Moore makes sure there's no magical traps or anything and looks around, but will go and collect everything otherwise!
Dana comes along, "Well, dad fucking finally!" she says, as Moore looks it over. It's all magical.
Spellcraft.
Taking 10 and using 12 more from Improvisation for 57.[/i[
All of the treasures are cursed. Taking them will make you slow, sluggish and barely able to move.
"Bah, it's all cursed." Moore says with a frown. "We could probably break it, but it'd take some time."
Does he think he could break the curse on all the stuff or would it be too much of a hassle?
Can Greater Dispel Magic used an area just catch the cursed part without affecting the items themselves otherwise?
I don't follow. What do you aim to do here?
Use Greater Dispel Magic to remove the curse on everything via an Area Dispel rather than individually hitting each one with Remove Curse.
Moore nods and calls out over his shoulder. "Miss Balyss, I may need help with this if I can't quite manage it." With that, he turns and makes a motion to dispel the curse on all the items!
[11:53] <Nephrite> roll 1d20+20
[11:53] <Kobot> Nephrite rolled 1d20+20 --> [ 1d20=3 ]{23}
Balyss comes over, "Looks like it's needed," she agrees, "Moonlight shines down, purifying what should not be!"
Greater dispel magic. Merc, keep her sheet tallied and subtract a casting of it from her cleric spells.
> roll 1d20+20
<Kobot> Ko-EndlessTerror rolled 1d20+20 --> [ 1d20=11 ]{31}
The magic around the treasures is banished, the curse negated. A slow moan comes from them as it crumbles before the Lunatic's incantation, but nothing else.
"It looks like I still need some practice." Moore says with a nod.
We'll just go ahead and take everything and sort it out later, as long as there's no hidden magical tracking devices or something!
Will do, chief.
Ithea helps put away the uncursed treasure then continues to explore!
IS there anything left to explore since that was final room?
Looking around, you can see that things look cleared out by now. You return to the courtyard, nothing immediately - hello. As the party comes out, you see that 150ft away from the courtyard, back the way you came, the way forward is gone. A heavy wall of stone, dirt and metal has risen up to completely block the way out.
