reunite with my bored compatriots!
You find them waiting for you, Rosa the first to react, "There you are! What happened?" she asks right away.
