"They don't really think that's going to work, do they?" Moore asks.
"The monolith must be back," Balyss remarks, "Ithea, could you disintegrate that?"
"I can. You know, it's almost like they don't want us exploring what's the other way. I wonder why?" she asks rhetorically. She does cast detect magic first, just to make sure they didn't somehow put up another anti-disintegrate protection up or something. If nothing's amiss, well, certainly no reason not to cast disintegrate!
The wall is indeed enchanted.
Spellcrafting times.
[19:28] <Merc> roll d20+40 spellcraft
[19:28] <Kobot> Merc rolled d20+40 spellcraft --> [ 1d20=19 ]{59}
Coming to within 60ft of the wall, Ithea takes a good, long study of it.
The wall will reflect disintegrate or similar spells. It'll stop a creature from using earth glide to go through it, as well as ethereal creatures. It's also enchanted to be much harder than stone or iron.
"Well, maybe not. Jeez, they're putting some real effort into blocking the way. It'll reflect damage spells, prevents earth glide and ethereal, and it's extra hard to boot," Ithea comments as she rubs her chin in thought. "Smrgol's good against magic, maybe he can break through? If not, can't be much different than casting a dispel on cursed treasure and then disintegrating."
Hoping between Smrgol's abilities, penetration and sense weakness and a full attack, he can just crack it open. If not, checking to see who still has dispels to cast.
This draws a long frown out of Balyss, "That's not an attack, that's stalling," she remarks. "Why? In any case, I can try to dispel it."
Ithea chuckles. "Okay, okay, we'll skip giving Smrgol a chance. He probably had enough fun tearing out the gems from the walls."
Common Effects:
Heroes' Feast, Moore's +3 to Atk, Inspire Courage +12, Protection Devotion (+7AC) while within 30ft of Dana, Undeath's Eternal Foe, Haste on everyone but Smrgol (Ithea has 8 more rounds), Righteous Fury/Might on Crystal/Hope.
"Ithea": ShowHide
HP: 281/346
AC/Touch/Flat-Footed: 56/39/56
Effects: GMW (CL 25), Inspire Heroics
Qualities: DR 10/silver, SR 34, Darkvision, Low-Light Vision, +4 CMD vs Trip/Overrun/Bullrush, Evasion, Uncanny Dodge, Immunity to Frightful Presence, +4 vs Fear, Spellwarped
Inspiration: 3/6
Abilities:
Racial: Healing Touch 1/1
Rogue: Mimic 0/1
Factotum: Inspiration 0/6, Nerveskitter 0/1, Heroics 0/1, Piety 3/9
Duskblade: Attunement 0/14, Quick Cast 2/4
Feats: Chaos Devotion 1/1
Gear: Counterstrike 0/2, Greatreach 0/3, Reciprocate 0/2, Haste 0/10 (rounds), Daylight 0/1, See Invis 0/1, +2d6 electric damage 0/3, Gate 2/3
Spells:
Lv 0 - 0/6
Lv 1 - 0/23
Lv 2 - 1/23
Lv 3 - 2/23
Lv 4 - 5/18
Lv 5 - 6/12 (Note: Lost 2 spells from NL, counted already)
"Balyss": ShowHide
HP: 228/228
AC/Touch/Flat-Footed: 51/39/48
Effects: See above
Qualities: Darkvision, low-light vision, RE(Fire) 20, RE(cold) 15, RE(sonic) 10, RE(acid/electricity) 5, prophet's sight 3/day, Evasion, trap sense+2,  uncanny dodge, DR 10/cold iron and evil, Regen 1/cold iron and evil.
Spells Used:
9 - Gate (x1), Mass Heal, Undeath's Eternal Foe, Quickened Life's Grace, Miracle (x2)
6 - Greater Dispel Magic (x2)
Spells Lost due to NL:
10 - Energy Immunity, Mass Freedom of Movement, Curse of Inadequacy, Moonrise
TU's Used: 1
http://www.soulriders.net/forum/index.php/topic,102879.msg1046029.html#msg1046029
"Crystal/Hope": ShowHide
Crystal
HP: 207/245
AC/Touch/Flat-Footed: 43 / 39 / 31
Effects: See above, -2 NL
Qualities: Low-light vision, DR 10/cold iron, greater invisibility, SR 36, evasion
Used:
3x Smite Evil
1x Righteous Fury
1x Righteous Might
1x Greater Mirror Image
65 HP out of LoH
Spells Lost:
Divine Agility/Inner Beauty
http://www.soulriders.net/forum/index.php/topic,102879.msg1059605.html#msg1059605
Hope
HP: 400+26/484
AC/Touch/Flat-Footed: 51 / 21 / 41
Effects: See above
Qualities: Improved Evasion, +4 will vs enchantment, DR 15/epic, SR 32, immunity to sleep and paralysis, RE(acid/cold/electricity) 20, darkvision, low-light vision, water breathing, fast healing 3.
http://www.soulriders.net/forum/index.php/topic,102879.msg1059616.html#msg1059616
> roll 1d20+20
<Kobot> Kotono rolled 1d20+20 --> [ 1d20=8 ]{28}
> roll 1d20+20
<Kobot> Kotono rolled 1d20+20 --> [ 1d20=9 ]{29}
> roll 1d20+20
<Kobot> Kotono rolled 1d20+20 --> [ 1d20=18 ]{38}
Balyss chants, "As the moon rises, evil power fades away!" Nothing and a frown. "As the moon rises, evil power fades away!" Again nothing, this time Balyss walking to the wall and placing her holy symbol on it. "As the moon rises, Selune smites evil power and it fades away!" This time there's a flickering in the magic - it's disrupted, not dispelled. The effect is tenacious and will quickly recover from this dispelling.
Ithea quickly casts a disintegrate spell while she's able to!
If necessary, I can quick cast a second disintegrate while it's disrupted. Let me know.
Make the obligatory attack roll - only fearing a 1 - and then a damage roll.
[20:08] <Merc> roll d20+30+1 ranged touch
[20:08] <Kobot> Merc rolled d20+30+1 ranged touch --> [ 1d20=13 ]{44}
[20:09] <Merc> roll 40d6
[20:09] <Kobot> Merc rolled 40d6 --> [ 40d6=138 ]{138}
A hunk of earth vanishes away...only for another wall of pure stone to appear, filling the gap instantly. In the split second you can see out, you see the leg of what looks to be a rather large earth elemental.
Going to use your quick cast, Ithea?
Sure.
Ithea quick casts another disintegrate spell and tries to jump through the gap it makes before the elemental has a chance to fill it up again! Hopefully with the timing of the spell, the fact that it's already busy with the first spell, and her speed, she can make it through!
